Hi, greetings
I’m trying to make a surface with several ripple effects, i made a script and result isn’t so bad. I think there’s two things that need to change.
first: adding decay to waves
second: controlling wave height in each points
I will appreciate if you help me in this project.
thank you for helping.
regard
The Gh is on the Youtube page. You can add more ripple points by copying an existing section.
Its in mesh… so if you want to convert to NURBs, you might need to add a Quadremesh component.
