Hi, I’m trying to make a water ripple/ocean kinda texture for a mold, but all the videos I am finding online are for render texture, not physical. Appreciate any advice!
The “Turbulence” texture might be the closest you’ll come with out of the box Rhino. I think that the way the pros do it is by turning displacement on and then doing an “ExtractRenderMesh”. There’s probably better materials out there if you’re willing to look around though.
There are some discussions on this subject with Grasshopper tool. They are not physical but looks good. On this subject I am not sure an human can tell if some pattern exist really of are faked.
Many discussions on ripple drop …
bonjour, je voulais savoir comment je peux utiliser votre texture sur rhino j’arrive a l’ouvrir mais elle ne Bouge pas ni rien et comment et ou je l’ouvre ?
It is possible to make it in Grasshopper but you will have to generate a bitmap, then integrate in your material. So procedural texture seems a better idea.
But if you want to use the shader I used and convert it to a bitmap, no problem.
First make a mesh that is roughly between 1 and 10 units. Use the shader.
Then transform this heightmap to a colored Mesh, and to a bitmap, or using Nautilus plugin if same number of pixels in Y and X or add also Bitmap plugin if not square texture.
That’s the way to do it. Then you can have highly realistic ripples of any kind. All you need is a high-resolution top view image (or create the waves in Maya, for example). Just make sure that the displacement texture is greyscale and a 16-bit image.
