VisualARQ 2.12.4 is now available for download.
This is a minor release that solves most of the critical issues and crashes reported by users. Please report any problem or suggestion here or send us an email to visualarq@asuni.com.
Here is the list of changes:
Fixed bugs:
API: Script:
#11411
: “Integer” parameter in a Grasshopper style don’t work with VisualARQ Script APIFile:
#11546
: Cannot save a document after inserting a model as “Linked and Embed”Grasshopper: Components:
#11635
: Grasshopper Components don’t work when IronPython plugin cannot be loaded#11595
: Object parameters are baked as document parameters#11594
: Error: Object reference not set to an instance of an object#11495
: VisualARQ objects are not deleted when using the Elefront’s “Bakename” feature#10617
: Text is always baked with the Bottom-Left justificationGrasshopper: Style:
#11445
: Door Grasshopper style is not generated correctlyHelp:
#11433
: Some help links are not working with Rhino in JapaneseMaterial:
#11482
: Material dropdown in style editor doesn’t work with Flamingo nXt 3Object: Furniture:
#11626
: Furniture is not shown in a plan view when is inside a blockObject: Plan View:
#11511
: Strange artifact in Plan View#11510
: Plan view show the wall miter joints#11422
: Plan view doesn’t show wall section attributes when a window plan cut elevation is set as “Middle”Object: Railing:
#11515
: Crash when editing a railingObject: Slab:
#11516
: Intersections between slabs are drawn in wireframe display modeObject: Wall:
#11617
: I cannot select a curve to create a wall from a solid#11575
: Windows don’t make holes in walls after copying and pastingPrint:
#11285
: Layout is printed cutting the object in the wrong level when printing multiple layouts#11225
: Sections are not correctly enabled when printing multiple layoutsRender:
#11461
: VisualARQ objects turn into meshes after rendering with Flamigo nXt 5#11429
: VisualARQ objects don’t render Flamingo nXt materialsWorksessions:
#11450
: VisualARQ objects are not displayed in a worksession if you have a DWG embedded#11424
: Objects from an attached document are not printed correctly in Hidden vector output#11420
: Duplicated layer hierarchy when a non-active worksession document is updated
See the list of changes of VisualARQ 2.12
See the list of changes of VisualARQ 2.12.1
See the list of changes of VisualARQ 2.12.2
See the list of changes of VisualARQ 2.12.3
Enjoy!
Enric
