I have such a big issue. After two weeks of working on my model, I realized that my model unit was in meter and that I was drawing as in milimeter.
So I tried to fix it by first changing the model unit and then scale my model. But at the end all my polysurface are shakings and not straight anymore. The problem is that I saved it as it’s (shaking) and can’t undo anymore.
Hello - the model is almost certainly very far from the origin - try selecting everything and moving to the world origin and see if that cleans things up.
I think you can work around this issue for now by saving the “shaky” model to a NEW file name; shutting down Rhino and the restarting/loading the new file.
You are probably not using SR12 since we just released our first release candidate for it this week. I just checked and the fix that I made won’t be available until next Tuesday, sorry.
You can check to see what version you are using by looking at the help->about screen or by running the SystemInfo command.
Here is information on getting the SR12 release candidate. Again, this specific fix will probably not show up until next week.
Load your 3dm file and run SaveSmall to save the model without render meshes. The meshes render meshes somehow were the massive meshes that must have been in place before you scaled the model.
