Rhino 7 SR11 Release Candidate 4 for Windows and Mac (7.11.21278) is now available
To get it, subscribe to the Release Candidate update stream on Windows or on Mac.
Bugs Fixed:
Rendering: Textures: Loops of texture baking failures froze Rhino (RH-65697)
Rhino 7 SR12 Release Candidate 1 for Windows and Mac (7.12.21285) is now available
Rhino 7 SR12 Release Candidate 2 for Windows and Mac (7.12.21292) is now available
Bugs Fixed:
Annotation: Text: Editing text showed debug messages in command history (RH-65959)
Display:
Background of Pen display mode was brighter in inactive detail views (RH-63140)
rotating uv mapping (at least box) can cause stretching (RH-65817)
ExtractPt: Created duplicate points at polycurve segment ends (RH-65980)
File IO: A simple polysurface was exported to 3DS with too many faces (RH-65936)
GrasshopperPlayer: Support input from a defined set (RH-57836)
Rhino 7 SR12 Release Candidate 3 for Windows and Mac (7.12.21299) is now available
Bugs Fixed:
Rendering: Materials: Drag and drop import stopped working for PBR materials (RH-65998)
Rhino 7 SR13 Release Candidate 1 for Windows and Mac (7.13.21313) is now available
Rhino 7 SR13 Release Candidate 2 for Windows and Mac (7.13.21327) is now available
Bugs Fixed:
Layout: Remove View[[1897]] localized string from LayoutsPanelViewModel (RH-65383)
Rhino 7 SR13 Release Candidate 3 for Windows and Mac (7.13.21334) is now available
Regressions Fixed:
RDK: Placeholder material gets duplicated (RH-66489)
Rhino 7 SR13 Release Candidate 4 for Windows and Mac (7.13.21341) is now available
Enhancements:
Annotation: Hatch: Right-click to only check a pattern in the list, and allows check/uncheck all selected patterns at once (RH-66538)
Windows-Only Changes
Bugs Fixed:
Rendering: Cycles: Crashed when using OpenCL as the render device (RH-66535)
Rhino 7 SR14 Release Candidate 1 for Windows and Mac (7.14.21348) is now available
Rhino 7 SR14 Release Candidate 2 for Windows and Mac (7.14.21362) is now available
Bugs Fixed:
SDK: RhinoCommon:
CreateFromSweepSegmented problem when specifying an endpoint (RH-66765)
Rhino 7 SR14 Release Candidate 3 for Windows and Mac (7.14.22004) is now available
Crashes Fixed:
SDK: RhinoCommon: Crash Grasshopper in sweep2 (RH-66839)
Rhino 7 SR15 Release Candidate 1 for Windows and Mac (7.15.22011) is now available
Bugs Fixed:
Material assignment lost when material plug-in is loaded (RH-66913)
Display: Incorrect shadow in Rendered mode (RH-66793)
Rhino 7 SR15 Release Candidate 2 for Windows and Mac (7.15.22012) is now available
Rhino 7 SR16 Release Candidate 1 for Windows and Mac (7.16.22039) is now available
Bugs Fixed:
Contour: Created open curves from closed sections of meshes (RH-66997)
Drag: Allow gumball dragging even if object or control point dragging is disabled (RH-67320)
File IO:
Step Import failed to detect a planar NURBS if it was trivially trimmed (RH-67122)
Exports slightly non-planar surfaces to STEP as planes (RH-67211)
Rhino 7 SR16 Release Candidate 2 for Windows and Mac (7.16.22046) is now available
Bugs Fixed:
Annotation: DimRadial: Radius and Diameter Dimension Text Were Incorrect (RH-67328)
Display: Point clouds imported from PLY files were invisible (RH-66750)
SDK: Python: IronPython is not reported for platform.python_implementation (RH-67339)
Regressions Fixed:
DevLoft: Issue when two rails met at one end (RH-67434)
Mac-Only Changes
Enhancements:
Rendering: Materials: SBSAR image data is now stored in 3dm as PNG instead of TIFF (RH-67449)
Bugs Fixed:
EditPythonScript: EditPythonScript and GHPython did not load (RH-67409)
Rhino 7 SR16 Release Candidate 3 for Windows and Mac (7.16.22053) is now available
Enhancements:
File IO: SOLIDWORKS Import - Supports up to version 2022 (RH-67502)
Rhino 7 SR17 Release Candidate 1 for Windows and Mac (7.17.22069) is now available
Bugs Fixed:
MeshCylinder: Vertex normals of base cap pointed inwards (RH-67428)
SDK: RhinoScript: MeshMeshIntersection rhinoscript (VbScript) tolerance problem (RH-67504)
SpaceMouse: 'Auto Rotation Center' moved target very close to camera and caused objects far away to be clipped (RH-67392)
SubD: Edge sector coefficient evaluation was wrong for corner vertices (RH-67377)
Enhancements:
RecordAnimation: Supports creating animation from Raytraced viewport (RH-57903)
SDK Enhancement:
RDK: Added C++ and C# API for creating an OCS type ON_TextureMapping (RH-67578)
Mac-Only Changes
Bugs Fixed:
Eto: Occasional crash in plugins panel on Mac (RH-67444)
Regressions Fixed:
Annotation: Dot: Unicode Symbols (L Sep / Line Separator) visible in German Rhino (RH-67411)
SDK Enhancement:
SDK: 3dm export allows specifying a different unit system (RH-67485)
Rhino 7 SR17 Release Candidate 2 for Windows and Mac (7.17.22081) is now available
Enhancements:
Display: Shows "Enable GPU detection" button when initializing of CUDA fails and GPU is disabled (RH-67747)
Tasks Completed:
Help: Rewrite the help and other docs for commands using the mesh detailed options dialog (RH-66828)
Mac-Only Changes
Bugs Fixed:
DocumentProperties: Changing units did not prompt for scaling the model (RH-67851)
Update System: Updating to 7.17 failed on MacOS (RH-67833)
Rhino 7 SR17 Release Candidate 3 for Windows and Mac (7.17.22088) is now available
Tasks Completed:
