brian
(Brian Gillespie)
April 27, 2021, 9:55pm
21
Rhino 7 SR6 Release Candidate 3 for Windows and Mac (7.6.21117) is now available
To get it, subscribe to the Release Candidate update stream on Windows or on Mac .
Bugs Fixed:
MeshTrim: MeshSplit: Does not complete (RH-63887 )
SubD Symmetry: Fixed Radiate failure example (RH-63888 )
Crashes Fixed:
PointCloud: Transforming a large point cloud several times caused memory leak and crashed Rhino (RH-62530 )
SubD: nfriend Command: opennurbs!ON_NurbsCurve::SubDFriendlyTag – Access Denied (RH-63928 )
Mac-Only Changes
Bugs Fixed:
Grasshopper: Right-click did not bring up context menu on secondary monitor (RH-63853 )
Windows-Only Changes
Bugs Fixed:
Display: OptionsImport: Display modes lag when imported (RH-63242 )
Installer: Installer reboots during install (RH-63974 )
brian
(Brian Gillespie)
May 4, 2021, 9:13pm
22
Rhino 7 SR6 Release Candidate 4 for Windows and Mac (7.6.21124) is now available
Bugs Fixed:
Display:
Symmetry settings controlled appearance of Radiate parent, but Reflect child (RH-64019 )
Colors of Reflect and Radiate objects were slightly different (RH-64021 )
File IO: Scripted .PLY export fails (RH-64061 )
Regressions Fixed:
Display: Reflect preview loses render mesh on faces during edit (RH-63079 )
Mac-Only Changes
Crashes Fixed:
Mesh: Meshing causes Rhino to crash (RH-56932 )
brian
(Brian Gillespie)
May 11, 2021, 11:28pm
23
Rhino 7 SR7 Release Candidate 1 for Windows and Mac (7.7.21131) is now available
Bugs Fixed:
Annotation: Redundant missing font warnings for each imported layout (RH-59598 )
Annotation: DimLinear: History update did not rotate dimensions with parent objects (RH-63861 )
Arc: Mouse pick did not apply distance constraint as pressing Enter (RH-63830 )
ArrayCrv: Objects were not consistently spaced (RH-64062 )
BoundingBox: Cumulative=No hanged Rhino (RH-64110 )
BoxEdit: Lagged with a lot of objects (RH-63807 )
Display:
Block display was slow (RH-62371 )
Transparency from texture doesn’t show base color correctly in Rendered mode (RH-62424 )
Shade command: toggle the SubD wires as well (RH-62792 )
Block attribute calculation made Rhino unresponsive (RH-63264 )
Dragging SubD vertices reverted smooth/flat modes (RH-63832 )
Shadows lost for transparency mapped materials (RH-64116 )
Drag: Alt-copy a single group member created a one-object group (RH-63960 )
EndBulge: End bulge - control opposite edges at the same time (RH-59953 )
Export:
File IO:
Export PDF: Preview issues (RH-62125 )
SVG Export - Text colors were not exported correctly (RH-63352 )
Prompts should be removed when importing files into a headless document (RH-63814 )
DWG Export/Import - Hatch patterns shifted when they round-tripped back into Rhino (RH-63819 )
DWG Export/Import - Leader text size did not round-trip (RH-63924 )
OBJ Export - “UseRenderMeshes” option was missing in scriptable version (RH-63962 )
DWG/DXF Import - Dimensions might be viewed from behind (RH-63990 )
FindText: Did not remember "Match case" and "Whole word" settings (RH-62011 )
GrasshopperPlayer:
No output contextual components in definition (RH-59105 )
Polysurface faces could not be selected when GetGeometry component only accepts surfaces (RH-63914 )
History: Render meshes of Edge Softening did not update (RH-63716 )
Make2D: Leaves clipping plane selected (RH-63363 )
Mesh: extreme density on extrusion objects (RH-64087 )
NamedSelections:
NamedSelection: Multiply with BlockEdit (RH-63834 )
Named Selections: Fails on points from multiple objects (RH-64126 )
NamedView: List view scrolled to top when a named view was restored (RH-63742 )
OSnap:Mid: Mid Osnap behavior has changed between V5 and V6 (RH-47066 )
OpenNURBS: ONX_Model::AddDefaultDimensionStyle threw exception (RH-64090 )
PackageManager: Had a huge dialog box (RH-63826 )
Patch: Behaved differently when same edges were selected differently (RH-61810 )
PerFaceDisplayColor: Typo in RemovePerFaceColors command's feedback message (RH-63947 )
Print:
Detail views using Rendered mode did not print (RH-63402 )
Arctic mode printed horizon (RH-63860 )
Tiled with 300 PDI Raster & Artic display modes (RH-63903 )
QuadRemesh: Quadremesh: worksession ouput remains in the inactive file (RH-61040 )
RDK:
EXR texture rotated (RH-51581 )
Raytraced mode required a viewport wiggle to show changes of baked textures (RH-58954 )
Constant material updates from ChangeQueue prevented Raytraced mode from rendering (RH-63792 )
Constant material updates from ChangeQueue prevented ProRender from rendering (RH-63915 )
Assigning material changed material base color (RH-64053 )
Rendering: RenderOpenRenderImage command did not open window with correct size (RH-61873 )
Rendering: Cycles:
Multi-device broken (RH-57576 )
Color mask for Picture material did not work with Cycles (RH-61836 )
Basic environment using background color did not work correctly with Skylight (RH-61842 )
Sun size was different between sessions (RH-64003 )
Rendering: Materials:
Objects were not selected/deselected properly after dropping a material (RH-56570 )
Metal bump textures did not show up in Rendered mode (RH-63413 )
Sphere preview thumbnail gave wrong info (RH-63520 )
PBR normal map and environment were mixed (RH-64007 )
Filename did not stick with an unhandled exception (RH-64057 )
Rendering: Realtime SDK: Restoring snapshot did not trigger skylight change event in ChangeQueue (RH-63734 )
Rendering: Texture Mapping:
Object properties showed incorrect mapping type (RH-60653 )
Repeat of Grit texture did not display properly in Rendered mode with “Advanced texture preview” enabled (RH-63778 )
Rendering: Textures:
Advanced texture preview caused progressive baking in Raytraced mode (RH-63865 )
Base color channel was baked unexpectedly (RH-63868 )
Models with lots of baked textures took a long time for second load (RH-63879 )
Stock bump textures did not update properly (RH-63970 )
Baking high resolution textures used up a huge amount of disk space (RH-64037 )
SDK: RhinoOffsetCurveOnSrf did not work across seam of closed surface (RH-63132 )
SDK: GhPython: Intersect caused memory leak in Grasshopper (RH-63426 )
SDK: RhinoCommon:
RhinoWindows.Controls.RenderContentUserControlCollapsibleSection did not work in Visual Studio Design mode (RH-50717 )
Expose RhinoGetDibAsTextureFileReference to RhinoCommon (RH-59674 )
RhinoObject.CommitChanges() returning false in headless Rhino Document (RH-63577 )
GumballAppearanceSettings CreatePointer() caused memory leak (RH-64076 )
Selection: Selecting sub-objects in blocks caused out of memory (RH-63919 )
SubD: SubD shared pointer use leaking memory (RH-63281 )
SubD Symmetry:
SubD Symmetry won’t update after Bridge (RH-62915 )
Radiate extrude error example (RH-63939 )
Radiate with motif count 2 doesn’t work right (RH-64081 )
Subobject Selection: Deleting SubD sub-objects worked differently between Shaded and Wireframe modes (RH-64035 )
Sweep1: Failed in a specific case (RH-62112 )
UVEditor: Did not work well with Advanced texture preview in Rendered mode (RH-63468 )
Undo: Did not update perface material display when Displacement plug-in was loaded (RH-50584 )
UnrollSrf: UnrollSrfUV - Prompt did not include text dots and points (RH-62551 )
ViewCaptureToClipboard: ViewCapture: Shadows missed if the image is tiled (RH-60041 )
Crashes Fixed:
RDK:
Repeated renderings ran out of memory and crashed Rhino (RH-64004 )
Color button caused a crash (RH-64119 )
Enhancements:
Annotation:
Frame around text pays attention to print width settings (RH-62036 )
SelDimOverride command now selects any annotation, not only dimension, that has a style override (RH-63693 )
Color Picker: Added RGB sliders to HSV, HSL, CMYK wheel modes (RH-62785 )
Connect: ExtendOtherCurvesBy=Smooth is made not to add control points (RH-63393 )
DocumentProperties:
Document User Text now hides keys added by Guides of modeling aids (RH-63781 )
Document User Text now hides keys added by BoxEdit (RH-63782 )
File IO:
STEP Import - Reports unit and tolerance in command history (RH-50775 )
PDF Export - Lines are printed with rounded end caps (RH-50899 )
OBJ Export - New “Export as triangles” option (RH-62328 )
AI Import - Uses PDF import options for PDF-based .ai files (RH-62392 )
SKP Import/Export: Added support for SketchUp 2021 files (RH-62766 )
SVG Export: Saves files without UTF-8 BOM to improve readability for other apps (RH-63372 )
Inset: Added Group mode for multiple selected SubD faces (RH-52735 )
Layout: In the overlapped region of detail views, double-click close to the center of a detail view to activate it (RH-63408 )
Lights: Shadow intensity of Spot, Point and Directional lights now changes shadow softness (RH-63856 )
MatchProperties: Added "Texture mapping" option (RH-54829 )
Modeling Aids: Elevator mode now instantly updates preview when typing a distance (RH-62447 )
Options: Added ExportDocumentUserText advanced setting that decides if Document User Text will be exported or copied to Clipboard (RH-63589 )
Panels: NamedCPlane, NamedView, NamedPosition, Snapshot items can be sorted by ascending, descending, or custom orders (RH-60323 )
Picture: Texture display will not change when Picture plane is split and shrunk (RH-62508 )
Properties: Column width in Attribute User Text can be remembered in a Rhino session (RH-60074 )
Reflect: Control points across the reflection plane can be edited (RH-63636 )
Rendering: Stops testing tangents when edge display is turned off to speed up startup time (RH-63522 )
Added “Yes to All” button for assigning a material to objects inside a block (RH-60150 )
“Assign to object” prompts to keep or override sub-object materials (RH-62543 )
UntrimAll: UnTrimAll: Supports removing holes in hatches (RH-62914 )
UserText: "Paste key and value to all layouts" now skips existing keys (RH-56774 )
WireCut: Supports multi-cutting curves (RH-39776 )
Features Added:
Rendering: Textures: New RenderReportImageFiles command (RH-62387 )
Selection: New SelFontUse command (RH-63724 )
Regressions Fixed:
Annotation: DimCurveLength and DimArea did not allow selecting curves in non-active detail views (RH-63149 )
FindText: Did not find text strings in dots (RH-63047 )
SelBrush: RealTimeSelection did not work with points, curves, and meshes (RH-63842 )
SDK Enhancement:
Developer Tools: Added dotnet new templates (RH-63812 )
SDK:
Allows adding objects to inactive layouts (RH-49373 )
Added change event watcher for document user text (RH-64028 )
SDK: RhinoCommon:
Expanded enum for GripType now includes EditPoints (RH-56945 )
Added .NET SDK access to get the C++ SubD vertex faces (RH-63232 )
ON_BrepFace::m_face_uuid is exposed (RH-63902 )
Tasks Completed:
ApplyDisplacement: Is changed to a hidden command (RH-63502 )
UI Change:
Reflect: Option RemoveExistingSymmetry is renamed to RemoveExistingReflectSymmetry (RH-62436 )
SubD: add split by subd edge loop to the edit menu in the subd menu - (RH-64042 )
Usability Problems Fixed:
Eto: Named item panels were not selected until mouse button was released (RH-63748 )
Mac-Only Changes
Bugs Fixed:
Block: Annotation style doesn't survive paste into new file (RH-62979 )
Display: Shaded controls missing from a new display mode. (RH-58120 )
Groundplane: Setting a negative height crashed Rhino (RH-63708 )
ImportOptions: ImportPreferences fails (RH-63979 )
Menu: Capture commands missing from the Viewport menu (RH-57629 )
PropertiesPage: Light properties did not allow values grater than 100 (RH-54373 )
Rendering: Textures: Missing textures made model not open (RH-63925 )
Crashes Fixed:
Eto: Opening a model caused instant crash on Mac (RH-63976 )
Enhancements:
File IO:
Allows a damaged 3DM to open on Mac so it can be reverted to a valid version (RH-61095 )
3DM - Added “Do not show this again” checkbox to “Auto Save disabled” warning when opening an old version 3DM (RH-62544 )
Templates: Annotation styles are updated to use Arial font to avoid font missing on Windows (RH-58931 )
Incomplete Port:
ExtractIsocurve: Added History support on Mac (RH-62623 )
Bugs Fixed:
Display: OpenGL Cap - Transparent layer (RH-63537 )
DocumentProperties: Some render settings were not scriptable (RH-62269 )
Eto:
Several dialogs were a lot larger than necessary (RH-63828 )
ComboBoxCell did not function correctly (RH-63922 )
Gumball: Gumball not working in this model (RH-63917 )
Print: Some views were partially clipped (RH-58678 )
Rendering: Texture Bake Quality was not set correctly in Render options (RH-63867 )
SDK: Dialog with warning blocks python script (RH-51402 )
SDK: RhinoScript: Rhino.idl and RhinoScript.idl reported 6.0 instead of 7.0 (RH-63874 )
SpaceMouse: 3D Connexion did not work properly on Rhino.Inside Revit (RH-62038 )
Enhancements:
BlockManager: Special characters in block names are exported as underscores (RH-62906 )
Display: OpenGL Cap - SystemInfo (RH-64069 )
Fullscreen: Fullscreen - sticky between sessions (RH-53683 )
Interface: Added InactiveTabBackground advanced setting for changing color of inactive tabs (RH-62579 )
Layer: Allows deleting layers with the keyboard delete key (RH-63265 )
brian
(Brian Gillespie)
May 18, 2021, 11:10pm
24
Rhino 7 SR7 Release Candidate 2 for Windows and Mac (7.7.21138) is now available
Bugs Fixed:
RDK: Need more precision in displacement amount control (PBR) (RH-64214 )
Rendering: Post Effect: Gaussian Blur causes overexposure effect (RH-64172 )
Mac-Only Changes
Bugs Fixed:
Grasshopper: Grasshopper Preferences crashes (RH-64179 )
brian
(Brian Gillespie)
May 26, 2021, 12:24am
25
Rhino 7 SR7 Release Candidate 3 for Windows and Mac (7.7.21145) is now available
Bugs Fixed:
Rendering: Cycles: HDRi with high dynamic EV were underpowered (RH-61976 )
Rendering: Textures: Progressive baking did not stop (RH-64238 )
Regressions Fixed:
Rendering: Cycles: Texture mapping errors in Render versus Rendered mode (RH-64230 )
Rendering: Textures: Texture baking froze Rhino while manipulating Rendered view (RH-64240 )
Bugs Fixed:
Installer: Offline installation of Rhino 7/8 failed (RH-64041 )
brian
(Brian Gillespie)
June 2, 2021, 10:37pm
26
Rhino 7 SR7 Release Candidate 4 for Windows and Mac (7.7.21151) is now available
Bugs Fixed:
Curve-curve intersection: Did not find intersection between duplicate lines (RH-50401 )
UDT: Flow - Dimensions in groups caused the result skewed (RH-64413 )
Regressions Fixed:
Rendering: Textures: Long lag when updating baked textures (RH-64302 )
brian
(Brian Gillespie)
June 9, 2021, 4:01pm
27
Rhino 7 SR8 Release Candidate 1 for Windows and Mac (7.8.21160) is now available
Bugs Fixed:
Display:
Visibility checkbox of “Show clipping planes” was missing in Technical/Artistic/Pen mode options (RH-62708 )
Background of Pen display mode displayed brighter in inactive detail views (RH-63140 )
SubD shaded display did not persist through Tab key smooth/flat toggle (RH-64276 )
Feedback was updating slowly when SubD and clipping plane coexisting in shaded viewport (RH-64281 )
DraftAngleAnalysis: DraftAngleAnalysis panel on mac loses document focus (RH-64308 )
DupEdge: SubD edges and grouping (RH-64444 )
File IO: STEP Import - Failed to read many surfaces in a STEP file from Solidworks (RH-62368 )
Grasshopper:
IGH_Param.ReplaceSource bug. (RH-51591 )
Unnamed objects are found when converting empty strings to shapes. (RH-54605 )
Offset Curve requires Plane input on RH7, not RH6 (RH-62293 )
‘Simplify’ error: “An entry with the same key already exists.” (RH-62584 )
Mesh Surface Equalize=True bug (RH-63496 )
Volume on open brep doesn’t work any more in Rhino7 (RH-63510 )
Selected components are not showing wire preview (RH-63627 )
Grasshopper: Components: Object Details doesn't work for points (RH-63519 )
Gumball: gumball not centered on sub object selected edges- (RH-64551 )
History: urge: Tell the user about hidden objects (RH-27956 )
MatchProperties: Inconsistent (RH-64135 )
MeshSplit: Make MeshSplit work with Infinite Planes (RH-53735 )
Picture: Texture mapping incorrect in Raytraced mode when picture plane was trimmed (RH-64309 )
Print: Vector output had extra lines in preview (RH-62636 )
Rebuild: "Preserve end tangent directions" did not work when rebuilding with a master curve (RH-64357 )
Reflect: Radiate: Segment count should be session sticky (RH-64459 )
Rendering: Gamma post effect should be disabled when renderer doesn't support Linear Workflow (RH-64381 )
Rendering: Post Effect: Problem with 'distance from camera' channel (RH-54546 )
Proxies appeared in UI after instancing Render Content (RH-63533 )
Baking of gradient textures caused high memory consumption and crash (RH-64194 )
Rendering Texture: Modal editor failed to render preview (RH-64296 )
Raytraced mode required view rotation to update baked textures (RH-64420 )
SDK:
RhinoSmoothMesh ignoring the bFixBoundaries parameter (RH-64487 )
Brep.CreateFromOffsetFace with loose tolerance slow (RH-64535 )
SDK: RhinoCommon:
Unable to set InstanceDefinition.SkipNestedLinkedDefinitions property (RH-51646 )
Block name conflict detection (RH-57128 )
RhinoCommon: create example how to pull SubD edit points (RH-60373 )
Item templates were in the wrong category (RH-64123 )
No way to assign a Material to an object’s attributes directly (RH-64331 )
Expose CRhinoZebraAnalysisSettings to RhinoCommon (RH-64442 )
Snapshot: Snapshots - Import enables all clients (RH-58937 )
SubD Symmetry:
radiate issue (RH-64084 )
Bug in finding Radial symmetry radial count in segment count 2 cases (RH-64493 )
Added SubD SDK tool to automatically mark the primary motif in RadiateAdd (RH-64500 )
Face arrangement could be better (RH-64504 )
Change ON_Symmetry::Type::Rotate to use new radial symmetry code. (RH-64550 )
Sweep2: History update twisted the surface (RH-64405 )
Text: Text object duplicates the string when saved as v5 format 3dm (RH-64471 )
Toolbar: Set dim macros to Continue=No (RH-64469 )
ViewCaptureToFile: Failed with 4-color gradient background (RH-64000 )
Cosmetics:
ToolPalettes: HatchScale Toggle toolbar button macro incorrect (RH-63641 )
Enhancements:
InsertControlPoint: Keeps SubDFriendly state (RH-63329 )
Rendering: Cycles Viewport: Updating sample count in Rendering panel did not update sample count on HUD (RH-61138 )
Rendering: Textures: Texture baking supports multi-thread processing (RH-63864 )
SelMaterialName: Select subobjects (RH-61222 )
Split: Added EdgeLoop option for splitting SubD (RH-59074 )
Features Added:
SubD Symmetry: New Radiate command (RH-55857 )
SDK Enhancement:
RDK: Added option to show only certain categories/types in ShowContentChooser (RH-58381 )
SDK: RhinoCommon: Exposed ON_InstanceDefinition::SetLinkedComponentAppearance (RH-55139 )
UI Change:
Menu: Added "Split at Edge Loop" to SubD -> Edit Tools menu (RH-64042 )
Mac-Only Changes
Bugs Fixed:
Eto: Toolbar buttons not properly displayed when expanded (RH-58048 )
File IO: PDF: Windows vs Mac Output Difference (RH-62671 )
Grasshopper:
Dark Mode: Some text labels are illegible when they white on grey background (RH-57263 )
Some visual and layout issues on Mac (RH-64233 )
Rendering: Cycles: Could not type more than one digit in Rhino render advanced settings in Rendering panel (RH-64400 )
Rendering: Materials: Name change did not stick (RH-64463 )
SVG: ViewCapture.CaptureToSvg() adds Rectangle on Rhino for Mac 6 and 7 (RH-64191 )
Tutorials: File list in Tutorials panel was not expandable on OS X Mojave (RH-63810 )
Crashes Fixed:
Rendering: Materials: Materials: Changing name caused crash (RH-64466 )
Bugs Fixed:
Alerter: Help button does not open the topic (RH-64485 )
Grasshopper: Geometry Pipeline locked filter broken. (RH-49901 )
SelMaterialName:
SelMaterialName does not see per-face materials (RH-42471 )
SelMaterialName should work on Sub-object assigned materials (RH-42474 )
ZoomExtents: ZoomExtends: Failed in detail views after an object was selected and deselected (RH-64202 )
brian
(Brian Gillespie)
June 17, 2021, 2:31pm
28
Rhino 7 SR8 Release Candidate 2 for Windows and Mac (7.8.21168) is now available
Bugs Fixed:
Block: Inserted Block turns into display haywire (RH-61930 )
Display:
Objects with color transparency disappeared when they were made into a block (RH-62634 )
Curves with color transparency were invisible in blocks (RH-64224 )
Grasshopper:
Offset Curve component required Plane input on RH7, not RH6 (RH-62293 )
Object Details component did not work for points (RH-63519 )
MeshRepair: Reported increasing total naked edges for multiple selection (RH-64549 )
RecordAnimation: RecordAnimation needs to learn about RealtimeDisplayMode integrations (RH-57154 )
Snapshot: Import enabled all clients (RH-58937 )
Trim: Trimming Surfaces -> Rhino Closes, No Error (RH-64587 )
Enhancements:
Rendering: Cycles Viewport: Relaunch raytrace (RH-61673 )
Bugs Fixed:
SDK: RhinoSmoothMesh ignoring the bFixBoundaries parameter (RH-64487 )
brian
(Brian Gillespie)
June 24, 2021, 5:04am
29
Rhino 7 SR8 Release Candidate 3 for Windows and Mac (7.8.21174) is now available
Bugs Fixed:
Align: Align broken for control points (RH-64665 )
File IO: Layouts to PDF - Missing Text (RH-62446 )
Grasshopper: ‘Simplify’ error: “An entry with the same key already exists.” (RH-62584 )
Rendering: Cycles: Material thumbnails and Raytraced viewport flipped upside down (RH-64674 )
brian
(Brian Gillespie)
June 29, 2021, 10:28pm
30
Rhino 7 SR8 Release Candidate 4 for Windows and Mac (7.8.21180) is now available
Bugs Fixed:
Rendering: Cycles Viewport: Gradient env flipped in Raytraced mode and Render (RH-64773 )
brian
(Brian Gillespie)
July 15, 2021, 5:41pm
31
brian
(Brian Gillespie)
July 20, 2021, 10:50pm
32
Rhino 7 SR9 Release Candidate 2 for Windows and Mac (7.9.21201) is now available
Bugs Fixed:
MeshRepair: Reported a mesh as good and invalid at the same time (RH-64846 )
RDK: Render Content mistakenly allowed invalid field names (RH-64873 )
brian
(Brian Gillespie)
August 4, 2021, 6:52pm
33
Rhino 7 SR9 Release Candidate 3 for Windows and Mac (7.9.21215) is now available
Bugs Fixed:
Rendering: Textures: Initial texture preview did not respect "Preview local mapping" setting (RH-63773 )
TextField: Units below "Miles" on the list were not set correctly for Volume, Area, and Curve Length (RH-65137 )
SDK Enhancement:
SDK: RhinoCommon: Added PointCloudUnsafeLock (RH-64318 )
Mac-Only Changes
Bugs Fixed:
Rendering: Materials: Preview thumbnails did not update on Mac (RH-65160 )
brian
(Brian Gillespie)
August 11, 2021, 5:03pm
34
Rhino 7 SR10 Release Candidate 1 for Windows and Mac (7.10.21223) is now available
Bugs Fixed:
BoxEdit: Input was added to the existing size (RH-64916 )
Display: Casting receiving shadows was ignored in linked blocks (RH-64860 )
File IO:
Read-only warning popped up when scripting a file opening (RH-64932 )
OBJ Import - Commas as decimal separators failed (RH-65090 )
PDF Export - Scale values did not update properly (RH-65098 )
DWG Export - Text object was saved with incorrect annotation style (RH-65115 )
DWG Export - Text size was incorrect (RH-65155 )
PDF import page 2 error (RH-65250 )
FilletCorners: Kept the wrong side (RH-21609 )
Grasshopper: Components: "Component ID conflict" dialog showed instead of "File Conflict" on multiple conflicts (RH-65096 )
Gumball:
Missing scale handles when aligning to text object (RH-64901 )
Activating the scale handle was harder in V7 (RH-64915 )
History:
Link to dimensions was broken without a warning when editing converted an extrusion to a polysurface (RH-32233 )
Locking children too agressive with annotation (RH-49644 )
“All” option of HistoryUpdate command did not update history child that was locked, hidden, or on a locked layer (RH-65232 )
Layer: Layers not turned off in layouts (RH-65079 )
MergeAllCoplanarFaces:
NamedSelections: Drag and drop to reorder was broken (RH-64987 )
Options: Options causes remeshing (RH-65017 )
PointDeviation:
Hair left on screen when “Display hair” was turned off (RH-65167 )
PointDeviation - numbers do not match colors (RH-65182 )
Print: Preview drew text with wrong colors (RH-63128 )
QuadRemesh: Display conduit stuck when remeshing multiple objects (RH-65023 )
RDK: Child content was not instanced with instanced parent content (RH-65040 )
Rendering: Single color texture using object color did not render (RH-64914 )
Plastic was exported as PBR (RH-64756 )
Hidden materials caused confusion in object properties (RH-65041 )
Rendering: Textures: Rendered display: mesh objects use low res simulation of procedurals (RH-64754 )
SDK:
Grasshopper template in v7 did not generate a new GUID (RH-64988 )
RhinoBrepTrim failure (RH-65209 )
SDK: RhinoCommon:
Project template did not ask about WinForms/WPF (RH-64575 )
Bug in Rhino.Geometry.Transform.GetHashCode (RH-65150 )
Crash in VolumeMasProperties (RH-65162 )
ScriptCompiler: Compiled GH Script using cached values (RH-65097 )
SetPt: Pressing x, y, z keys did not toggle the checkboxes (RH-65123 )
SubD: SubDExpandEdges - Rhino 7.x test command. (RH-65157 )
Crashes Fixed:
tl!TL_MeshBrepFace – Access Denied (RH-64946 )
Enhancements:
File IO: CSV Export - Saves attribute user text of top level blocks (RH-65035 )
NamedSelections: SubD faces and edges in selection set can be post input for commands (RH-64986 )
RDK: Material type conversion is improved (RH-64750 )
SDK: RhinoCommon:
BrepFaceList.ShrinkFaces() method was broken for certain multiface breps (RH-64138 )
Added overload to volume massprop calc to include tolerance (RH-64317 )
SubD Symmetry: Reflect command allows existing Reflect object as input (RH-60738 )
SDK Enhancement:
Rendering: Materials: Tree mode list kept collapsing (RH-65070 )
Rendering: Texture Mapping: UVW mapping box text windows are too small- (RH-64980 )
Mac-Only Changes
Bugs Fixed:
File IO: PDF Export - Vector output failed on Mac if custom size * dpi was too large (RH-65116 )
SDK: Python: A script failed on Mac (RH-65056 )
ToolPalettes: Preferences > Tool Palettes > Hide tool palettes when starting commands: should exclude some commands (RH-65131 )
Features Added:
Preferences: Added advanced setting to suppress tool palettes reappearing after command completes (RH-57945 )
Bugs Fixed:
SelFontUse: finds hidden text (RH-65077 )
Enhancements:
Keyboard Shortcuts: Added Ctrl+Q to quit Rhino (Exit command) (RH-64974 )
LoadScript: Supports Windows environment variables in file paths (RH-65034 )
Options:
Updates and Statistics page now shows the current version (RH-50906 )
Double-clicking on the name of an advanced setting copies it to clipboard (RH-65122 )
SDK Enhancement:
SDK: RhinoScript: Enhancements about alpha value of colors (RH-65170 )
brian
(Brian Gillespie)
August 19, 2021, 7:02pm
35
Rhino 7 SR10 Release Candidate 2 for Windows and Mac (7.10.21231) is now available
Bugs Fixed:
Trim: Object cut remains selected after Trim is completed (RH-65316 )
Regressions Fixed:
Rendering: Cycles Viewport: Raytracing repeatedly restarted in parallel views (RH-65147 )
dan
(Dan)
August 24, 2021, 9:58pm
36
Rhino 7 SR10 Release Candidate 3 for Windows and Mac (7.10.21236) is now available
Enhancements:
Translation (localization) updates
brian
(Brian Gillespie)
September 1, 2021, 9:30pm
37
Rhino 7 SR10 Release Candidate 4 for Windows and Mac (7.10.21243) is now available
Bugs Fixed:
Trim: Object being cut remained selected (RH-65316 )
Enhancements:
Keyboard: Arrow keys are able to select through items in named panels (RH-64824 )
brian
(Brian Gillespie)
September 14, 2021, 10:47pm
38
Rhino 7 SR11 Release Candidate 1 for Windows and Mac (7.11.21257) is now available
Bugs Fixed:
Annotation: DimAngular:
Flipped between angle and reflex angle when moving the whole dimension (RH-65501 )
Moving resulted in a different angle (RH-65502 )
Display: Skylight shadow shading issues when selecting objects (RH-65518 )
EditText: Non-native Windows fonts could not be set italic for text in groups (RH-58645 )
ExtrudeSubD: Faces in child segment of a single reflect symmetry could be selected (RH-65470 )
File IO:
PDF Export - Preview stretched (RH-65517 )
SketchUp Import - Group materials were assigned to objects that did not have materials (RH-65531 )
Match: Match - scripted mode option missing (RH-65530 )
Panels: Bugs in named item thumbnail mode (RH-64631 )
Rendering: Materials: Duplicate material acted as if the texture is instanced (RH-65449 )
SDK: RhinoCommon:
Bug in the copying of SubD objects (RH-64960 )
Convert quaternion to Euler angles and vice versa (RH-65317 )
Crashes Fixed:
PackageManager: Null reference exception (RH-65550 )
Enhancements:
Display: Caches analysis meshes for EMap (RH-65252 )
File IO: CSV Export - Saves text fields as evaluated values instead of formula strings (RH-65483 )
Gumball: Remembers mouse dragged distance/angle/scale values for next click input (RH-65480 )
Match:
Keeps SubDFriendly+ properties (RH-52487 )
Preview missing in scripted mode (RH-65561 )
SubD Symmetry:
Radiate command - Added “pie slice” feedback display for Reflect+Radiate symmetry (RH-65233 )
Added “Flip” option to Reflect, Reflect+Reflect, and Reflect+Radiate symmetries (RH-65421 )
Radiate now uses a cleanup tolerance (based on document’s absolute tolerance) when creating child motifs (RH-65081 )
Radiate command - Flips “cheese wedge” display when cursor moving across object bounding box center (RH-65498 )
Reflect command - Automatically adjust reflection plane direction, while picking, towards SubD’s bounding box center (RH-65499 )
InsertPoint command is allowed to modify only primary motif (RH-64634 )
TextField: Exports evaluated values instead of formula strings (RH-63311 )
Features Added:
SDK: RhinoCommon: Added ability to crease/smooth SubD edges to Rhino 7 grasshopper (RH-63863 )
Regressions Fixed:
UI Change:
Toolbar: Added SubDRevolve command (RH-63941 )
Mac-Only Changes
Bugs Fixed:
File IO: PDF Export - Failed when exporting some, but not all, layouts (RH-64221 )
RDK: Renaming viewport title did not update "Specific Viewport" list (RH-64853 )
Rendering: Content Panels: Quick preview was initialized slowly (RH-65469 )
Issues with Raytrace Mode and Two Docs (RH-61046 )
Raytraced in multiple documents fails (RH-65043 )
Crashes Fixed:
Grasshopper: Frequent crashes (RH-65514 )
Incomplete Port:
Grasshopper: CMD+A did not select all text in Scribble component (RH-60286 )
Bugs Fixed:
File IO:
STEP Export - Failed with some folder names in Japanese/Korean (RH-63414 )
PDF Export - Preview did not update when switching from “Window” to “Multiple Layouts” (RH-65529 )
Undo: Did not work with material changes made by RhinoScript (RH-65476 )
Tasks Completed:
Help: Added simplified Chinese V7 for Windows offline help (RH-65194 )
brian
(Brian Gillespie)
September 21, 2021, 10:09pm
39
Rhino 7 SR11 Release Candidate 2 for Windows and Mac (7.11.21264) is now available
Bugs Fixed:
Rendering: Textures: Texture baker freezes Rhino (RH-65628 )
SmartTrack: Rotate does not place a smart point with no snap. (RH-65668 )
SDK Enhancement:
SDK: Added support for manipulating per-face materials without having to know the details (RH-64719 )
SDK: RhinoCommon: Added abilities to convert angles between quaternion and Euler angles (RH-65317 )
dan
(Dan)
September 28, 2021, 10:14pm
40
Rhino 7 SR11 Release Candidate 3 for Windows and Mac (7.11.21271) is now available
Bugs Fixed:
Gumball: remembered value is used too agressively (RH-65751 )
History: Showed false breaking warning when editing converted parent from Extrusion to polysurface (RH-65728 )
Mac-Only Changes
Bugs Fixed:
Grasshopper: Some icons on context menus were not scaled properly (RH-65658 )
Rendering: Realtime SDK: Raytraced mode failed with multiple documents (RH-65043 )
