Voronoi (3D) Ring
Hello, I am new in Grasshopper so I use a lot of tutorials from the web. Today I tried to create voronoi ring but got this on the screenshot.
Where are the mistakes? I know this question sounds lame.
Many thanks in advance.
And also I found this grasshopper tutorial photo and couldn’t sum-up what are the steps.
Vor Ring.gh (9.1 KB)
Have a try dendro plugin.
Thanks for your time. I don’t know what did I do wrong but it says ‘1. Input parameter Curve Radius failed to collect data’
Here’s the screenshot. Please help whenever you have time.
Thanks in advance
Joseph
Well… You don’t have anything plugged into curve radius. :smiley:
Oops. But… Doesn’t help anyways.
Post your file, The issue seems to be with your curves (the wire is orange, what does the data coming out look like).
Here and thanks again.
V1.gh (57.5 KB)
Internalize geometry so we can look at it.
Capture
See number 3. How to ask effective questions
And you MUST put a radius that is 2 or 3 times bigger than the voxel size !!!
V1.gh (56.9 KB)
Guess I did it here
V1.gh (104.0 KB)
Your Brep and cells don’t intersect, what do you expect to happen?
Change scale factor (F input of scale) to something like 1.1 (so it is bigger) rather than its default 0.5. @HS_Kim probably changed the factor internally so it is not in his screenshot.
Now it has another warning. :frowning:
Just out of curiosity, are you a native english speaker? If not it is ok, just curious because in English the messages are pretty self explanatory. (Also @laurent_delrieu told you this two times). Radius must be atleast 33% bigger than voxel size. What else could that mean besides what it means?
Your voxel size is 0.10, your radius is 0.08. Is 0.08 atleast 33% bigger than 0.10? :smiley:
Got it. I am native English speaker. I’m not Grasshopper native speaker. The last message helped I guess. Thank you very much.
And if you want some nice rounding on intersection you could use Polyline smoothing
Without smoothing
V1_LD.gh (108.5 KB)
Hey Guys, the project looks super interesting. Sadly it seems i have some problems with my liberiers and i cant get it to run properly.
I would like to test if i could incorporate it into a wedding ring that i want to make for my current girlfriend. Maybe one of you guys could make me model according to some measurements for a small fee. it should actually be super simple if i understand the process correctly.
It should have these dimensions, no feature size should be smaller then 0,3mm if i understood the Metal-3D-Printing requirements correctly and it should be 2D, so basically like the rings on top just without the inner bottom.
If one of you guys would be into such a project let me know :slight_smile:
Here’s a Voronoi Ring file I found here several years ago.
I neatened it up a bit, but otherwise never did anything with it. Maybe the OP will find it useful.
VoronoiRing.gh (67.9 KB)
thank you so much! I will have a loon into it! Thank you Birk
