VisualARQ 3.12 - Release Candidate 2 is now available for download.
NOTE: This is a release candidate (RC), meaning it is not the final version but has undergone internal testing and is considered stable enough for end-user testing. VisualARQ 3.12 is scheduled for official release on
Wednesday, October 7th, 2026
This release fixes most of the problems and crashes reported by users. Please report any problems or suggestions here or email us at visualarq@asuni.com.
List of changes since 3.12 RC1:
Improvements (2)
- Object: Openings:
15934: Extend opening profile to cut out the Normal layers of slabs
- Object: Section:
7213: Detect the sectioned edges of geometry for snapping
Changes (1)
- Grasshopper: Components:
15868: Replace icon for Plan Type Input in Grasshopper
Fixed Errors (32)
- DWG Export:
15936: vaExportToDWG crashes Rhino15929: Displaced Drawing in DWG Export15919: Rhino crashes when exporting layout to DWG
- Dynamic Section:
15895: Realtime plan viewport turns black
15148: Space preview fails when geometry is referenced with Query Model Objects
- IFC:
6109: Load VisualARQ when opening an IFC file
- Interferences:
15911: Crash after adding a beam as Interference to a wall
- Level:
11496: Wrong picking when a level cut plane is enabled
- Object:
15068: Difficulty to select a slab with the model displayed in section14353: Difficult to select objects in Wireframe mode when some levels are hidden14008: Difficulty to select objects in top viewport11723: Rectangle Selection of objects in plan view only works with walls11390: Difficulty to select a window in plan view
- Object: Curtain Wall:
8999: Uneven curtain wall cells distribution
- Object: Openings:
15921: Doors and windows are inserted in the base of the wall, instead of in the level elevation
- Object: Section View:
15890: Projection elements are not printed according to the Section Style configuration
- Object: Wall:
15134: Wall can’t be selected14648: Wall extension arrow is not selectable when it is above the level cut plane
- Object: Window:
15664: Window 2D representation is not displaying correctly in plan view, wall cut is missing
- Performance:
14906: Moving a wall is very slow in this file
- Print:
15907: Angular dimension text alignment is wrong in a printing result15892: Anti aliasing breaks after printing
- Print: Hidden Vector:
15588: Element from block doesn’t print with the color by Layer
- Rhino WIP - BETA:
15940: VisualARQ doesn’t load in Rhino 9 BETA
- Snap:
15917: The Intersection snap doesn’t work between a wall and a curve in plan view15777: Osnap not working when creating building blocks14967: Snapping on a corner wall doesn’t work13060: Osnaps are not working with sectioned objects in perspective view11689: Some snap points are not working in the layout
- View:
15930: Columns cannot be selected in plan view9707: I cannot select a wall with pick option in Hidden display
- View: Plan and RCP:
15565: Element from block hides when activating the plan view
Download links:
Previous version:
Enjoy!
