brian
(Brian Gillespie)
23
Rhino 8 SR5 Release Candidate 5 for Windows and Mac (8.5.24058) is now available
Requires Rhino 8
Bugs Fixed:
- Extend: ExtendDynmanic deletes input (RH-80606)
- MeshIntersect: Technical Display Mesh/Mesh Intersections Missing Segments (RH-76568)
- Rendering: Texture Mapping: New test command TestFillInLegacyTextureCoordinates (RH-80470)
- SDK: RhinoCommon: RhinoCommon SDK: LayerTable.Duplicate method returns empty int even when successful (RH-80624)
- Selection: ExtractSrf: Subobject picking may miss a face (RH-80584)
Features Added:
- File IO: Wish: A "pack and go" tool to bundle up Linked blocks (RH-60896)
Regressions Fixed:
- Layer: Layer" Nested Blocks not hiding/showing correct geometry in preview when layers turn on/off (RH-80418)
- ScriptEditor: Grasshopper sources in project report incorrect paths (RH-80603)
Mac-Only Changes
Bugs Fixed:
Windows-Only Changes
Bugs Fixed:
- Section Tools: clipping drawing not updating (RH-80638)
brian
(Brian Gillespie)
24
Rhino 8 SR5 Release Candidate 6 for Windows and Mac (8.5.24065) is now available
Requires Rhino 8
Bugs Fixed:
- SDK: RhinoCommon: Setting MenuVisible false hides OSnap panel (RH-80714)
- ScriptEditor: Python subprocess keeps Rhino file open (RH-73933)
- Selection: Selection - control polygon visibility (RH-80725)
- SelectionFilter: "Others" option missing from horizontal layout (RH-80712)
- Toolbar:
- Appearance is not saved when saving rui file (RH-79744)
- Saving .rui resets both toolbars and buttons appearance to default (RH-80764)
Regressions Fixed:
- OSnap: Osnaps - right click on Disable (RH-80762)
- SetDocumentUserText: Document user text broken in v8 (RH-80683)
Mac-Only Changes
Bugs Fixed:
- PluginManager: PluginManager cut off on Mac (RH-80761)
Performance Improvements:
- Display Metal: Display performance in Metal Arctic (RH-78033)
Bugs Fixed:
- Rendering: Cycles: HDR Light Studio environments don't work correctly (RH-80780)
brian
(Brian Gillespie)
25
brian
(Brian Gillespie)
26
Rhino 8 SR6 Release Candidate 2 for Windows and Mac (8.6.24079) is now available
Requires Rhino 8
Bugs Fixed:
- ClippingPlane: Higher Precision Depth Setting (RH-80996)
- Help: ExtractSrf options (RH-80528)
- Properties: : Delete key (RH-81014)
- Rendering: Environment rotation not updating in Raytraced display mode (RH-80731)
- TextField: DetailScale issue (RH-80964)
- Units: Cannot script AbsoluteTolerance (RH-81016)
Enhancements:
- SDK: RhinoCommon: Added SaveToLibraryFile method for textures (RH-80872)
brian
(Brian Gillespie)
27
Rhino 8 SR6 Release Candidate 3 for Windows and Mac (8.6.24086) is now available
Requires Rhino 8
Bugs Fixed:
- Print - Pen Display issue when picking window (RH-81082)
- Displacement: Moving object recalculates displacement mesh (RH-72387)
- Display: GPU tessellation setting makes highlighted edges not look as good as they did in v7 (RH-73635)
- Gumball: Oriented to Plane in Block regression (RH-80593)
- Layer: "Select Sublayer objects" does not work when sublayer not in search result (RH-80837)
- LineTypeDisplay: LinetypeDisplay: DisplayLinetypes option does not work (RH-81101)
- MacroLibrary: Macro dialog does not show icons in dark mode (RH-81065)
- ScriptEditor:
- Script component does not run when input has cast error (RH-81109)
- Add undo support to editor to undo converting to script instance and other changes to script by editor host (RH-77882)
- Sticky âRestore Packagesâ progress bar when running published commands (RH-81100)
- List and Tree conversion error on null input has bad message (RH-81162)
- SmartTrack: SmartOrtho and distance constraint (RH-81183)
- Toolbar:
Crashes Fixed:
- Toolbar: Deleting menu and saving the RUI hangs Rhino (RH-81069)
Regressions Fixed:
- Volume: Issue with extrusions in blocks (RH-81079)
Usability Problems Fixed:
- ScriptEditor: Python 3 to set locale before running script (RH-81130)
Mac-Only Changes
Bugs Fixed:
- ImportOptions: Cannot import Rhino 7 Mac palettes into Rhino 8 Mac (RH-78809)
- Print: Fake2D hidden dash length on macOS (RH-79537)
Regressions Fixed:
- CommandHistory: Cmd-C not copying text to clipboard as in v7 (RH-81154)
Bugs Fixed:
- Display: Issues when turning off GPU tessellation (RH-81046)
- Toolbar: Toolbar appearance bug - overlapping buttons (RH-80766)
- UI Appearance: Light mode icons are used in fly-outs (RH-77241)
dan
(Dan)
28
Rhino 8 SR6 Release Candidate 4 for Windows and Mac (8.6.24093) is now available
Requires Rhino 8
Bugs Fixed:
- Display: Curves move around when zooming in closely (RH-81185)
- Grasshopper: Components: Model Attribute Key Selection breaks up when . is in Key (RH-81311)
- Keyboard Shortcuts: Default shortcuts cannot be overridden (RH-80307)
- Polyline: Flashing polyline control points - visual glitch (RH-81310)
- Print: Printing gradient hatch issue (RH-79888)
- ScriptEditor:
- Python 3 converts polyline inputs to list of points (RH-81314)
- GH editor closes on save and it is annoying (RH-81303)
- Rectangle to Polyline type hints turns to point?! (RH-81302)
- Python 3 stream wrapper does not have .fileno() method (RH-81299)
- ghpythonlib CullDuplicates can not convert python 3 inputs (RH-81296)
- Autocomplete over-population (RH-81248)
- Add System.Linq as a default import to csharp templates (RH-81237)
- Script param converter regression in 8.6 (RH-81269)
- Add zoom support on terminal (RH-81243)
- Toolbar: Importing SVG hangs button editor (RH-78367)
- UI Appearance:
- Toolbar height needs to snap to button heights. (RH-71925)
- min height for toolbar tabs (RH-74842)
Enhancements:
- ScriptEditor: Add Option to avoid closing editor window when saving in GH (RH-80898)
Regressions Fixed:
- Join: Duplicates disjoint SubDs (RH-81242)
- ScriptEditor: Editor window ends up out of monitor bounds (RH-81318)
- ScriptEditor: Cleanup NuGet package reference formats (RH-81308)
Bugs Fixed:
- Toolbar: Restore Defaults on Size and Styles page doesn't (RH-81323)
Tasks Completed:
- Help: Added traditional Chinese offline help for download (RH-80983)
dan
(Dan)
29
brian
(Brian Gillespie)
30
Rhino 8 SR7 Release Candidate 2 for Windows and Mac (8.7.24107) is now available
Requires Rhino 8
Bugs Fixed:
- Localization: Concatenation issue (RH-80558)
- Make2D: Failure in removing lines behind clipping plane caps (RH-77105)
- Rendering: Cycles: Log file access problem while starting Rhino (RH-81208)
- SVG: Gradients export with incorrect decimal separators (RH-81531)
- ScriptEditor:
- Dictionary conversion to and from python 3 dict fails to grab values (RH-81521)
- Grasshopper script editor out of screen (RH-81508)
- Toolbar: Duplicated entries in the default macro library (RH-81061)
Enhancements:
- SVG:
- Added gradient support to SVG export (RH-79097)
- Supports exporting gradient colors with opacity (RH-81532)
Regressions Fixed:
Mac-Only Changes
Bugs Fixed:
brian
(Brian Gillespie)
31
Rhino 8 SR7 Release Candidate 3 for Windows and Mac (8.7.24113) is now available
Requires Rhino 8
Bugs Fixed:
- File IO: Pasting or importing curves from Illustrator creates invisible hatch (RH-81524)
- Rendering: Cycles: Fails to load when trying to clean up logs (RH-81630)
- ScriptEditor:
- Published python components are missing ghenv (RH-81638)
- C# Script instance does not have access to ghenv but does not throw errors (RH-81623)
- Exported script overrides GH component storage (RH-81629)
- GH Script component changes upstream mesh (RH-81617)
- Toolbar: Macro edit not sticking (RH-81604)
Features Added:
- ScriptEditor: Create separate manifest.yml in build (RH-81610)
Regressions Fixed:
- Project: Projecting curves to meshes several times slower in V7/V8 than in V5/V6 (RH-81126)
- ScriptEditor: GH component regression in marshalling guids on inputs (RH-81624)
- ScriptEditor: DebugStop exception throws stack trace in terminal (RH-81596)
brian
(Brian Gillespie)
32
Rhino 8 SR7 Release Candidate 4 for Windows and Mac (8.7.24121) is now available
Requires Rhino 8
Bugs Fixed:
- Containers: Scrollwheel on multitabbed containers should also work when mouse cursor is over the toolbars (RH-72232)
- Intersect: Out of tolerance between a cylinder and a trimmed plane (RH-81627)
- Toolbar: scrolling tune up (RH-76615)
Bugs Fixed:
- UI Appearance: Toolbar: Main toolbar detaching loses its container top bar (RH-81506)
brian
(Brian Gillespie)
33
Rhino 8 SR7 Release Candidate 5 for Windows and Mac (8.7.24128) is now available
Requires Rhino 8
Bugs Fixed:
- ReduceMesh: Re-reduction when hitting Ok after Preview (RH-42740)
- ScriptEditor: RunScript backporter keeps resetting Type Hints (RH-81870)
- Toolbar: Copied button overwrite (RH-81161)
Crashes Fixed:
- Grasshopper: Slow selection and lags when rotating view (RH-80348)
- ReduceMesh: Use the preview mesh (RH-62170)
dan
(Dan)
34
dan
(Dan)
35
Rhino 8 SR8 Release Candidate 2 for Windows and Mac (8.8.24137) is now available
Requires Rhino 8
To get it, subscribe to the Release Candidate update stream.
Bugs Fixed:
- OSnap: Snap lag with many blocks (RH-82015)
Crashes Fixed:
- File IO: Reading gh file crashes Rhino (RH-81806)
SDK Enhancement:
- Grasshopper 2: Constrained Tesselation SDK method (RH-81704)
dan
(Dan)
36
Rhino 8 SR8 Release Candidate 3 for Windows and Mac (8.8.24138) is now available
Requires Rhino 8
Bugs Fixed:
- ScriptEditor:
- Python component resets âNo Hintâ to âghobjâ hint (RH-82051)
- Script component shows language button when disabled (RH-82050)
- PointCloud gets split into its items on script component output (RH-82044)
- Toolbar: Commands ran from custom toolbar get added to diff file (RH-81935)
Regressions Fixed:
- ScriptEditor: IronPython is getting dotnet types instead of python types (RH-82019)
This update also addresses some upstream issues from 8.7.
dan
(Dan)
37
Rhino 8 SR8 Release Candidate 4 for Windows and Mac (8.8.24142) is now available
Requires Rhino 8
Bugs Fixed:
- ScriptEditor: Zero versioning of C# script dynamic assemblies causes issues (RH-82075)
Features Added:
- Grasshopper: Allow for filtering of Instance Definition Name on Model Objects (RH-78812)
- ScriptEditor: Fix script out multiple compile issue (RH-82071)
SDK Enhancement:
- SDK: RhinoCommon: Add backface color override to DisplayPipelineAttributes (RH-81831)
brian
(Brian Gillespie)
38
Rhino 8 SR8 Release Candidate 5 for Windows and Mac (8.8.24149) is now available
Requires Rhino 8
Bugs Fixed:
- Display: Raytraced mode fails when clipping fill is enabled (RH-82120)
- Grasshopper: Inconsistent Text Height and Arrow Size on Leaders (RH-81865)
- OSnap: Snapping to Occluded (RH-82190)
- Print: Vector PDF lines issue (RH-82109)
- RhinoStart: Initial startup is surprisingly slow V8 for Windows (RH-79171)
- Shrinkwrap: Some TextField boxes - RibbonOffset, QuadRemesh, ShrinkWrap - slow (MAC) (RH-82089)
Crashes Fixed:
- Layer: Only allows dragging name column to reorder (RH-82159)
Mac-Only Changes
Bugs Fixed:
- Panels: Rename Linetype loses focus (RH-82171)
brian
(Brian Gillespie)
39
Rhino 8 SR8 Release Candidate 6 for Windows and Mac (8.8.24158) is now available
Requires Rhino 8
Bugs Fixed:
- BooleanDifference: Wirecut fails, extrude curve and Trim works (RH-81583)
- Grasshopper: Extrude is offset from base curve (RH-82220)
- Installer: No Safe Mode option (RH-81899)
- Layer: Layer panel RMB menu missing (RH-82247)
- SDK: RhinoCommon:
- RhinoCommon: RhinoObject.SetTextureMapping ignores object transform (RH-81860)
- RhinoCommon: RhinoObject.SetTextureMapping misses existing channels (RH-81859)
Crashes Fixed:
- File IO: file crashes on opening (RH-82377)
Enhancements:
- OSnap: Mid object snap can snap to midpoint of linear/angular dimension line/arc (RH-9321)
Regressions Fixed:
- Join: GH Join Curves - regression from 8.7; curve order produces unwanted result (RH-82192)
Bugs Fixed:
dan
(Dan)
40
dan
(Dan)
41
Rhino 8 SR9 Release Candidate 2 for Windows and Mac (8.9.24171) is now available
Requires Rhino 8
Bugs Fixed:
- Code Editor Control: C# can not autocomplete ScriptInstance properties and their members (RH-77879)
- Grasshopper: Import SHP - .NET Issue (RH-82504)
- Print: Vector Print does not occlude intersections (RH-82454)
Enhancements:
- ScriptEditor: Search and Replace Improvements (RH-82434)
Regressions Fixed:
- Gumball: Made extruding with Ctrl (CMD) + plane control always creates open object (RH-82411)
- Fails when user-text key contains a dot (RH-82582)
- Model Attribute Key Selection breaks up at dots (RH-81311)
- RhinoCommon SDK Break in 8.7 (RH-82629)
- ScriptEditor: Cpython autocompletion sometimes returns too much data (RH-77886)
brian
(Brian Gillespie)
42
Rhino 8 SR9 Release Candidate 3 for Windows and Mac (8.9.24177) is now available
Requires Rhino 8
Bugs Fixed:
- Annotation: Hatch:
- Undo gets cleared after hatch match (RH-82686)
- Hatch match properties fails (RH-82678)
- Rendering: Texture Mapping: KeyShot: texture mapping wrong on Rhino 8 model (RH-80057)
Regressions Fixed:
- ScriptEditor:
- Editor minimum size should be smaller (RH-82705)
- sys.stderr is missing (RH-82704)
