VisualARQ 3.8 - Release Candidate 1 is now available for download.
NOTE: This is a release candidate (RC), meaning it is not the final version but has undergone internal testing and is considered stable enough for end-user testing. VisualARQ 3.8 is scheduled for official release on
Wednesday, February 4th, 2026
This release fixes most of the problems and crashes reported by users. Please report any problems or suggestionas here or email us at visualarq@asuni.com.
Here is the list of changes:
Improvements (2)
- DWG Export:
15143: Preserve dimension entities when exporting to DWG
- Performance:
14397: Improve the performance of wall-slabs intersections
Fixed Errors (29)
- API: Script:
14911: Error in the funcion AddRoofFromCurve. Roof Type parameter is missing
- Clashes:
15305: Duplicated intersection issues14441: Clashes report doesn’t work with blocks
- DWG Export:
15429: Missing geometry in the exported DWG15415: Detail View rotates after being exported to DWG15368: Rhino crashes when exporting multiple layouts to DWG15028: Text dimensions in the model space are exported in wrong size to DWG13924: Dimensions are exploded in AutoCAD when I export in dwg format
- Grasshopper: Components:
15309: Fail to explode a VisualARQ Object Style Component
- Help:
15337: Wrong syntax description in VisualARQ Help to display custom parameters in tag styles
- Interferences:
15398: Update VisualARQ object automatically when an object used as interference is deleted15384: Rhino freezes when deleting a wall
- Object: Curtain Wall:
15340: Curtain wall is not extended properly15294: Curtain Wall’s center curve is not taking the Alignment Offset into account15239: Door doesn’t cut properly a curtain wall14964: Door doesn’t cut properly a curtain wall14575: Door in a curtain wall doesn’t generate well the opening14503: Curtain wall error when it is coincident with a window and a wall14498: Door doesn’t cut properly a curtain wall12602: Door doesn’t cut properly the curtain wall where it is inserted
- Object: Guide:
15405: Gumball in Guide Point is not Aligned with Guide even in Gumball Object Mode
- Object: Roof:
15363: After opening old files some roofs got proyected to zero elevation15333: Gable roof breakes when another one intersects with it
- Object: Wall:
12676: vaFillet is not side sensitive to these walls12674: vaFillet changes the wall alignment
- Object: Window:
15380: Window doesn’t detect a roof
- Performance:
15237: Rhino freezes when updating some walls14944: Moving a window is slow in this file11876: It takes a long time to delete a column
Download links:
Previous version:
Enjoy!
