VisualARQ 3 - Version 3.12 released
Hi everyone,
VisualARQ 3.12 is now available for :arrow_down: download.
This is a maintenance release that fixes most of the critical issues and crashes reported by users. Please report any problems or suggestions here or send us an email to visualarq@asuni.com.
List of changes since 3.11:
Improvements (4)
  • API: Script:
    • 15433: Add method to get “Area” and “Volume” properties of VisualARQ objects
  • Object: Openings:
    • 15934: Extend opening profile to cut out the Normal layers of slabs
  • Object: Section:
    • 7213: Detect the sectioned edges of geometry for snapping
  • Rhino 9:
    • 15824: Support for Direct3D GPU Technology in Rhino 9
Changes (1)
  • Grasshopper: Components:
    • 15868: Replace icon for Plan Type Input in Grasshopper
Fixed Errors (56)
  • Crash:
    • 15945: Crash creating a plan view
  • DWG Export:
    • 15936: vaExportToDWG crashes Rhino
    • 15929: Displaced Drawing in DWG Export
    • 15919: Rhino crashes when exporting layout to DWG
  • Display:
    • 15970: Display slows down on a zoomed viewport when building boundaries are visible
    • 12332: Hidden display mode doesn’t show the selection dialogue
  • Dynamic Section:
    • 15895: Realtime plan viewport turns black
    • 15148: Space preview fails when geometry is referenced with Query Model Objects
  • IFC:
    • 16097: IFC import converts the same geometry more than once in parallel
    • 15820: Objects GUIDs should be 22 character length when exporting files to IFC with V4 Engine
    • 11500: Rhino closes after trying to export a file to IFC
    • 6109: Load VisualARQ when opening an IFC file
  • Interferences:
    • 15911: Crash after adding a beam as Interference to a wall
    • 15657: Strange holes appear in a roof
    • 15599: Slabs disappear when intersecting with some walls
    • 14879: I takes a long time to calculate the interference between a beam and a wall
  • Level:
    • 11496: Wrong picking when a level cut plane is enabled
  • Object:
    • 15068: Difficulty to select a slab with the model displayed in section
    • 14353: Difficult to select objects in Wireframe mode when some levels are hidden
    • 14008: Difficulty to select objects in top viewport
    • 11723: Rectangle Selection of objects in plan view only works with walls
    • 11390: Difficulty to select a window in plan view
    • 9449: 2D geometry is not completely selected in Hidden display
  • Object: Curtain Wall:
    • 8999: Uneven curtain wall cells distribution
  • Object: Openings:
    • 15921: Doors and windows are inserted in the base of the wall, instead of in the level elevation
  • Object: Plan View:
    • 15444: Wrong print color of hatch pattern set as view overrides in a plan view
  • Object: Section View:
    • 15890: Projection elements are not printed according to the Section Style configuration
    • 15876: 2D Section view doesn’t show section hatches of a polysurface
  • Object: Slab:
    • 15052: Slab disappears after joining with other walls and slabs
  • Object: Wall:
    • 15878: Invisible wall segment
    • 15134: Wall can’t be selected
    • 14648: Wall extension arrow is not selectable when it is above the level cut plane
  • Object: Window:
    • 15664: Window 2D representation is not displaying correctly in plan view, wall cut is missing
  • Other:
    • 13528: I cannot select curves in Hidden display mode
  • Performance:
    • 14906: Moving a wall is very slow in this file
  • Print:
    • 15907: Angular dimension text alignment is wrong in a printing result
    • 15892: Anti aliasing breaks after printing
    • 15209: Space labels don’t print
    • 14278: Missing lines when printing a model displayed in RCP
  • Print: Hidden Vector:
    • 15588: Element from block doesn’t print with the color by Layer
  • Rhino 9:
    • 16118: VisualARQ does’t load in Rhino 9 BETA
    • 16112: Objects can’t be selected in plan view / Hidden display when using Direct3D GPU
    • 16111: Section hatches on walls are not displayed when using Direct3D
    • 15943: VisualARQ objects are not displayed properly in Concept Display
    • 15940: VisualARQ doesn’t load in Rhino 9 BETA
    • 15823: VisualARQ display mode issues in Rhino 9
  • Snap:
    • 15917: The Intersection snap doesn’t work between a wall and a curve in plan view
    • 15777: Osnap not working when creating building blocks
    • 14967: Snapping on a corner wall doesn’t work
    • 13075: Dimensioning on a section is slow and unprecise
    • 13060: Osnaps are not working with sectioned objects in perspective view
    • 11689: Some snap points are not working in the layout
  • View:
    • 15930: Columns cannot be selected in plan view
    • 15224: It is not possible to select a group of objects with the rectangular selection in Hidden display
    • 9707: I cannot select a wall with pick option in Hidden display
  • View: Plan and RCP:
    • 15565: Element from block hides when activating the plan view
Previous version:
Enjoy!
Enric
i am having the same issue with levels i had with RC12 version, so i reverted back to version 3.11.
Please take a look at it.
Have you tried uninstalling all your VisualARQ versions (and also Lands Design if you have it) before installing this new update, as you did before?
Does this happen in the 3.13 RC1 update (if you have the chance to try it)? VisualARQ 3 - Version 3.13 RC1 released - #4 by fn_a
Hello @fsalla ,
I thought this is necessary for VA RC versions. If i need to do this for every Va update, i will not be updating in the future.
Its been sometimes now we have faced issues mid project. This makes it very difficult to both troubleshoot (install other versions, create posts with images explaining the issue) and keep our office productivity in good levels, which so far we are struggling, due to minor or moderate Va challenges. These mostly arise after deciding to update unfortunately..
So i will report back later, given the opportunity, about the 3.13 RC1 version.
best
alex
Thanks @ng5_Alex. Uninstalling VisualARQ is only necessary when rolling back to a previous version (from the 3.12 RC2 to the 3.11 SR0, for example). But going from the 3.12. SR0 to the 3.13 RC1 it is not necessary to uninstall first.
This problem should be fixed in VisualARQ 3.13 RC1, but we will include it in the next 3.12 SR1.
I see, sorry i misunderstood the uninstall part.
Ok, great, i will report back about 3.13 RC1 and/or 3.12 SR1.
