VisualARQ 2 - Version 2.12.5 released
VisualARQ 2.12.5 is now available for download.
This is a minor release that solves most of the critical issues and crashes reported by users. Please report any problem or suggestion here or send us an email to visualarq@asuni.com.
Here is the list of changes:
  • Crash:
    • #11747: Crash at opening file
    • #11716: Crash opening a file with linked blocks that was modified with VisualARQ blocked
    • #11667: Crash trying to create a plan view
  • Display:
    • #11790: It is not possible to select objects in a detail view if “Print Preview” is enabled with the “Hidden” display mode
  • Grasshopper: Components:
    • #11372: Geometry Cache component doesn’t work with VisualARQ objects
  • Grasshopper: Style:
    • #8472: Flipped texts in Grasshopper opening styles
  • Level:
    • #11772: Rhino crashes when activating a Cut Plane
  • Object: Annotation:
    • #11745: Annotation do not take into account the “Enable model space scaling” option
    • #11744: Annotations are not updated when the model space scale is enabled or disabled
  • Object: Plan View:
    • #11753: Crash after updating a plan view
    • #11736: Wall intersection lines are visible in plan view
    • #11704: Hatch is generated in a wrong rotation in a plan view
    • #11681: A hatch is drawn in Plan View when View Depth is “Level” or “Level Below”
    • #11179: Wrong size of section text in Plan Views
  • Object: Section View:
    • #11755: Section View overrides are not working
    • #11729: Flipped text in section view
    • #11654: Section view shows section hatches that should not be displayed
  • Object: Space:
    • #11743: Spaces are not updated when the annotation style is changed
  • Object: Views:
    • #11845: “By Parent” section pattern is not working on plan view
  • Other:
    • #11782: Object snaps are not working if there is any geometry on the level above
  • Performance:
    • #11759: VisualARQ regenerates graphics every time I draw a box
  • Print: Hidden Vector:
    • #11749: Curves missing when printing to pdf with the Hidden display mode
  • Template:
    • #11839: VisualARQ styles are not available in Japanese templates
    • #11455: Missing styles library in Russian VisualARQ templates
    • #11454: Missing styles library in Portuguese VisualARQ templates
    • #10104: Missing Korean styles library when opening a Korean template
    • #10008: Missing styles library in Chinese VisualARQ templates
See the list of changes of VisualARQ 2.12
See the list of changes of VisualARQ 2.12.1
See the list of changes of VisualARQ 2.12.2
See the list of changes of VisualARQ 2.12.3
See the list of changes of VisualARQ 2.12.4
Enjoy!
Enric
@enric @fsalla
Hi, after the update text sizes on VA objects freaked out. We defined text sizes in paper space, which is in mm (model space is in m). So, e.g. a text size of 2.5, was 2.5 mm on paper, and in the model whatever the “Model space scale” in the RH annotation styles was set to. This seemed to work for VA sections and Spaces too. Now both seem to ignore the model space scale value, though in opposite ways. Please see the file attached.
Edit: May you send us a link to roll back to the previous version. This is quite critical, because we cannot print at the moment.
Untitled.3dm (7.0 MB)
Hi @silvano,
The sections styles do not have any annotation style assigned, so the model space scaling is 1.0. If you set an annotation style, the scaling should be correctly applied.
Consider that the space scaling is not supported on VisualARQ objects, so the text will not scale on details. This will be implemented in VisualARQ 3.
Enric
Let me know if setting the appropriate annotation style fixes your issue. If not, I can send you a 2.12.4 installer if you are in a hurry, until we find out what the problem is.
Enric
Hi @enric Thanks for pointing out the missing Dimension Style setting. This fixes the issue. I am wondering if there was a change, because it was working for us before.
