Rhino 8 Service Release Available
Rhino 8 Service Release 1 for Windows and Mac (8.1.23325) is now available
Rhino will automatically update, unless updates are disabled.
Download the latest service release now…
Bugs Fixed:
  • Retain print settings for file after rhino restart (RH-77614)
  • RhRdkAssignMaterialToLayers doesn’t work properly (RH-78413)
  • Delete: Fails to delete mesh edges (RH-56326)
  • Display Metal: Rendered viewport shows colorful artifacts (RH-77271)
  • Gumball: Cut action always creates bad results from meshes (RH-77841)
  • Layer: Layers panel not ending undo record (RH-78325)
  • LayerStateManager: Model On state is not restored (RH-77719)
  • Localization: FitCurveToSurface shows comma in result (RH-78237)
  • Print:
    • Raster output with extended view shows a blank print (RH-60027)
    • Does not remember destination (RH-19435)
    • Pixel dimensions of output image incorrectly changed by DPI setting (RH-76437)
    • Vector output of solid hatches fails in details (RH-78015)
  • Rendering: Cycles:
    • Color mask doesn’t work (RH-78042)
    • Odd reflective behavior on default material (RH-77404)
  • SDK: RhinoCommon:
    • Issue with DrawMeshShaded in a Rhino 8 DisplayConduit (RH-78365)
    • Rhinocommon Leader class has typo in DuplicateShallowHelper which returns a LinearDimension instead of Leader (RH-78041)
  • ScriptEditor:
    • Missing Bitmap and Parallel in IronPython (RH-78129)
    • Problems panel icon stays red after closing a code with problems (RH-78130)
    • Ensure C# scripts can reference binaries that do not have .dll extension (RH-78079)
  • Subobject Selection: SubD face selection is harder (RH-78173)
  • TextObject: Text editing field not visible (RH-78227)
  • Toolbar: Cannot close default toolbar collection in Rhino skip apps (RH-76105)
Crashes Fixed:
  • Rendering: Textures: Crash bug when reusing blend texture (RH-78144)
Enhancements:
  • File IO: Added AcadExportSelectUnexportableObjects advanced setting to highlight skipped objects for saving DWG/DXF files (RH-77693)
  • Grasshopper: Create Get Plane Context Component (RH-76599)
  • Print: Rhino PDF remembers DPI setting (RH-57008)
  • PushPull: Added Loose option (RH-76269)
Features Added:
  • Grasshopper: Components: Allows setting Model Linetype and Hatch Scale in Grasshopper (RH-77367)
Regressions Fixed:
  • Display: Sub-object editing a SubD doesn't shade the preview anymore (RH-78065)
Usability Problems Fixed:
  • BlockManager: Incorrect selection state on block instances (RH-77501)
Mac-Only Changes
Bugs Fixed:
  • Annotation: Hatch: Unable to use custom hatch patterns (RH-77747)
  • Core Architecture: Idle Handler Affects Trackpad Performance (RH-78073)
  • Rendering: Materials: Sliders misbehave (RH-78222)
  • Selection: Objects don't select from popup (RH-78370)
  • Settings: Plugins: Allow plugin registration in com.mcneel.rhinoceros.x.plist (RH-77912)
Regressions Fixed:
  • Options: Settings > Mouse > context menu control missing (RH-78170)
Bugs Fixed:
  • Display Metal: Metal: Intel Macbooks cause visual glitch in shaded mode due to wire drawing (RH-77938)
Rhino 8 Service Release 2 for Windows and Mac (8.2.23346) is now available
Bugs Fixed:
  • Object properties panel - ensure Delete key clears Name text selection (RH-77630)
  • Annotation: Linetype: Linetypes panel out of sync with document properties (RH-78483)
  • Bridge: Options dialog does not display Dark mode (RH-78377)
  • CPlane: AutoAlign: Ngon failure sample (RH-78462)
  • Code Editor Control: Show vertical scroll bar when minimap is turned off (RH-76133)
  • CurvePiping: The source curve missing properties for the piping mesh (RH-78405)
  • Dark Mode: Set dark mode by code (RH-78558)
  • Display:
    • Block: Text In Block Not Displayed Horizontal to View (RH-75332)
    • Block transparency issue (RH-75335)
    • TriangulateMesh and display pipeline use different quads (RH-72067)
    • Dynamic feedback of shaded objects displays incorrect colors in all types of technical mode (RH-78040)
    • CurvatureGraph clipped by custom colors (RH-77473)
  • DraftAngleAnalysis: Analysis mesh does not preview (RH-73901)
  • File IO:
    • SVG export saves polycurves as separate curve segments (RH-78778)
    • Mirrored object missing faces when exported as STEP to AlphaCAM or MasterCAM (RH-78009)
  • FilletSrfToRail: Failure caused by curve direction (RH-77869)
  • GCon: Incorrectly reports G2, instead of G1, between surface edges (RH-78419)
  • Grasshopper:
    • Content cache causes page layout to lag (RH-78823)
    • Extrude curve failure (RH-76758)
    • Bounding box is not flat until curve is flipped (RH-78284)
    • Bug with referencing materials with textures and then baking (RH-77986)
    • Grasshopper GH1 Model Object crashes when Rhino Objects Table and Manifest have errors (RH-78315)
    • Data Output (GH DATA) component error in Rhino 8 (RH-78397)
  • Gumball:
    • Scale handles not displayed when it is set to object for decals (RH-78538)
    • Face translation does odd things (RH-78032)
  • Help: Review, correct and improve the gumball topic (RH-44392)
  • History: HistoryPurge command only removes info from children (RH-78059)
  • IntersectTwoSets: Incorrectly adding objects to reference layers of Worksession (RH-78724)
  • Layer: Borders of color and material controls in are blurry in Layers panel (RH-78058)
  • Lights: Light panel falloff doesn't change on first time (RH-78311)
  • LoadPlugin: Pufferfish doesn't run in GH in Rhino 8 (RH-78382)
  • Menu: : 4View menu item missing Enter in macro (RH-78023)
  • OSnap: "Snap to occluded object" does not work properly in Rendered display mode (RH-78334)
  • OpenNURBS: OpenNurbs hangs in ONX_Model::Read() function (RH-77657)
  • Options: File angle tolerance set to 0.01 gives an incorrect popup warning (RH-78037)
  • PackageManager: Search bar has low contrast (RH-77791)
  • Panels: Toolbar icons in Named panels are truncated instead of wrapping (RH-78471)
  • Print:
    • Gradient background repeating bands when printing in PDF (RH-63777)
    • Hatch Not Printing with Print Weight (RH-77631)
    • Linetypes in model units are not scaled on paper (RH-78154)
    • Vector output prints shaky lines when object is far from world origin (RH-76645)
    • Tabbing through margin fields may not select current value for editing (RH-16327)
    • Does not remember selected layout in next print (RH-43925)
    • Vector output missing geometry behind clipping plane (RH-77617)
    • Vector print of clipped scene issue (RH-77106)
  • PushPull: Does not recognize region bounded by curves (RH-77984)
  • Rendering: Image overexposed (RH-77923)
    • Physical Sky Texture not rendering in Raytraced / Rhino Render (RH-78269)
    • Emissive fails when lighting object is moved (RH-66473)
  • Rendering: Cycles Viewport: Ignores OCS mapping (RH-76980)
    • Previews are not updating correctly (RH-74512)
    • gLTF format doesn’t save texture repeat values (RH-75896)
  • Rendering: Realtime SDK: Default light gets added when light already exists (RH-78010)
    • Dot texture settings broken (RH-78141)
    • When adding a new blend texture, the texture is not being used (RH-78135)
    • Graph doesn’t refresh immediately (RH-78161)
  • SDK: CRhinoAppSettings::ShowOsnapDialog no longer works (RH-78331)
  • ScriptEditor:
    • Allow toggling single breakpoints (RH-78081)
    • Deserializing Parameter Type that contains System.Private.CoreLib fails on dotnet framework for published components (RH-78211)
    • Script fails to determine language from lang id specifier line (RH-78488)
  • Selection: Subobject selection does not work with SubDs in blocks (RH-78148)
  • Sphere: Rhino.Geometry.Sphere.FitSphereToPoints not working correctly. (RH-77868)
  • ToNURBS: ToNURBS of toroidal RevSurface creates invalid Brep (RH-57922)
  • Toolbar:
    • RUI file not registered from 8.0/MacPlugIns symlink (RH-78835)
    • Rhino needs a restart to be able to delete a button (RH-77523)
    • Removing a new Toolbar button does not work (RH-78350)
    • Incorrect ID’s for DimRotated.svg & DimRotated_darkmode.svg (RH-78533)
    • ClosestPoint icon is missing (RH-78459)
    • PopupToolbar glitch with Layers (RH-78366)
  • UDT: CageEdit slow example (RH-78098)
  • UI Appearance: Vertical-docked tabs don't show text (RH-77483)
  • UI Cleanup: Automatic UI sections show all sections even the empty ones (RH-78049)
  • ZoomSelected: Not working on sub-selected objects inside a block instance (RH-78030)
Crashes Fixed:
  • Eto: System.Exception: Could not initialize an instance of the type 'Foundation.NSUrl': the native 'initFileURLWithPath:isDirectory:' method returned nil. (RH-77593)
  • FilletSrfToRail: FilletSurfaceToRail: Crash in Grasshopper (RH-74236)
Enhancements:
  • Gumball:
    • Extending mode uses document tolerance for checking planarity of faces (RH-77687)
    • Cut operation shrinks the faces made from cutters surfaces (RH-78274)
  • Print: Now shows file path and name when printing to PDF completes (RH-78524)
  • PrintPreview: Added DetailBorder option to control visibility of detail view borders in layout viewports (RH-74306)
  • PushPull: Added SetBasePoint option (RH-78197)
  • SelLayer: Scriptable command allows picking more objects with preselect (RH-78335)
Features Added:
  • ScriptEditor: Added hotkeys for adjusting font sizes (RH-75779)
Regressions Fixed:
  • Grasshopper: Components: Data conversion failed from extrusion to surface (RH-78595)
  • Offset: In Grasshopper 1 / V8, setting corner style to 0 (no extension) fails on polycurves (RH-78581)
  • Rendering: Realtime SDK: Bella outputs error messages and fails to render objects (RH-78709)
  • SelLayer: Cannot specify a layer when an object is selected (RH-78290)
  • Subobject Selection: SubD face selection is still harder for non-planar ngons (RH-78578)
SDK Enhancement:
  • Layer: Added publicly exported function to sort the layers in the layer table (RH-78286)
  • LoadPlugin: Added support for multi-targeting plugins to have specific assemblies for .NET Core vs. .NET Framework (RH-76604)
  • SDK: RhinoCommon:
    • Added a public ViewInfo constructor, as well as in Rhino3dm (RH-70610)
    • Allows toggling visibility of Selection Filter panel (RH-78332)
    • Added IsInTiledDraw to RhinoCommon (RH-77822)
Tasks Completed:
  • File IO: Updated SketchUp SDK to latest (RH-78474)
UI Change:
  • CPlane: AutoAlign: Auto CPlane is now disabled by default (RH-78691)
  • Print: Colors of section styles override print colors (RH-78294)
  • ScriptEditor: Grasshopper: Allow removal of OLD label on legacy Python script components (RH-76151)
Mac-Only Changes
Bugs Fixed:
  • Annotation: Linetype: Default linetype panel should be taller (RH-76525)
  • Display Metal:
    • Section hatches in Monochrome (RH-77797)
    • Ghosted clipped part of geometry in shaded technical (RH-78208)
  • Export: Should deselect post selected objects (RH-78026)
  • Gumball: Disappears when opening a second document (RH-77645)
  • Layer:
    • Layers panel does not automatically switch between light/dark mode (RH-78700)
    • Column headers in Layers panel missing tooltips (RH-76570)
  • Layout: Move Up and Move Down buttons not responsive beyond first click (RH-77776)
  • Preferences: Is made scriptable on Mac (RH-61857)
  • Print: Vector output to the MS PDF Printer Produces a blank page (RH-66833)
  • Rendering: Textures: Not obvious when treat as linear button is disabled (RH-78136)
  • Splash and About: Allows Copy-Paste from the About dialog (RH-69006)
Features Added:
  • LoadPlugin: Plugins: Create version-specific MacPlugIns folder and load plugins from there (RH-78149)
Windows-Only Changes
Bugs Fixed:
  • Annotation: Linetype: (Sometimes) double width on Windows (RH-78031)
  • Display: Cannot cast shadows from unclipped objects when specified (RH-78193)
  • Rendering: Rendering through Frame buffer increases memory usage (RH-77045)
  • Rendering: Materials: Initial drag on a material causes Rhino to hang (RH-78241)
  • Selection: Selection - dots and layouts (RH-78771)
  • ShadedViewport: Frequently Shaders Turning Black in Rendered Mode on Rhino 8 (RH-78738)
UI Change:
  • Options: Added link to open the new location of the Crosshairs checkbox (RH-78181)
Rhino 8 Service Release 3 for Windows and Mac (8.3.24009) is now available
Bugs Fixed:
  • Annotation: Dot: Dot: Display text editing box does not expand with height of dialog (RH-77041)
    • Breps Linetype Width Not Previewing or Printing with Vector (RH-79352)
    • Linetype Width and Pattern Scale Incorrect on Layout (RH-78703)
    • Linetype Width Set to Pixels Not Displaying or Printing (RH-79349)
  • Annotation: Text: Text Panel does not show any option (RH-79011)
  • BlendCrv: Dialog not updating properly (RH-78243)
  • CPlane: AutoAlign: Sticky mode toggle doesn't script correctly (RH-78528)
  • Containers:
    • Removed OSnap panel reappears after restart (RH-77605)
    • PopUp a container blanks the buttons on the floated version (RH-78476)
    • When sidebar is pinned, clicking on Properties or Layer icon in the main toolbar should unfold the sidebar (RH-78750)
    • Flyout toolbar closes container popup (RH-78152)
    • Container: Right sidebar hides when hovering to another tab (RH-78749)
  • Delete: Slow on mesh subobjects (RH-78652)
  • Display:
    • Technical mode with custom EMap fails (RH-78782)
    • Gradient hatch far from origin looks like a solid hatch (RH-78408)
  • Docking: Osnaps and Filter glitch (RH-78363)
  • DocumentProperties: Hooked up custom units in the scriptable command (RH-8990)
  • Enter: Mouse right click repeat is slower than Space or Enter (RH-78895)
  • File IO:
    • OBJ material imported incorrectly (RH-71573)
    • Texture coordinates are all zeros in OBJ and FBX exports (RH-78676)
  • Grasshopper: Cannot copy with wire drag using alt key on Mac (RH-78693)
  • Helix: Helix - accept default radius on Enter (RH-79441)
  • History: Loft with Pt input - Tangency is lost after update (RH-78922)
  • Insert: Does not remember the "Insert as" setting (RH-44370)
  • Intersect: Point intersection not being detected (RH-78423)
  • Layer: Double-click leaves layer unselected (RH-78854)
  • Make2D: Missing clipping-plane intersection curves (RH-78825)
  • NamedView: Panel not populating when opening recent file from splash screen (RH-78696)
  • OSnap:
    • Docked OSnap panel sometimes not responding to Ctrl or Shift with mouse-over (RH-78852)
    • Checkbox items disappear when narrowing down the left sidebar (RH-78753)
  • Options: WindowColor 3 does nothing (RH-62608)
  • Print:
    • No longer export to a vector PDF in Pen mode or other shaded modes (RH-79092)
    • Closed polyline missing a segment (RH-79094)
    • Vector PDF output from technical creates white hatch (RH-79221)
    • Ensure selected printer exists before trying to recall settings (RH-78904)
    • Very very slow on Mac (RH-78885)
    • Rhino PDF won’t print multipages with vector output (RH-78674)
    • Raster printing line width issues (RH-78687)
  • RDK: Physical Sky texture controls don't work properly (RH-78305)
  • RefitTrim: Fails on surface with singularity at opposite end (RH-73421)
  • Rendering: Content Panels: Pixelated icons in Lights panel (RH-78679)
    • Decals do not show in Raytraced mode (RH-78768)
    • Bring back out-of-process kernel compilation (RH-78287)
    • Substance support broken for some materials (RH-78220)
    • Name sometimes changes when changing type (RH-78668)
  • Rhino Installer Engine: Installed plugin appears twice in the Menu (RH-78113)
  • SDK: Add IsWcsProjected and IsWcsBoxProjected to ON_Texture and Rhino.DocObjects.Texture (RH-78920)
  • SDK: RhinoCommon:
    • DrawSubDWires method is not working (RH-78897)
    • Brep.JoinBreps modifies edges (RH-78899)
    • Exposed EarthAnchorPoint to Rhino.FileIO.File3dmSettings (RH-34447)
    • Added bounding box overrides to Rhino custom objects (RH-32678)
    • ShrinkWrap offset and smoothing have no effect on Point Clouds (RH-78656)
    • MeshLine leaks memory (RH-78469)
  • ScriptEditor:
    • ScriptEditor close buttons should have light and dark mode icons (RH-79361)
    • Single script component is missing when language is not initially available when gh plugin is loaded (RH-79552)
    • Point3d is missing .Clone() and .Duplicate() in python 3 (RH-77315)
    • References assemblies in #r do not work in python (RH-79116)
    • Non-single file assemblies fail to load in Pythonnet (RH-78289)
    • Use Object does not load when base component updates legacy parameters to new ones (RH-79338)
    • RhinoScriptSyntax mesh.py has a CPython error in AddMesh (RH-79163)
    • Node in code Python returns troubling (RH-78865)
    • Roslyn does not compile when Memory Load is enabled in GrasshopperDeveloperOptions (RH-78555)
    • No module named ‘scriptcontext’ (RH-78435)
    • Pretty name should match Variable name when is not set specifically (RH-78616)
    • Editor sometimes resets caret position to the top in Grasshopper script component (RH-78618)
    • Int parameter is converted to “Object Print Width” parameter when using new script editor compiler (RH-78617)
    • Applying modified script to component is awkward now with the “Do you want to save” prompt addition (RH-78543)
    • Make sure type hinting works for linked scripts (RH-78090)
  • Section Tools: Clipping drawing location jumps (RH-77320)
  • Selection:
    • Inconsistent point selection via picking the control polygon (RH-78946)
    • Made SelNakedMeshEdgePt command not turn on control points (RH-78653)
  • SetDisplayMode: Display Mode > Object > SubD options not sticking (RH-78918)
  • SetDocumentUserText: The Document User Text panel doesn't update when importing a 3DM file with Document User Text (RH-78846)
  • ShadeOptions:
    • Grid settings affect Z-axis visibility (RH-78772)
    • Grid and axis stay visible in grid appearance “use transparent grid” (RH-78727)
    • Grid settings issues (RH-78726)
  • SrfSeam: Fails in V direction of a surface (RH-56626)
  • Sun: Daylight saving checkbox is broken (RH-78824)
  • Toolbar:
    • Rhino 8 showing duplicate menus from plug-ins (RH-78914)
    • Difficult to close “Default Toolbars” when importing from Rhino 7 RUI (RH-78858)
    • Duplicating a button needs the Macros command to properly change the tooltip (RH-79138)
    • missing icons in select dimensions toolbar (RH-78748)
    • Missing icon in visibility toolbar (RH-78756)
    • WindowLayout: Duplicate sidebars on Mac (RH-70348)
    • Issue of button and text setting (RH-78383)
    • PopUp is slower on Mac (RH-76248)
  • UI Appearance:
    • RhinoArtisan: Space on top of command prompt in Rhino for Windows (RH-78557)
    • Detaching toolbars modifies its size + size is not stored after modifying (RH-76803)
    • Changing a button to text needs a restart of Rhino (RH-77909)
  • WindowLayout: Include tab size settings in exported RHW file (RH-77995)
Cosmetics:
  • File IO: Fixed capital letter file extensions when exporting AI files (RH-78651)
  • ScriptEditor: Fix Input as Path Icon on Grasshopper component (RH-78210)
  • Toolbar: "Size to Content" does not re-size floating container properly (RH-70719)
Crashes Fixed:
  • Make2D: Cannot cancel properly (RH-78990)
  • ScriptEditor: Passing function to Rhino.RhinoApp.InvokeOnUiThread() crashes Rhino (RH-79021)
Enhancements:
  • BlockManager: Added "Group similar block instances" setting (RH-77975)
  • Code Editor Control: Provide snippet completions like found in Rhino 7 Gh C# scripting components (RH-78789)
  • Docking: Added margin around sidebar to avoid auto-hiding accidently (RH-77224)
  • File IO:
    • Added AcadExportSortLayers (True by default) and AcadExportWriteEmptyLayers (False by default) advanced settings (RH-78977)
    • Rounding numbers when saving Points (*.txt) file type (RH-78573)
  • Grasshopper: Added Transpose Surface and Reverse Surface components (RH-77254)
  • Gumball: Maintain relocation for sub-object editing until selection is cleared (RH-75509)
  • Offset: Closing offset arcs into circles if they form a region (RH-78494)
  • Osnap:Point: Now snaps to points on the near side of a point cloud (RH-10862)
  • Rendering: Cycles Viewport: Added device state indicator and "Recompile kernels" and "Show compile log" buttons (RH-78682)
  • ScriptEditor: Allow RhinoCode homedirectory to be changed from Rhino (RH-78915)
  • Shrinkwrap: ShrinkWrap: Added "Compute vertex colors" checkbox (RH-75395)
Features Added:
  • Enter: Added DisableRightClickAsEnter advanced setting (RH-20644)
  • ScriptEditor: Expose virtual envs for cpython (RH-66285)
  • SelChildern: SelChildren: Added IgnoreAnnotations=Yes/No option (RH-63113)
  • Toolbar: Added "Cascade as menu" setting back (RH-67717)
Regressions Fixed:
  • Annotation: Linetype: Model space pattern scale gone missing (RH-79307)
  • Grasshopper: Extruding surface issue (RH-79261)
  • Print: Control points on "single selected" Objects Print (RH-79362)
  • Properties: Glitch of renaming materials (RH-78477)
  • Rendering: Materials: Sorting alphabetically does not update the list (RH-78839)
  • Rendering: Texture Mapping: Texture baking UVW transform wrong on WCS projected textures (RH-78975)
  • Rendering: Textures: Image paths need to be editable (RH-78427)
  • ScriptEditor:
    • Grasshopper component does not show previews on output parameter (RH-79120)
    • “Out” parameter on new Script component is not removable from ZUI interface (RH-78322)
    • Implement custom iter and len extensions for Pythonnet (RH-78987)
    • GH Python3 output polyline is different from IronPython (RH-79323)
    • Grasshopper python input string is incorrectly a list (RH-79030)
    • CPython does not apply implicit casting especially when dealing with operator overloads (RH-79099)
    • CPython Point3d non-iterable problem (RH-79162)
    • VB Script Component in GH should not be Obsolete (RH-78855)
    • Python 3 can not slice dotnet lists (RH-78908)
    • Allow indexing and slicing on grasshopper inputs lists in python 3 (RH-76311)
    • Improve script component exec performance (RH-78353)
    • Pass Grasshopper list inputs as List<> into the scripts. Figure out a way to generate python 3 lists for inputs (RH-78321)
  • Toolbar: Float To Top does not work (RH-77681)
SDK Enhancement:
  • File IO: Support exporting glTF programmatically with options (RH-78795)
  • SDK: Exposed RhGetTanPerpPoint to the C++ SDK (RH-78612)
  • SDK: RhinoCommon:
    • Allows offsetting curve tangent to surface (RH-78999)
    • Some added linetypes get marked as non-delete in Options > Linetypes (RH-78509)
    • Exposed ON_Texture::m_magfilter to Rhino.DocObjects.Texture (RH-50589)
UI Change:
  • ClippingPlane: Made clipping planes only snapped by Point OSnap at three locations where control points show (RH-78226)
  • Layer: Disabled Delete key in Layers panel for deleting layers (RH-78615)
  • Options: Toolbar Options Page: Eliminate weird macOS UI (RH-78781)
  • Properties: Changed type name of Picture from "surface" to "picture surface" (RH-78414)
  • Section Tools: ClippingDrawings command now sets print width to ByLayer (RH-78060)
  • Toolbar: Replace Gear with menus in Edit Image dialog (RH-79395)
  • Grasshopper: Undo action regression from v7 to v8 (RH-78853)
  • Grasshopper: Bake: Output objects don't land on selected layer (RH-78959)
  • Properties: Viewport info hard to read in dark mode (RH-78521)
  • ScriptEditor:
    • Modify python error diag to say use .NONE instead of .None (RH-79152)
    • Grasshopper window drags really slowly when there are many script components placed on the canvas (RH-79189)
    • Add import math to python template scripts in editor and Grashopper (RH-79154)
    • Put language init window on a timer so it opens after a second or so (RH-77294)
    • Record component script saves in Grasshopper undo history (RH-78544)
    • Python lint to mention to use .NONE instead of .None (RH-77801)
    • Input parameter Name filed is a little visually distracting from the Variable Name field (RH-78552)
    • Improve discoveribility of creating languages in new script component (RH-76674)
    • Modify C# script and add default assignments to out parameters (RH-78547)
  • SelLayer: Spacebar should act as Enter key in dialog (RH-78761)
Mac-Only Changes
Bugs Fixed:
  • Containers:
    • Floating Command container cannot be re-docked (RH-78731)
    • Floating containers stack at screen corner when Rhino starts (RH-71060)
  • Display: Custom color not working for surface naked edges (RH-78568)
  • Panels: Floating a container outside of virtual desktop causes container to disappear on Mac (RH-69542)
  • SmartTrack: Status bar does not update on Mac (RH-78660)
  • UI Appearance: Mac: Command feedback is too slow and distracting (RH-77197)
  • WindowLayout: Ignore the left sidebar (RH-76415)
Crashes Fixed:
  • Export: Crash: ExportAll to 3DS, OBJ in 8.3 (RH-79550)
Features Added:
  • Rendering: Post Effect: Intel denoiser is now integrated into Rhino 8.3 and works on Apple Silicon (RH-71149)
Regressions Fixed:
  • Print: Vector output prints layouts upside down (RH-76966)
UI Change:
  • Options: Hide ShowFullPathInTitleBar in advanced settings on Mac (RH-54289)
  • Analysis: EdgeContinuity: Only last digit of input number shows (RH-78685)
Bugs Fixed:
  • Grasshopper: Rhino.inside.Revit starts to flash and spin the cursor in latest versions (8.2-8.3) (RH-78879)
  • Panels: Some panels do not fade out (RH-75220)
  • Print: 3rd party pdf writers & Physical Printers not saving correct page dimensions (RH-77985)
  • ScriptEditor: Crash with SaveAs same file name (RH-79103)
  • Settings: Raytraced mode settings won't restore to defaults or un-highlight (RH-38066)
  • UI Appearance: Rhino 8 looses focus when dragging out a cascaded toolbar (RH-78099)
Enhancements:
  • Display: Edges in technical display modes display faster (RH-76241)
  • Section Tools:
    • ExportClippingDrawings command saves files to the model folder by default (RH-78873)
    • ExportClippingDrawings command remembers file saving path in current Rhino window (RH-78874)
Regressions Fixed:
  • Layer: Layer names cannot copy and paste from right-click menu (RH-78025)
Rhino 8 Service Release 4 for Windows and Mac (8.4.24044) is now available
Bugs Fixed:
  • Print: PDF Paper Size is blank after switching printer (RH-80138)
  • IRhinoUiHolder doesn’t work for VRay (RH-79667)
  • Annotation: Dot: Dialog opens with squished text editing box (RH-79432)
  • Annotation: Text: Double-click to edit not working properly (RH-79297)
  • BlockManager:
    • Block typing to command-line (RH-78045)
    • Setting multiple block instances values that show “Varies” doesn’t work properly (RH-74513)
    • Pink highlight inconsistent with selection (RH-78202)
  • ChangeLayer: OK button is in focus instead of the layer name input box (RH-79359)
  • Crease: Added Crease command back into SubD Tools toolbar (RH-79519)
  • Display: Print width is not turned off (RH-79770)
    • Scriptable command missing text in a prompt (RH-79526)
    • Annotations style rename warning jumps the gun (RH-79268)
  • Drag and Drop: Dropping a .png file causes Rhino to hang (RH-78280)
  • DupEdge: On SubD, Output Layer is Inverse (RH-79317)
  • Export: "Export with Origin" Not Using Origin (RH-79112)
  • ExtendSrf:
    • Resulting extension is shorter than preview (RH-70311)
    • Typed distance is ignored (RH-80360)
    • Always extending smooth (RH-80362)
  • ExtractMeshFaces: Changes texture mapping on extracted mesh faces (RH-78887)
  • File IO:
    • Rhino hangs reading DWG file (RH-79421)
    • glTF format roundtrip back to Rhino with material errors (RH-75864)
    • Export PDF missing custom paper size controls (RH-79161)
  • Fill: Edge selection does not clear after fill command is run (RH-77554)
  • FilletSrf: Scriptable command always fails (RH-79157)
  • Grasshopper:
    • Custom preview ignores render checkbox (RH-76903)
    • Make 2D Rhino 6 Clipping Plane issue (RH-58607)
  • Grasshopper: Components: Exploding text of single line font returns wrong geometry (RH-78936)
  • Gumball:
    • Polyline as cutter creates kinked surfaces (RH-79533)
    • Arrows draw too small at high DPI scaling (RH-79088)
    • Slight delay (RH-79195)
  • History: Deactivating detail makes dimensions jump (RH-78926)
  • Import: Error importing SVG (that opens fine in Chrome and Illustrator) (RH-79299)
  • Layer:
    • Layers with same name can be dropped under a layer as child layers of same level (RH-79755)
    • Layers panel visible slows down OSnap checkboxes (RH-79587)
    • Missing context menu on the layer list popped up from status bar (RH-78751)
  • Layout: Object snapping fails in layout (RH-79912)
  • Localization: Rotation has a comma instead of a point (RH-79276)
  • OSnap: One shots disabled if persistent OSnaps are disabled (RH-79867)
  • OpenNURBS: Remove deprecation tags from ON_Extrusion::SetMesh, etc. (RH-79060)
  • Options: Options dialog glitch (RH-79684)
  • PointsOn: Curve control points stay on after an edit in v8 (RH-78393)
  • Print:
    • Displayed scale controls aren’t correct when printing to image file (RH-80036)
    • Technical view intersection lines do not honor layer print color (RH-28051)
    • In Model scale and On Paper scale controls unresponsive (RH-80003)
    • Scale / Extents combination is not working correctly (RH-79728)
    • Print width of hairline does not print (RH-78455)
    • Vector PDF output from Technical view draws geometry occluded by other objects (RH-79808)
    • Missing single pixel hatch (RH-79860)
    • Some objects in layouts are not printing in technical vector output (RH-79070)
    • Vector PDF draws unexpected intersection (RH-79539)
    • Fake2d Not Invoked When Printing Layouts (RH-79629)
    • Details in Technical draw heavier silhouettes (RH-79527)
    • Vector print of extrusion objects shows artifacts (RH-79328)
    • Vector PDF draws intersections on hidden layer (RH-79517)
    • Vector PDF overrides black and white setting for curves (RH-79536)
    • when printing raster it is not possible to set the correct size (RH-78765)
    • Vector PDF draws hidden linetype curves as continuous (RH-79523)
    • Technical mode with HLR does not clip curves (RH-79091)
    • Vector output exports curves to PDF as polylines (RH-79113)
    • Print dialog ignores Extents on layouts (RH-79101)
  • Properties: Editing text makes it not selectable (RH-73252)
  • RDK:
    • Integrated Intel Denoiser into Rhino as “Denoise” post effect (RH-78807)
    • Childslot texture amount does not update in the UI (RH-79044)
  • Rendering: Bella Render calls to non-functional ChangeQueue properties (RH-79136)
    • Objects selected from Materials panel doesn’t show Gumball (RH-78969)
    • IOR dropdown doesn’t show when material editing via layer panel (RH-79062)
    • Child slot not displayed (RH-79719)
    • Incorrect mapping for textures with same name (RH-77168)
    • “Group similar textures” checkbox affects copied materials (RH-78891)
  • Rhino Installer Engine: Rhino 8 RHP in RHI not compatible (RH-78866)
  • SDK: RhinoCommon:
    • Exposed ExtractLinetypeSegments (RH-79448)
    • Added lighting schema to display attributes (RH-79223)
    • Cannot add a group to File3dm.AllGroups table (RH-56334)
  • ScriptEditor:
    • ghdoc is not set for external scripts (RH-80140)
    • PIP sometimes gets stuck when installing package (RH-80090)
    • RhinoApp.Runscript not working in C# script from toolbar (RH-79530)
    • Unset outputs will use the persistent value from previous runs (RH-79615)
    • Python error line is wrong in GH when importing gmsh (RH-79662)
    • Error in Python 3 exception parser (RH-79830)
    • Add search paths ui to new editor for Python engines (RH-79027)
    • Published scripts as components do not carry their persistent data (RH-79336)
  • Section Tools:
    • Added ShowHatch and ShowSolid options to ClippingDrawings and EditClippingDrawings commands (RH-79367)
    • Clipping drawing not showing hatch for blocks (RH-79006)
    • ClippingDrawings: Section Style of block instances (RH-77426)
  • SelectionFilter: Disable state not persist between sessions (RH-79389)
  • Shrinkwrap: ShrinkWrap: Command history missing average edge length and face count (RH-78817)
  • SmartTrack: Issue about tracking of parallels (RH-79058)
  • SrfSeam: Direction set by typing is not remembered of next run (RH-78822)
  • SubDSphere:
  • Toolbar:
    • Docked Side, with Flyout has no icons (RH-79246)
    • Copy toolbar/buttons/macros between libraries instead of linking them (RH-78798)
    • Copied toolbar buttons are ‘cleared’ when copied from a linked toolbar (RH-78592)
    • Layout macros missing (RH-79591)
    • Copy toolbar button glitch (RH-79452)
    • Wrong icon for ReduceMesh (RH-79325)
    • Editing button image in linked RUI causes an empty button (RH-78900)
    • Change OSnap “toolbar” to “panel” in button tooltips (RH-79333)
    • Icons not precise (RH-78570)
  • Trim: Unexpected behavior (RH-80000)
  • UI Appearance: Modified linked toolbars from Rhino 7 should be saved under a new name (RH-78594)
  • UVEditor: Unwrap of a Rhino 7 custom unwrapped mesh is bad (RH-79784)
  • VariableFilletSrf: : Ugly preview (RH-79549)
  • WindowLayout: Need to fill in the name field on export (RH-69707)
Crashes Fixed:
  • ExportOptions: Rhino closes suddenly Rhino 8.4 RC4 (RH-79616)
  • Menu: Adding menu item crashes Rhino (RH-79874)
  • Rendering: Decals: Crash when positioning a decal (RH-79164)
  • ScriptEditor:
    • Python 3 marshaller crashes on self referencing objects (RH-80142)
    • Crash when saving a project (RH-79879)
    • Crashes Rhino8 when C# script is changed from VisualStudio (RH-79763)
    • importing ghpythonlib module crashes Rhino (RH-79982)
  • Toolbar: Crash when opening toolbar properties (RH-79717)
Enhancements:
  • Annotation: Hatch: Added a +/- button to column header of Import Hatch Pattern dialog to check or uncheck all hatch patterns (RH-52796)
  • Extend: Added Join=Yes/No/Merge to Extend and ExtendDynamic commands (RH-5921)
  • ExtractLineTypeSegments: Extracts linear segments as lines (RH-79459)
  • File IO: SaveACopy command now saves 3dm files of different versions (RH-79387)
  • ScriptEditor:
    • Extract script input parameters as their hinted type? (RH-79032)
    • Add File Path hint to script parameters so relative paths can automatically resolve to absolute based on GH definition location (RH-79186)
    • Create Editor options window like existing (RH-73245)
  • Section Tools:
    • Added AddHidden and AddSilhouette options to ClippingDrawings and EditClippingDrawing commands when AddBaground=Yes (RH-79269)
    • Added LabelStyle=Dot/Text option to ClippingDrawings and EditClippingDrawings commands (RH-78954)
Regressions Fixed:
  • Annotation: DimLinear: Inch Fractional Dimensions missing a space (RH-80143)
  • Annotation: Text: Stays Highlighted After Editing (RH-79442)
  • Export: "Solid As Mesh" Creates Empty DWG File (RH-79110)
  • ExtendSrf: : Surface moves (RH-78626)
  • ExtractSubCrv: Stops at polylines (RH-79445)
  • Grasshopper: Extruding surface issue (RH-79428)
  • Gumball: Small delay that causes a behavior slightly different than Rhino 7 (RH-79124)
  • Layer: Typing initial letter of layer names does not highlight layer (RH-79200)
  • Offset: Fails in V8 (RH-79398)
  • Print:
    • Fitting Print to Paper Not Expected (RH-79932)
    • Hidden edges not drawn in vector PDF (RH-79735)
    • Visible edges not drawn in vector PDF (RH-79734)
  • ScriptEditor:
    • dotnet Dictionaries sometimes fail to convert to python (RH-80321)
    • Script Editor does not clear prompt after running script (RH-80271)
    • Command history is not clear with Script: Run or :Edit commands (RH-80272)
    • Legacy Python component has multiline standard output (RH-79618)
    • Add Rhino appdata scripts paths to sys.path (RH-79864)
SDK Enhancement:
  • SDK: RhinoCommon:
    • Exposed additional display modes (RH-74943)
    • Added a new RevSurface.IsTransposed property (RH-79529)
    • Added options to SerializationOptions to exclude meshes (RH-78409)
    • Added ThicknessUsage properties to DisplayPipelineAttributes (RH-77652)
    • Added DrawLight method for Display Pipeline (RH-79364)
UI Change:
  • Gumball: Changed numeric input relocate behaviors for arrow, arc, and scale handles (RH-79437)
  • Menu: Changed menu items of Crease and SubDCrease commands (RH-79521)
  • Toolbar: Allows Delete button to delete empty toolbars (RH-79369)
Mac-Only Changes
Bugs Fixed:
  • Context Menu: Viewport Context Menu: Set Camera: Labels are wrong (RH-79169)
  • DocumentProperties: Units change before closing causes repeated dialogs to pop up (RH-80346)
  • HeightField: Incorrect with surface output (RH-79293)
  • OSnap: Panel doesn't sync during GetPoint operations on MacOS (RH-79825)
  • Print:
  • Rendering: ResetMessageBoxes does not bring back the "Would you like to save the image?" dialog box (RH-78937)
  • WindowLayout: WIndowLayout: Sidebar is not restored on Mac (RH-74074)
Crashes Fixed:
  • Shrinkwrap: ShrinkWrap: Crashes on Mac (RH-79135)
Regressions Fixed:
  • Print: MAC: Trimmed Picture Causing Incomplete Vector Print On Layout (RH-79865)
UI Change:
  • Keyboard Shortcuts: Added Cmd+Ctrl+ to the list (RH-77588)
  • Settings: Made right mouse button repeat command and show context menu like Windows version (RH-78395)
Bugs Fixed:
  • DocumentProperties: Left column top alignment (RH-79518)
  • Export: "Solid As Mesh" to DWG: File Written with Errors (RH-79238)
  • Layer: Move Up and Move Down buttons may not order layers correctly (RH-79219)
  • Selection: Settings on context menu of Selection menu don't change (RH-79188)
  • WindowLayout: Fails to restore after Fullscreen (RH-73631)
Rhino 8 Service Release 5 for Windows and Mac (8.5.24072) is now available
Bugs Fixed:
  • AlignVertices: AlignVertices works better on control polygon versus SubD (RH-80631)
  • Annotation: DimAngular: Dimension line not drawn (RH-80224)
  • Annotation: Hatch: Exception errors when importing from 3dm without hatches (RH-79713)
  • Annotation: Linetype: SetLinetypeScale does not change the scale value elsewhere (RH-79676)
  • BlockManager:
    • Block Definitions Panel can insert ^-character for unnamed geometry names (RH-80298)
    • CSV file incorrect for blocks with quotes in name (RH-80215)
  • ClippingPlane:
    • Bounding box incorrectly includes dot labels of clipping sections (RH-80618)
    • Moving geometry temporarily unclips geometry (RH-80128)
    • Sub Selection Highlight not showing when clipping plane is active (RH-80127)
    • Hitting dot while autocompleting does not choose selected (RH-80287)
    • allow completion items to call back into the editor control to fetch more info (RH-80102)
  • Copy: Last copy of a block cannot be selected and snapped (RH-80472)
  • Display:
    • Technical draws random intersections (RH-79288)
    • Technical draws incomplete lines (RH-79394)
    • Extrusion Block Instance Seams Displayed Incorrectly In Technical Views (RH-80250)
    • SubD wireframe on back draws during editing (RH-79344)
    • Wireframe post effect looks terrible (RH-26879)
  • DocumentProperties: Grid units update lag (RH-79321)
  • Extend: ExtendDynamic command deletes input when Join=No (RH-80606)
  • ExtractControlPolygon: Incorrectly extracts NURBS control polygons from a single face SubD (RH-80313)
  • File IO:
    • No feedback of failure to write PDF (RH-80198)
    • PDF import does not give command line interface for -import/open (RH-80170)
    • EPS import does not accept decimal integers in import box (RH-79904)
  • Fillet: Creates fillet on wrong corner instead of reporting failure when radius is too large (RH-80024)
  • Grasshopper:
    • Object type cast error when converting GH_Surface to Brep (RH-80668)
    • GH Explode Objects and objects with per-face color issue (RH-79588)
    • Mesh-Curve Intersection failure (RH-67931)
    • Curve zero-twisting frames inconsistent. (RH-41494)
    • Empty lists are removed from Manage Data editor (RH-46344)
    • Export Instance Definition saves the file in millimeters instead of current document units (RH-80304)
    • Canvas requires a refresh regression (RH-79974)
    • Not all materials show up or work in GH (RH-43961)
    • OnPingDocument() returns null when called during BeforeSolveInstance (RH-79833)
    • After Solution Exception on GH_CustomPreviewComponent (RH-80153)
    • Point In Curve bug. (RH-46359)
    • Region Difference / Curve intersection problem. (RH-46356)
    • CCX component suspicious. (RH-46354)
    • Replace component doesn’t handle null indices. (RH-45592)
  • Gumball:
    • Does not show (RH-80238)
    • Gets a double translation (RH-80225)
    • Location is off target in Rhino 8 on sub-object (RH-79983)
    • Reset (oriented to Object) on Rotated Sphere is not correct (RH-79972)
    • Gumball origin is displaced on spotlight (RH-79911)
  • Helix: Preview is different from the created helix (RH-79739)
  • Icons: Panel icon of display settings is blurry (RH-79675)
  • Inset: IgnoreSeams Not working (RH-80236)
  • Layer:
    • Left arrow key exits naming of sublayer (RH-70731)
    • Duplicate Layer (and Object) - Name active for editing (RH-79866)
  • Libraries: Right-click does not show context menu (RH-79850)
  • Lights: Object with emissive material in block instance isn't handled as light (RH-79698)
  • MeshIntersect:
    • Technical Display Mesh/Mesh Intersections Missing Segments (RH-76568)
    • Crash in Grasshopper (RH-79150)
  • Offset:
    • Adds extra points to polyline output (RH-80116)
    • OffsetMultiple command creates open results (RH-79416)
    • Result is open (RH-78620)
  • OpenNURBS: Intersection.LineCircle() never fails (RH-48633)
  • Options: Color setting glitch (RH-79854)
  • OrientOnSrf: Settings incorrectly grayed out (RH-80091)
  • Print:
    • Vector output does not clip wireframe properly (RH-80679)
    • Vector output prints hatches far from origin incorrect (RH-80436)
    • Printing to physical printer prints landscape instead of portrait (RH-79378)
    • ng 1:1 to pdf vector isn’t properly scaled (RH-79052)
    • Line width scale has no effect with Vector output (RH-79940)
    • Centered Setting of Position Missing from Print Dialog (RH-78614)
    • Vector output does not pay attention to silhouette line width of Technical display mode (RH-79942)
    • Vector output skips scaled block (RH-79971)
    • Silhouettes are wrong (RH-79939)
  • Properties: Layer info not synchronized between panels (RH-79731)
  • Pull: Bad Pullback at Seam (RH-80175)
  • PushPull:
    • Does not select curved region after first edit (RH-79687)
    • Crashes if you select the same area twice (RH-79947)
  • RDK:
    • Automatic UI Combobox control value does not stick. (RH-80440)
    • RenderWindow.AddChannel doesn’t support MaterialID nor ObjectID (RH-80080)
  • Rebuild: No deviation feedback for curves (RH-80458)
  • Rendering:
    • Pause button doesn’t work in the Render window (RH-76860)
    • Render mesh settings don’t restore to defaults (RH-80085)
    • Anisotropic in Rhino 8 behaves different than in Rhino 7 (RH-78939)
    • Material ID needs to be part of RenderMaterial CRC (RH-80076)
    • Viewport responsiveness doesn’t work (RH-75824)
    • Dimensions render jaggy on transparent background (RH-67798)
    • Search in Object properties > Material acts weird (RH-80176)
    • Renaming fails in tree view (RH-79950)
    • Lights panel isolates too greedy (RH-79454)
    • Albedo pass not written correctly (RH-80123)
    • Multiple GPU support needs to be added back for Cycles (RH-77275)
    • RhinoCycles initialization error when starting multiple at the same time (RH-79851)
    • Resizing Raytraced viewport causes black rendering (RH-79696)
    • RhinoCycles doesn’t correctly tell when rendering is done (RH-80266)
    • Black stripes on viewport when using multi device (RH-80227)
  • Rendering: Environments:
    • Rendering Environment: Raytraced viewport doesn’t update environment (RH-80124)
    • Rendering Environment: Crash changing render content type from texture to environment (RH-80260)
    • Substance importer broken (RH-80148)
    • Sorting in tree view does not refresh list (RH-80063)
    • Sub-object assignment on a brep doesn’t show in Rendered display mode (RH-79900)
    • Changing AlphaTransparency through a script doesn’t work (RH-79648)
    • Drag and drop doesn’t work from Texture editor (RH-58164)
  • Rendering: Post Effect: Surface edges in renderings look bad compared to Rendered and Raytraced (RH-79086)
    • Textures: Keep the focus on the current texture (RH-80084)
    • Undo duplicates textures (RH-79720)
    • Procedural textures not baked for Bella Render (RH-78706)
  • SDK: Python:
    • Replace ‘ToString()’ with ‘str()’ (RH-80185)
    • rs.GetLineType() error (RH-80347)
  • SDK: RhinoCommon:
    • RhinoCommon SDK: LayerTable.Duplicate method returns empty int even when successful (RH-80624)
    • Setting MenuVisible false hides OSnap panel (RH-80714)
    • ON_Mesh double precision vertices synchronisation issue. (RH-46728)
  • ScriptEditor:
    • Python subprocess keeps Rhino file open (RH-73933)
    • Publishing fails due to missing Newtonsoft.Json (RH-75990)
    • Reopen glitch (RH-79718)
    • ghpythonlib does not show up in autocompletion (RH-78085)
    • Pip fails installing noise (RH-80275)
    • Ctrl-A incorrectly selects line numbers on a new script (RH-80172)
    • Contextual Surface parameter does not accept plane (RH-80209)
    • rs.GetDistance cannot match argument inputs (RH-79073)
    • The Garden Path sample does not work because of the GetDistance Argument matching (RH-79558)
    • Subtracting Point3d from Point3d returns a Point3d instead of Vector3d (RH-79303)
    • BrepClosestPoint fails (RH-79239)
    • Python 3 fails to import Generic IEnumerable (RH-79704)
    • Improve Pythonnet Method binder and argument converter (RH-79301)
    • A specific script doesn’t run (RH-79889)
    • Search results incorrectly include closed files (RH-79595)
    • CPython fails on creating generic types with python types e.g. DataTree[object] (RH-77500)
  • Section Tools: Clipping drawing may not update (RH-80638)
  • SelBoundary: Does not pay attention to sub-object selection filter state (RH-80078)
  • SelDup: Does not pay attention to SubD sharpness (RH-78005)
  • Selection:
    • SubD control polygon sometimes not being pickable (RH-80725)
    • ExtractSrf: Subobject picking may miss a face (RH-80584)
  • SelectionFilter:
    • “Others” option missing from horizontal layout (RH-80712)
    • Right clicking on Selection Filters panel broken (RH-79589)
  • Shade: Wireframe collision with display modes (RH-37320)
  • Toolbar:
    • Appearance is not saved when saving rui file (RH-79744)
    • Line drawing doesn’t start from clicked pixel (RH-79893)
  • Units: Units change warning doesn't appear if no objects are visible (RH-79579)
  • Viewports: Switching viewport with Ctrl+(Shift)+Tab hickup (RH-80199)
Crashes Fixed:
  • RDK: Tweaking texture slot value crashes (RH-80160)
  • Rebuild: Command: opennurbs!ON_EvaluateNurbsSpan – Access Denied (RH-80406)
  • Rendering: Cycles Viewport: Crash changing gamma setting with active Raytraced (RH-80480)
Enhancements:
  • BlockManager:
    • Added Object Count column (RH-80068)
    • Added ability of inserting block from file (RH-80109)
    • Search field supports object UUIDs (RH-79992)
    • Added column headers and allows sorting list (RH-77899)
  • ClippingPlane: Clicking on label now selects the widget (RH-75633)
  • Context Menu: Added Display Modes to viewport context menu (RH-79868)
  • Extend: Apply analysis mode on input object to separate output of Extend and ExtendSrf commands (RH-79871)
  • Fill: Now works with mesh objects (RH-76553)
  • Grasshopper: Added 3rd Party Plugin information to GH document if a component is used (RH-78613)
  • Gumball: Relocating Gumball origin does not accept 0 as 0,0,0 (RH-79520)
  • Properties: Shows tooltip for long object name (RH-53492)
  • Rendering: Cycles: Ensure for materials pass_id is set (RH-80077)
  • Selection: SelKey, SelValue, and SelKeyValue commands support wildcards "*" (RH-54830)
  • Shade: Added Technical, Artistic, Pen, and Monochrome display modes (RH-23502)
  • Toolbar: Scriptable Toolbar command manages loading of rui files (libraries) and toolbar visibility (RH-77225)
Features Added:
  • BlockManager: New ExportLinkedBlocks command (RH-80155)
  • Code Editor Control: Added method descriptions to autocompletion for C# (RH-80097)
  • File IO: Added ability to bundle up linked blocks (RH-60896)
  • Properties: Shows Surveyor's Units for line segments when Model units is Feet and Distance display is Decimal (RH-4854)
  • Section Tools: Detect existence of clipping planes before starting related commands (RH-75453)
Performance Improvements:
Regressions Fixed:
  • AlignVertices: Doesn't work on SubDs (RH-80352)
  • BooleanSplit: Creates open objects (RH-79376)
  • Display:
    • DisplayPipeline.DrawPoint bug (R8) (RH-79853)
    • UV textures do not update in Rendered display mode (RH-79611)
  • ExtendSrf:
    • Fails often (RH-79435)
    • Smooth type adds fully multiple knot at original edge (RH-79545)
  • ExtractRenderMesh: Wrong texture mapping (RH-79840)
  • Grasshopper:
    • Brep Deconstruct returning one surface (RH-80710)
    • PopGeo doesn’t accept extrusion (RH-80004)
  • Gumball: Origin moved when copying objects (RH-80268)
  • Layer: Layer" Nested Blocks not hiding/showing correct geometry in preview when layers turn on/off (RH-80418)
  • OSnap: : Right-click on Disable does not toggle all checkboxes (RH-80762)
  • Print:
    • Physical Printer Orientation Scaling Image (RH-79906)
    • Printer Margins Not Displayed In Preview (RH-79930)
    • Printer details needed for Rhino 8 print dialog (RH-78713)
  • SDK: RhinoScript: Dismiss error with Esc (RH-79388)
  • ScriptEditor:
    • rs.PolylineVertices needs StrongBox | Pythonnet to use overloads with least out params (RH-80838)
    • Grasshopper: Sources in project report incorrect paths (RH-80603)
    • Failed to create System.Drawing.Color from floats (RH-79173)
    • Pythonnet can not resolve to Brep.ClosestPoint(Point3d, double) (mix of out params) (RH-79005)
    • rs.Distance() Python 3 can’t compute distance between points (RH-79852)
    • Bug with rhinoscriptsyntax Arc helper functions (RH-78917)
    • Error on RC function (RH-79759)
  • Selection: Regression of sub-object deselection method (RH-80274)
  • SetDocumentUserText: Document user text broken in v8 (RH-80683)
  • SimplifyCrv: Not working with a specific polyline (RH-78932)
  • StatusBar: Z Coordinate Rounding Off Issue (RH-79954)
  • Toolbar:
    • Releasing MMB on popup toolbar does not execute command under mouse cursor (RH-78837)
    • Extra click needed to access a command in a flyout toolbar (RH-73900)
  • Tutorials: Opening File from Tutorials Panel Broken (RH-79791)
  • UDT: FlowAlongSurface Result Uglier in V8 (RH-80359)
  • ViewCaptureToFile: View capture is not a gradient (RH-79689)
  • ZoomExtents: Incorrect in Layouts (RH-78833)
SDK Enhancement:
  • DotNET: Added Newtonsoft.Json to system assemblies in Rhino (RH-78541)
  • SDK: RhinoCommon:
    • Move convex hull code (2d and 3d) from GH2 into RhinoCommon. (RH-68446)
    • Exposed CRhinoDoc::InGetPoint() (RH-79824)
UI Change:
  • CurvePiping: Now thickness of curve piping mesh matches linetype width in length units (RH-79411)
  • Keyboard Shortcuts: Alt keys are changed to Option keys on Mac (RH-79924)
  • NamedView: Removed "Lock named view" setting (RH-69049)
  • BlockManager: Scrolls to selected items after running Get Selection From Viewport (RH-80134)
  • Grasshopper: Components: Two old GhPython Script components (RH-80050)
Mac-Only Changes
Bugs Fixed:
  • BlockManager: Keyboard lost focus in search field (RH-79046)
  • Display:
    • Silhouettes ‘mix’ with Edges (Monochrome) (RH-79938)
    • SetOutputRect offset causes border repeat issue (RH-80056)
    • Textures change in Rendered view (Mac) (RH-79672)
  • Eto: Tooltips in Lights panel do not work on Mac (RH-78403)
  • Grasshopper: MacOS Rhino crashes on closing GH window (RH-79955)
  • Layer:
    • With Layer Panel focused it overrides keyboard layout input (RH-78406)
    • Rename bug (RH-80529)
  • Panels:
    • Floating a container outside of virtual desktop causes container to disappear on Mac (RH-69542)
    • OSnap panel not visible after Reset (RH-80291)
  • PluginManager: Dialog not tall enough to show all plug-in information (RH-80761)
  • Preferences: Advanced settings on Mac difficult to read (RH-79455)
  • Print: Vector output flips layouts upside down in preview (RH-77653)
  • Properties: Layer pulldown disappears behind floating panel (RH-79708)
    • SubD renders black only on Mac (RH-65522)
    • Substance materials are not rendered correctly (RH-78373)
  • Rendering: Materials: Name does not stick (RH-79515)
  • Rendering: Post Effect: Don't work on Mac (RH-80239)
  • Rendering: Textures: Custom Curve in gradient texture crashes Rhino (RH-80376)
  • Subobject Selection: Edge selection inconsistent on Intel Mac (RH-80711)
  • Toolbar: Icons are missing in toolbar items that cascade further (RH-79805)
Cosmetics:
  • Localization: Panel: Texture - Texture menu - shortcuts? (RH-52636)
Crashes Fixed:
  • ScriptEditor: Script Editor does not autocomplete numpy or scipy and might crash on other similar modules (RH-78429)
Enhancements:
    • Added Ctrl + Option + Function keys (RH-79604)
    • Added Ctrl + Function keys (RH-79603)
    • Added Option + Function keys (RH-79606)
    • Added Option + Shift + * (RH-79607)
    • Added Ctrl + Shift + Function keys (RH-79605)
    • Added CMD + Ctrl + Function Keys (RH-79608)
  • Display Metal: Display performance in Metal Arctic (RH-78033)
Regressions Fixed:
  • Selection: Command-line history does not print amount of objects selected (RH-80094)
Bugs Fixed:
  • Containers: Command-line loses focus during property change (RH-80265)
  • Core Architecture: RhinoCore.dll could not be loaded (RH-79832)
  • Display:
    • AA cannot be completely turned off (RH-79022)
    • ClippingPlane display glitch (RH-79291)
  • Localization:
    • Gumball tooltip gets truncated on simplified Chinese Windows when DPI@100% (RH-79804)
    • Figure out local name of font for Options dialog (RH-37971)
    • Display font change won’t stick in zh-tw Rhino 8 (RH-79356)
  • Panels: Floating Containers: floating a container outside of virtual desktop causes container to disappear (RH-78951)
  • Rendering: Cycles: HDR Light Studio environments don't work correctly (RH-80780)
  • Rendering: Textures: Closing Texture Editor pushes Rhino to the background (RH-80277)
  • ScriptEditor: C# exception on placement (RH-80065)
  • UI Appearance:
    • Ellipse tool in Icon editor flickers (RH-76210)
    • Eliminate useless tooltips from Linetype settings (RH-80019)
    • Eliminate useless tooltips from viewport properties (RH-80020)
Cosmetics:
  • SetDisplayMode: Text on "Shadows" page is pixelated (RH-79632)
Enhancements:
  • Display: Added NURBS surface remeshing toggle and timing settings for Nudge keys to Advanced settings (RH-80251)
Regressions Fixed:
  • Display: Section edges have become hidden (RH-79647)
  • UI Appearance: moving containers between different screens needs to adapt to screen dpi scaling (RH-76203)
Rhino 8 Service Release 6 for Windows and Mac (8.6.24101) is now available
Bugs Fixed:
  • CPython Env Reset Doesn't Reimport Modules (RH-79880)
    • Can’t See Hatch Import Check Marks (RH-80929)
    • Matching properties incorrectly adds hatch to group (RH-80620)
  • BlendCrv: History update problem (RH-59212)
  • BlockManager: Issue about listing definitions without instances (RH-69713)
  • ChangeLayer: Select Not Using Sublayer (RH-80799)
  • Code Editor Control: ScriptEditor: Break points not displayed (RH-80902)
  • Detail: Print display does not remember DetailBorder setting (RH-78522)
  • Displacement: Moving object recalculates displacement mesh (RH-72387)
  • Display:
    • Shadows incorrect on selected block instances (RH-80922)
    • Set object display mode issue (RH-75329)
    • Curves move around when zooming in closely (RH-81185)
    • GPU tessellation setting makes highlighted edges not look as good as they did in v7 (RH-73635)
    • Raytrace kills locked object display (RH-80703)
    • “Show shadows only” fails with self-illuminating ground plane material (RH-80599)
    • Clipped block instances not displayed correctly in technical modes (RH-80614)
    • Flickers intermittently for a split second (RH-75091)
    • Image backgrounds in Detail views don’t print/tile correctly (RH-80670)
    • Ground plane in detail views gets clipped (RH-80532)
    • Two Point Perspective shows horizon line (RH-80177)
  • Document UserText:
    • Key editing in panel does not create Undo record (RH-43816)
    • SetDocumentUserText command not undo-able (RH-43817)
  • DraftAngleAnalysis: Draft angle curves don't get generated on second file (RH-80483)
  • ExtractPipedCurve: Creates invalid mesh (RH-74078)
  • ExtrudeCrvTapered:
  • File IO:
    • DWG import/export has issues about backslash symbol (RH-76727)
    • Case where VCs are read wrong from an OBJ file (RH-80953)
    • Save as OBJ doesn’t save all textures (RH-80831)
    • FBX import scatters objects when mapping Y axis to Z (RH-80890)
    • SaveACopy: Cannot save file without time stamp (RH-80772)
  • FilletEdge: Filleting on multiple objects with Preview=Yes does not preview all results (RH-80809)
  • Grasshopper:
    • Bug in GH_ModelObject where it doesn’t bake on every even instance (RH-80970)
    • Slider expression rounding issue (RH-80444)
    • Can’t Offset Loose with less than 2 units of length (RH-80564)
    • Incorrect preview when no annotation style is assigned (RH-80864)
  • Grasshopper 2: GH2 documentation fails to show. (RH-80701)
    • Model Attribute Key Selection breaks up at dots (RH-81311)
    • C# component not saving input hint (RH-80561)
  • Group: RemoveFromGroup command - Toggling Copy option clears current selection (RH-80803)
  • Gumball:
    • Oriented to Plane in Block regression (RH-80593)
    • Clicking on handle repeats last command (RH-79440)
    • Should remember SubD subobject orientations (RH-79013)
    • Extrude relocates gumball of extruded object (RH-80522)
    • Relocate does not show snap highlight (RH-80451)
    • Relocate does not snap to occluded positions (RH-80439)
  • Help: ExtractSrf options (RH-80528)
  • Isolate: Undo breaks Unisolate (RH-57579)
  • Keyboard Shortcuts: Default shortcuts cannot be overridden (RH-80307)
  • Layer:
    • File IO: Loss of information reading Rhino 7 file (RH-81418)
    • “Select Sublayer objects” does not work when sublayer not in search result (RH-80837)
  • Layout: Editing name in Layouts panel ignores case change (RH-80833)
  • Lights: Skylight intensity adjustment fails (RH-80759)
  • LineTypeDisplay: LinetypeDisplay: DisplayLinetypes option does not work (RH-81101)
  • MacroLibrary: Macro dialog does not show icons in dark mode (RH-81065)
  • Make2D: Draws clipped block instances as unclipped (RH-80723)
  • Mesh:
    • Grasshopper: Mesh Eval component gives incorrect points for non triangulated meshes (RH-65889)
    • Exporting presets reports fake failure (RH-80493)
  • Ortho: Tracking along Z axis is forbidden with shallow view angles (RH-80760)
  • PointGrid: Failure caused by grid size limitation (RH-80507)
  • Polyline: Visual glitch of flashing polyline control points (RH-81310)
  • Print:
    • Printing gradient hatch issue (RH-79888)
    • Pen display issue when defining print window (RH-81082)
    • Layouts with detail view left active won’t print (RH-80937)
    • Section Styles not Printing in Vector Output (RH-80609)
    • PDF or Image file repeats gradient background (RH-20508)
  • PrintPreview: Add "Model Unit" Scaling to linetype (RH-79551)
  • Properties:
    • : Pressing Delete key does not delete highlighted object name (RH-81014)
    • Hatch page slows down operations (RH-80538)
  • RDK: Problem with CRM sample code (RH-79937)
  • Rendering:
    • Environment rotation not updating in Raytraced display mode (RH-80731)
    • Saving depth channel should not alter information put into it (RH-80330)
    • Adjusting ground plane texture makes it disappear in Raytraced mode (RH-80625)
    • Texture mapping changes don’t update in Raytraced mode (RH-80626)
    • Editing material triggers unnecessary re-calculation of edge softening (RH-80340)
    • Material Ids and Object Ids not visualized properly (RH-80263)
    • Depth channel lacking resolution (RH-61748)
  • Rendering: Content Panels: Sliders are hard to use (RH-80433)
  • Rendering: Post Effect: Bloom doesn't update while adjusting (RH-75586)
    • Applying per-face material reverts top level object to UV mapping (RH-46932)
    • Planar mapping inconsistent on SubD (RH-59962)
  • Rendering: Textures: OpenGL previews broken on Mac with dots texture (RH-80573)
  • SDK: ModelComponent.TextureMapping unimplemented (RH-80456)
  • SDK: RhinoCommon: MessageBox not wrapping (RH-80166)
  • ScriptEditor:
    • Script param converter regression in 8.6 (RH-81269)
    • Add zoom support on terminal (RH-81243)
    • Add System.Linq as a default import to csharp templates (RH-81237)
    • ghpythonlib CullDuplicates can not convert python 3 inputs (RH-81296)
    • Python 3 stream wrapper does not have .fileno() method (RH-81299)
    • Rectangle to Polyline type hints turns to point?! (RH-81302)
    • GH editor closes on save and it is annoying (RH-81303)
    • Python 3 converts polyline inputs to list of points (RH-81314)
    • Add undo support to editor to undo converting to script instance and other changes to script by editor host (RH-77882)
    • Remove script option not working (RH-81353)
    • Autocomplete over-population (RH-81248)
    • Sticky “Restore Packages” progress bar when running published commands (RH-81100)
    • Script component does not run when input has cast error (RH-81109)
    • List and Tree conversion error on null input has bad message (RH-81162)
    • Improve error capture on display conduits (RH-80928)
    • Search broken during debugging (RH-76162)
    • Old tags don’t show up on published components (RH-78088)
    • Gumball does not show when script ends (RH-79039)
    • Does not show Gumball on selected face (RH-79525)
    • Project scripts in IronPython should show the correct icon (RH-78106)
    • Python 3 does not autocomplete DriveInfo (RH-80427)
    • RUI files from ScriptEditor will have tags if dark icon is not specified (RH-80820)
    • ScriptInstance does not throw ExecuteException (RH-80755)
    • Fix installing dlib in CPython (RH-77989)
    • Sometimes empties script if also open in VSCode (RH-80416)
    • Modify published plugins to load RhinoCodePlugin (RH-80394)
  • Selection: Dot picking fails (RH-80574)
  • SetDisplayMode:
    • SetObjectDisplayMode: Ignores wire settings (RH-80690)
    • Special characters in display mode names cause multiple issues… (RH-80485)
  • SmartTrack: SmartOrtho incorrectly doubles diameter of circle (RH-81183)
  • SubD: Sharp edges:
    • Bug on torus (RH-80676)
    • Sharp info is lost when inserting an edge (RH-80388)
    • OffsetSubD reflect issue (RH-76871)
    • Glitchy across interior creases (RH-80633)
    • Reflect: Not quite the same on both sides (RH-80535)
  • Surface-surface intersection: NonManifoldMerge and trim type issue (RH-77064)
  • Templates: Notes missing from Small mm Small inches feet template files (RH-80208)
  • TextField:
    • DetailScale by ID fails to add text (RH-80964)
    • Volume units on layout issue (RH-80815)
  • Toolbar:
    • Container properties not saved in rui (RH-81160)
    • Button appearance is not saved (RH-81362)
    • Snap to button edge when adjusting width of vertically docked toolbar containers (RH-81315)
    • Importing SVG hangs button editor (RH-78367)
    • Button images not saving (RH-81059)
    • Button images lost on save of RUI (RH-81060)
    • Editing a menu is not possible (RH-81070)
    • Saving to single RUI causes several problems (RH-81035)
    • Saving a RUI file doesn’t store the menu associated with it (RH-79994)
    • Cannot delete toolbar group (RH-79987)
    • Tooltip shows up after cursor leaving the button (RH-80270)
  • UDT: SubD captive incorrectly released from cage when whole control object is moved (RH-80426)
  • UI Appearance: Toolbar height needs to snap to button heights. (RH-71925)
  • UVEditor: Edited object show gray and black (RH-50599)
  • Units: Absolute tolerance is not scriptable (RH-81016)
  • ViewPropertiesPage: Viewport size can be set larger than Rhino window (RH-59260)
Cosmetics:
  • ScriptEditor:
    • Simplify menu items names. Maybe bring the icons back to visualize state? (RH-78550)
    • Shows unnecessary tooltips (RH-80484)
Crashes Fixed:
  • OpenNURBS: Repeatable crash in Mesh.CreateFromIterativeCleanup (RH-80032)
  • Rendering: Crash opening EXR without alpha channel (RH-80730)
  • ScriptEditor: C# script with NuGet reference crashes on non-ui thread (RH-79758)
  • Toolbar: Deleting menu and saving the RUI hangs Rhino (RH-81069)
Enhancements:
  • Annotation: Hatch: Allows selecting with Shift and Ctrl key on import list (RH-80699)
  • BlockManager:
    • Added “status bar” that shows selection count etc. (RH-80370)
    • Supports searching block definitions with wildcards (RH-80369)
  • ClippingPlane: Increased precision of custom depth to 3 decimals (RH-80996)
  • Documentation: /runscript command line documentation improvement (RH-80848)
  • File IO:
    • Show failure message when WAMIT (*.gdf) export encounters invalid meshes (RH-80729)
    • DWG/DXF import supports 4, 8, 12 for DimZin variable (RH-80400)
    • OBJ insert does not show linked referenced layers (RH-79903)
  • Grasshopper:
    • Added runtime warning to Explode component for invalid geometry (RH-81317)
    • GH Point Deform now works with SubD vertices (RH-80640)
    • Added serialization to GH_Number param to read/write AngleParameter property (RH-80595)
    • Link to Learn from Help (RH-80497)
  • Gumball: Alignment mode now sticks across Rhino sessions (RH-80583)
  • History: Editing control points of an angular dimension updates its position in history record (RH-80816)
  • Ortho: Added ShowOrthoHashMarks advanced setting for turning off angle hash marks (RH-80798)
  • Print:
    • Section pattern not drawn in vector PDF (RH-79736)
    • Remembers the last unit settings (RH-80193)
  • RebuildEdges: Now removes micro naked edges (RH-80666)
  • Rendering:
    • Render Window - Enable menu and toolbar entries only for added channels (RH-80476)
    • Clipping planes now clip geometry but not lighting (RH-75825)
  • SDK: RhinoCommon: Added SaveToLibraryFile method for textures (RH-80872)
  • ScriptEditor:
    • Add Option to avoid closing editor window when saving in GH (RH-80898)
    • Support drag-drop of multiple .py files (RH-52159)
    • Support importing cs files in cs scripts using #load directive (RH-80364)
    • Fold using and notes sections in Grasshopper init scripts (RH-78546)
    • -ScriptEditor _Run now supports using system environment variables in file path (RH-80852)
    • -ScriptEditor _Run now looks in Rhino’s search path (RH-80851)
    • Added a “Add/Install Package” to the dashboard that installs a package on active script (RH-79155)
  • Section Tools: Added PrintWidth=ByLayer/ByInputObject option to ClippingDrawings and EditClippingDrawings commands (RH-80218)
  • Selection: SelKey, SelValue, and SelKeyValue commands support wildcards "?" and "~" (RH-80384)
  • Toolbar: Snap to button edge when adjusting height of horizontally docked toolbar containers (RH-74842)
Features Added:
  • Grasshopper: Added new datatype for Lights (RH-79341)
  • ScriptEditor: Minimize RhinoCodePlugin assembly loading footprint on Rhino start (RH-80380)
Regressions Fixed:
  • ExtrudeCrvTapered: Missing surfaces (RH-80865)
  • Gumball: Location not saved for individual objects in v8 (RH-80353)
  • Join: Duplicates disjoint SubDs (RH-81242)
  • LineTypeDisplay: PatternBySegment ignored in V8 (RH-80715)
  • Print: No dialog appears (RH-80907)
  • ScriptEditor:
    • Editor window ends up out of monitor bounds (RH-81318)
    • Pythonnet IReadOnlyList[str] is not Array[str] (RH-80652)
    • Provide support for _ResetEngine option in RunPythonScript (RH-80381)
  • Volume: Unable to calculate from extrusions in blocks (RH-81079)
SDK Enhancement:
  • SDK: RhinoCommon: Allows updating status bar progress label (RH-80733)
UI Change:
  • Annotation: Linetype: Changed text buttons in Linetypes document properties to icon buttons (RH-80449)
  • Containers: Hide "Show Panels" menu item on containers with only toolbars (RH-79980)
  • Section Tools: ShowSolidClipping is renamed to ShowSolid in NestedClippingDrawing command (RH-80158)
Usability Problems Fixed:
  • ScriptEditor:
    • Cleanup NuGet package reference formats (RH-81308)
    • Python 3 to set locale before running script (RH-81130)
    • Confirm clear recents (RH-80927)
    • Does not show any indication of errors when Problem tab icon is turned off in Rhino options (RH-79151)
    • Display language init progress on GH component (RH-80510)
    • Script Editor to notify when installing packages but make it block the UI (RH-79324)
    • Move Toggle debug trays from Run menu to Window menu (RH-78549)
    • Add scripts path to PATH when launching Python3 shell (RH-80719)
    • Console panel buttons on the right are less discoverable (RH-80717)
    • Improved package install visual feedback (RH-80718)
    • New file from template does not add second file (RH-78599)
    • Allows modifying compact options from the Window menu (RH-78551)
    • File dialog opens behind editor (RH-80210)
    • Stop debug on error (RH-79790)
    • Allows scrolling through document tabs with mouse wheel (RH-79431)
Mac-Only Changes
Bugs Fixed:
  • Display Metal:
    • Display: Poor mesh wire quality on external monitor (RH-77808)
    • No section hatch (RH-80950)
  • Keyboard Shortcuts: Keyboard: Shortcuts: Overriding macOS shortcuts does not work (RH-78732)
  • Modeling Aids: OSnap highlight setting on Mac doesn't change anything (RH-80452)
  • Options: StatusBar command locks up Rhino for Mac (RH-80756)
  • Panels: Settings out of sync (RH-80601)
  • Print:
    • Hidden dash length incorrect on macOS (RH-79537)
    • Print Dialog Needs Close Button on Mac to Save Changes (RH-80650)
    • Substance material black in Rendered display mode (RH-80316)
    • Black in Rendered display mode (RH-80371)
  • ScriptEditor: Cannot run script without first opening the editor (RH-80560)
  • Toolbar:
    • Button editor starts off blank (RH-79555)
    • Floating panel containers behaving badly (RH-80039)
    • Remove Worksession toolbar from Mac (RH-80414)
    • Fails to save high resolution PNG with transparent background (RH-78401)
    • ViewCaptureToFIle: High resolution error (RH-80533)
  • WindowLayout:
    • Reset to default Window Layout won’t restore (RH-79910)
    • Losing custom layout all the time (RH-79838)
Enhancements:
  • Display: Added NURBS surface remeshing toggle and timing settings for Nudge keys to Advanced settings (RH-80496)
Regressions Fixed:
  • CommandHistory: Cmd-C not copying text to clipboard as in v7 (RH-81154)
  • Containers: Don't stay in place when opening new document (RH-80204)
Bugs Fixed:
  • Annotation: Linetype: "Add Defaults" not working properly on Windows (RH-80740)
  • BlockManager: Should use block names on export (RH-57137)
  • Display:
    • Issues when turning off GPU tessellation (RH-81046)
    • Technical Display Varies if Block is Involved (RH-80721)
    • OpenGL/Metal preview wrong for 2D Checker Texture (RH-80587)
    • Render Material Not Displaying for Clipped Block (RH-70874)
  • Lights: Text of numeric values uses incorrect color after editing in Dark mode (RH-80925)
  • Print: Printer properties not working in v8 (RH-79796)
  • Rendering: RGBA channel button missing in Render window (RH-80935)
  • Rendering: Texture Mapping: Procedural texture on sub-object has seams and when editing mapping on single objects (RH-69154)
  • SDK: RhinoCommon:
    • RhPicture not loading properly in V7 (RH-65100)
    • RhinoDoc.ExtractPreviewImage does not work as advertised (RH-80425)
  • Section Tools: ExportClippingDrawings: Fail on elevations (RH-80885)
  • Toolbar:
    • Restore Defaults on Size and Styles options doesn’t work (RH-81323)
    • Overlapping buttons (RH-80766)
  • UI Appearance: Light mode icons are used in fly-outs (RH-77241)
  • UVEditor: Importing geometry with UVEditor open causes error message (RH-80099)
Regressions Fixed:
  • Display: Receives Shadows setting is broken in V8 (RH-80390)
  • Print: Custom Page Sizes not available for Printer (RH-80709)
Tasks Completed:
  • Help: Added traditional Chinese offline help for download (RH-80983)
UI Change:
  • CommandPrompt: Added "Paste as plain text" to context menu of Command-line (RH-69168)
  • Print: Added a Close button print dialog (RH-76918)
Rhino 8 Service Release 7 for Windows and Mac (8.7.24134) is now available
Rhino will automatically update, unless updates are disabled.
Download the latest service release now…
Bugs Fixed:
  • Annotation: DimArea and DimCurveLength don't remember Type setting (RH-78877)
  • ArrayCrv: Command ends with no result if target curve is shorter than last used distance (RH-81288)
  • Autocomplete: TestParallelMeshing incorrectly listed (RH-81424)
  • BlendSrf: Problem with periodic surface (RH-81448)
  • BlockManager:
    • Slow Block Manager responses in larger projects. (RH-81374)
    • Block Definitions panel responses slow in larger projects (RH-81009)
  • ChamferEdge: Leaves gaps (RH-20898)
  • Containers: Scrollwheel on multitabbed containers should also work when mouse cursor is over the toolbars (RH-72232)
  • Display:
    • Blocks are slower in Rhino 8 than in Rhino 7 (RH-80594)
    • Pattern segments display incorrect with GPU Tessellation off (RH-81411)
    • Nesting blocks affects edge and isocurve visibility (RH-80621)
    • Select blocks show transparent in Rendered and Arctic Display Modes (RH-80804)
    • Ghosted mode AA is off when not using the default background color (RH-78906)
    • Inserting a block mess up display (RH-80720)
    • SubD boundaries do not display locked color (RH-80965)
  • Export: Pressing Enter key when editing DPI continues PDF export instead of accepting DPI changes (RH-60075)
  • ExtrudeCrvTapered: Does not fill the corner at curve seam (RH-80869)
  • File IO:
    • Recursion limit in the SKP ngon maker is too restrictive (RH-81915)
    • Pasting or importing curves from Illustrator creates invisible hatch (RH-81524)
    • Pasting curves, text or hatches incorrectly adds a material (RH-81526)
    • Roundtrip the strings exported to 3mf (RH-81277)
    • glTF doesn’t export box mappings correctly (RH-81045)
    • OBJ export creates too many materials (RH-81245)
  • FilletSrf: FilletSrf* commands do not accept space key as Enter (RH-81072)
  • FlatShade: Doesn't work on Mac in v8 (RH-77946)
  • Grasshopper:
    • Curve Seam Location on Offset Regression (RH-81013)
    • Mesh Preview stops working as expected (RH-81196)
  • Grasshopper: Components: Model Material component can't be edited after material is set (RH-81190)
  • Gumball:
    • Free translation occasionally gets constrained (RH-80200)
    • AutoReset acts differently in Rhino 8 (RH-81205)
  • InsertEdge: Fails with Reflect (RH-81239)
  • Installer: Shortcut error on install (RH-81233)
  • Intersect: Out of tolerance between a cylinder and a trimmed plane (RH-81627)
  • Isolate: Invert / Isolate doesn't work on annotation objects perpendicular to view (RH-81360)
  • Layer: Reorder bug with drag and drop (RH-80754)
  • Localization: Concatenation issue (RH-80558)
  • Make2D:
    • Failure in removing lines behind clipping plane caps (RH-77105)
    • HLD Use Only One Clipping Plane When Occlude=True (RH-81316)
  • NamedView:
    • Auto-update thumbnails setting does not work (RH-80920)
    • Name editing does not accept only case change (RH-81370)
  • Offset: Does not create caps when requested (RH-76297)
  • Ortho: Hash marks incorrectly appear with gumball scale (RH-80978)
  • Print:
    • Saving image file shows decimals for pixel units (RH-81068)
    • Saving image file shows too many decimals for width and height (RH-81200)
    • Options for Rhino PDF incorrectly visible other printers (RH-81199)
    • Print dialog missing window control buttons (RH-81067)
    • Vector output draws hidden lines in front (RH-80971)
  • Properties: Scripted hatch properties missing background color option (RH-81266)
  • PushPull: Makes object disappear (RH-79707)
  • RDK:
    • Child texture is not shown in tree view (RH-81256)
    • Modal Content editor name change bug (RH-81415)
    • Content details section is missing (RH-80411)
  • ReduceMesh: Re-reduction when hitting OK after Preview (RH-42740)
  • Rendering:
    • Material swatches aren’t reliably indicating object assignment (RH-81354)
    • Does not restart when changing amount of some settings (RH-81096)
    • Mapping lock not working (RH-80677)
    • Saving rendering does not remember last used file format (RH-80379)
    • Fails to load when trying to clean up logs (RH-81630)
    • Textures in rhino environment aren’t observing adjustments (RH-81386)
    • Log file access problem while starting Rhino (RH-81208)
    • Tree view thumbnails refresh despite no changes (RH-74642)
    • Rhino hangs when quitting search in tree view (RH-81088)
    • UV Mapping Discrepancy in Raytraced Mode in Rhino 8 (RH-78186)
    • Artifacts in custom mesh mapping (RH-43051)
    • Slow performance with imported obj that has no texture coordinates (RH-81312)
    • Added TestFillInLegacyTextureCoordinates test command for correcting texture mapping in KeyShot (RH-80470)
    • Gradient custom curves only RGB by default (RH-81407)
    • Glitches when editing gradient texture in floating dialog (RH-81406)
  • SDK: IsLinear is not accessible from ON_Texture/DocObjects.Texture (RH-81175)
  • SDK: RhinoCommon:
    • ToolbarFiles.Open returns null (RH-76914)
    • Setting DetailViewObject.IsActive does not trigger event (RH-81422)
    • Missing CRhinoPlugIn::AddToPlugInHelpMenu() and CRhinoPlugIn::OnDisplayPlugInHelp() (RH-81148)
    • ClippingPlaneObject.GetFillSurfaces makes no result with SubD (RH-67669)
  • SVG:
    • Gradients export with incorrect decimal separators (RH-81531)
    • Import SVG loses text (RH-81257)
  • ScriptEditor:
    • RunScript backporter keeps resetting Type Hints (RH-81870)
    • Published python components are missing ghenv (RH-81638)
    • C# Script instance does not have access to ghenv but does not throw errors (RH-81623)
    • Exported script overrides GH component storage (RH-81629)
    • GH Script component changes upstream mesh (RH-81617)
    • Dictionary conversion to and from python 3 dict fails to grab values (RH-81521)
    • Pythonnet derived classes attempt to overload assembly-internal members (RH-81356)
    • rs.Command throws exceptions in new script component (RH-80008)
    • CSharp scripts shows incorrect error on this.Component of scriptinstance (RH-81345)
    • Output list of Circle can not convert to any hint (RH-81429)
    • Component does not send errors to out parameter (RH-81426)
    • Grasshopper script editor out of screen (RH-81508)
    • Python- rs.ObjectsByType() glitch (RH-78831)
    • Pythonnet does not wrap return interface types correctly (RH-79621)
    • Pythonnet derived classes from dotnet types does not find python dunder methods (RH-80651)
    • Script.Instance RunScript output needs to be marshalled (RH-81136)
    • “type(obj) is” does not recognize the type correctly (RH-76942)
    • Try to install pip from embedded if get_pip fails (RH-80990)
  • Section Tools: ClippingSections command not always save useful named views (RH-81194)
  • SelBadObjects: Missing bad objects (RH-81184)
  • SelBoundary: SelBoundary fails in V8 when used within RemoveFromGroup (RH-81956)
  • Selection: Selecting block with By View Display Mode enabled is inconsistent (RH-81437)
  • Shrinkwrap: Blocks with meshes return different meshes (RH-81387)
  • Sidebars: Cannot re-dock after made floating (RH-81182)
  • Toolbar:
    • Copied button overwrite the original (RH-81161)
    • Scrolling mouse wheel over buttons does not scroll through tabs (RH-76615)
    • Separators wider than buttons in vertical containers (RH-79886)
    • Macro edit not sticking (RH-81604)
    • Duplicated entries in the default macro library (RH-81061)
    • Recently used toolbar issue (RH-79929)
    • Importing or pasting SVG takes a long time or hangs Rhino (RH-79884)
    • Flyout cascade down instead of to the right (RH-80269)
  • UDT: UTD: CageEdit preview not getting transformed to world coordinates (RH-81074)
  • UVEditor: Curve objects can not be copied into UV Editor (RH-79010)
  • UserText: Export keys with variable values (RH-56778)
  • WindowLayout:
    • Dialog needs cleanups (RH-81402)
    • Incorrectly allows saving over built-in name (RH-73983)
Cosmetics:
  • Preferences: Bold value text truncated at bottom in Advanced settings (RH-58167)
Crashes Fixed:
  • Bridge: Crash on Mac (RH-81749)
  • Docking: Eto: Crash when resizing container (RH-80913)
  • Rendering: Textures: Save as Image with very high resolution crashes Rhino immediately (RH-80886)
  • Shade: Switch to new display mode crashes (RH-81006)
Enhancements:
  • CPlane: AutoAlign: Added advanced setting to decide if Auto CPlane orientation is view related (RH-81260)
  • Eto: Added Rhino.UI extension method for mapping physical pixels to Eto logical pixels (RH-68077)
  • File IO:
    • Added custom metadata to 3mf export (RH-81320)
    • USD export prefixes mesh names with object name (RH-81145)
  • Grasshopper: Added "00 From Rhino to Grasshopper" tutorial file (RH-80498)
  • Layout:
    • Added “Print” to context menu in Layouts panel (RH-81187)
    • Print button in Layouts panel supports printing multiple selected layouts (RH-55300)
  • Print:
    • Allows setting file name prefix when saving each layout to a separate PDF file (RH-78902)
    • Offer layout name as the pdf file name (RH-64199)
  • Rendering: Sun settings use current local date and time by default (RH-80940)
  • SVG:
    • Added gradient support to SVG export (RH-79097)
    • Supports exporting gradient colors with opacity (RH-81532)
  • SaveWindowLayout: SavingWindowLayout: Now overwrites existing custom window layouts (RH-72169)
  • ScriptEditor:
    • Output script from script component for analysis and sharing (RH-81372)
    • Support hint/signature provider for python (RH-78115)
    • Search highlight uses different color for selected string (RH-80874)
Features Added:
  • ScriptEditor: Create separate manifest.yml in build (RH-81610)
  • Grasshopper: Slow selection and lags when rotating view (RH-80348)
  • ReduceMesh: Use the preview mesh (RH-62170)
  • ScriptEditor: Printing to "Terminal" is slow (RH-78093)
Regressions Fixed:
  • Annotation: Hatch: Curve direction affects pattern orientation (RH-80855)
  • Context Menu: Recently used command list shows keyboard shortcuts instead of command names (RH-81115)
  • Display:
  • ExtendSrf:
  • Grasshopper: Extrusion object to mesh (RH-80861)
  • InsertPoint: Fails on reflected object (RH-81085)
  • Make2D: Performance lower in v8 (RH-80901)
  • Offset: Curve.Offset Seam problem (RH-81253)
  • Project: Projecting curves to meshes several times slower in V7/V8 than in V5/V6 (RH-81126)
  • ScriptEditor:
    • GH component regression in marshalling guids on inputs (RH-81624)
    • Change IList back to List type for input in GH (RH-81452)
    • Do not show Marshall Guids on CSharp components (RH-81472)
    • Stderr does not capture exceptions thrown from ScriptInstance (RH-80509)
    • Python int fails to convert to System.Boolean (RH-81272)
    • Python derived classes do not follow str methods up the class chain if there is a break (RH-81027)
    • Python 3 does not consider ObjectType.None as False (RH-80145)
    • Example script fails (RH-79614)
  • Stitch: Fails with Reflect (RH-81240)
SDK Enhancement:
  • File IO: Added USD export options to RhinoCommon (RH-78794)
  • SDK:
    • Added SetCachedTextureCoordinatesFromMaterial and GetCachedTextureCoordinates to ON_Mesh (RH-80877)
    • Added variable radius fillet to C++ and .NET SDK (RH-81002)
  • SDK: RhinoCommon:
    • Exposed surfaces settings of display modes (RH-69035)
    • Exposed what Rhino.CheckNewObjects() does (RH-70968)
    • Hooked up export options for 3MF file (RH-81158)
    • Added SetCachedTextureCoordinatesFromMaterial and GetCachedTextureCoordinates to Rhino.Geometry.Mesh (RH-80878)
    • Exposed ON_Brep::GetTangentConnectedComponents (RH-81106)
UI Change:
  • Print: Added layout navigation buttons above preview area (RH-80692)
  • OffsetSrf: Added TestOffsetSrfMergeEdges test command to disable merging edges when offsetting surfaces (RH-81414)
  • ScriptEditor:
    • DebugStop exception throws stack trace in terminal (RH-81596)
    • With no internet “Restoring Packages” get stuck (RH-76006)
    • Script editor ↔ Component cone wrong (RH-75781)
    • Reimplement editor positioning close to component (RH-81319)
    • Help panel improved for rhinoscript syntax (RH-79118)
    • Added “Open Help In Browser” to right-click menu of items in Help panel (RH-81276)
  • Units: Prompt to Change both Model and Layout Units (RH-81439)
Mac-Only Changes
Bugs Fixed:
  • CommandHelp: Filter in Help panel is slow and autocomplete does not work well (RH-81030)
  • Display: Technical Display Varies if Block is Involved (RH-81054)
  • Display Metal:
    • Point cloud created from GH1 export has wrong initial location (RH-81371)
    • Wireframes are no longer drawing (RH-81203)
  • ExtrudeCrv: : Output=SubDs/Surfaces inconsistent (RH-51435)
  • HatchScale: Display precision bug (RH-59223)
  • Import: File IO: USDZ file can not be opened with some version of Rhino 8 (RH-81083)
  • Keyboard: Cmd+Shift+S not working (RH-79585)
  • Layer: Dropdown shows only Default when clicking on top edge (RH-81264)
  • Layout: Canceling rename causes failure of reorder (RH-80906)
  • Notes: Do not save on Mac (RH-52374)
  • OSnap: One shot Osnap panel doesn't refresh on mouse out (RH-81280)
  • Rendering: Save button reads "Export" (RH-80378)
  • Rendering: Materials: Material assign menu items do not show on Mac (RH-81351)
  • Rendering: Textures: Does not remember previous folder on Mac (RH-59505)
  • Shrinkwrap: Block instances don't get wrapped on Mac (RH-78150)
  • StatusBar: Minutes from last save not updating on Mac (RH-80984)
  • Toolbar: Toolbars needs to be removed from Appearance (RH-80300)
  • UVEditor: Importing geometry with UVEditor open causes error message (RH-80643)
  • Viewports: Viewports - "unable to zoom" after zooming out (RH-74566)
  • WindowLayout: Command panel gets a tab (RH-80724)
Cosmetics:
  • Zoom: "1 To 1" option name missing a space (RH-38005)
Crashes Fixed:
  • ScriptEditor: Crashes when publishing project (RH-81459)
Enhancements:
  • NamedSelections: Allow Drag Drop Reordering of Parent Items (RH-60070)
Windows-Only Changes
Bugs Fixed:
  • ChangeLayer: Dialog too tall (RH-79958)
  • Display: Cannot cast shadows from unclipped objects when specified (RH-78193)
  • File IO: glTF export fails from Rhino.Inside when objects have custom materials (RH-81003)
  • Installer: Rhino WIP highlights Rhino 6 taskbar icon on Windows (RH-60614)
  • Layer: Layer tree collapses when editing a sublayer name (RH-78431)
  • PackageManager: Error with /NetFX (RH-81227)
  • PointCloud: TestPointCloudStyle no longer works fully in Rhino 8 (RH-78714)
  • SelVisible: Gets everything (RH-44001)
  • Toolbar:
    • Middle mouse pop up broken v8 sr7 (RH-81153)
    • Tabs no longer update Sidebar (RH-81142)
  • UI Appearance: Toolbar: Main toolbar detaching loses its container top bar (RH-81506)
UI Change:
  • Print: "Preview " between pages Missing in Print Dialog (RH-76466)
  • Detail: Can't change scale without moving focus from the properties panel (RH-55963)
Rhino 8 Service Release 7 HOTFIX for Windows and Mac (8.7.24138) is now available
This hotfix release contains all the fixes listed :point_up: above in 8.7.24134 as well as…
Bugs Fixed:
  • Layer: Changing Current Layer Disables Command Typing (RH-80790)
Mac-Only Changes
Bugs Fixed:
Rhino 8 Service Release 8 for Windows and Mac (8.8.24163) is now available
Bugs Fixed:
  • Annotation: DimLinear: Dimension in layout jumps when detail is activated and deactivated (RH-81775)
  • Annotation: Linetype: Deleting linetype with delete key triggers handled exception on MacOS (RH-81770)
  • ArrayPolar: Filling 360 degrees has one item overlaps the original (RH-81869)
  • BlendSrf: Surface blend rotation messes up history (RH-81446)
  • BlockManager: Can't delete blocks that are nested in other blocks (RH-81715)
  • BooleanDifference: Wirecut fails, extrude curve and Trim works (RH-81583)
  • BringToFront: Not working properly for hatch borders (RH-81889)
  • ClippingPlane: Depth setting in properties inconsistent with viewport display (RH-81834)
    • Configure editor so completion window doesn’t show up when the signature help window is open (RH-81607)
    • Signature help in embedded signatures fails when cycling though overloads (RH-81591)
    • Completion suggestions for this. is not always correct (RH-81587)
  • Crash Processing System: Crash reporter dialog does not appear (RH-78162)
  • Developer Tools: Yak.exe fails with multi-targeted plugin (RH-80648)
  • Display:
    • Raytraced mode fails when clipping fill is enabled (RH-82120)
    • Black Clipping Plane Fill Is Shown White (RH-77080)
    • Single color texture does not work correctly when multiple objects are involved (RH-74604)
    • Rendered display mode updates too slow when moving sliders in Material settings (RH-72909)
    • Inserted block shows up as see through when selected (RH-71686)
    • Selection candidate shows thicker highlight when linetype width in model units (RH-81603)
    • Keep Edges Visible when Using Opacity (RH-81487)
  • EdgeSoftening: Disable materials (RH-81823)
  • Eto: Avoid OverflowException in WPF when using certain mice (RH-80893)
  • ExtendSrf: ExtendSrf with Merge=Yes produces internal naked edge and invalid border (RH-81519)
  • ExtractClippingSections: Sectioned objects incorrectly added to output group (RH-81221)
  • ExtractClippingSlices: Incorrect slice through an open mesh (RH-76594)
  • File IO:
    • DWG import missing letter and flipping text (RH-81258)
    • DGN files imported with all lines Print Width set to “No Print” (RH-81881)
    • glTF export fails when texture is missing (RH-81862)
    • Importing DWG Changes Current Model Base Point (RH-81802)
    • Reading glTF - failure case (RH-81805)
    • RhinoCommon OBJ mesh writer : NullReferenceException (RH-81786)
    • glTF export ignores object display colors (RH-81576)
  • GetObject: OSnapping to object in a block causes crash (RH-81739)
  • Grasshopper:
    • MergeFaces causes Invalid Brep (RH-82374)
    • Extrude is offset from base curve (RH-82220)
    • Inconsistent Text Height and Arrow Size on Leaders (RH-81865)
    • Application data folder changed (RH-82035)
    • Lunchbox does not load (RH-82014)
    • GH_Cluster that does not dispose its internal document when removed (RH-81896)
  • Grasshopper: Bake:
    • Undo does not work after attaching a value list (RH-82066)
    • Cached Objects leave the Gumball behind (RH-81919)
    • Content Cache does not return enough Layers (RH-81849)
    • Rhino Content Cache with Branches misses (RH-81842)
    • Model Material custom preview doesn’t show texture maps (RH-81191)
    • GH Model Linetypes component - no consistent hint/warning (RH-81577)
  • Gumball:
    • extruding a single curve will result in a polysurface (RH-75672)
    • Doesn’t follow the moved object with Ctrl+Z (RH-81481)
  • History:
    • Fails to update when OSnapping to extrusion profiles & walls (RH-81822)
    • OSnapping to a point cloud point not getting History recorded properly (RH-81682)
  • Icons: Autogenerated icons that need fixing for dark mode (RH-77458)
  • InterpCrv: Periodic curve interpolation with uniform knots and even degree fails on given points (RH-81651)
  • Join: Makes the wrong choice (RH-81778)
  • Layer: Layers panel missing RMB menu (RH-82247)
  • Localization: SetDotNetRuntime - localization issue (RH-78670)
  • Make2D:
    • Result in nested blocks (RH-81927)
    • Draws clipped block instances as unclipped (RH-80723)
  • MergeAllCoplanarFaces:
    • Mid and end snaps are left over (RH-61476)
    • Causes incorrect mid point snapping (RH-81578)
  • MergeAllEdges: Colinear edges should be merged into single edge (RH-74831)
  • OSnap:
    • Incorrectly snapping to occluded positions (RH-82190)
    • Lags with many blocks (RH-82015)
  • OffsetSrf: Bad result (RH-81263)
  • OpenNURBS: Unable to load large .rtml / .renv files due to artificial character limit of 100M (RH-81953)
  • Print:
    • Custom Sheet Size Not Remembered (RH-82208)
    • Vector PDF lines issue (RH-82109)
    • Rhino PDF does not remember last used location (RH-81893)
  • Project: Circles onto trimmed planar surfaces produces bad results (RH-71531)
  • Properties: Invalid name glitch (RH-81917)
  • Purge: Custom hatch is wrongly purged (RH-81794)
  • RDK: Display crash due to deleted RDK content (RH-81569)
  • RDKCrash: Rhino is hung on loading from particular directory (RH-81837)
  • Rendering:
    • Ground Plane doesn’t adjust for Custom Previews in GH (RH-81223)
    • Ground plane shows white reflection incorrectly (RH-73770)
    • Decal with alpha channel on custom material shows incorrect base color (RH-79660)
    • Fresnel is broken (RH-77702)
    • Background image rendering upside down in Rhino Render (RH-81645)
    • Environments overly bright (RH-81685)
    • Sunlight is not visible in reflection (RH-77709)
    • Intensity of background environment is not used by Cycle (RH-81548)
    • Don’t match between Rendered and Raytraced modes (RH-73875)
    • UI elements overlapping in Materials panel (RH-80519)
  • Rendering: Realtime SDK: ChangeQueue: Do not treat copy transforms as transforms (RH-81660)
  • Rendering: Texture Mapping: Mesh object drawn using wrong mapping in Rendered display mode (RH-60441)
    • Incorrectly duplicated (RH-71966)
    • Wood procedural looks pixelated (RH-67626)
    • Physical sky texture renders black when “Document Sun” is not selected (RH-81470)
    • Importing 3dm file extracts embedded files to parent 3dm folder (RH-81534)
  • SDK: Python: ObjectsByType ignores type (RH-80814)
  • SDK: RhinoCommon:
    • Sweep2 gives BRep instead of surface (RH-81872)
    • Curve.ProjectToPlane not like ProjectToCPlane command (RH-81921)
    • Layer.SetPerViewportVisible not working model views (RH-81265)
  • ScriptEditor:
    • Published plugins are not built against rhinocode ref assembly (RH-82463)
    • Published GH1 command holds on to previous contextual data (RH-82444)
    • Zero versioning of C# script dynamic assemblies causes issues (RH-82075)
    • Python Enum autocompletion does not show methods (RH-81977)
    • Turn Guid marshalling off for C# scripts by default (RH-81841)
    • PointCloud gets split into its items on script component output (RH-82044)
    • Script component shows language button when disabled (RH-82050)
    • Python component resets “No Hint” to “ghobj” hint (RH-82051)
    • Python runtime to include packages installed in site_packages in all envs (RH-81895)
    • CPython env checker is paying too much attention to hyphen vs underscore (RH-81913)
    • Open and save failure (RH-81888)
    • C# script component shows Reload Python engine menu items (RH-81840)
    • Missing diagnostics in roslyn class methods (RH-81809)
    • Point3dList hint does not have a Grasshopper parameter (RH-81473)
    • Script Editor undo step is missing the name (RH-81602)
    • Fails to setup on macOS arm with no internet (RH-81744)
    • Autocomplete is not complete (RH-81350)
  • SelBrush:
    • Cannot select and display goes black on SubD n-gons in SubD flat display mode (RH-81468)
    • In SubD flat display mode, incorrectly selects faces where just an edge is visible (RH-81469)
  • Selection: Group selection fails (RH-81926)
  • SubD: Issue referencing SubD object from model (RH-80602)
  • Toolbar:
    • Commands ran from custom toolbar get added to default xml diff file (RH-81935)
    • Check that icons are on the grid (RH-78678)
    • Appearance of FilletEdge Edit button is set to image instead of inherit (RH-81713)
    • Save() and SaveAs() in script don’t work (RH-81455)
  • UI Appearance:
    • Tooltip doesn’t refresh (RH-81445)
    • Gears should stay the same size when changing the size of the container tabs icons (RH-77931)
    • Tooltips need to hide as soon as you start typing (RH-78583)
  • UI Cleanup: Pressing Esc does not exit out of Container Menus (RH-81898)
  • UserText: BlockAttributeText not working with Leader objects (RH-77015)
  • Weld: Now prints failure messages to command window (RH-81348)
  • Worksession: Attach Changes Current Model Basepoint (RH-81803)
Crashes Fixed:
  • File IO:
  • Layer: Only allows dragging name column to reorder (RH-82159)
  • Print: Vector print crashes Rhino (RH-81540)
  • ScriptEditor: Crashing script (RH-81922)
Enhancements:
  • Annotation: Linetype: Allows sorting linetypes by clicking column header in Linetypes panel (RH-81527)
  • BlockEdit: Added options to the scriptable command (RH-34493)
  • CheckNewObjects: Shows warning only at very first time an object is detected bad (RH-81536)
  • Grasshopper:
    • Export Block definition now includes Userdata on objects (RH-82067)
    • Convert Units component now takes a string as input and casts that to the correct unit system (RH-81692)
  • Grasshopper: Components: Added Annotation Model/Layout Scaling settings to Drafting Scale component (RH-81811)
  • Join:
    • Keeps mesh vertex colors (RH-81987)
    • Added UseLegacyCurveJoiner advanced setting to allow curve join working like Rhino 5 (RH-81815)
  • OSnap:
    • Mid object snap can snap to midpoint of linear/angular dimension line/arc (RH-9321)
    • Size of snapping point follows control point size of display mode (RH-81846)
  • OSnap:Cen:
    • ExtrudeCrvToPoint history update supports center OSnap for apex point (RH-81906)
    • History update of dimensions supports OSnapping to ellipse center (RH-81901)
  • Options: Never repeat command list supports wild cards (RH-6631)
  • Properties: Allows highlighting and copying object type name (RH-61358)
  • Rendering: Materials: Pointing to texture icon now shows tooltip for texture name (RH-79322)
  • SDK: Allows even degrees for curve interpolation in C++ and RhinoCommon (RH-81632)
  • ScriptEditor: Remember the folder where last script was opened (RH-80887)
  • Section Tools:
    • ClippingDrawings command shows section label during placing drawings (RH-80678)
    • ClippingDrawings command sets colors of background curves by input objects (RH-81400)
Features Added:
  • Grasshopper: Allow for filtering of Instance Definition Name on Model Objects (RH-78812)
  • Display: Adding Ambient Occlusion texture to PBR material makes rendering really slow (RH-56233)
  • ScriptEditor: Fix script out multiple compile issue (RH-82071)
Regressions Fixed:
  • Bevel: Does not work on symmetric SubD (RH-81980)
  • ExtrudeCrvTapered: Direction option fails (RH-81559)
  • Gumball: No longer extrudes SubD (RH-81699)
  • Join:
    • GH Join produces unwanted result caused by curve order (RH-82192)
    • Incorrectly stacks mesh vertices (RH-81696)
  • OSnap: Snapping point occluded by geometry (RH-81845)
  • OffsetSrf:
  • Reflect: Fails with appending face (RH-81836)
  • ScriptEditor: IronPython is getting dotnet types instead of python types (RH-82019)
  • acad import: File IO: Block definitions not read when importing DXF file (RH-81701)
SDK Enhancement:
  • Grasshopper 2: Constrained Tesselation SDK method (RH-81704)
  • OpenNURBS: Added ON_Mesh::CreateFrom2dPointsAndEdges() to C++ SDK (RH-81723)
  • SDK:
    • Exposed Inset for brep faces/surfaces in RhinoCommon (RH-78601)
    • Exposed Theme Colors (RH-81838)
  • SDK: RhinoCommon:
    • Added backface color override to DisplayPipelineAttributes (RH-81831)
    • Added IsOverGumball to get gumball mouse over mode on MouseCallbackEventArgs (RH-81819)
    • Exposed RhinoGetSubCurves (RH-81979)
    • Delaunay Triangulation solver in 2D (RH-79402)
    • Exposed CRhinoInstanceDefinition::UsesLinetype (RH-81492)
  • ScriptEditor: Allows creating script components from code (RH-81754)
UI Change:
  • Toolbar: Added ScalePositions icon (RH-81873)
  • Code Editor Control: Provide an option to turn off autocompletion from the tokens found in the script (RH-78548)
  • ExtractClippingSections: ExtractClippingSlices: History update works when clipped object is hidden (RH-76946)
  • Join: Does not give flash feedback when meshes are joined (RH-81816)
  • ScriptEditor:
    • Script Component/Parameter Tooltip does not accept multiple lines (RH-81925)
    • Added a C# guide (RH-81403)
  • Selection: Added PickOccluded advanced setting for picking subobjects behind opaque surfaces (RH-81337)
Mac-Only Changes
Bugs Fixed:
  • Display: Meshes do not show vertex colors in Rendered mode when GroundPlane is off (RH-81622)
  • Display Metal: Strange ghosting artifacts in shadows on Mac (RH-81850)
  • Layer: Cannot rename in floating Layers panel (RH-81525)
  • OSnap: One shot OSnap setting out of sync on Mac (RH-81118)
  • Options: mport: The selected (plist) is not a valid options file (RH-81137)
  • Panels:
    • Panel: Renaming Linetype loses focus (RH-82171)
    • Color Backfaces missing in Display panel on Mac (RH-81463)
  • Print: Rendered and Arctic views are blank when printing (RH-79093)
  • QuadRemesh: Fails silently in Rhino, but give CPU error in GH (RH-81687)
  • Rendering: Saving image should remember last used format (RH-81537)
    • Fresnel switch does not change the material appearance in rendered display mode on Mac (RH-81894)
    • Bump map turns object black in rendered viewport (RH-80317)
    • Slider does not change to allow typing (RH-81626)
  • Shrinkwrap: Some TextField boxes - RibbonOffset, QuadRemesh, ShrinkWrap - slow (MAC) (RH-82089)
  • Toolbar: Can't be closed by script (RH-81346)
Bugs Fixed:
  • Help: Offline help does not load when DisableInternetAccess=1 (RH-53073)
  • Menu: Icons are not shown (RH-81746)
  • Print: Switching from Rhino PDF to Image gets Layout dimensions incorrect (RH-82072)
  • Rendering: Environments: Background image not rendered in Front View (RH-80661)
  • SDK: CRhinoUiFile::Bitmap not working (RH-81759)
  • UI Appearance: Slider settings does not work well in dark mode (RH-81648)
Regressions Fixed:
  • Layer: Change current layer loses layer selection (RH-81904)
  • Print: Printer defined in Layout properties is not respected (RH-81760)
Rhino 8 Service Release 8 HOTFIX for Windows and Mac (8.8.24170) is now available
This hotfix release contains all the fixes listed :point_up: above in 8.8.24163 as well as…
Regressions Fixed:
    • Fails when user-text key contains a dot (RH-82582)
  • RhinoCommon SDK Break in 8.7 (RH-82629)
Rhino 8 Service Release 9 for Windows and Mac (8.9.24194) is now available
Bugs Fixed:
    • Undo gets cleared after hatch match (RH-82686)
    • Matching properties fails (RH-82678)
  • BlockEdit: Point cloud colors removed (RH-62019)
  • BlockManager:
    • Slows down viewport when objects are selected (RH-80279)
    • Block Attributes panel doesn’t appear (RH-81867)
    • Delete from block manager takes ages (RH-80069)
  • BooleanDifference: Failure example (RH-80968)
  • BooleanUnion: Only merges some faces (RH-80942)
    • C# can not autocomplete ScriptInstance properties and their members (RH-77879)
    • “Intellisense” for function signatures not always shown (RH-82160)
  • CommandHelp: CommandContextHelpUrl from 3rd party plug-in does not work in V8 (RH-78415)
  • Dir: Dir and ShowDir display texture differently when swapping UVs (RH-82027)
  • Displacement: Mesh with thickening causes empty display in most modes (RH-82113)
  • Display:
    • Monochrome section hatch background issue (RH-81443)
    • Material texture with adjustment applied doesn’t show up in preview (RH-81612)
    • Low FPS in Rhino 8 with PBR material (RH-79766)
    • Plastic material with bump unreasonably slow (RH-80473)
  • DocumentProperties: Rendering settings set by script are ignored (RH-80455)
  • DupLayer: Full path layer name is not scriptable (RH-77128)
  • ExtrudeCrvTapered: Creates too many faces (RH-82091)
  • File IO: Updated import_3dm to rhino3dm latest 8.x (RH-81173)
  • FitCrv: Inaccurate result (RH-82376)
  • Grasshopper:
    • Grasshopper import component ignoring layer filter (RH-82241)
    • Import SHP - .NET Issue (RH-82504)
    • SubD Preview Display Issue (RH-82186)
    • GH_BorderComponent.vb does not take into account the Max Size property (RH-82207)
    • Linear Dimensions return the wrong points (RH-82005)
    • Importing Model Block Definition with Clipped View fails to explode object (RH-82898)
    • Default Hatch Errors Content Cache component (RH-82331)
    • Model material texture repeat doesn’t cause update (RH-81751)
    • Shrinkwrap fails after opening (RH-81282)
  • Gumball:
    • Extending face shows Wireframes (RH-82375)
    • Moves to incorrect location when curves are joined (RH-82037)
  • History: Broken history on dimension (RH-62561)
  • Join: Curves disappear (RH-82151)
  • Layer:
    • Custom print width is rounded to one decimal when editing (RH-82410)
    • Releasing left mouse button on lock column after highlighting layer name quits name editing and toggles locking state (RH-80598)
  • LineTypeDisplay: Linetypes with pixel width don't display when model is opened (RH-77096)
  • Loft:
    • History update flips surface direction (RH-82165)
    • Edge domain of straight loft changes (RH-82166)
    • BlendSrf: History update does not find entire edge (RH-63881)
  • Make2D: Incorrectly shows hidden geometry (RH-80980)
  • MatchProperties: Ignores groups (RH-82345)
  • OSnap: Snaps to Clipped Targets (RH-82379)
  • OffsetCrvOnSrf: Creates incorrect result (RH-82196)
  • Print: Vector Print does not occlude intersections (RH-82454)
  • PrintPreview: Print display scale has no effect on line width set in linetypes (RH-82329)
  • Properties: Matching properties ungroups hatches (RH-82346)
  • PushPull: Issue Sample (RH-82221)
  • RDK: Modal Content editor name change bug (RH-81415)
  • Rebuild: Incorrect deviation feedback (RH-82344)
  • Rendering: Physical sky texture changes don't do anything (RH-81326)
  • Rendering: Content Panels: Render Libraries option not scriptable (RH-81594)
  • Rendering: Cycles: Spotlight not working properly (RH-82279)
    • Rendered display mode is slow with texture maps (RH-71371)
    • Poor display performance with transparency and procedural texture (RH-71486)
    • Bump maps and AA level cripple frame rates in Rendered mode (RH-72115)
  • Rendering: Texture Mapping: Breaks on per face material (RH-59908)
    • Stucco texture scale is off in Rendered view (RH-82189)
    • Texture editor popup keeps showing (RH-82013)
    • Choose Existing creates many textures (RH-81876)
  • SDK: Block Explode: Skip when hidden in Model Space (RH-82312)
  • SDK: GhPython: rs.StatusBarProgressMeterHide needs RhinoApp.Wait() in Rhino 8 (RH-81996)
  • SDK: Python: RunScript vs RunPythonScript inside commands problem (RH-56354)
  • SDK: RhinoCommon:
    • Added SubD display properties to .Net SDK (RH-82090)
    • RhinoObject.SetTextureMapping misses existing channels (RH-81859)
    • RhinoObject.SetTextureMapping ignores object transform (RH-81860)
    • RhinoObject.SetHistory doesn’t work (RH-82509)
    • Developer documentation search results unnavigable (RH-82182)
    • Missing method to create rounding rectangle (RH-81997)
  • SVG Editor: Pressing Enter makes you loose your work (RH-82253)
  • ScriptEditor:
    • Missing blinking cursor when switching between search results (RH-82244)
    • Debug does not stop after python code is saves as (RH-82443)
    • ImportError on importing numpy from source directory (RH-80494)
    • python signature help window closes when cursor moves away from open paren. (RH-82164)
    • CSharp Script Instance Converter bugs (RH-82125)
    • Python 3 ScriptInstance converter has a few minor bugs (RH-79253)
  • Section: Clipping drawing Hatch Orientation 2D output different than Live Section (RH-82330)
  • Section Tools:
    • ClippingDrawings: Inconsistent hatch direction (RH-77430)
    • Parts of model disappear when working with layouts (RH-82197)
    • Drawing is moved to layout (RH-80054)
    • Hidden lines behind clipping fill are incorrectly drawn (RH-78206)
    • ClippingDrawings does not pay attention to block layers (RH-81909)
  • Selection:
    • Selects Clipped Objects (RH-82380)
    • BoxEdit panel delays edge and face loop selection (RH-82092)
    • Mouse scroll screws up ctrl+ deselect (RH-82036)
  • Snapshot: Scriptable cmmand missing settings (RH-82086)
  • SoftMove: Editing of SubD edit/control points does not stick (RH-56127)
  • Sun:
    • Sun rotation control does not update the sun color (RH-82107)
    • Editing location creates a large undo stack (RH-82181)
  • Toolbar:
    • SVG editor - cancel on changing tools to selection (RH-82212)
    • PopUp toolbar disappears (RH-82103)
    • Esc cancels SVG edit session (RH-80252)
  • Torus: Plane.WorldXY is invalid (RH-82169)
  • UDT: Flow cannot select target surface (RH-82761)
  • UVEditor: Deleting mapping to return to 'Surface' mapping doesn't update in the viewport (RH-72072)
  • VariableFilletEdge: Rounding errors influence result visibly (RH-82225)
Cosmetics:
  • Dark Mode: Component Name Conflict dialog doesn't support dark mode (RH-82320)
Enhancements:
  • CPlane: Object option sets CPlane-Z to surface normal direction (RH-82076)
  • Code Editor Control: Allow manually collapsing certain sections (RH-78545)
  • DupEdge: Creates simple circle from circular edge on extrusions and breps (RH-82422)
  • File IO: Read construction geometry in Solidworks file as points (RH-81999)
  • Gumball: Added Shift-Both Sides to Gumball Surface Extrusion Tooltip (RH-82372)
  • History:
    • Works with Fin and OffsetNormal commands (RH-80768)
    • Made history replay of Sweep1, Sweep2 and Revolve more closely match what the commands do (RH-82032)
  • Mesh: Importing presets does not overwrite existing ones (RH-80492)
  • Rebuild: Preserve curve domain if DeleteInput=Yes and the curve to rebuild is a history parent (RH-82163)
  • ScriptEditor:
    • Added user templates to ‘New’ dropdown list (RH-79251)
    • Better Closing of Multiple Tabs (RH-82437)
    • Allows setting default Hint for python script component (RH-82009)
    • Added “Toggle Line Numbers” to Edit menu (RH-82121)
  • SelName: Select option in scriptable command supports preselect (RH-82431)
  • Selection: Made pick culling pay attention to draw order (RH-82337)
  • Shrinkwrap: 0.01 too coarse for Imperial units (RH-78489)
Features Added:
  • ScriptEditor: Package installation now checks environment first to specify which packages to be installed (RH-77108)
Performance Improvements:
  • Rendering: Some of the noise textures make rendered view very slow (RH-77286)
Regressions Fixed:
  • BooleanDifference: Fails in Rhino 5 and 8, not in 6 and 7 (RH-78426)
  • File IO: Sketchup textures not imported properly in V8 (RH-82017)
  • Gumball: Made extruding with Ctrl (CMD) + plane control always creates open object (RH-82411)
  • Properties:
    • Matching options limited (RH-82322)
    • Scriptable command applies color for sub-object to whole object (RH-82204)
  • ScriptEditor:
    • Editor minimum size should be smaller (RH-82705)
    • sys.stderr is missing (RH-82704)
    • Interface wrapped object can not set value (RH-82012)
  • Select: Issues about selecting point on surface in command (RH-82295)
SDK Enhancement:
  • OpenNURBS: Added ON_RUNTIME_WASM (RH-82453)
  • SDK: Exposed ConnectSrf functionality (RH-64396)
  • SDK: RhinoCommon:
    • Made RibbonOffset SDK as good as the command (RH-81554)
    • Wrapped RhinoExtendBrepFacesToConnect (RH-82205)
    • Added Hatch.ToBrep() for converting a hatch to a Brep (RH-82461)
    • Exposed CRhinoLayer::m_bIsVisibleInRhinoUserInterface (RH-81522)
    • Wrap CRhinoInstanceObject::Explode with bSkipHiddenPieces (RH-82153)
UI Change:
  • SplitFace: Renamed SelCurves option to SelectCurves (RH-82492)
  • Code Editor Control: Improve inline error prompt in code editor (RH-80592)
  • ScriptEditor:
    • Cpython autocompletion sometimes returns too much data (RH-77886)
    • Allow option to choose active or open codes for search and replace (RH-80934)
    • Search results locate in the document (RH-82262)
    • Added ‘Whole Word’ to search panel (RH-81502)
    • Provides autocompletes when typing comments (RH-81189)
    • Allows toggling autocomplete in signature complete (RH-82473)
    • Made type hinting menu searchable (RH-78084)
    • Added Toggle to show/hide “Non-Public” items in debug variables (RH-82351)
    • Open location on two screens (RH-80868)
    • Added blank templates to New dropdown menu (RH-80243)
    • RunScriptCommand only searches for python files inside IronPython plugin search paths (RH-78659)
    • Install Package dialog to allow selecting dll from an open dialog (RH-81910)
    • Includes Full Stack Trace in error message tag hover (RH-82263)
    • Improved error colors in dark mode (RH-82265)
    • Show warnings about super()._ _ init _ () call inside _ _ init _() (RH-82029)
    • Improvement about dealing with errors (RH-79256)
    • Increase max size of error message tag (RH-82264)
    • Python stubs with out params should put out in return tuple for signature (RH-82158)
    • File Open and search messiness (RH-79207)
  • StatusBar: Pressing Esc key does not close layer popup (RH-82341)
Mac-Only Changes
Bugs Fixed:
  • Annotation: Linetype: Model Space spinner uses comma (RH-80018)
  • BoxEdit: Panel Broken (RH-82154)
  • Containers: Sidebar container is not correct on start (RH-80873)
  • Display: Textures display with splotchy colors on Mac (RH-63350)
  • Display Metal: Grid display messy with high contrast (RH-80246)
  • ExtrudeCrvToPoint: Run out of memory (RH-80508)
  • Layer: Layers panel does not automatically switch between light/dark mode (RH-78700)
    • Anisotropy doesn’t preview correctly (RH-80318)
    • Not shown in Rendered mode on Intel Mac (RH-82068)
    • Flip alternate gradient option doesn’t work in Raytraced (RH-71665)
  • Rendering: Texture Mapping: Broken in Rendered display (RH-80487)
  • Spotlight: Spotlitght: Limited to 16 on Mac (RH-82464)
  • UVEditor: Can't use Lasso or SelBrush when picking vertices to Pin (RH-73099)
Regressions Fixed:
  • Display: Rhino becomes slow after multiple documents have been opened (RH-82080)
  • ScriptEditor: Window gets caught behind Rhino main window (RH-80086)
Bugs Fixed:
  • Display: Incorrect drawing of object with material and alpha transparency (RH-82282)
  • Eto: TreeGridView Expand and Collapse Slow (RH-82010)
  • OffsetCrvOnSrf: GH component gives curve that goes way off (RH-82256)
  • Options: Shadows page is ugly when disabled in dark mode (RH-75383)
  • SendToBack: Not working with hatches in Rendered and Artic (RH-82370)
  • Toolbar: Grippers have odd shading (RH-81331)
Enhancements:
  • ViewCaptureToFile: Added file format note to Transparent background option (RH-64908)
  • ScriptEditor: Tuned up closing behavior (RH-80600)
Rhino 8 Service Release 10 for Windows and Mac (8.10.24226) is now available
Bugs Fixed:
  • OSnap One Shot incorrectly remains disabled (RH-82829)
  • BlockEdit: Adding group objects to a block maintains relationship with group. (RH-82921)
  • BooleanDifference: Normal direction flipped on a mirrored block (RH-82669)
  • BooleanUnion:
    • RhinoBooleanUnion function 10x slower in V8 than V7 (RH-82742)
    • Makes one object disappear (RH-79084)
  • BoxEdit: Panel gets disabled until additional click (RH-82612)
  • Bridge: Causes creases to be removed (RH-82462)
  • Cap: Bails when all mesh faces are coplanar (RH-82671)
  • ClippingPlane: Causes a crash (RH-81765)
  • Code Editor Control: C# autocompletes null) to Nullable) when close bracket is typed (RH-82575)
  • CreateSolid: Supports History when DeleteInput=No (RH-13146)
  • Dir: Only one object is flipped when multiple objects are selected (RH-82599)
  • Displacement: Addition texture gives different results in raytraced (RH-75365)
  • Display:
    • Section Color is Wrong in Arctic (RH-82893)
    • Changing surface direction does not update texture (RH-74064)
    • All procedural textures are calculated on GPU (RH-36299)
    • Render mesh does not update when editing sharp edges (RH-82765)
    • Extra Block Instance Section Hatch In Technical Display Modes (RH-82637)
    • Locked detail camera moves (RH-82390)
    • Technical mode is constantly printing “Updating wire cache”… (RH-82657)
    • Lines parallel to view direction of plan view are not visible (RH-62347)
  • DocumentProperties: Changing units via -documentproperties throws an exception. (RH-83230)
  • EdgeSoftening: Stops working (RH-82987)
  • Emap: Mesh setting is ignored (RH-82838)
  • File IO:
    • import_3dm: support nurbs curves and circles better (RH-81212)
    • Opening Takes a Long Time on 8 (RH-82647)
    • OBJ - Fixed issues about IOR, colored metal, and emissive materials (RH-82536)
    • Vertex colors confused in obj import (RH-82561)
  • FillMeshHole: Creates various results (RH-82897)
  • FilletEdge: Editing radii not starting with saved handles (RH-82515)
  • Grasshopper:
    • Custom Preview component shows wrong UVs (RH-82042)
    • Nested group reversed when baking into Rhino (RH-81228)
    • Texture disappears when switching display modes (RH-82650)
    • “Manage … Collection” dialog does not open for new component (RH-82503)
    • Fillet Distance does not work on PolyCurve (RH-82697)
    • Custom Hatch Pattern doesn’t accept or respond to scale inputs (RH-82993)
    • Import Model Block unexpectantly changes view Top view to Perspective (RH-82899)
    • UserText Change on Block Instances removes Values (RH-82664)
  • GrasshopperBlocks: Blocks show their transform axis in Monochrome/Arctic display mode (RH-82674)
  • Gumball:
    • Doesn’t work with OneView on Mac (RH-82608)
    • Does not reset after object is trimmed (RH-82028)
    • Extrude dot incorrectly shows when rectangular light is selected (RH-82371)
    • GumballAutoReset should be saved between sessions (RH-82659)
    • Extrude dots incorrectly shown on Clipping Plane (RH-82548)
  • History: Parent-Child Not As Expected (RH-64470)
  • Layer: Layer pane shows wrong layer when a worksession attached object is selected (RH-82857)
  • Layout: Chinese dialog for layout is clipped (RH-82955)
  • Lights: Slider value in Light properties gets divided by 1000 (RH-82466)
  • Localization: Commands.rhp not loaded if regional format is set to Thailand (RH-83005)
  • MacroEditor: Macros run from the MacroEditor are not repeatable on the Mac (RH-82882)
  • Mesh:
    • Quad Mesh support (RH-17694)
    • Aspect ratio and angle settings ignored (RH-82596)
  • MeshPolyline: Normal Direction/Inconsistency (RH-82193)
  • NamedView: Grid settings lost (RH-1575)
  • Paste: Pasting from AutoCAD Uses Wrong Coordinates (RH-82933)
  • Print:
    • New Rhino session forgets last printer used (RH-82949)
    • Join Style Issue with Vector Preview/Printing (RH-82720)
    • Printing specific Layout in Multi-Layout print always prints first layout (RH-82805)
    • Vector Print of Curves Messes with Ends (RH-82579)
    • Vector Print does Not Occlude Curves (RH-82576)
    • Vector output with clipping plane text mask showing (RH-82587)
  • Rendering: Cycles: OCS texture mapping broken in Cycles (RH-66048)
  • Rendering: Environments: Skylight intensity turns to -1.00 when physical sky texture does not have an intensity parameter (RH-82366)
    • ‘Sort alphabetically’ doesn’t play well with numeric postfixes (RH-82537)
    • Name won’t accept (1) or any integer in parentheses (RH-82528)
  • Rendering: Post Effect: Modifying RenderWindow contents after render doesn't work properly (RH-81122)
  • SDK:
    • Added an advanced setting to make CapPlanarHoles work like Rhino 5 (RH-82566)
    • Correct custom mesh mapping for public openNURBS (RH-81962)
  • SDK: RhinoCommon:
    • User text removed in rhinoscriptsyntax (RH-49260)
    • RhinoDoc.Open an already open file: ActiveDoc serial# mismatch (RH-82580)
  • ScriptEditor:
    • Python autocompletion reads code inside of comments too (RH-82568)
    • Signature has wrong param index (RH-82584)
    • Match Script Editor client side colors to Rhino (RH-82562)
    • Missing Super.Init warning (RH-82559)
  • Section Style: F1 Help Leads Nowhere (RH-82549)
  • Section Tools: ApplyToAll=Yes should not change Placement Point (RH-80646)
  • SelectionFilter: Container pops up when already docked (RH-82558)
  • ShutLining: Multiple mesh modifiers create a bad render mesh (RH-28101)
  • SplitDisjointMesh: Doesn't preserve UVs (RH-82825)
  • SubD: Slow unresponsive when assigning color to face (RH-82907)
  • Sun:
    • Enabling sun during night gives unexpected result (RH-82131)
    • Certain widths of dialog cause Rhino to crash (RH-82741)
  • Toolbar: Deleted Macros Come Back (RH-81456)
  • UI Cleanup: Layer popup reopens when last layer is clicked (RH-82653)
  • ViewCaptureToFile: Default to PNG and make extension stick (RH-65583)
  • Zebra: UI focus is lost easily (RH-82116)
Crashes Fixed:
  • Annotation: Hatch: Rhino 8 keeps crashing when creating hatches (RH-82935)
  • Code Editor Control: C# editor crashes in Rhino 8 (RH-83060)
  • Crash: in CRhinoDisplayEngine_OGL::ShowBackBuffer (RH-81020)
  • Display: Crash in CRhVboChunkMetal::SetupVertexBuffer (RH-82682)
  • Make2D: Cannot cancel properly (RH-78990)
Enhancements:
  • Block: Groups can be saved in block definitions (RH-39190)
  • ClippingPlane: Copies of a named clipping plane get incremental suffix numbers in their names (RH-79425)
  • Code Editor Control: Optimized completion list sorting order in C# (RH-80524)
  • Drag and Drop: Python - support script drag and drop (RH-82540)
  • File IO: DWG/DXF export supports writing degree 1 curves (RH-82317)
  • Section Tools: NestedClippingDrawing: All option now creates clipping section drawings ordered by section names in alphabetical order (RH-77581)
  • TextField: Allows using "" as object ID for referencing the object itself in Attribute User Text (RH-82648)
Features Added:
  • File IO:
    • import_3dm: import Rhino annotations (RH-81210)
    • import_3dm: import Rhino dimensions (RH-81211)
  • Section Tools: Changing clipping plane name updates associated clipping drawings, layers, named views, and named CPlanes (RH-75371)
Regressions Fixed:
  • Display: Linetypes don't show segments when far from origin (RH-81516)
  • OffsetSubD: Error on scaled SubD Plane (RH-82665)
  • Print: Hardware settings being lost (RH-81693)
  • Rendering: Textures: WCS/OCS mapping gets scaled with blocks (RH-82266)
  • ScriptEditor: RunScript should enable Redraw after running (RH-83100)
  • Trim: Failure case in v8 (RH-78036)
  • UI Cleanup: Layer popup lost focus after changing color of layer (RH-82977)
SDK Enhancement:
  • SDK: Exposed RhStartedAsRhinoExe to C++ SDK (RH-82701)
  • SDK: RhinoCommon:
    • Added two methods to GripObject class for retrieving NURBS curve/surface control point indices (RH-82920)
    • Made Curve.CreateControlPointCurve work in Rhino3dm (RH-81969)
    • Exposed display mode SubD edge visibility (RH-82636)
    • Exposed display mode ground plane properties to .NET (RH-82276)
  • ScriptEditor: Implemented RhinoCommon PythonScript in new rhinocode (RH-81267)
UI Change:
  • Properties: Added display mode setting to viewport properties for active detail view (RH-82456)
  • UserText: UI improvements for Block Attribute Text in Attribute User Text properties (RH-82760)
  • ViewCaptureToFile: Removed jpg and bmp formats from Save dialog when transparent background is enabled (RH-42926)
  • MatchProperties: Hatch should match other properties - not just hatch properties (RH-27591)
  • ScriptEditor:
    • Bring back Collapse to Definitions (RH-82703)
    • Published contextual component does not preview output geometry (RH-79902)
    • Added options to UI to use tabs vs spaces and to set the tab/space size (RH-82525)
    • Private members of Script_Instance are not in the editor so there is no autocompletion for them. (RH-81585)
Bugs Fixed:
  • OpenNURBS: Makefile is not able to compile examples on Linux; android_uuid missing (RH-82660)
Mac-Only Changes
Bugs Fixed:
  • Display: Grid lines thicker in shaded mode (RH-82880)
  • Polyline: Enter to finish command fails when using command option window (RH-82680)
  • SubD: Sharp edges are lost when copy-pasting (RH-82577)
  • UI Cleanup: Right click menu in layer popup does not work on Mac (RH-82976)
  • Units: Infinite dialogs pop up on doc close if layout units are not inches or mm on Mac (RH-83058)
  • ViewCaptureToFile: Transparent background forces png format (RH-82581)
Crashes Fixed:
  • AutoSave: Corgi package causes macOS Autosave hang requiring Force Quit (RH-81891)
Enhancements:
  • MatchSrf: Made OK button focused by default instead of Distance field (RH-82468)
  • ScriptEditor: MacOS menu is confusing (RH-82727)
Bugs Fixed:
  • Display: OpenGL 2.1 does not display arrowheads of dimension lines (RH-82480)
  • Eto: Rhino 8 in .Net 8 (rhino.Inside.Revit 2025) UI jump (RH-81674)
  • Keyboard Shortcuts: Keyboard Shortcut: Ctrl+Shift+M needs pressing twice to run macro (RH-82780)
  • Rendering: Materials: Switching Issue in Worksessions (Always in this case) (RH-82707)
  • SelName: Dialog Version Shows No Names from Attached Files (RH-82886)
Crashes Fixed:
  • File IO: SKP Import Crashes Rhino 8.9, 8.10, and BOTD (RH-82833)
  • Print: Crash with Vector Output (RH-82980)
  • ReadViewportsFromFile: Ignores environment strings (RH-82719)
Enhancements:
  • File IO: DWG/DXF import detects and resolves conflicted block names (RH-82252)
Regressions Fixed:
  • ChangeLayer: Can't click on right side to change layer (RH-82762)
  • StatusBar: Layer popup blocks Layer pan (RH-82747)
  • Grasshopper: Parameter input keyboard shortcuts required enter or space to complete (RH-82929)
Rhino 8 Service Release 11 for Windows and Mac (8.11.24254) is now available
Bugs Fixed:
  • Don’t make Selected Objects Only hide multiple layout controls (RH-83536)
  • rint: Image resolution presets not saving/restoring correctly (RH-83254)
  • Annotation: Linetype: Added search box to linetype import dialogs (RH-82978)
  • CPlane: AutoAlign: Auto CPlane won't align to planar face (RH-83499)
  • Cage: CageEdit on particular curves not working (RH-83497)
  • ClippingDrawings: Block sectioning is broken (RH-83197)
  • ClippingPlane: Clipping Plane creates havoc (RH-82726)
  • Commands: Pressing Enter does not repeat Snap command (RH-82789)
  • CopyLayout: CopyLayout to Keep Original Layer Visibility Settings (RH-83485)
  • Crash: Wireframe geometry crashes ARM Windows Computers (RH-83663)
  • CrvDeviation:
    • Reporting incorrect maximum distance (RH-83032)
    • Does not find overlap on some curves (RH-43741)
    • Different results on CrvDeviation (RH-81220)
    • Reports incorrect deviation on nearly identical curves (RH-37212)
    • Does not work well on far-from-origin curves (RH-38458)
  • Detail: Detail View Panel display mode setter fires incorrectly (RH-83673)
  • Displacement: Mesh update incomplete in Technical display mode (RH-82499)
  • Display:
    • Text Drawing Incorrect For OratorStd Font (RH-45774)
    • UndoView on a detail view while PrintDisplay is ON creates a mess (RH-83187)
    • Low speed for blocks in Rhino 8 in Ghosted mode (RH-83267)
    • SubD boundaries in flat mode do not display locked color (RH-80965)
    • Zooming into a layout view causes slowdown… (RH-83121)
    • Ghosted mode is about 40% slower on the Mac (RH-83065)
  • File IO:
    • glTF creates bad meshes on import (RH-83386)
    • Error Importing GLB (RH-83710)
    • Section Curve is Highlighted in PDF (RH-83628)
    • PDF Export - Font is “uncondensed” (RH-54669)
    • Diameter dimension baking with 2 symbols (RH-83265)
    • Text Entity component reports Invalid on all text (RH-83173)
  • Gumball:
    • Gumball AutoReset doesn’t work with the click transform (RH-83500)
    • Extrude handle incorrectly shown on hatches (RH-82737)
    • Extrude handle incorrectly shown on Dimensions (RH-82739)
    • Extrude handle incorrectly shown on Text (RH-82734)
  • Intersect: Fails with a case of two surfaces (RH-82922)
  • Keyboard Shortcuts: Proposal for adding commands to keyboard shortcuts. (RH-79531)
  • Layer:
    • Deleting layer doesn’t redraw viewports (RH-83532)
    • Detail Views Layer visibility not updating correctly (RH-83357)
  • Layout: Geometry disappears in detail view (RH-83587)
  • OffsetCrvOnSrf: Trims incorrectly (RH-83206)
  • Options: OpenGL.WireThicknessScale in Advanced settings shows too many decimals (RH-45405)
  • Print:
    • Print widths don’t work correctly for dimensions (RH-83328)
    • Vector: Occlude PointClouds (RH-83567)
    • Rhino PDF fails to print (RH-81691)
    • Vector: Section Hatches not Clipped (RH-82141)
    • some special characters display but do not print (RH-68835)
    • Vector Output Shifts Centered and Right Justified Text (RH-64543)
    • RhinoPDF Printing Text with Bahnschrift Font Incorrectly (RH-64213)
    • Text offset in PDF print (RH-47886)
    • Unicode symbols lost in vector output (RH-65395)
    • Failure to create PDF with Ubuntu font (RH-44699)
    • Added TestSavePdfTo3dmPath command for saving PDF to 3dm path (RH-83225)
  • QuadRemesh:
    • ToSubD fails; works in two steps (RH-82676)
    • Removed clamp on target edge length values (RH-83189)
  • Rebuild: Polysurface faces incorrectly being pickable (RH-83079)
  • Rendering: Cycles: Focal blur works in Parallel view but no controls are available (RH-82715)
    • Drag and dropping a ZIP material with EXR files creates bitmap textures (RH-83183)
    • “Assign to Layer” not using layer tree control (RH-82979)
    • Tone mapping settings not updating correctly (RH-82813)
    • Should stay off per view (RH-79777)
  • Rendering: Textures: Edit button should be more clear (RH-82521)
  • SDK: GhPython: clr.AddReference("GhPython") fails in Rhino > 8.3 (RH-83122)
  • SDK: RhinoCommon: Curve.ExtendOnSurface method crashes Rhino.Compute (RH-83304)
  • ScriptEditor:
    • Adding IronPython to project still uses python 3 (RH-83675)
    • Rhino Obj to Guid converter on script component does not work (RH-83704)
    • Script doesn’t work when run as python 3 (RH-83002)
    • Editor mangles script when it is updated during debug (RH-83287)
    • Scripts with async specifier do not run async outside of editor (RH-83097)
    • Disable other editors when one is in debug (RH-82512)
    • C# Debugger breaks on lambda style function body (RH-83216)
    • Adding inputs on component fails when RunScript is multiline (RH-83124)
    • Published GH1 command does not clear contextual data consistently (RH-83231)
    • RunScript parameter named outline automatically turns into output (RH-83087)
    • Published components do not show icon on Rhino 7 (RH-81170)
  • SetPt: Surface to Z is not flat (RH-82835)
  • Snapshot: Screenshot: Restore called through SDK does not work properly (RH-83172)
  • StatusBar:
    • Status Bar Info Pane: Selected object layer shows “Varies” incorrectly (RH-83430)
    • Shows a blank button (RH-77783)
    • Coordinates are harder to read in V8 (RH-77445)
  • Sun: Map and city list do not select initial city (RH-82786)
  • TextField: 8.10 breaks empty values in BlockAttributeText (RH-83491)
  • TweenSurfaces: TweenSurface: Display refresh issue (RH-82782)
  • UDT:
    • History update rotates output of Flow command (RH-83381)
    • Added GroupFrameOrigin=BoundingBoxCenter/ObjectFrameAverage to FlowAlongSrf command (RH-83131)
  • Undo: Fails with renaming grouped lights (RH-83064)
Cosmetics:
  • UI Cleanup: ReduceMesh command dialog not theme aware (RH-83266)
Crashes Fixed:
  • Properties: Crash When Changing Arrow Style (RH-83599)
  • Rendering: Risky Action [<.ctor>g__RunGuarded|1] System.InvalidOperationException: Sequence contains no elements (RH-82298)
Enhancements:
  • Annotation: Hatch: Improve performance of loading hatch thumbs in dropdowns (RH-83017)
  • Annotation: Linetype: Added search box to Document Properties > Linetypes (RH-83008)
  • Block: Exploding blocks keeps groups (RH-83029)
  • BooleanUnion: Added MergeCoplanarFaces=Yes/No option (RH-83171)
  • Code Editor Control: Added Setting to add/remove indentation guides (RH-82613)
  • File IO:
    • Scripted export to SVG no longer displays a dialog box (RH-62643)
    • Detects and resolves block name conflict when importing STEP file (RH-68343)
  • Grasshopper:
    • Added caster to GH_Brep to retain reference ID if converting from GH_Extrusion or GH_SubD (RH-83226)
    • Auto-populate parameters with selection (RH-82968)
  • Installer: Insntaller: Provide a URL to query for latest rhino installer (RH-80327)
  • Layer: Add Expand and Collapse options to -Layer command (RH-83351)
  • Rendering: Texture Mapping: Added SetMeshSurfaceParameters command to avoid losing UVs on squish mesh (RH-80911)
  • SVG Editor: : Cannot save to PNG (RH-82532)
  • ScriptEditor: Implement Save As for projects (RH-75462)
  • Section Tools: Added "from" option to PlacementPoint option of EditClippingDrawings command for precise placement (RH-83161)
  • Toolbar: Allows selecting which rhi file to add new toolbar (RH-81286)
  • UserText: Paste key and value to all -> Make context aware (RH-62668)
  • WindowLayout: Scriptable WindowLayout command need "Import" option (RH-83468)
Features Added:
  • Grasshopper:
    • Created Interop methods for accessing trees and data files (RH-67100)
    • One of the most common problems with GH that I see when I teach it… (RH-37737)
  • Rendering: Texture Mapping: New SetMeshSurfaceParameters command (RH-66671)
  • SVG Editor:
    • SVG Editor - End Caps / Stroke / Colors cannot be edited during / before object is created (RH-82217)
    • New SVG editor for toolbar icons (RH-83160)
  • ScriptEditor: Support other filetypes in the editor (RH-81609)
  • Section Tools: Added DisplayColor=ByLayer/ByInputObject option to ClippingDrawings and EditClippingDrawings commands (RH-83145)
  • Display: Lagging with Many Curves (RH-82891)
Regressions Fixed:
  • ExtendSrf: ExtendSrf removes trims (RH-83317)
  • MergeAllCoplanarFaces: Creates invalid Brep (RH-82695)
  • MergeAllEdges: Creates invalid Brep (RH-82696)
  • Print: Detail Print Width Not being printed or modified (RH-83487)
  • Rendering: Textures: Dots texture pattern discontinuity (RH-82644)
  • ScriptEditor:
    • Calling struct ctor with only kwargs create invalid data (RH-83233)
    • Implement RunToEnd in debugger (RH-83214)
    • RUI files for Rhino 7 get cropped icons in Rhino 8 (RH-80821)
  • Tab Constraint: Lock is Broken (RH-83670)
SDK Enhancement:
  • OpenNURBS: Added C++ ON_Integrate() tools for integrating 1 and 2 variable functions (RH-83256)
  • SDK: RhinoCommon:
    • Expose ON_SubD::TransformComponents to RhinoCommon (RH-83674)
    • Added Shadow and Grid display properties (RH-83215)
    • Provide a public constructor for ClippingPlaneSurface type (RH-83213)
    • Provide ExtractControlPolygon functonality (RH-83271)
    • Added Object display properties (RH-83136)
    • Added Light and Clipping Plane Display Properties to .Net SDK (RH-83095)
UI Change:
  • BlockEdit: Forbid commands of section tools when editing an embedded block (RH-71830)
  • Grasshopper: Components: Misspelling of Deconstruct in Component (RH-83484)
  • Rendering: Content Panels: Added Back and Forward buttons back to Materials, Environments, Textures panels (RH-82522)
  • Toolbar: Cascade triangles are heavy (RH-79275)
  • ViewPropertiesPage: Removed "Pick" button from Focal Blur settings of parallel views (RH-83158)
Usability Problems Fixed:
  • Panels: "One Click" Show Panels (RH-74338)
  • ScriptEditor:
    • Improve stdout handling (RH-77370)
    • : Project author editing does not update (RH-75881)
    • Added option to “Run Without Debugging” (RH-82713)
    • Allow multiple scripts to be added to a project to compile into a plug-in (RH-80870)
    • Support default icons for published components (RH-81169)
    • Allows building project from rhinocode CLI (RH-75546)
    • Improved error reporting on the publish plugin window (RH-77167)
  • StatusBar: Improving coordinates readability (RH-79957)
Mac-Only Changes
Bugs Fixed:
  • Display:
    • Render Material Not Displaying for Clipped Block (RH-80891)
    • Sections show picture material only on Mac (RH-83107)
  • Display Metal: Pointcloud display style on Mac doesn't work. (RH-83416)
  • Grasshopper:
    • Renaming input/output variables is unresponsive (RH-81454)
    • Can’t tab to parameter name after right clicking (RH-78627)
    • Failure of Jump component in Sonoma (RH-83347)
    • Copy and Paste (CMD+C/CMD+V) isn’t working on the Mac when editing GH component name (RH-58811)
  • Options: Mouse option out of sync with corresponding advanced settings (RH-42536)
  • SDK: Bella plug-in fails to load in 8SRC11 (RH-83330)
  • UI Appearance: Coordinates in statusbar update slowly (RH-77199)
Bugs Fixed:
  • Display:
    • Block display: Some objects loose their surface shading when added to a block (RH-81019)
    • Objects in Monochrome mode leave a silhouette (RH-82293)
    • Edges are not displayed correctly with transparent objects (RH-83229)
    • Slow display speed in Layout (RH-83061)
  • DotNET: Support running on later versions of .NET (RH-81818)
  • Layout:
    • Move or Copy layout - incorrect order (RH-83634)
    • Slower performance in a layout detail in Rhino 8 (RH-79768)
  • Print:
    • Text scaled different between vector and raster (RH-52821)
    • Rhino PDF does not print Chinese (RH-47964)
    • Special Glyphs in Arial preview but do not print to RhinoPDF in V6 and V7 (RH-59681)
  • ScriptEditor: Loading exception error (RH-83162)
  • Display: Slow performance drawing lots of curves (RH-80310)
Regressions Fixed:
  • Display: Custom material with env map created in Rhino 7 loads incorrectly in Rhino 8 Rendered mode (RH-82896)
  • Print: Leader with Japanese text Not Printing with V8 RhinoPDF (RH-79834)
SDK Enhancement:
  • SDK: Expose function behind ParseTextField to C++ SDK (RH-83723)
Rhino 8 Service Release 12 for Windows and Mac (8.12.24282) is now available
Rhino will automatically update, unless updates are disabled.
Download the latest service release now…
Bugs Fixed:
  • BlockManager: Fail to insert file with a dot in the name (RH-83562)
  • BooleanDifference: Boolean* commands unable to select blocks by layer (RH-83420)
  • BoxEdit: Remains disabled after command completion (RH-83359)
  • CPlane: AutoAlign: CPlane does not align to planar face a seam (RH-83499)
  • ClippingPlane: Custom depth doesn't work on dots & points (RH-83165)
  • Copy: Needs to Keep Detail Layer Visibility Settings (RH-83701)
  • CopyLayout: Need to Keep Original Layer Visibility Settings (RH-83485)
  • CrvDeviation: Different results on CrvDeviation (RH-81220)
  • Detail:
    • UndoView fails in Detail view for the first undoable view change (RH-83678)
    • Adding detail show not show AroundCurve option (RH-66580)
  • Display:
    • Activating Detail Sets Display mode to Wireframe (RH-83677)
    • Array Preview Messed Up with Clipping Plane (RH-83563)
    • Text dots don’t respect layer print color (RH-74199)
  • DraftAngleAnalysis: Panel at startup is missing a doc (RH-83407)
  • Eto: Search Tree still steals focus when tree is reloaded (RH-82513)
  • Export: Scripting export of SVG changes view size (RH-79117)
  • ExtendSrf: Locks up Rhino on user geometry (RH-83139)
  • File IO:
    • Missing Objects from STEP (RH-83827)
    • Error Importing GLB file (RH-83710)
    • glTF import creates bad meshes (RH-83386)
    • No Text on DXF Import (RH-83577)
    • SaveSmall missing textures (RH-83209)
    • Exporting polysurfaces (not extrusions) results in separate meshes in V8 (RH-83395)
    • PDF doesn’t print mesh as seen in the viewport (RH-69647)
  • FilletEdge:
    • Messy transition (RH-76852)
    • BlendEdge: Surface curls up (RH-83418)
    • Stacked control points and caused shading issue (RH-83398)
  • Grasshopper:
    • Util>Get Components Location and Help (RH-83564)
    • Capsule background color does not display properly in GH preview (RH-83504)
  • Grasshopper: Bake: Grasshopper: Long processing times on change of Model Block Visibility > Content Cache (RH-83545)
  • Grasshopper: Components: Mesh conversion from SubD has changed (RH-83829)
  • Groundplane: Doesn't clip edges and isocurves in Raytraced/Render mode (RH-83320)
  • Gumball: AutoReset doesn't work with the click transform (RH-83500)
  • Help: Rhino 5 links found on google need an index (RH-83135)
  • Layer: Cut and paste for layer names don't work (RH-83412)
  • Licensing: UI: Incorrect message when running .NET Core (RH-83370)
  • NamedView: Overwriting a named view does not remove "*" from viewport title (RH-83205)
  • Options: Changes to Display Modes Do Not Stick (RH-83868)
  • Panels: Right Click Menu On Tab No Longer Working (RH-83349)
  • Print:
    • Locked objects don’t print in raster to pdf (RH-83653)
    • No vector output in Pen (or other tech) mode (RH-83694)
    • Don’t make “Only Selected Objects” hide multiple layout controls (RH-83536)
    • Line widths don’t work correctly for dimension lines (RH-83328)
    • Vector output missing some textures (RH-66545)
    • Improve start and load speed (RH-83451)
    • Raytraced mode incorrectly uses OCS frame instead of mapping channel (RH-66233)
  • Rendering: Cycles Viewport: Texture of planar mapping offset (RH-76904)
    • Open file dialog closed when Materials panel auto-hides (RH-80817)
    • Multiple mapping channels used on sub-objects don’t Render (RH-75830)
  • Rendering: Post Effect: Render Window channel buttons don't work unless RenderFeature.PostEffects = true (RH-83446)
  • SDK: RhinoCommon:
    • Curve.Offset Issues (RH-83373)
    • Curve.ProjectToMesh fails in Compute (RH-83339)
  • SVG Editor:
    • Drawings on top of existing SVG doesn’t save (RH-83193)
    • Cannot Edit Toolbar Bitmap Icon (RH-83167)
    • Background SVG not saved with edits (RH-83334)
  • ScriptEditor:
    • Undo stops working (RH-83835)
    • Python library is deployed in doubly nested folder structure (RH-83764)
    • sc.escape_test does not reset between script runs (RH-83435)
  • Settings:
    • Memory leak with PersistentSettings (RH-82124)
    • Advanced Setting Causes Deselect to Fail (RH-83514)
  • StatusBar: Selected object layer shows "Varies" incorrectly in Info pane (RH-83430)
  • Sun: Rhino 8 Solar System Location Error (RH-83413)
  • SynchronizeViews: Does not work in a new layout in some files (RH-83639)
  • Toolbar:
    • Popup toolbar with text buttons not sizing correctly (RH-83572)
    • Overflow buttons don’t display well in context menu (RH-83573)
    • Custom ItemDisplayStyle Lost (RH-83574)
  • UI Appearance: OBJ import dialog is not dark (RH-83908)
  • WireCut: Does not Use Groups (RH-83465)
Crashes Fixed:
  • Display: Arraying a block crashes Rhino (RH-84055)
  • Grasshopper: Grasshopper.GUI.MRU.GH_FileEntry.ResolveFileState_Threaded () (RH-83415)
  • Offset: Crash with no reporter (RH-83606)
  • SVG Editor: Crash when selecting (RH-83939)
Enhancements:
  • Detail: Added display mode setting to detail view properties (RH-81788)
  • File IO: Scripted export to SVG no longer displays a dialog box (RH-62643)
  • Grasshopper: Components: Model Object Point not casting to point in the Average (arithmetic mean) Component (RH-83309)
  • Keyboard Shortcuts: Allows sorting shortcut list (RH-83740)
  • Layer: Added Expand and Collapse options to -Layer command (RH-83351)
  • LayerStateManager: Added "Expanded" checkbox (RH-83352)
  • Print: Added commonly used 1-1/2" = 1’-0" to built-in print scale list (RH-69140)
  • Properties: Display color now applies to whole mesh when mesh subobjects are in selection (RH-83409)
  • Rendering: Improved default date and time in Sun settings (RH-80940)
  • SVG Editor: Allow for Pasting a bitmap (RH-83490)
  • WindowLayout: Added "Import" option to scriptable command (RH-83468)
  • Worksession: Keeps conflict materials from attached files (RH-66666)
Features Added:
  • Grasshopper: One of the most common problems with GH that I see when I teach it… (RH-37737)
  • SVG Editor: End Caps / Stroke / Colors cannot be edited during / before object is created (RH-82217)
  • ScriptEditor: Support other filetypes (RH-81609)
Meta Issue:
  • SDK: RhinoCommon: Incorrectly references ON_COMPILER_ANDROIDNDK (RH-26081)
  • Grasshopper: Components: Content Cache iterated through all blocks while in the Edit Block Command (RH-83871)
Regressions Fixed:
  • ExtendSrf: Incorrectly removes trims (RH-83317)
  • FilletEdge: Deletes a surface (RH-83934)
  • Grasshopper:
    • Error When Exploding Block with Hatch (RH-83801)
    • Apply custom string sorting for subcategories (RH-83156)
  • Grasshopper: Components: Query Model Objects behavior changed (RH-84168)
  • MergeAllCoplanarFaces: Brep.MergeCoplanarFaces returns invalid Breps (RH-83332)
  • ScriptEditor: New IronPython is much slower than legacy GHPython (RH-82474)
SDK Enhancement:
  • SDK:
    • Added JoinCurves parameter to RhinoIntersectBreps (RH-83920)
    • RhinoCommon: Exposed ON_JoinCurves (RH-83945)
  • SDK: RhinoCommon:
    • Added equivalent methods of SelParents and SelChildren commands (RH-83743)
    • MeshVertexColorList.AppendColors not Python friendly (RH-83467)
UI Change:
  • SVG Editor: Discard Unsaved changes message shows unnecessarily (RH-83358)
  • Containers: Allows right-clicking on a tab to show/hide panels or toolbars (RH-74338)
  • DraftAngleAnalysis: Suspend display while waiting for user input (RH-63112)
  • Print: Notify the User of "Printing Only Selected Objects" in print preview area (RH-82953)
  • ScriptEditor:
    • Added Undo/Redo to V8 Script Editors Find & Replace (RH-81689)
Mac-Only Changes
Bugs Fixed:
  • Commands: Option field font size jumps (RH-83493)
  • Display:
    • Groundplane is no longer an infinite plane when switching display modes (RH-83679)
    • Monochrome edges and silhouette are not clipped by shadows only ground plane (RH-83316)
  • Gumball: Extrude ball size setting is missing on Mac (RH-83388)
  • Options:
    • Mouse option out of sync with corresponding advanced settings (RH-42536)
    • UI clips settings (RH-83389)
Crashes Fixed:
  • Properties: Resizing Properties panel to a small size causes a crash (RH-83553)
  • Rendering: Hang when Rendering in progress during Quit (RH-83440)
Regressions Fixed:
  • Display Metal: Pointclouds don't display (RH-84131)
Bugs Fixed:
  • CommandHistory: Uses incorrect font (RH-66640)
  • Display: Some objects loose their surface shading when added to a block (RH-81019)
  • Layout: Slower performance in a layout detail in Rhino 8 (RH-79768)
  • Options: Advanced settings page synchronization issues (RH-83548)
  • Print: Text scaled different between vector and raster outputs (RH-52821)
  • Undo: Array creation is slow after undo (RH-83191)
Cosmetics:
  • Print: Sorting the printer list (RH-66748)
Crashes Fixed:
  • ScriptEditor: Script editor search prompt is constantly resizing (RH-83470)
Enhancements:
Regressions Fixed:
  • Block: Wrong shading in block instances (RH-79981)
UI Change:
  • Layout: Renamed "Before" to "New location" in "Move or Copy" layout dialog (RH-83634)
Rhino 8 Service Release 13 for Windows and Mac (8.13.24317) is now available
Bugs Fixed:
  • Duplicated material does not show up in Enscape material editor (RH-82603)
  • Annotation: DimAngular:
    • Annotation: DimAngle: No Selection on Detail (RH-84133)
    • Arc mode history update issue (RH-84013)
    • Make segment units stick between Rhino sessions (RH-63784)
    • Adding linetype while in inch should default to 1 inch (RH-84140)
    • Landing segment of leader not drawn with width set in linetypes (RH-84094)
    • Dimension issue with Continuous (RH-79414)
  • BlockManager: Does not report selection count in command window (RH-80103)
  • CPlane: AutoAlign: Makes strange view jumps with plan view (RH-79641)
  • ClippingPlane: Clipping section obscures polyline (RH-83783)
  • Dark Mode: Style Tree/GridView background color using WPF theme only (RH-81642)
  • Display:
    • Technical mode performance has gotten a lot worse since 8.9 (RH-84439)
    • Bad shading when arraying a block (RH-84095)
    • Pointcloud display styles don’t work on Windows… (RH-84138)
    • OpenGL preview mapping wrong (in material editor thumbnails) (RH-73993)
    • Locked Blocks Occlude When Set to be Transparent (RH-83645)
    • SendToBack Sends to Front (RH-83841)
  • EdgeSoftening:
    • Breaks sub-object material assignment (RH-83975)
    • Breaks by parent material assignment in block in Rendered mode (RH-82840)
  • ExportLinkedBlocks: Command not scriptable (RH-83699)
  • ExtendSrf:
    • Changes edge indices (RH-70644)
    • Incorrectly flip surface normal if its normal is not natural (RH-82649)
  • File IO:
    • .dae export fails when ampersand is in the file name (RH-84638)
    • DWG export plugin does not interpret the options dictionary properly (RH-84634)
    • SVG export empty file (RH-83959)
    • Conversion to SubD removes transform on FBX import (RH-83858)
  • Grasshopper:
    • Trigger component runs code while Rhino is closing (RH-83507)
    • Size of a .gh file changes depending on how the file is opened and saved (RH-82278)
    • GH_Surface::CastTo returns a plane surface instead of a trimmed Brep (RH-77173)
    • Rendered mode loses preview meshes on quality change (RH-84151)
    • Import 3D changes active view (RH-81053)
    • Removed default overrides in text entity (RH-83753)
  • Groundplane: Jumps to larger on tumble (RH-84093)
  • Gumball:
    • Added On/Off/Toggle options to GumballAutoReset command (RH-83750)
    • Should show less options in tooltip within UVEditor on UV meshes (RH-83011)
  • History: Prefixes (# and %) for one-shot history recording don't work with Aliases (RH-83798)
  • Inset: Creates Bad Object (RH-84038)
  • LayerStateManager: Continuous linetype not being restored (RH-83730)
  • Layout: Rhino Grid Settings Are Not Used (RH-83916)
  • Make2D: Unaware of English command-line option names in localized Rhino (RH-84391)
  • MergeAllFaces: Explodes a block instance (RH-59651)
  • Print:
    • Vector output prints wrong object colors (RH-84499)
    • Spaces are not Underscored in Vector PDF Output (RH-84169)
    • Section hatch ignores print widths (RH-83911)
    • Width Not Printing (RH-83745)
    • End-on lines not visible in vector output (RH-83796)
  • Properties: Select Clipped Layers (RH-83711)
  • QuadRemesh:
    • English option names starting with underline not recognized in localized Rhino (RH-84318)
    • Scriptable command missing SubDCreases and SubDCorners options (RH-83878)
  • RDK:
    • Undo deletes the entire material (RH-83897)
    • SetValues on framebuffer slow (RH-83576)
  • RailRevolve: Fixed history update problem when all input curves moved together (RH-81993)
    • Gamma is wrong in Raytraced mode (RH-84436)
    • Does not support “Parallel reflected” in Rhino 8 (RH-68891)
    • Reflection instead of shadow on shadows-only groundplane (RH-83327)
    • Bump map on ground plane imperceptible (RH-79944)
    • Show Distance Channel broken (RH-83223)
    • Issues about custom materials (RH-81725)
    • Bump texture broken for custom materials (RH-81890)
    • Raytraced stays paused after _Render (RH-82060)
    • Bump too strong (RH-84460)
    • Gamma 1.0 with linear workflow appears darker (RH-83550)
  • Rendering: Materials: Object with edge softening not updated when changing material color via Layers panel (RH-82007)
  • Revolve: History update bug (RH-72141)
  • SVG Editor:
    • SVGEditor: Thickness of 1.0 is not quite one pixel (RH-83807)
    • The SVG shows up in the wrong size and so does the toolbar button image (RH-84155)
    • Cannot import PNGs (RH-83944)
  • ScriptEditor:
    • Ensure GH docs are disposed (RH-84531)
    • Script input param tooltip shows mangled data when input is path to gh file (RH-84532)
    • -Run shows load progress but not language status (RH-84390)
    • CPython marshalling error (RH-84379)
    • GH1 editor should use last window size when opening new windows (RH-84060)
    • Rhino loses focus when closing C# editor in GH (RH-84058)
    • New file should not show GH template files (RH-84111)
    • Allow Escaping from Install Package dialog (RH-84165)
    • Updating explorer brings window to front (RH-84082)
    • List of Points shows cast error on publish component (RH-84136)
    • .md file does not update in ScriptEditor if edited externally (RH-84119)
    • Explorer flickering (RH-84081)
    • Extracted input of type Geometry Base creates floating Brep parameter (RH-84020)
    • Hangs under grasshopper (RH-83865)
    • Hitting Ctrl+W while help preview is open should close preview (RH-83891)
    • Rhino pip listens to PIP_USER global env var (RH-83985)
    • Update help preview to use new url format (RH-83551)
    • C# debugger applies switch-case local variables to all cases (RH-83950)
    • Run should only init script language (RH-83861)
    • Allow terminal to capture stdout during exec (RH-83809)
    • Published scripts do not show language loading progress bar (RH-83810)
    • Delete button does not remove missing libraries (RH-83762)
    • C# debugger throws error on if stmnt with is pattern (RH-83794)
    • Implementd rhinocode.get_python_executable() (RH-83790)
  • Section:
    • Don’t use the Group attribute of the input (RH-76578)
    • Creates hatches on voids (RH-76616)
  • SelName: <No name> incorrectly selects objects across model and layout spaces (RH-77632)
  • Shrinkwrap: Unaware of English command-line option names in localized Rhino (RH-84347)
  • SoftEditSrf: Direction constraint ignored (RH-57093)
  • Sphere: 2Point failure (RH-83895)
  • StatusBar: OrthoSnapToCPlaneZ Coammand-line Status is Wrong (RH-83773)
  • Subobject Selection: Selecting subobjects hard when isocurves and edges show (RH-83946)
  • Sweep1: Fails silently (RH-65798)
  • Toolbar:
    • VariableBlendSrf is missing from Surface Tools toolbar (RH-83909)
    • Shrinks after dragging the only tab in a floating container (RH-84063)
    • Move Y- Icon Shows Y+ (RH-83955)
    • Rounded corners left over in locked mode (RH-83929)
  • TweenCurves:
    • Creates skewed result (RH-72273)
    • Failure example when MatchMethod=Refit (RH-44892)
  • UVEditor:
    • Negative scaling causes internal errors (RH-77179)
    • Re-unwrapping flips UV islands (RH-84126)
  • UnTrim: Untrim: ReplaceEdge creates messy edges (RH-78279)
Crashes Fixed:
  • File IO:
    • Crash saving to CSV (Object properties) with blocks… (RH-84434)
    • Crash importing Assembly from 2024 SolidWorks (RH-84040)
Enhancements:
  • Annotation: Frame around text uses print width and linetype width (RH-71233)
  • Annotation: Hatch: Added SolidHatchMeshingTolerance advanced setting for controlling solid hatch mesh density (RH-83669)
  • ExtendSrf: Works with Near object snap (RH-82683)
  • Grasshopper: Added font orientation setting to AS-Text component (RH-83668)
  • Gumball: Added MergeFacesAfterExtrude option to GumballSettings command (RH-83867)
  • Layer: Changed Filter menu so right-click can enable an option and disable all others (RH-77216)
  • RDK: Select Color dialog opened from Emission material shows a list of Kelvin colors (RH-64646)
  • ScriptEditor:
    • Support single Python .PTH file (RH-84078)
    • Search and Replace Improvements (RH-82434)
    • Implemented is_interactive for published commands (RH-83849)
  • SplitFace: Accepts typing U, V or B (Both) to set direction at selecting isocurve prompt (RH-73579)
  • StatusBar: Added tooltips to Auto CPlane pane (RH-79535)
  • ToNURBS: Added options to preview and update face packs in SubDs (RH-83893)
  • UVEditor: Allows flipping UV islands by scaling of -1 (RH-83977)
Features Added:
  • ScriptEditor: Allow script to add menu items in GH1 (RH-84115)
  • UI Appearance: Hide grippers on locked docked containers (RH-80525)
Regressions Fixed:
  • Annotation: Hatch: Cannot not control pattern width (RH-75741)
  • Display: Material preview texture missing (RH-84057)
  • ExtendSrf: Failure cases (RH-83755)
  • Rendering: Texture Mapping: Does not follow moved object with CRM in Rendered view (RH-80235)
  • ScriptEditor: Incorrect rhino command and doc params in GH code (RH-84373)
  • UVEditor: Vertex constraints broken (RH-83242)
SDK Enhancement:
  • OpenNURBS: Added functions for finding spans and subdomains where a control point is active (RH-83969)
  • SDK:
    • Added a custom event watcher when getpoint receives a point (RH-84022)
    • Exposed RhinoRepairCurve to RhinoCommon (RH-83923)
    • Exposed RhinoCutUpSurface to RhinoCommon (RH-83922)
UI Change:
  • File IO: Tuned up glTF export dialog (RH-81657)
  • Toolbar:
    • ExtrudeMesh and ExtrudeSubD commands have the same icon (RH-83989)
    • Added Inset command to “Solid Tools” and “Solid Editing” toolbars (RH-83971)
  • Grasshopper: Drawing full names causes errors (RH-35790)
  • Grasshopper: Components: "Mesh From SubD" now returns control polygon for D=0 (RH-65870)
  • ScriptEditor:
    • Upgrade embedded pip (RH-83860)
    • Published Plugins create libs/ dir under ProgramFiles (RH-83843)
Mac-Only Changes
Bugs Fixed:
  • File IO:
    • Export to PDF skips symbol (RH-69280)
    • PDF export on mac doesn’t deal well with Norwegian characters (RH-72250)
    • Not working properly on Mac (RH-79192)
    • Can’t delete existing shortcuts (RH-83734)
    • Modified command macro not being used (RH-83963)
  • Layout: Mac crash on creating layout with particular Advanced setting unchecked (RH-83947)
  • Print:
    • Trimmed Picture surfaces don’t print on Mac (RH-60790)
    • Printing PDF gives different result in mac / windows (RH-83458)
    • Helvetica font not printing to PDF correctly on Mac (RH-82246)
  • PrintPreview: TextDot shows larger in Vector preview and inverted (RH-78145)
  • ScriptEditor: Fixed missing SSL certs on macOS (RH-83793)
  • Grasshopper: Parameter input keyboard shortcuts required enter or space to complete (RH-57216)
Windows-Only Changes
Bugs Fixed:
  • Eto: Setting TextBox.Text can sometimes throw exceptions (RH-83744)
  • Grasshopper: Poor SubD display in V8 (RH-84066)
  • Panels: Importing Linetypes Crashes Rhino (RH-84427)
  • Properties: Panel icon change in size when selected (RH-83915)
  • SVG Editor: Imported SVG gets cropped (RH-83957)
  • ScriptEditor:
    • Different behaviour when activating debugger (RH-84123)
    • Displaying help crashes (RH-83883)
  • WindowLayout:
    • Switching from default window layout to rendering or drafting and back causes repeatable crash (RH-84134)
    • Rhino becomes inaccessible after changing print color (RH-83887)
Crashes Fixed:
  • Display: Crash drawing large point cloud (RH-83818)
Enhancements:
  • DotNET: Failover to use .NET 8 automatically when v7 is not installed (RH-84023)
  • SystemInfo: Added GPU Tessellation State (RH-84033)
Tasks Completed:
  • SDK: C++ code sample: history and edit (RH-75629)
Rhino 8 Service Release 14 for Windows and Mac (8.14.24345) is now available
Bugs Fixed:
  • DocumentProperties RenderSettings edit dialog for contents are not the topmost window. (RH-84585)
  • Annotation: Linetype: Pattern segments fail localization (RH-84828)
  • Autocomplete: Suggests Unused Commands First (RH-84565)
  • ChangeLayer: Key navigation not working properly (RH-77139)
  • ClippingPlane:
    • Depth grip-point does not show in clipped view (RH-84355)
    • Section fills incomplete (RH-81388)
    • Cap failure case (RH-84176)
    • Strange behavior (RH-84301)
    • Clipping fill missing after dragging (RH-83092)
    • rs. RestoreNamedView does not restore clipping planes (RH-84218)
  • CommandHelp: Pressing F1 does not open topic for BlendCrv command (RH-84150)
  • Contour: History replay changes locked state (RH-84340)
  • CopyLayout: Does not update object ID in text fields (RH-84691)
  • Displacement: RhinoRender fails to render displaced mesh if the async is not finished (RH-84370)
  • Display:
    • Curve drawing preview invisible when GPU Tessellation is Off (RH-84709)
    • Disabled Alpha is not used correctly in Rendered mode or Raytraced (RH-84450)
    • Custom lighting not exported (RH-84416)
    • Ground plane appears in technical modes when Shadows-Only is ON (RH-84533)
    • Shade-highlight selected doesn’t work with Raytraced (RH-84425)
    • Scriptable version of ViewportProperties command missing “Parallel Reflected” option (RH-83640)
    • Custom Preview and Create Material cause display issues (RH-82108)
    • Blocks on locked layer show locked color (RH-84365)
    • Grasshopper Text Tag Issue (RH-84255)
    • Curve invisible while drawing in clipped scene (RH-80197)
    • Display mode does not load correctly (RH-84129)
  • Docking: Re-parented Rhino cannot resize docked containers (RH-84819)
  • DocumentProperties: In Render settings, creating a new ground plane material is not directly assigned (RH-84586)
  • Explode: Text exploded with "model space scaling" when it is disabled (RH-84650)
  • File IO:
    • SaveSmall incorrectly shows option checkboxes in Save dialog (RH-84487)
    • GLB Export Failing (RH-84432)
    • Physically Based Material to OBJ (RH-84157)
    • glTF import sets AO, Roughness and Metallic textures to wrong channels (RH-84269)
    • glTF import crops textures (RH-84268)
  • Grasshopper:
    • Shows “You have unsaved documents” when gh file is already saved (RH-81306)
    • Space morph components do not work with instance objects (RH-84615)
    • Content Cache Push Doesn’t Update Material Data (RH-84658)
    • Text Value overridden to 1 still returns null (RH-84330)
  • GrasshopperPlayer:
    • Plugin doesn’t run when launched the second time (RH-84943)
    • Fixed ghosting issues (RH-66768)
    • Frozen UI on compiled Grasshopper scripts (RH-84801)
    • Does not show default value (RH-84551)
  • Gumball: Resets after running GumballRelocate in Subobject selection mode (RH-84593)
  • Help:
    • UV Editor straightening help wrong (RH-83260)
    • Added notes about polysurface to Trim and Split command topics (RH-84408)
  • Intersect: Brep x Brep Intersection flips direction at seam (RH-83968)
    • Allow overriding system shortcuts for Cut/Copy/Paste/Select All (RH-5243)
    • Ctrl+Alt+F1 runs macro of Ctrl+F1 (RH-3701)
    • Keyboard Shortcut: Text in Shortcut Editor needs fine-tune (RH-84294)
  • Layer:
    • Clicking “Detail On” does not sort layers (RH-84331)
    • No Filter When In Layout (RH-84461)
    • Tooltips don’t work in Layer manager (RH-83331)
  • Layout: Incorrect page size for "ARCH E" (RH-84550)
  • Lights: Changing light intensity deselects light (RH-84673)
  • LineTypeDisplay: Round caps might show flat (RH-78420)
  • MergeFace: Fails when seams of 2 adjacent faces aligned (RH-58849)
  • Mesh:
    • Does not remember previous simple/detailed state (RH-84686)
    • Preset saving over existing issue (RH-84351)
  • MeshPatch: Create Concave Mesh (RH-84670)
  • OSnap:
    • Should not snap to occluded clipping edges (RH-84337)
    • Not working with drag behind clipping section (RH-83919)
  • Paste: Copied textfield does not update to reference copied object (RH-84692)
  • Print:
    • Curves Print As Hatch Dots (RH-84872)
    • Clipped objects appear open in Vector output (RH-82145)
    • Vector output ignores linetype taper (RH-84536)
    • Curve in Block Doesn’t Use Print Color (RH-84344)
  • Properties:
    • No Scrollbar on Layer Pulldown (RH-84648)
    • Can’t Scroll Entire Layer List (RH-84544)
    • Layer popup goes off screen (RH-83378)
  • QuadRemesh:
    • Scriptable command does not wait for picking more objects (RH-84387)
    • Creates duplicate mesh (RH-84220)
  • RecordAnimation: invalid JS for animations with dates (RH-84295)
    • Jiggle factor incorrect, leading to gaps (RH-84866)
    • Spotlight casts an elongated stripe over the entire scene (RH-84852)
    • Uses incorrection projection for environment textures in materials (RH-84799)
    • Ambient Occlusion doesn’t work (RH-84519)
    • View scaling not taken into account (RH-84428)
    • Missing random objects (RH-84299)
  • Rendering: Materials: "Select All" incorrectly selects materials hidden by filters (RH-84458)
    • Intel denoiser doesn’t have time to denoise before render finishes (RH-73339)
    • Do not execute until rendering finishes (RH-84336)
    • Denoise post effect bug with Bloom (RH-84312)
    • Cannot apply OCS mapping in script (RH-84574)
    • SubD losing mapping in Rhino 8.10 update (RH-83593)
  • SDK: Python: rs.AddPictureFrame raises exception (RH-84502)
  • SDK: RhinoCommon: Memory leak in DrawSprite (RH-74126)
  • SVG Editor:
    • Selector button is black in Rhino light mode (RH-84885)
    • Adds a duplicate version attribute (RH-84304)
    • Darkmode preview shows only a white silhouette (RH-84170)
    • Copy / Paste not functioning (RH-84446)
  • ScriptEditor:
    • C# library language does not update (RH-84689)
    • Disable gh document after script is executed in Grasshopper1Code (RH-84530)
    • Published component should not draw previews on itself (RH-84528)
    • C# library is not compiled and added to python commands in project (RH-84426)
    • Project remove library does not work (RH-84492)
    • Does not pay attention to PreRelease check (RH-84604)
    • Project library is not added to codes that are already open (RH-84429)
    • Hidden published commands shown in toolbar (RH-84578)
    • Node in code result can not be expanded like IronPython (RH-84572)
    • C# not completing items after ‘.’ in some contexts (RH-84410)
    • Python not completing items after ‘.’ in some contexts (RH-84233)
    • Expire cached GH_Document when Rhino active doc changes (RH-84632)
    • CPython language server fails reading large data (RH-84618)
    • Roslyn should use netfw ref assemblies to compile on netfw Rhino (RH-84389)
    • Adding multiple scripts of same name can cause conflicts (RH-83900)
  • SelName: Reports deleted items (RH-84298)
  • Snapshot: Scriptable command does not generate last thumbnail (RH-84184)
  • Sweep2: Scriptable command does not handle "maintain height" correctly (RH-84480)
  • Toolbar:
    • RUI shipped with RHP in YAK package fails to load (RH-84575)
    • Icon editing does not work in toolbar properties (RH-84652)
  • UVEditor:
    • Mirror does not work on UV mesh (RH-80732)
    • Error dialog when copy-pasting curves (RH-77462)
  • Undo: Changes Layer Visibility in Details (RH-83914)
  • ViewCaptureToClipboard: View capture color does not work correctly with scaling (RH-83315)
  • Viewports: Viewport: Two point perspective not working (RH-83697)
Cosmetics:
  • Annotation: Improved alignment for stacked fractions (RH-56856)
  • Icons: White curves in icons are almost invisible to the eye (RH-50625)
Crashes Fixed:
  • Annotation: Hatch: Deleting hatch grip crash (RH-85086)
  • BlockManager: Crash When Docked (RH-84249)
  • Keyboard Shortcuts: Crash when messing with Keyboard shortcuts (RH-84272)
  • Layer: Layer table window not updating and crashing (RH-84451)
Enhancements:
  • Animation: RecordAnimation command remembers target folder in current session (RH-76601)
  • DupLayer: Update object ID when a text field is copied with its referenced object (RH-84573)
  • Keyboard Shortcuts: Improved feedback messages (RH-84676)
  • LoadPlugin: Support multi-targeting with GH plugins in libraries folder (RH-84510)
  • Mesh: Added system units to physical distance meshing parameters (RH-46808)
  • PluginManager: Allows clicking on a checkbox to enable/disable selected plug-ins at once (RH-84466)
  • PointsOn: Allows showing more than one million control points (RH-84462)
  • RecordAnimation: Allows setting default target folder in Advanced settings (RH-79386)
  • RelocateGumball: "Align to View" remembers Gumball position for object in current app session (RH-84453)
  • ScriptEditor:
    • Implement IGH_DocumentOwner on published component (RH-84523)
    • Published component to look at optional property of inputs (RH-84579)
    • Support expanding list returns into multiple outputs (RH-84235)
  • Shrinkwrap: Added SaveSettings command-line option to scriptable command (RH-84236)
  • TextField: Update object ID when a text field is copied with its referenced object (RH-84489)
Features Added:
  • Grasshopper: Allows baking a view to a Rhino Named View (RH-81517)
  • Print: Added scale setting for text dots to Print dialog (RH-47981)
Incomplete Port:
  • Print: Missing "Text dot font size" setting in Print dialog (RH-71644)
Regressions Fixed:
  • Arctic display: Incorrectly shows colors (RH-84211)
  • Block: Locking Mirrored Copy Locks All (RH-84602)
  • Copy: UseLastDirection cannot be turned off (RH-84287)
  • RDK: Rhino.DocObjects.Texture.UvwTransform is not working (RH-80966)
  • Rendering: Materials: Layer Texture Edits Incorrectly Saved (RH-84024)
SDK Enhancement:
  • SDK: RhinoCommon:
    • Allows querying if a hatch pattern is used by the model (RH-84738)
    • DefinedViewportProjection add Reflected Ceiling Plan (RH-84231)
    • Added RevCloud method (RH-84353)
    • Added TweenSurfaces function (RH-35494)
  • ScriptEditor:
    • Capture Environment.Exit() in Roslyn code (RH-84640)
    • Throw CommandExit with Command result as input value (RH-84633)
UI Change:
  • Gumball: Hide RelativeHandlePositionMultiplier for absolute scale handles (RH-84161)
  • Properties: Hide transparency setting for per-face colors (RH-84784)
  • Mesh: Selecting Jagged and Faster / Smooth and Slower now switches to Simple Controls (RH-84108)
  • ScriptEditor:
    • Use same last uri for Open and Save operations (RH-84680)
    • Made preview tab more obvious as Preview (RH-84556)
    • Scrollbars is made wider (RH-84628)
    • Cleanup Tools > Script > Run (RH-84595)
Mac-Only Changes
Bugs Fixed:
  • AutoSave: Disabled -> Warns About Saving Too Frequently (RH-84513)
  • CopyToClipboard: Copy and paste are slow on Mac (RH-84516)
  • Display:
    • Setting custom light color fails (RH-84491)
    • Technical mode shadows are busted on the Mac (RH-84257)
    • Shadows cannot be set to ignore clipping planes (RH-78308)
    • Width scale not used (RH-80350)
  • Display Metal: Solid clipping plane cap has transparency (RH-79419)
  • Grasshopper: Cmd+0 doc switching doesn't work (RH-80223)
    • Control Key Doesn’t Work (RH-84540)
    • Regression in CMD+A in command line (RH-84325)
  • Print: Underlined Text Is Not Underlined In Print Preview (RH-84276)
  • UI Cleanup: Settings panel size keeps changing (RH-73702)
Enhancements:
  • File IO: DWG/DXF Export Support AutoCAD 2010, 2013, & 2018 on Mac (RH-77489)
  • Settings: Document settings dialog is made resizable (RH-62735)
Regressions Fixed:
  • Keyboard Shortcuts: Home / End keys not working (RH-84809)
UI Change:
  • Options: Settings on Mac needs a tune up (RH-67860)
  • UI Appearance: File > Settings on Mac should do a better job of showing all sections (RH-65796)
Bugs Fixed:
  • Core bugs: Semi model dialog issue when Rhino is re-parented (RH-84865)
  • Dark Mode: Dock Bars Panel is Not in Dark Mode (RH-84395)
  • Display: Surface Edge Settings not updating (RH-84515)
  • Keyboard Shortcuts: Alt+(*) should be always invalid (RH-84474)
  • Layout:
    • Clicking away from a floating viewport into a layout performs a double-click (RH-84418)
    • Rhino hangs when switching to layouts (RH-84097)
  • LoadPlugin: .NET 4.8 plugin fails to load (RH-84187)
  • Options: Surface Edge Settings not marked as changed (RH-84369)
  • ReduceMesh: Mesh won't reduce without preview (RH-84405)
  • Rendering: Content Panels: Video Texture's section goes over the Material area (RH-84341)
  • SVG Editor:
    • Takes long time to load and takes away system resources (RH-84791)
    • Does not save changes (RH-84352)
  • ScriptEditor: .md file open blank if edited externally (RH-84159)
Features Added:
  • Notes: Remembers text cursor location when Notes panel regain focus (RH-23213)
  • RhinoOffsetCurve() causes a Rhino 8 hang in some situations (RH-84100)
Regressions Fixed:
  • DocumentProperties: Stuck on the Render page (RH-84744)
  • Print: Rhino Print to New Epilog Driver Regression (RH-84786)
Rhino 8 Service Release 15 for Windows and Mac (8.15.25013) is now available
Bugs Fixed:
  • Tags are crashing in the textures panel (RH-85018)
  • BlockEdit: Pop up a warning when called from a python script (RH-84753)
  • BoxEdit: Scrolling in a value box also scrolls the panel (RH-79594)
    • Text selection highlight not visible when the line has an error message (RH-81933)
    • Error line gets copied with copy/pasted code (RH-84860)
  • Displacement:
    • ExtractRenderMesh intermittently not working for Displacements (RH-85220)
    • Black point adjustment requires view to change for update (RH-77345)
  • Display: Grasshopper Preview in Artic mode fails on complex geometry (RH-85072)
  • Edit Dimension: Aligned Dimension not staying on dimension plane (RH-85028)
  • File IO: Pasting Causes Error Missing Patches (RH-84407)
  • FilletSrf: Left a gap at closed seam (RH-83961)
  • FilletSrfToRail:
    • Incorrect preview in Rendered mode (RH-72315)
    • Fails if curve ‘sticks out’ (RH-82294)
  • Flip: Does not work on a surface if a point is also selected (RH-84825)
  • Grasshopper:
    • Custom Preview of Annotation Dots with Color (RH-84248)
    • Multi-save is confusing and causes loss of edits (RH-84507)
    • Contextual geometry input returns objects twice (RH-82338)
  • Gumball: Extrude is slow with many objects (RH-84804)
  • History:
    • Edge indices mess up History replay (RH-84972)
    • Dim on Model Section and Paper Update Issue (RH-84750)
  • Keyboard Shortcuts: Dialog needs focus (RH-84730)
  • Layer: Material name and preview don't refresh (RH-85168)
  • MatchProperties: Hatch Border is Missed (RH-84858)
  • Mesh: Changing Mesh dialog from Simple to Detailed doesnt stick when returning (RH-85081)
  • NamedSelections:
    • NamedSelections not updated after undo of delete (RH-84496)
    • UI refresh lags script (RH-84774)
  • NamedView: Animation jumps at last frame (RH-83752)
  • OSnap: No Snap in Clipped Scene (RH-84977)
  • PlaceCameraTarget: Tilts view if negative Z axis is up (RH-85043)
  • PointDeviation: Performance and UI issues (RH-85003)
  • Print: Ignores Section Style Boundary Scale (RH-84895)
  • Project: Loose option not creating periodic output from periodic input (RH-84803)
    • Object appears black when geometry lacks UVs and use anisotropy (RH-85008)
    • Alpha in custom material broken (RH-84849)
    • Background color too dark (RH-84939)
    • RhinoCycles: Transparency texture not applied correctly (RH-84976)
  • Rendering: Textures: Replace texture map doesn't work (RH-84983)
  • Rhino Inside: Published GH commands do not work until Grasshopper is loaded (RH-84726)
  • SDK: RhinoCommon:
    • Exploding a block gives document controlled objects (RH-48919)
    • CreateFromPolyline Failure Sample (RH-84302)
    • Projection and TextureSpace missing from TextureMapping (RH-84773)
  • SVG Editor:
    • SVG import shows blank (RH-84906)
    • Eating up polylines (RH-84212)
    • Scales Strangely (RH-84447)
    • ViewBoxes do not scale correctly for nested SVGs (RH-84795)
    • ViewBox is not respected correctly (RH-84122)
  • ScriptEditor:
    • Reported syntax error not shown in Script Editor (RH-84554)
    • C# async code compile error (RH-85085)
    • C# autocompletion does not suggest useful stuff anymore (RH-85098)
    • Python3 stub maker errors on CurveComponent dependency (RH-85070)
    • GH editor console collapses when info and warning buttons are clicked (RH-84867)
    • Allow unsafe code in C# scripts (RH-84779)
  • Section Style: Hatch Patterns Display and Print Over Boundaries (RH-84883)
  • Selection: Sub-Object Edge Loop Selection - Odd Behavior (RH-84736)
  • ToNURBS: SubD ForceUpdateFacePacks breaks ToNurbs (RH-84973)
  • Toolbar: YAK package fails to update RUI file (RH-84576)
  • Undo: Wlow when material tab is open (RH-84959)
  • Unwrap: Added ShowEnds option to display endpoints on selected seams (RH-84969)
  • Worksession: Crash when attaching DWG files (RH-84824)
Crashes Fixed:
  • File IO:
    • Hang while reading PDF files (RH-85035)
    • PDF Import can cause Rhino to hang (RH-85026)
  • Rendering: Cycles: Crash when wallpaper file isn't set (RH-85149)
  • ScriptEditor:
    • Typing fast causes a crash (RH-84999)
    • Crash with string replace in monaco editor (RH-84989)
Enhancements:
  • CPlane: AutoAlign: AutoCPlane now aligns to a planar surface edge (RH-84890)
  • Centermark: Allows selecting objects in detail views from a layout (RH-62512)
  • Circle: "FitPoints" option in all circular-based commands support picking a group of points (RH-84952)
  • File IO: DWG/DXF Export uses relative paths for saving image files used by Picture objects (RH-46885)
  • OSnap:PerpTo: Treat Perp-Cen osnap pair the same as Near-Cen pair (RH-84904)
  • ScriptEditor:
    • Added RunWithGHPlayer to project commands from gh files (RH-84116)
    • Support hover in Python 3 (RH-85077)
    • Made code snippets togglable - default off (RH-84861)
    • Provide toggle to turn off C# snippets (RH-84863)
    • Font variations does not work in new script editor (RH-78080)
    • Added collapse all in debug variables (RH-82352)
    • Debugger does not capture class props in local scope (RH-81598)
  • SelNonManifold: Supports selecting Non-Manifold meshes (RH-84814)
  • UserText: Changed sorting order of Block attribute / Text field / Plain text (RH-84770)
Features Added:
  • Radius: Allows evaluating radius on clipping section edges (RH-85127)
Performance Improvements:
  • Layer: Cache Layers panel images (RH-85053)
Regressions Fixed:
  • Displacement: Sub-object workflow regression (RH-82114)
  • Display: Inverted bitmap drawing (regression)… (RH-85324)
  • ExtendSrf: Locks up Rhino (RH-84459)
  • Grasshopper: "Curve | Self" component fails (RH-84675)
  • Mesh: Options > Mesh doesn't apply preset in simple mode (RH-85389)
  • Rendering: Materials: Editing Dialog Stays on Top of All (RH-85188)
  • Subobject Selection: Picking vertices in SubD / Shaded mode is awful in 8.15 (RH-85196)
SDK Enhancement:
  • RDK: Added an API to get the content editor selection (RH-84443)
  • SDK: Added a new RhinoSeparateBreps function to C++ SDK (RH-85074)
  • SDK: RhinoCommon:
    • Support saving a pattern as a pat file (RH-31342)
    • Exposed CRhinoObjRef::SubDVertex (RH-85079)
  • ScriptEditor:
    • Support special project variables in script components (RH-84900)
    • Update pythonnet to 3.4 (RH-84780)
  • Mesh: Preview mesh appearance is based on display modes and ignores object display colors and materials (RH-84741)
  • ScriptEditor:
    • Python 3 to set locale before running script (RH-81130)
    • C# scripting: add assemblies to code completion provider on the fly (RH-72523)
    • Should not complain about missing specials in commands (RH-83901)
    • Project Command help needs to be there for end users (ACADIA 2024) (RH-84722)
    • Component source gh file does not open on dclick (ACADIA 2024) (RH-84719)
Mac-Only Changes
Bugs Fixed:
  • CommandHistory: Does not scroll to the bottom (RH-73417)
  • CommandPrompt: Undocked command prompt requires extra click (RH-76524)
  • Display:
    • Zooming in and out makes some hatches move around (RH-85025)
    • Clipping plane affects selection window outline (RH-85054)
    • Switching to Custom Display Mode crashes Mac (RH-84982)
  • Grasshopper:
    • Mesh Edge Preview Requires View Update (RH-84870)
    • Button states don’t work well in Mac OS 15.0.1 (RH-84703)
  • Layout: Column width in Layouts panel does not stick on Mac (RH-85105)
  • Rebuild: Span count missing label when rebuilding curves on Mac (RH-83981)
  • SVG Editor: Have to press Cancel twice (Mac) (RH-84748)
  • SetPt: Needs two clicks in viewport when CurvatureGraph is active (RH-71507)
  • Text: Focus moves to Command-line when editing text (RH-85059)
  • Viewports: Viewport: Takes 2 clicks to activate UV Editor viewport on Mac (RH-80982)
Crashes Fixed:
  • Rendering: Materials: Crash occurs when editing an instanced child texture (RH-55423)
Regressions Fixed:
  • Export: STL export settings have too much padding (RH-85240)
  • Grasshopper: Improving editing of long layer names in Geometry Pipeline (RH-67813)
  • UI Cleanup: Improved accessibility of command options (RH-84437)
Bugs Fixed:
  • ChangeLayer: Dialog size is reset by Purge command (RH-78621)
  • Dark Mode: SaveAs PDF custom units not visible (RH-69622)
  • Document UserText: Hang When Collapsed Sidebar is Used (RH-85042)
  • Installer: Zoo server registry key is deleted when updating Rhino (RH-85020)
  • RDK: Bogus (.jpeg) and (.tiff) entries in drop-down list (RH-84800)
  • Rendering: Texture Mapping: Texture mapping Properties page delays viewport manipulation (RH-85323)
  • TextObject: Toggling case setting resets font to Arial (RH-47587)
Regressions Fixed:
  • Display: Curve display regression in Parallels (RH-84957)
Rhino 8 Service Release 15 Hot Fix 1 for Windows and Mac (8.15.25019) is now available
Regressions Fixed:
Rhino 8 Service Release 16 for Windows and Mac (8.16.25042) is now available
Bugs Fixed:
  • Material duplicate and undo breaks the material. (RH-85860)
  • Analysis: EdgeContinuity: Distance-only labels show angles (RH-85117)
  • Annotation: Section curves in Details are not pickable (RH-85219)
  • BlendSrf: History: Replay issue with closed edges (RH-66364)
  • Block: Inserting block through scripting changes ID order in the model (RH-85134)
  • BooleanUnion:
    • Failure example (RH-73000)
    • BooleanUnino: Fails in v8, but works in v7 (RH-85345)
    • MergeCoplanarFaces=Yes causes naked edges (RH-85347)
    • Fails but intersection curves are closed (RH-31085)
  • ClippingPlane:
    • Clipping edge in segments (RH-80324)
    • Creates an incomplete section from a low-angle intersection (RH-76479)
    • Text dot in block not properly clipped (RH-83833)
    • Cap failure case (RH-76494)
    • No cap is produced (RH-77020)
    • Missing clipping fill in a case (RH-80658)
    • Intersection is incomplete (RH-85563)
  • Code Editor Control: Don't show single spaces between words when showing whitespace (RH-85303)
  • CommandHelp: Help: Remove header from help panel (RH-85598)
  • Connect: Incorrectly converts NURBS curve to Arc (RH-85447)
  • Developer Tools: New Rhino Command in Visual Studio Code defaults to CPP (RH-84112)
  • Displacement: ExtractRenderMesh intermittently not working for Displacements (RH-85220)
  • Display:
    • Control polygon of SubD and NURBS objects displays with different thicknesses (RH-85373)
    • Clipping plane section is not drawn after pressing Esc key (RH-77090)
    • Selected edges are not displayed when not participating in clipping (RH-77222)
    • PrintDisplay Does Not Show Edge Width (RH-84273)
    • Feedback drawing is incorrect when holding Ctrl key before dragging object (RH-85298)
    • Selected edges not visible when they point straight towards view (RH-85106)
    • Explode Makes Object Invisible (RH-85131)
  • ExtendSrf: Surface fails to extend with numeric distance input (RH-85135)
  • File IO:
    • Files Open Fine in RH7, Not in RH8 (RH-85040)
    • Missing ACAD Import UI on Mac (RH-85409)
    • Imported STEP File Exports Empty to SKP (RH-85461)
    • Import DWG Also Sets Material for Existing Layers (RH-85449)
    • Rhino.FileIO.FileObj.Write does not pay attention to FileObjWriteOptions.MapZtoY (RH-85213)
  • FilletSrf: Need to remember the entered radius even if the command is canceled (RH-85383)
  • Grasshopper: Components that don't show location (RH-70738)
    • Right Click bake on Model Object only updates 1 branch (RH-85560)
    • Typo in Annotation Text Settings component (RH-85497)
    • Boundary Volume working differently in R6? (RH-46351)
  • Gumball: Strange cylinder created with Extrude dot (RH-85280)
  • Help: RenderAddDecal command doesn't exist (RH-85382)
  • History:
    • One shot toggle not working with aliases (RH-85379)
    • SelParents should not select objects with missing parent objects (RH-85430)
  • Intersect:
    • Incomplete Intersection (RH-49219)
    • Intersecting points of breps do not get calculated (RH-19235)
  • Keyboard Shortcuts: Allows creating shortcuts with 4 and 5 key combinations (RH-79635)
  • Offset: Preview color doesn't update when current layer is changed in command (RH-85157)
  • Print:
    • Color of Block Objects is Not Print Color (RH-85167)
    • Block Print Color “By Parent” Not Being Printed or Previewed (RH-85372)
  • RDK: Quickpreview does not use the cached texture produced by the render viewport (RH-85183)
  • RelocateGumball: Failed with Text (RH-85082)
  • Rendering: Loading textures from Google Drive takes longer to initialize (RH-85181)
  • Rendering: Cycles: Tone mapping settings not updating in GUI and running Raytraced (RH-84848)
    • Preview in floating editor is limited (RH-85432)
    • Extremely slow when loading thumbnails (RH-85019)
    • Cannot set IOR below 1.0 for PBR materials (RH-85339)
  • Rendering: Realtime SDK: Realtime display modes looping with edge softening in blocks (RH-85152)
  • ScriptEditor:
    • rs.GetObectEx fails when objectlist is supplied (RH-85381)
    • Async void RunScript fails to populate arguments (RH-85144)
    • Variable sorting in debug does not match between py3 and 2 (RH-85275)
    • LanguageSpec should ignore case but it does not (RH-85270)
    • Project new command file won’t reference libraries until Rhino is restarted (RH-76623)
    • Autocompletion does not work before GH script instance class (RH-85193)
    • Comments after methods prevent compiling (RH-85148)
    • Failing to write component.json file stops user from using script component (RH-85147)
  • SDK: RhinoProjectToPlane not deforming curves (RH-85269)
  • Subobject Selection: Doesn't work properly for SubD faces (RH-85024)
  • SVG Editor:
    • Cannot change stroke width (RH-85294)
  • Toolbar:
    • Do not change Recently Used toolbar when a command already on it runs (RH-85141)
    • : Clicking the latest button on the Recently Used tools crashes Rhino (RH-85571)
  • Unwrap: Added hidden SubDLevel option to select mapping mesh density for SubD (RH-85014)
  • UVEditor:
    • Constraints are broken (RH-85454)
    • Only unused UV islands are highlighted (RH-85264)
    • Mesh object UV islands not drawn with Unused color (RH-85263)
Crashes Fixed:
  • UVEditor: Crash with AsRigidAsPossible unwrap method (RH-85073)
Enhancements:
  • Annotation: DimRadial: Allows dimensioning along clipping section edges (RH-84711)
  • Display: Force Sweep1, Sweep2, Loft show isocurves in preview (RH-85132)
  • Extrude: Typing Zero sets extrusion distance by snapping to current CPlane origin (RH-85232)
  • File IO: Added the repeat value to OBJ MTL file (RH-61731)
    • Added a new “Quad Remesh Settings” component that includes “Target Edge Length” option (RH-85355)
    • Treat unconnected values like Null values in Model Content components (RH-85360)
  • Layer: Improved scrolling smoothness for a large number of layers in Layers panel (RH-78609)
  • ScriptEditor: Implement Assert component for GH2 (RH-85482)
  • SDK: Allow RhinoApp().Print() to be routed to stdout (RH-85039)
  • Split: Made scripts work regardless of what's pre- or postpicked (RH-85367)
Features Added:
  • Chat: New command (RH-85453)
  • ScriptEditor: Implement script component for Grasshopper2 (RH-83510)
  • SelectionFilterEnable: New command (RH-85209)
Incomplete Port:
  • Grasshopper 2: Migrate GH2 from .NET Framework 4.8 to .NET Core 7.0 (RH-81669)
Regressions Fixed:
  • ExtendSrf: A failure case (RH-85400)
  • Grasshopper:
    • ShouldDrawPreview Changes Breaks Rhino.Inside Application (RH-85828)
    • Extrusion can not convert to Extrusion anymore (RH-85313)
  • Grid: Z axis stays visible when CPlane grid is turned off (RH-85495)
  • Rendering: Zoom to cursor position does not work in Render window (RH-85165)
  • SelectionFilter: Closing Selection Filters panel should disable all filters (RH-85198)
SDK Enhancement:
  • Analysis: EdgeContinuity: : Allow access to EdgeContinuity calculations in C++ (RH-85153)
  • Rendering: Exposed new method for Deleting Channel (and Widget) from Object (RH-85002)
  • SDK:
    • Display panel not triggering DisplayPipeline.DisplayModeChanged event (RH-85456)
    • Added function for PushPull extend (RH-85004)
Tasks Completed:
  • Grasshopper 2: Created Nuget Package and Templates (RH-84521)
UI Change:
  • Grasshopper: Created icons for Export/Import Hatch Patterns components (RH-85191)
  • Stitch: Prevent selecting same edges twice (RH-62027)
Mac-Only Changes
Bugs Fixed:
  • Chat: Window disappears on 2nd monitor (RH-85643)
  • Core Architecture: Unsaved changes inconsistency when Layouts present in file (RH-78629)
  • Display Metal:
    • Selection highlight inconsistent between Viewport and Floating Viewport on Mac (RH-80685)
    • Materials can change when manipulating the view on Mac (RH-85204)
  • Layout: New layout dialog does not read paper sizes from printer properties (RH-85227)
  • Notes: Gets deleted when opening other file (RH-80829)
  • Viewports: Viewport: New floating viewport UI glitch (RH-84324)
  • Grasshopper: Slower performance in Rhino 6 than Rhino 5 with some components (RH-53015)
Regressions Fixed:
  • Analytics: Running an analysis command cancels the other (RH-85154)
  • ScriptEditor: Does not allow for running script with args (RH-85226)
Bugs Fixed:
  • Block: Adjusting width of block creation dialog doesn't resize controls (RH-85391)
  • Display: Hatch patterns get overdrawn by clipping fill (RH-77541)
  • Grasshopper: Panels treat empty strings different between R5 and R6. (RH-45547)
  • Layout: New layout dialog does not read paper sizes from printer properties (RH-73618)
  • PackageManager: System.Runtime.Caching not found when running "yak.exe --source" on Windows (RH-85602)
  • Rendering: Undo is delayed by 3 seconds (RH-85242)
  • Rendering: Materials: TreeView in content editor jumps when adding a new material (RH-85163)
  • SDK: RhinoCommon: .NET Semi Modal dialogs don't work in re-parented Rhino (RH-85097)
  • SelectFilter: SelectionFilter: The panel may flash slowly when selecting unselectable object types (RH-85491)
  • SelectionFilter: Steals focus (RH-85366)
  • SVG Editor: Shows File twice on menu bar (RH-83333)
  • UI Appearance: Docked Selection Filters panel keeps showing the >> arrows (RH-71596)
Crashes Fixed:
  • Rendering: Materials: Searching for materials crash in Tree view (RH-85595)
