VisualARQ 3 - Version 3.10 released
Hi everyone,
VisualARQ 3.10 is now available for :arrow_down: download.
This is a maintenance release that fixes most of the critical issues and crashes reported by users. Please report any problems or suggestions here or send us an email to visualarq@asuni.com.
List of changes since 3.9.3:
Improvements (2)
  • Object: Tag:
    • 15625: Display Object Layer name in tags
  • Style:
    • 14981: Keep Layer list order in the Styles dialog
Fixed Errors (48)
  • Attributes:
    • 15656: Wrong Section hatch color in wall layer
    • 15618: Section hatch color is not used as printing color
    • 15504: Wrong Section Boundary color in print preview
  • Block:
    • 15645: The Purge command removes block definitions that are used by VisualARQ styles
  • Crash:
    • 15671: Crash after updating a section view
    • 15660: Crash after baking objects from a worksession file
    • 15644: Crash when using coma for decimals in door or window sizes
    • 15486: Rhino crashes when deleting a slab
  • Display:
    • 14147: Control points are not visible nor selectable when are occluded by other objects in Hidden display mode
  • Dynamic Section:
    • 15617: Section edges are not displayed in jogged sections
  • Grasshopper: Components:
    • 15706: Flip normals of solids with negative volume in the Add Solids and Subtract Solids components
    • 15703: Rhino hangs when baking extended walls with the Content Cache
    • 15702: Window Host doesn’t return any GUID
    • 15698: Rhino freezes when trying to push a roof with the Content Cache
    • 15662: Preview bug in old Grasshopper file with VisualARQ Objects
    • 15522: No Roof Preview
  • Grasshopper: Style:
    • 15649: Solid of subtraction is not visible in VisualARQ objects created as Grasshopper Styles
    • 15598: Hatch explode error in Grasshopper when using it in a Grasshopper Style
  • Help:
    • 15195: Link to “VisualARQ Forum” redirects to the wrong site
  • IFC:
    • 15746: Missing holes in slabs when importing an IFC file with the V4 engine > Parametric objects
    • 15745: Hidden objects are exported to IFC with the _Export command
    • 15722: Wall has no opening when exported to IFC using V4 engine
    • 15719: It takes a long time to export an IFC file
    • 15661: Crash opening an IFC2x3 file with the V4 Engine
    • 15659: Names in guides are not preserved in IFC files
    • 15653: VisualARQ gets stuck at opening this IFC 4 file
    • 15515: IFC file with V4 Engine and Parametric objects opens a model with incomplete geometry
    • 15376: Custom parameters are not detected in V4 Engine
    • 14815: Crash after opening an IFC file
    • 12124: Transparent materials are not exported correctly to IFC with V4 Engine
  • Interferences:
    • 15650: 2D curves in VisualARQ objects are not subtracted with the vaSubtractSolids command
  • Level:
    • 15647: Tooltips for the Level Manager
  • Material:
    • 15700: “By Parent” missing in Window Style material assignment
  • Object:
    • 15713: VisualARQ objects disappear after the Autosave
    • 15547: Snap doesn’t ignore the occluded objects
  • Object: Curtain Wall:
    • 15773: Door doesn’t generate properly the opening in a curtain wall
  • Object: Guide:
    • 15614: Control points are not editable in jagged section guides
    • 14411: Guides are not printed above the objects
  • Object: Section:
    • 14765: Surfaces section edges are not displayed
  • Object: Tag:
    • 15609: Tag is not displayed in perspective view
    • 15383: Show tags above the cut plane in RCP
  • Object: Views:
    • 15717: Make “Section Hatch Color” the print color in View overrides
  • Parameter:
    • 15665: Parameter filters are not saved
  • Plug-In: Block Edit New:
    • 15602: VisualARQ objects become block instances when exploding blocks created with the “Block Edit New” plug-in
    • 15354: Copied objects are not located correctly inside blocks, when using the “Block Edit New” plug-in
    • 15353: VisualARQ object control points are not available when using the “Block Edit New” plug-in
  • Print: Hidden Vector:
    • 15499: Dimension texts are not printed with the proper alignment
  • Solid Modifiers:
    • 15648: Handle component from Furniture object is not subtracted
Previous version:
Enjoy!
Enric
I detected an error with VisualArq version 3.10. Mirrored blocks unmirrored around the block baseplane while exporting to .ifc. I uninstalled visualarq and reinstalled an older version (3.7) which I still had on my computer. Then it exported correctly.
Hi @Tomas_van_Hamond I can see mirrored blocks are not being exported properly to IFC when using the V4 Engine. If you use the V3 Engine, it will work fine. We will fix it for the V4 Engine in the upcoming updates.
