VisualARQ 3.11 - Release Candidate 2 is now available for download.
NOTE: This is a release candidate (RC), meaning it is not the final version but has undergone internal testing and is considered stable enough for end-user testing. VisualARQ 3.11 is scheduled for official release on
Wednesday, August 5th, 2026
This release fixes most of the problems and crashes reported by users. Please report any problems or suggestions here or email us at visualarq@asuni.com.
List of changes since 3.11 RC1:
New Features (3)
- Object: Beam:
7615: Custom plane for beam end cuts
- Panel: Tables:
14941: List objects ID in tables
- Rhino WIP:
15795: Compatibility with Rhino 9
Improvements (1)
- Object: Guide:
15811: When a guide is outside an active section boundary, its elevation guides should not be shown
Fixed Errors (21)
- Crash:
15815: Crash after copying a curtain wall
- Grasshopper: Components:
15821: Wall main Level should be where the wall path is located14741: Wall is detected in two levels incorrectly
- Grasshopper: Style:
15510: Gumball at origin in a Grasshopper Style based beam
- IFC:
10087: It takes 30 minutes to open an IFC file
- Interferences:
15102: Door generates a wrong gap in a slab after adding it as interference14842: The subtraction of an object added as interference doesn’t update
- Level:
15858: Show Plan View reference on top of other objects
- Object:
15850: Hide UUID parameter from the Properties panel
- Object: Beam:
15826: I cannot set a custom Beam cut plane until I reload the Properties panel
- Object: Curtain Wall:
15359: Curtain wall extension error when curtain wall and surface borders are coincident14589: Curtain wall wrong result when moving it
- Object: Openings:
15844: It is not possible to change the opening dimensions when it is set to Other15834: Door opening doesn’t follow the grip point position
- Object: Plan View:
15853: Cut Plane Elevation property in Plan views doesn’t work
- Object: Roof:
15752: Roof gets flat after subtracting an inner boundary15029: Roof flips the alignment when it is moved next to another14527: Wrong gable roof intersections
- Object: Window:
15421: Leaf grip point doesn’t work for changing opening side of a window in a slab14567: Window can’t be placed in the extended part of a wall
- Print: Hidden Vector:
13836: Text in leader is not correctly aligned when printing it to PDF
Download links:
Previous version:
Enjoy!
