Hi everyone,
VisualARQ 3.9 is now available for
download.
This is a maintenance release that fixes most of the critical issues and crashes reported by users. Please report any problems or suggestions here or send us an email to visualarq@asuni.com.
List of changes since 3.8.3:
Improvements (2)
- Grasshopper: Style:
15592: Make the vaSubtractSolids command work with hatches in Grasshopper Styles
- Level:
15465: Show plan view reference even when the cut plane is not activated
Changes (1)
- Other:
15584: Hide the vaNavigate command
Fixed Errors (37)
- Attributes:
14244: Wrong Print color for section boundary when using Levels
- Crash:
15613: Crash after opening a VisualARQ 215586: Crash after selecting a Grasshopper file during the Grasshopper Style Wizard for a new wall style
- DWG Export:
15580: vaExportToDWG exports nothing from the model space15514: Wall layer internal line missing in a DWG export15447: Hatch artifact appears in exported DWG15446: Wall hatch is not exported properly to DWG15425: Section hatch displaced in DWG file
- Display:
15587: Section fill in Realistic mode is always displayed black in Rhino 7
- Dynamic Section:
15535: Cone is not displayed correctly in section
- Grasshopper: Components:
15553: Roof Explode returns no slabs
- IFC:
15595: IFC Import plug-in does not load
- Layer:
15593: When default object layer is assigned to “None” then the objects are not drawn
- Level:
15491: Level cut planes don’t work
- Object:
15492: Smart Track doesn’t work well with VisualARQ objects
- Object: Curtain Wall:
15571: Curtain walls don’t extend properly to a polysurface15560: Curtain Wall From Surface does not work properly15559: Curtain Wall does not extend correctly to complex surfaces15537: Curtain walls did not extend to a planar surface15490: Missing horizontal mullions in some curtain walls15228: Curtain wall with small cell size is very slow
- Object: Opening Elevation:
15513: Opening leaves are generated out of their position in 2D Opening Elevations15497: Muntins are generated out of their position in 2D Opening Elevations
- Object: Openings:
8928: Doors and Windows don’t work well with the Smart Track
- Object: Plan View:
15536: Guides are not generated in a 2D RCP View11733: Dimension line disappears in plan view
- Object: Roof:
15608: Roof keeps layer material instead of style material15594: Roof control arrows are out of place15576: Roof Gumball is always located in the Coordinates Origin15496: Window is detached from a roof when changing its edge cut
- Object: Section View:
15362: Wrong Section view from a jogged section15331: 2D Section view is not consistent with the real-time jogged section view15330: 2D Section view from a jogged section line doesn’t generate section hatches
- Panel: Sections:
15578: Section doesn’t work
- Parameter:
15569: Filters in Custom parameters are not available when language is not English
- View:
14619: 2D door arcs and space labels are not displayed in plan view
- View: Plan and RCP:
14852: Door 2D aperture is not displayed in this file
Previous version:
Enjoy!
Enric
