VisualARQ 3 - Version 3.7 released
Hi everyone,
VisualARQ 3.7 is now available for :arrow_down: download.
This is a maintenance release that fixes most of the critical issues and crashes reported by users. Please report any problems or suggestions here or send us an email to visualarq@asuni.com.
List of changes since 3.6.2:
Fixed Errors (35)
  • Clashes:
    • 13487: Objects involved in a clash are not highlighted properly
    • 13196: Clash&Clear takes long recalculating clash issues
  • Developer:
    • 15214: Curtain Wall triggers several assertions
  • DWG Export:
    • 15205: DWG Export errors with multiple Layouts
    • 15204: Strange circle appear in a plan view exported to DWG
    • 15144: Guide labels are exported flipped and out of place to DWG
  • Grasshopper: Style:
    • 15393: Revolving door generates duplicated leaves
    • 10241: Open polysurface can’t be selected as input parameter
  • IFC:
    • 15262: IFC4 with multiple “Model” representation contexts cannot be opened
  • Level:
    • 15315: “Set Floor Plan” doesn’t work in lateral views
  • Material:
    • 15114: Texture mapping changes when moving VisualARQ objects
  • Object:
    • 15264: Wall in locked layer can be selected
  • Object: Beam:
    • 14041: Beam Cut Length is not properly calculated
  • Object: Curtain Wall:
    • 13915: The position of the supports in relation to the cells change depending on the curtain wall alignment
  • Object: Guide:
    • 15298: Big slow performance when guides are visible
    • 14394: Guides don’t print
  • Object: Plan View:
    • 14018: Elements appear beyond the 2D plan view boundary
  • Object: Roof:
    • 15234: Roof is not visible in Rhino 7
    • 15193: vaRoofStyles doesn’t work in Czech toolbar
    • 14518: Windows can’t be inserted in Shed roofs
  • Object: Section:
    • 15286: Inconsistent selection of a section
  • Object: Slab:
    • 15329: Wrong intersection between two slabs with solids subtracted
    • 15292: Rhino freezes when moving or modifying slab
  • Object: Space:
    • 14600: Space labels are not oriented to the XY axis of a custom CPlane
  • Object: Table:
    • 15213: Roof areas with solids subtracted are not correctly calculated
  • Object: Views:
    • 15289: Print color of section hatches in a plan view are lost
  • Object: Wall:
    • 15313: Wall extended to two intersecting roofs has a missing extension part
  • Panel: Tables:
    • 14347: Level filters don’t work for spaces that occupy more than one level
  • Parameter:
    • 15240: Filters in Custom parameters are not saved
  • Performance:
    • 15296: I takes 30 minutes to open a file
  • Print: Hidden Vector:
    • 14707: Missing lines of a roof in a RCP view
  • Snap:
    • 15290: Extension control points don’t snap in Rhino 7
  • View:
    • 14688: Jogged section is not properly displayed in a section view
  • View: Plan and RCP:
    • 15319: Set floor plan fails to do a proper zoom extents
  • Worksessions:
    • 15288: Crash after activating file in a Worksession
Previous version:
Enjoy!
Enric
is it IFC4 already working in this version?
Hi Leo, only the Import option. We are still working on the IFC4 Export.
