Rhino BETA Available Now!
New feature development for Rhino 9 happens in the Rhino BETA. You need a Rhino 8 license to download and run Rhino BETA. Download now!
Below is a complete list of changes in Rhino BETA (starting with a couple years of Rhino WIP release notes). For release-by-release notes, scroll down.
Rhino 9 WIP (9.0.24114) is now available for Windows and Mac
New in Rhino WIP:
  • All the fixes in Rhino 8, plus:
Bugs Fixed:
  • Gumball: Moving origin not remembered on Groups (RH-16422)
  • MergeAllCoplanarFaces: Creates weird geometry (RH-77273)
  • Undo: CRhinoGroupTable::AddGroup not undo-able (RH-13444)
Enhancements:
  • Layout: Added "New Detail" Button to Layout Panel (RH-81408)
  • SelDup: Finds polylines of same shape with different seam locations (RH-79074)
  • TextObject: Allows setting scale of small caps to 100% and above (RH-76797)
Features Added:
  • Constraints: Added MidPointConstraint command (RH-70516)
  • NextDetail: New NextDetail command (RH-81112)
  • PrevDetail: New PrevDetail command (RH-81113)
UI Change:
  • Line: FourPoint option is renamed 4Point (RH-79314)
  • MergeEdge: Improved workflow (RH-80332)
Rhino 9 WIP (9.0.24135) is now available for Windows and Mac
This release of the RhinoWIP contains only upstream fixes from Rhino 8.
Rhino 9 WIP (9.0.24137) is now available for Windows and Mac
Rhino 9 WIP (9.0.24138) is now available for Windows and Mac
Rhino 9 WIP (9.0.24142) is now available for Windows and Mac
Rhino 9 WIP (9.0.24157) is now available for Windows and Mac
This release of the RhinoWIP includes upstream fixes from Rhino 8, plus:
Bugs Fixed:
  • ImportOptions: Rhino 9 for Mac cannot read plist (RH-82313)
Rhino 9 WIP (9.0.24163) is now available for Windows and Mac
Rhino 9 WIP (9.0.24170) is now available for Windows and Mac
This release of the RhinoWIP contains upstream fixes from Rhino 8 as well as …
Bugs Fixed:
  • Offset: Improve loose curve offset results (RH-81146)
Enhancements:
  • Grasshopper: Added Texture Evaluator component for rasterizing a procedural texture (RH-82500)
:building_construction:
Rhino 9 WIP (9.0.24177) is now available for Windows and Mac
This release of the RhinoWIP contains upstream fixes from Rhino 8.
Rhino 9 WIP (9.0.24191) is now available for Windows and Mac
New Features:
Bugs Fixed:
  • Rendering: Mapping, display, rendering; meshes and breps: inconsistent (RH-32597)
Rhino 9 WIP (9.0.24198) is now available for Windows and Mac
Features Added:
  • Elmo:
Rhino 9 WIP (9.0.24205) is now available for Windows and Mac
Bugs Fixed:
  • MergeAllCoplanarFaces: Broken in Rhino 9 WIP (RH-83072)
Features Added:
  • Elmo: Preserve kinks during curve reconstruction (RH-82873)
Rhino 9 WIP (9.0.24212) is now available for Windows and Mac
Bugs Fixed:
  • SelDup: selects duplicates in V9 when no duplicates exist (RH-83101)
Rhino 9 WIP (9.0.24219) is now available for Windows and Mac
Features Added:
  • TextObject: Added "Apply Kerning" option (RH-25758)
Rhino 9 WIP (9.0.24240) is now available for Windows and Mac
Bugs Fixed:
  • Keyboard Shortcuts: Add single key aliases (RH-79255)
  • Rendering: Materials: Blend material does not blend (RH-72321)
Features Added:
  • Keyboard Shortcuts: Instant Aliases (RH-83422)
Rhino 9 WIP (9.0.24254) is now available for Windows and Mac
Bugs Fixed:
  • Options: Eto version of Aliases Page (RH-83423)
Features Added:
  • Keyboard Shortcuts: ToggleInstantAliases Command (RH-83687)
Rhino 9 WIP (9.0.24261) is now available for Windows and Mac
Bugs Fixed:
  • Detail: FromCurve Shortcut Letter (RH-83767)
    • Aliases list gets erased when Restore Defaults is clicked (RH-83737)
    • CA does not work as an Instant alias (RH-83738)
  • Layout: Non rectangular details (RH-2574)
  • Offset: Offset fails to trim on open case (RH-72891)
Enhancements:
  • Display: Added Method in Display Pipeline to be able to DrawClippingPlane (RH-83198)
Regressions Fixed:
  • Detail: Projection Option Missing (RH-83768)
Mac-Only Changes
Enhancements:
  • Rebuild: Not clear when preview is automatic (RH-83698)
Rhino 9 WIP (9.0.24268) is now available for Windows and Mac
Bugs Fixed:
  • Filtered Alias list incorrectly saves on apply (RH-83877)
Enhancements:
  • Keyboard Shortcuts: ToggleInstantAliases - Delay Option (RH-83907)
Windows-Only Changes
Bugs Fixed:
  • Settings: OptionsImport - Freeze (RH-83873)
