Hi, I have a pproblem from Voronoi that I refer to this video https://www.youtube.com/watch?v=226ESXK5tHg&t=614s and my organic polysurface cannot connect to it =, can someone help me up ?
the attachment below is GH filemy model and gh file
Please don’t use file sharing and upload your files directly into a post by drag and drop.
Voronoi 3.0.gh (25.9 KB)
Model 1.4.zip (17.9 MB)
I don’t open *.zip files from sources I don’t know.
Maybe delete some irrelevant stuff from your Rhino file…
Hello
did you search on forum ? This youtube video has many references here
but the file is too big 150mb ++ for me to share here ![]()
Yup I have try because my model is organic 3D model, I have try alots of ways but it still cannot work
here is my model before bake from grasshopper
Water to rock .gh (24.6 KB)
here is my voronoi script
I can’t help you. I’m not using Dendro… I added the dendro tag to your topic.
Hello
I think you missed some parts, as you inputted a mesh instead of brep. In Rhino there are various geometry types as surface, trimmed surface, brep, subd and mesh. All doesn’t have the same tools …
As output from Dendro it seems best to output quad mesh so it could be converted to SubD then Brep if needed.
For the Voronoi part I changed some part but as there is no trim curve I used SubD then Brep but it is very long. A trim curve from mesh could be useful here. Tweak the script with your own to adjust the output you want.
For the curves you can stay in Dendro
Voronoi 3.0 curves.gh (989.4 KB)
Voronoi 3.0 LD.gh (230.2 KB)
Water to rock LD .gh (21.5 KB)
Thank you so mucxhhhhhh
