VisualARQ 3 - Version 3.9 RC1 released
VisualARQ 3.9 - Release Candidate 1 is now available for download.
:information_source:  NOTE: This is a release candidate (RC), meaning it is not the final version but has undergone internal testing and is considered stable enough for end-user testing. VisualARQ 3.9 is scheduled for official release on :spiral_calendar: Wednesday, April 1th, 2026
This release fixes most of the problems and crashes reported by users. Please report any problems or suggestions here or email us at visualarq@asuni.com.
Here is the list of changes:
New Features (1)
  • Object: Table:
    • 14413: Make “area” property available for Curves
Improvements (2)
  • Grasshopper: Style:
    • 15592: Make the vaSubtractSolids command work with hatches in Grasshopper Styles
  • Level:
    • 15465: Show plan view reference even when the cut plane is not activated
Changes (1)
  • Other:
    • 15584: Hide the vaNavigate command
Fixed Errors (35)
  • Attributes:
    • 14244: Wrong Print color for section boundary when using Levels
  • Crash:
    • 15586: Crash after selecting a Grasshopper file during the Grasshopper Style Wizard for a new wall style
  • Display:
    • 15587: Section fill in Realistic mode is always displayed black in Rhino 7
  • DWG Export:
    • 15580: vaExportToDWG exports nothing from the model space
    • 15514: Wall layer internal line missing in a DWG export
    • 15447: Hatch artifact appears in exported DWG
    • 15446: Wall hatch is not exported properly to DWG
    • 15425: Section hatch displaced in DWG file
  • Dynamic Section:
    • 15535: Cone is not displayed correctly in section
  • Grasshopper: Components:
    • 15553: Roof Explode returns no slabs
  • IFC:
    • 15595: IFC Import plug-in does not load
  • Layer:
    • 15593: When default object layer is assigned to “none” then the objects are not drawn
  • Level:
    • 15491: Level Cut planes don’t work
  • Object:
    • 15492: Smart Track doesn’t work well with VisualARQ objects
  • Object: Curtain Wall:
    • 15571: Curtain walls don’t extend properly to a polysurface
    • 15560: Curtain Wall From Surface does not work properly
    • 15559: Curtain Wall does not extend correctly to complex surfaces
    • 15537: Curtain walls did not extend to a planar surface
    • 15490: Missing horizontal mullions in some curtain walls
    • 15228: Curtain wall with small cell size is very slow
  • Object: Opening Elevation:
    • 15513: Opening leafs are generated out of their position in 2D Opening Elevations
    • 15497: Muntins are generated out of their position in 2D Opening Elevations
  • Object: Openings:
    • 8928: Doors and Windows don’t work well with the Smart Track
  • Object: Plan View:
    • 15536: Guides are not generated in a 2D RCP View
    • 11733: Dimension line disappears in plan view
  • Object: Roof:
    • 15594: Roof control arrows are out of place
    • 15576: Roof Gumball is always located in the Coordinates Origin
    • 15496: Window is detached from a roof when changing its edge cut
  • Object: Section View:
    • 15362: Wrong Section view from a jogged section
    • 15331: 2D Section view is not consistent with the real-time jogged section view
    • 15330: 2D Section view from a jogged section line doesn’t generate section hatches
  • Panel: Sections:
    • 15578: Section doesn’t work
  • Parameter:
    • 15569: Filters in Custom parameters are not available when language is not English
  • View:
    • 14619: 2D door arcs and space labels are not displayed in plan view
  • View: Plan and RCP:
    • 14852: Door 2D aperture is not displayed in this file
Download links:
Previous version:
Enjoy!
Hi @enric ,
a small request. Could you add similar command as the _vaWallExtractPath to all VARQ object types that can be created by using a path curve. Currently for e.g. beam objects, it is only possible through Gh.
Hi @Toni_Osterlund there’s a command in the VisualARQ Labs that does that (vaExtractCurves): https://www.food4rhino.com/en/app/visualarq-labs
It works with objects defined by a path curve (walls, beams, curtain walls and railings), but also with slabs, roofs, doors and windows.
Thank you @fsalla.
Have to test it out.
