VisualARQ 3 - Version 3.7 RC1 released
VisualARQ 3.7 - Release Candidate 1 is now available for download.
:information_source:  NOTE: This is a release candidate (RC), meaning it is not the final version but has undergone internal testing and is considered stable enough for end-user testing. VisualARQ 3.7 is scheduled for official release on :spiral_calendar: Wednesday, December 3th, 2025
This release fixes most of the problems and crashes reported by users. Please report any problems or suggestionas here or email us at visualarq@asuni.com.
Here is the list of changes:
Fixed Errors (20)
  • DWG Export:
    • 15205: DWG Export errors with multiple Layouts
    • 15204: Strange circle appear in a plan view exported to DWG
    • 15144: Guide labels are exported flipped and out of place to DWG
  • Grasshopper: Style:
    • 10241: Open polysurface can’t be selected as input parameter
  • IFC:
    • 15262: IFC4 with multiple “Model” representation contexts cannot be opened
  • Material:
    • `15114 Texture mapping changes when moving VisualARQ objects
  • Object:
    • 15264: Wall in locked layer can be selected
  • Object: Beam:
    • 14041: Beam Cut Length is not properly calculated
  • Object: Curtain Wall:
    • 13915: The position of the supports in relation to the cells change depending on the curtain wall alignment
  • Object: Plan View:
    • 14018: Elements appear beyond the 2D plan view boundary
  • Object: Roof:
    • 15234: Roof is not visible in Rhino 7
    • 14518: Windows can’t be inserted in Shed roofs
  • Object: Section:
    • 15286: Inconsistent selection of a section
  • Object: Space:
    • 14600: Space labels are not oriented to the XY axis of a custom Cplane
  • Object: Table:
    • 15213: Roof areas with solids subtracted are not correctly calculated
  • Panel: Tables:
    • 14347: Level filters don’t work for spaces that occupy more than one level
  • Parameter:
    • 15240: Filters in Custom parmaeters are not saved
  • Print: Hidden Vector:
    • 14707: Missing lines of a roof in a RCP view
  • View:
    • 14688: Jogged section is not properly displayed in a section view
  • Worksessions:
    • 15288: Crash after activating file in a worksession
Download links:
Previous version:
Enjoy!
Enric
