Hi everyone,
VisualARQ 3.11 is now available for
download.
This is a maintenance release that fixes most of the critical issues and crashes reported by users. Please report any problems or suggestions here or send us an email to visualarq@asuni.com.
List of changes since 3.10:
New Features (3)
- Object: Beam:
7615: Custom plane for beam end cuts
- Panel: Tables:
14941: List objects ID in tables
- Rhino WIP - BETA:
15795: Compatibility with Rhino 9
Improvements (1)
- Object: Guide:
15811: When a guide is outside an active section boundary, its elevation guides should not be shown
Changes (1)
- Interferences:
15394: Make slab layers have priority over wall layers in equal conditions
Fixed Errors (70)
- Attributes:
15503: Wrong section hatch print preview15325: Inconsistent Print Preview of section boundary color in Hidden display
- Constraints:
15744: Sub-level constraints don’t work properly to change wall height15743: Constraints don’t work in this file15374: Objects height doesn’t adjust to level changes
- Crash:
15886: Crash after deleting objects while running a clash test15815: Crash after copying a curtain wall
- DWG Export:
15691: Tags are appearing duplicated or out of place in the exported DWG file.15689: Wall lines are not visible in the exported DWG file.
- Display:
15762: Transparency issue with VisualARQ objects in Ghosted display
- Grasshopper: Components:
15871:eWasOpenForWriteerror in Stair component15821: Wall main Level should be where the wall path is located15699: Stair path curve is always in the 0 elevation15524: Error when defining a list of roof slopes in Grasshopper15202: Wrong tree structure when deconstructing slabs15136: Content Cache doesn’t bake VisualARQ objects to specific Layers14751: A slab created as Grasshopper style doesn’t recognize the input curve when it is created in Grasshopper14741: Wall is detected in two levels incorrectly12646: Set property changes the Elevation of a window unexpectetly
- Grasshopper: Style:
15510: Gumball at origin in a Grasshopper Style based beam14943: Window created as a Grasshopper Style is inserted in slabs undesirably
- IFC:
15747: Nothing imports in IFC file with VisualARQ 3.1110087: It takes 30 minutes to open an IFC file
- Interferences:
15538: Wrong intersection between multilayer wall and slab15102: Door generates a wrong gap in a slab after adding it as interference14842: The subtraction of an object added as interference doesn’t update14655: Interference error between a beam and a slab
- Language:
14022: Untranslated strings in VisualARQ 3
- Level:
15858: Show Plan View reference on top of other objects15790: Level manager get hanged when activating the top level (with sublevels at inferior elevations only)
- Object:
15850: Hide UUID parameter from the Properties panel
- Object: Beam:
15826: I cannot set a custom Beam cut plane until I reload the Properties panel
- Object: Column:
15709: Column alignment offset is not consistent
- Object: Curtain Wall:
15673: Curtain Wall from Curve: Glass panels not placed correctly15672: Circular curtain wall, the frame does not appear as expected.15359: Curtain wall extension error when curtain wall and surface borders are coincident14589: Curtain wall wrong result when moving it
- Object: Guide:
15640: Guides in a plan view lose their layer when plan view is exploded15615: Objects don’t snap properly on jogged guides15554: Guides are not displayed on the current CPlane15509: Snap to guides doesn’t work
- Object: Openings:
15844: It is not possible to change the opening dimensions when it is set to Other15834: Door opening doesn’t follow the grip point position
- Object: Plan View:
15853: “Cut Plane Elevation” property in Plan views doesn’t work15759: Furniture object doesn’t appear in a plan view
- Object: Roof:
15763: vaRoofSubtract shrinks the roof boundary15753: vaSubtracSolids doesn’t work with roofs15752: Roof gets flat after subtracting an inner boundary15561: Roof intersection bug15412: Window in roof doesn’t create the opening properly.15231: Shed roof slope changes direction when I decrease its angle15029: Roof flips the alignment when it is moved next to another14696: Wrong generation of a roof that has a window inserted14527: Wrong gable roof intersections
- Object: Slab:
15549: Wrong generation of slab with extended walls to it
- Object: Tag:
15728: vaPlanView plan displays tags from multiple floors15663: Tag above cut plane is displayed in plan view in page layout
- Object: Wall:
15381: Wall disappears after filleting it with another wall
- Object: Window:
15668: Window snapping below wall instead of base15421: Leaf grip point doesn’t work for changing opening side of a window in a slab15391: Do not change the Sill position when editing the window “Alignment Offset”14567: Window can’t be placed in the extended part of a wall
- Print:
15685: Leaders are not printed correctly15568: Hatch prints above the 2D representation of a Furniture15189: Wall joints are visible in a Priting result of RCP
- Print: Hidden Vector:
13836: Text in leader is not correctly aligned when printing it to PDF
- Rhino WIP - BETA:
15884: VisualARQ data is not saved in Rhino 915829: Rhino 9 crashes when opening a file
- Style:
15694: The Order of “By Layer” in the drop down list for Linetype attribute in styles dialog is different than other attributes
- View: Plan and RCP:
15775: Cut Plane not showing sectioned plan in Top view when units are blocks
Previous version:
Enjoy!
Enric
