Ripple/Raindrop Pattern
Nice elegant definition @maje90
I was inspired to have a play with an iterative version using Kangaroo-
Using springs instead of Laplacian smoothing gives a slightly different effect, with more isolated waves-
surface_ripples_kangaroo.gh (12.0 KB)
Doing it with only existing goals this simulation ends up doing a lot of unnecessary work - since it is calculating all the 3d forces and then restraining them to be only vertical, when all that really needs to be updated is a single scalar per vertex. It could be interesting to make a custom goal for this, since it should be much more efficient.
I imagine it would even be possible to put all this in a GhGl shader.
Also - have a look at this:
