It seems that a bug in VisualArq workflows, is rhino dependent and it’s about clipping plane when touching solids, the zero thickness face of the solid is produced. The related topic is this one: Section behavior when boundary touching walls - #13 by fsalla
Hi Gabriel -
Please post a 3dm file and the output from the Rhino SystemInfo command.
Hi Wim,
The zero-length face is unwanted. Accuracy is important, so workarounds like moving the clipping plane 1mm is not something i’d prefer. Maybe this is how clipping plane works, but this results to problems - as mentioned in the linked topic.
test-clipping-plane.3dm (4.6 MB)
Rhino 8 SR32 2026-6-9 (Rhino 8, 8.32.26160.13001, Git hash:master @ 2804b73b0f4b4feba10cb8b0b07c18fce290de93)
License type: Commercial, build 2026-06-09
License details: Cloud ZooWindows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 15GB)
.NET 8.0.19Computer platform: LAPTOP - Plugged in [100% battery remaining]
Primary display: AMD Radeon™ Graphics (AMD) Memory: 1GB, Driver date: 5-29-2026 (M-D-Y).Integrated accelerated graphics device with 5 adapter port(s)
Primary OpenGL: NVIDIA GeForce RTX 4060 Laptop GPU (NVidia) Memory: 8GB, Driver date: 4-23-2026 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 596.36Integrated accelerated graphics device with 1 adapter port(s)
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Graphics level being used: OpenGL 4.6 (primary GPU’s maximum)Anti-alias mode: 4x
Mip Map Filtering: Linear
Anisotropic Filtering Mode: HighVendor Name: NVIDIA Corporation
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-23-2026
Driver Version: 32.0.15.9636
Z-Buffer depth: 24 bits
Total Video Memory: 8188 MBRhino plugins that do not ship with Rhino
C:\Users\gabri\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\D5LiveSync (e0d5e210-02f6-4ee9-a2b0-1675e225d958)\D5Conv.rhp “D5 Live Sync for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\Lands.rhp “Lands Design”
C:\ProgramData\McNeel\Rhinoceros\8.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino8.rhp “Datasmith Exporter” 5.7.4.0
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\VisualARQ.rhp “VisualARQ”
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\Users\gabri\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\Speckle.Connectors.Rhino8 (2153799A-0CEC-40DE-BC3A-01E5055222FF)\Speckle.Connectors.Rhino8.rhp “Speckle” 3.20.0.0
C:\Users\gabri\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\OmniverseLink\1.0.0-dev.20260511213634\OmniverseLink.rhp “OmniverseLink” 1.0.0.0
C:\Users\gabri\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\RhinoAgentHost\1.0.0-dev.20260508065801\RhinoAgentHost.rhp “RhinoAgentHost” 1.0.0.0
C:\ProgramData\McNeel\Rhinoceros\packages\8.0\LadybugTools\1.39.7\net8.0-windows\Ladybug.RH.Loader.rhp “Ladybug.RH.Loader” 1.39.7.0
C:\ProgramData\McNeel\Rhinoceros\packages\8.0\Pollination\1.65.21\net8.0-windows\Pollination.RH.Loader.rhp “Pollination.RH.Loader” 1.65.21.0
c:\Users\gabri\Documents\vs-code\project-point\src\ProjectPoint\bin\Debug\net48\ProjectPointPlugin.rhp “ProjectPointPlugin” 0.0.0.0Rhino plugins that ship with Rhino
C:\Program Files\Rhino 8\Plug-ins\SolidTools.rhp “SolidTools”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.32.26160.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.32.26160.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.32.26160.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.32.26160.13001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.32.26160.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.32.26160.13001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.32.26160.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.32.26160.13001
C:\Program Files\Rhino 8\Plug-ins\Calc.rhp “Calc”
