Trying out WIP 8 today. Immediately noticed that the antialiasing is not working very well. R7 is much sharper looking with settings at 8x. Changing between 2x, 4x and 8x antialiasing settings in WIP 8 seems to have no effect, but it gets worse when you change it to ‘none’. Anyone else report or experience this? To be honest it looks so bad I am going to switch back to R7 for now
Hi Brady,
Do you have your labels mixed up? That top image looks a lot smoother than the bottom, but you have the top labelled as WIP 8. I’m guessing the bottom one is really from the WIP.
Oh my gosh, yes I did mix the labels up sorry.
First of all run the systeminfo tool on both rhino and upload them here.
My first guess is that wip8 is using the embedded Intel video device instead of your dedicated card.
SYSTEM INFO FOR RHINO 7
Rhino 7 SR22 2022-8-29 (Rhino 7, 7.22.22241.07001, Git hash:master @ 752c32917c9a5a67a84684d402757f922e6d7ed9)
License type: Commercial, build 2022-08-29
License details: Cloud Zoo
Windows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA RTX A4000 (NVidia) Memory: 16GB, Driver date: 7-21-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 516.94
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-21-2022
Driver Version: 31.0.15.1694
Z-Buffer depth: 24 bits
Total Video Memory: 16376 MB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.22.22241.7001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.22.22241.7001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.22.22241.7001
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.22.22241.7001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.22.22241.7001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.22.22241.7001
C:\Program Files\Rhino 7\Plug-ins\BlockEdit.rhp “BlockEdit” 7.22.22241.7001
C:\Users\brady\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SectionTools\2021.4.30.511\SectionTools.rhp “SectionTools”
SYSTEM INFO FOR WIP 8
Rhino 8 SR0 2022-8-30 (Rhino WIP, 8.0.22242.00305, Git hash:master @ 4db61e882aa09c39e4a74abb93e956c0185012c5)
License type: Commercial, build 2022-08-30
Expires on: 2022-10-14
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Render version: 4.6
C:\Program Files\Rhino 8 WIP\Plug-ins\Commands.rhp “Commands” 8.0.22242.305
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.0.22242.305
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.0.22242.305
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk_ui.rhp “Renderer Development Kit UI”
C:\Program Files\Rhino 8 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 8 WIP\Plug-ins\Constraints.rhp “Constraints”
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.0.22242.305
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCode\RhinoRoslyn.rhp “RhinoRoslyn” 8.0.22242.305
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.0.22242.305
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCode\RhinoCPython.rhp “RhinoCPython” 8.0.22242.305
C:\Program Files\Rhino 8 WIP\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.0.22242.305
C:\Program Files\Rhino 8 WIP\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino 8 WIP\Plug-ins\BlockEdit.rhp “BlockEdit” 8.0.22242.305
C:\Program Files\Rhino 8 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 8 WIP\Plug-ins\ConstraintsUI.rhp “Constraints UI” 8.0.22242.305
Hi Brady -
If I’m not mistaken, that’s on the list:
Seems like a similar problem yes. Any comment on why changing the antialiasing settings has no visible effect (ie, x2 looks the same as x8)?
I have this same problem using a 3060ti… So probably related to NVIDIA drivers?
By turning on FXAA in the nvidia control panel I was able to get some AA back, but It’s not as good as Rhino 6 or 7.
Glad I am not alone. I think this would be considered a regression and I would expect to see a fix before R8 launch.
Talked about it also here:
NVIDIA GTX 1060 used there.
RH-66088 - reported in the other topic - is fixed in the latest WIP.
I’m also having anti-aliasing issues with the R8 release version. Doesn’t seem to be working at all and changing OpenGL setting does nothing.
Rhino 8 SR0 2023-10-31 (Rhino 8, 8.0.23304.09001, Git hash:master @ 20e15cf9bd66e6676f849f22e485cb3e82a8beac)
License type: Evaluation, build 2023-10-31
Expires on: 2024-02-05
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 96Gb)
.NET 7.0.0
Primary display and OpenGL: NVIDIA GeForce RTX 4090 (NVidia) Memory: 24GB, Driver date: 10-26-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 546.01
Secondary graphics devices.
Intel(R) UHD Graphics 770 (Intel) Memory: 1GB, Driver date: 7-24-2023 (M-D-Y).
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.6 (primary GPU's maximum)
Anti-alias mode: 8x
Render version: 4.6
Driver Date: 10-26-2023
Driver Version: 31.0.15.4601
Total Video Memory: 24564 MB
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp "Datasmith Exporter" 5.2.0.0
C:\Users\Primoz\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp "NVIDIADenoiser.Windows" 0.4.3.0
C:\Users\Primoz\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\AutoCameraTarget\2.2.0\Libx.Fix.AutoCameraTarget.rhp "AutoCameraTarget" 2.2.0.0
C:\Users\Primoz\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Corgi\0.5.6\Corgi.rhp "Corgi" 0.5.5.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp "Commands" 8.0.23304.9001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp "WebBrowser"
C:\Program Files\Rhino 8\Plug-ins\rdk.rhp "Renderer Development Kit"
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp "RhinoScript"
C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp "AnimationTools"
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp "IdleProcessor"
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp "Rhino Render" 8.0.23304.9001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp "Legacy Rhino Render"
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp "RDK_EtoUI" 8.0.23304.9001
C:\Program Files\Rhino 8\Plug-ins\NamedSnapshots.rhp "Snapshots"
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp "MeshCommands" 8.0.23304.9001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp "RhinoCycles" 8.0.23304.9001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp "RhinoCodePlugin" 8.0.23304.9001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp "Toolbars" 8.0.23304.9001
C:\Program Files\Rhino 8\Plug-ins\3dxrhino.rhp "3Dconnexion 3D Mouse"
C:\Program Files\Rhino 8\Plug-ins\Displacement.rhp "Displacement"
C:\Program Files\Rhino 8\Plug-ins\SectionTools.rhp "SectionTools"
Also same results on my laptop. The curve is also jagged for some reason.
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 32Gb)
.NET 7.0.8
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 6-15-2023 (M-D-Y).
- Windows Main Display is laptop's integrated screen or built-in port
Primary OpenGL: NVIDIA GeForce RTX 4060 Laptop GPU (NVidia) Memory: 8GB, Driver date: 10-26-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 546.01
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Render version: 4.6
Total Video Memory: 8188 MB
C:\Users\Primoz\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\BoltGen_py (283dd9db-bcac-ab3c-9b9a-6f41eaf6160f)\1.0.6642.13019\BoltGen_py.rhp "BoltGen_py" 1.0.0.0
Since starting this thread, my anti aliasing issues have remained persistent to this day. Display quality is still visibly worse than R7 ever was. I am used to it now so not so big a deal but it would be nice to be able to crisp up the visuals
We are encountering the same issue with anti aliasing with the R8 version.
See below the screenshots with different settings:
The result is much better with the R7 version.
It is very uncomfortable to work with R8, especially with 1 px thick lines.
Rhino 8 SR1 2023-11-21 (Rhino 8, 8.1.23325.13001, Git hash:master @ 8a4a437248efac5d9cb04d3904481b83e4c23a64)
License type: Commercial, version 2023-11-21
License details: Stand-Alone
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 16Gb)
.NET 7.0.14
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 7-11-2023 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 3050 Ti Laptop GPU (NVidia) Memory: 4GB, Driver date: 11-26-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 527.37
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 11-26-2022
Driver Version: 31.0.15.2737
Total Video Memory: 4 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp "Commands" 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp "NavigateurInternet"
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp "Rendu de Rhino" 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp "Ancien rendu de Rhino"
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp "RDK_EtoUI" 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp "MeshCommands" 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp "RhinoCycles" 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp "RhinoCodePlugin" 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp "Toolbars" 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\BlockEdit.rhp "BlockEdit" 8.1.23325.13001
Does anyone know if McNeel is working on this issue for a next release ?
Thanks,
Somebody wrote on this forum that AA looked the best in Rhino 5. Because I also noticed AA quality degradation between RH 7 and RH 8, out of curiosity I installed Rhino 5 to compare the results. Rhino 5 is a clear winner IMO. It’s hard to give up on this after seeing how smooth lines can be - there is something about them. It’s especially apparent during highlighted object selection.
In all cases, I have 8x AA.
System Info
Rhino 8 SR2 2023-11-29 (Rhino 8, 8.2.23333.09481, Git hash:master @ f86ef9263572569e355077b20611612127c1a79a)
License type: Evaluation, build 2023-11-29
Expires on: 2024-01-30
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 64Gb)
.NET 7.0.11
Primary display and OpenGL: NVIDIA RTX A3000 12GB Laptop GPU (NVidia) Memory: 11GB, Driver date: 10-4-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 537.58
- Windows Main Display attached to adapter port #1
Primary OpenGL: NVIDIA RTX A3000 12GB Laptop GPU (NVidia) Memory: 11GB, Driver date: 10-4-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 537.58
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Render version: 4.6
Driver Date: 10-4-2023
Driver Version: 31.0.15.3758
Total Video Memory: 11520 MB
C:\Users\Czaja\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\Bella (813de3fb-18eb-405f-bfcd-b0b4d3da91fb)\23.4.0.0\bella_rhino.rhp “Bella” 23.4.0.0
C:\Users\Czaja\Desktop\Rhino_7_Win_2023.0417\HDRLightStudioTexture.rhp “HDRLightStudioTexture”
C:\Program Files\Common Files\McNeel\Rhinoceros\8.0\Plug-ins\Crayon (39629248-4fa6-47b8-83c7-745a7efea259)\1.2.0.0\Crayon\Crayon.rhp “Crayon” 1.0.0.0
C:\Users\Czaja\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\SubstanceImporter\2.0.3\Substance.Win.rhp “SubstanceImporter” 2.0.3.0
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp “Datasmith Exporter” 5.3.2.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.2.23333.9481
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.2.23333.9481
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.2.23333.9481
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.2.23333.9481
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.2.23333.9481
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.2.23333.9481
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.2.23333.9481
Thanks, all -
I’ve put this on the list as RH-78744 Display: Curve drawing quality
