Section behavior when boundary touching walls
3 relevant questions in one thread:
  1. Sections are useful when wanting to cut unwanted geometry in a view. When accurately placing the section with the accurate desired boundaries, and the boundaries are touching the wall, in the 3d view a zero-thickness-surface of the wall appears. Which is the desired behavior of accurate sections?
  1. How can someone customize the UI of VA sections (and of other VA objects) for example enlarge the grip points, the arrows etc? We keep searching for hidden grips in all VA objects. Maybe I miss something on this and it’s doable somehow.
  2. WISH: jagged sections is something that’s missing right now. I’ve pointed out this out in the past. I believe it should be a top priority feature. Archicad has the desired functionality - I believe REVIT too. In VA you can create jagged sections, but only in terms of the section line. When activating the section in 3d the geometry is sectioned correctlyBut when the geometry is sectioned in a plan view (hidden mode for example) there are many things missing and I believe it’s not sectioned properly. It creates a section plan, based on a section-line-segment-direction of the jagged section line or an average vector of the jagged section line and also believe that there should exist the hidden-lines in each section change of direction. Check the images below. Also check the first image below, you should be able to select which segments will be involved in a section. For example in the first image, the red-circled line should be ignored and not create a perpendicular section-part on this but instead skipped in the section creation. From this point on, this segment (the ignored one) can be presented differently in floorpan (with a dashdot line or something).
Hello Gabriel,
regarding point #2 i have not found a VA specific option for this, so for the size of grip control etc points you can do it through Options/View/Display Modes/ and select a display mode (or change it for all available) to set the control point etc sizes in the available options menus.
This affects all rhino behavior and not only VA objects.
best
alexandros
Hello Alexandros,
that was useful. I confirm that there is some customizability. Although, I cannot find a way to customize the fill-color also. If you have any idea on how can we do this, please do not hesitate :slight_smile:
@fsalla Maybe controlling globally the draw order when editing (selecting) a vaelement, should be a nice way to do this.
Hello @GabrielB,
i would expect the solid square option to give full red color. At the moment its gets the same behavior with “square with white center” option, so i guess this is a rhino bug.
best
alexandros
*edit rhino geometry respects full color grips with solid option selected, thus not rhino bug.
@GabrielB
I guess the wall external surface should not be displayed, but I’m not sure if this is feasible. You can just move the section a bit to not be coincident with the wall.
  1. As @ng5_Alex pointed out, the grip points size of VisualARQ objects take the same settings as Rhino objects by Display.
I don’t understand what is missing here. Take into account that when you align a section to a view, the view is oriented perpendicular to the first segment of the section line. The rest of the view is displayed in projection from that first segment perpendicular direction. This doesn’t affect the plan view at all.
Exactly. It should not align the entire section to the first segment. It’s a feature WISH. I understand that it terms of development this is the desired functionality. What I am suggesting here, each segment should align differently but all the segments of the section should be connected. The same that Archicad handles the jagged sections. I’ve made notes above with red. A jagged section should work as a jagged section in plan view also. And respecting each segment projection and section per segment not apllying globally the first segment’s etc.
Yes for now it’s the only way. But you may want to study this, because there are things that are being limited due to this, such as auto section creation among a project. Precision is key. If the desired behavior is not displaying this zero thickness surface, then you might want to study this for future version.
I cannot make it filled red.Ah maybe you mean it gets filled by layer color?
Ok, I add your vote for this request. We may implement this in 2D Section views. Doing this in real-time views might be very difficult to implement.
We will see if we can avoid seeing that 0 thickness surface of the wall.
I see the VisualARQ objects are not taking all settings of the Rhino objects control points. They are only taking the size.
Hi @fsalla . Has this been fixed in the latest RC? By the way, can I install the RC while having the 3.10 installed? I am afraid to make the transition yet, because of the wall-slab priority change.
Hi @GabrielB we haven’t revised this issue yet. Since this has an easy workaround (move the section a bit to not be coincident with the wall), we are giving priority to other errors right now.
@fsalla ok, understood. What concerns me is not how difficult would it be to move a bit a single section. Please take into account, that we are actively building as users workflows all the time. In construction detailing, automating sections per room, per area etc is crucial. Please imagine having a large project, with many rooms and areas, and we’ve managed somehow to build this architecture of workflow:
automated room or area dependent section creation with a click, and automatic creation of layout with all the details and isometric per room/area. In that sense, it’s not about moving a single segment of the section, but taking into account the bugs and correcting constantly the workflow, otherwise we have to manually correct all sections. It’s not viable and it’s important for us to build precise workflows. So, I can understand why you place this bug low in your priorities but on the other hand in some aspects it’s important. Have you estimated how difficult whould it be to correct it? This bug and the automation problems behind this bug is relative to this post also: Stair inconsistent geometry when minimum widths applied
I don’t know if solving this problem is even feasible. Check what happens if you use a clipping plane with a solid, coincident with one of its faces:
okay, so once again, it’s rhino dependent? Can we report it somehow?
Yes, it might be Rhino dependent. VisualARQ Sections use the Clipping planes technology, and the VisualARQ objects are made out of Rhino solids. So if this worked with the Clipping plane and the solid, it would probably work well with the VisualARQ section and the wall. We can investigate if we can help it from our side, but again, there are other priorities right now. You can try to report that case of the clipping plane and a solid in the Forum (or write to McNeel Tech support).
