VisualARQ 3.11 - Release Candidate 1 is now available for download.
NOTE: This is a release candidate (RC), meaning it is not the final version but has undergone internal testing and is considered stable enough for end-user testing. VisualARQ 3.11 is scheduled for official release on
Wednesday, August 5th, 2026
This release fixes most of the problems and crashes reported by users. Please report any problems or suggestions here or email us at visualarq@asuni.com.
List of changes since 3.10:
New Features (1)
- Other:
15795: Compatibility with Rhino 9
Changes (1)
- Interferences:
15394: Make slab layers have priority over wall layers in equal conditions
Fixed Errors (47)
- Attributes:
15503: Wrong section hatch print preview15325: Inconsistent Print Preview of section boundary color in “Hidden” display
- Constraints:
15744: Sub-level constraints don’t work properly to change wall height15743: Constraints don’t work in this file15374: Objects height doesn’t adjust to level changes
- DWG Export:
15691: Tags are appearing duplicated or out of place in the exported DWG file.15689: Wall lines are not visible in the exported DWG file.
- Display:
15762: Transparency issue with VisualARQ objects in “Ghosted” display
- Grasshopper: Components:
15699: Stair path curve is always in the 0 elevation15524: Error when defining a list of roof slopes in Grasshopper15202: Wrong tree structure when deconstructing slabs15136: Content Cache doesn’t bake VisualARQ objects to specific Layers14751: A slab created as Grasshopper style doesn’t recognize the input curve when it is created in Grasshopper14741: Wall is detected in two levels incorrectly
- Grasshopper: Style:
14943: Window created as a Grasshopper Style is inserted in slabs undesirably
- IFC:
15747: Nothing imports in IFC file
- Interferences:
15538: Wrong intersection between multilayer wall and slab14655: Interference error between a beam and a slab
- Language:
14022: Untranslated strings in VisualARQ 3
- Level:
15790: Level manager get hanged when activating the top level (with sublevels at inferior elevations only)
- Object: Column:
15709: Column alignment offset is not consistent
- Object: Curtain Wall:
15673: Curtain Wall from Curve: Glass panels not placed correctly15672: Circular curtain wall, the frame does not appear as expected.15416: Curtain wall from surface is not properly aligned15359: Curtain wall extension error when curtain wall and surface borders are coincident
- Object: Guide:
15640: Guides in a plan view lose their layer when plan view is exploded15615: Objects don’t snap properly on jogged guides15554: Guides are not displayed on the current CPlane15509: Snap to guides doesn’t work
- Object: Plan View:
15759: Furniture object doesn’t appear in a plan view
- Object: Roof:
15763: vaRoofSubtract shrinks the roof boundary15753: vaSubtracSolids doesn’t work with roofs15752: Roof gets flat after subtracting an inner boundary15561: Roof intersection bug15412: Window in roof doesn’t create the opening properly.15231: Shed roof slope changes direction when I decrease its angle14696: Wrong generation of a roof that has a window inserted
- Object: Slab:
15549: Wrong generation of slab with extended walls to it
- Object: Tag:
15728: vaPlanView plan displays tags from multiple floors15663: Tag above cut plane is displayed in plan view in page layout
- Object: Window:
15668: Window snapping below wall instead of base15391: Do not change the sill position when editing the window alignment offset
- Print:
15685: Leaders are not printed correctly15568: Hatch prints above the 2D representation of a Furniture15189: Wall joints are visible in a priting result of RCP
- Style:
15694: The Order of “By Layer” in the drop down list for linetype attribute in styles dialog is different than other attributes
- View: Plan and RCP:
15775: Cut Plane not showing sectioned plan in Top view when units are blocks
Download links:
Previous version:
Enjoy!
