Rhino BETA Available Now!
Rhino 9 WIP (9.0.24275) is now available for Windows and Mac
Bugs Fixed:
  • Alias: Reimplement Jump to existing (RH-83724)
  • Keyboard Shortcuts: CA does not work as an Instant alias (RH-83738)
Rhino 9 WIP (9.0.24282) is now available for Windows and Mac
Features Added:
  • Annotation: Leader: Leader: Round mask (Balloon leaders) (RH-29235)
Rhino 9 WIP (9.0.24303) is now available for Windows and Mac
Bugs Fixed:
  • Keyboard Shortcuts: Global checkbox to make all aliases "instant" (RH-83876)
Enhancements:
  • Ribbon: BothSides option merges surfaces if possible (RH-5500)
Rhino 9 WIP (9.0.24311) is now available for Windows and Mac
Bugs Fixed:
  • Annotation: Text: Kerning text (RH-52520)
  • BooleanUnion: Booleans should continue through failure (RH-83180)
Rhino 9 WIP (9.0.24317) is now available for Windows and Mac
Bugs Fixed:
  • Display: Decal with transparency is incorrectly blended with object color (RH-83717)
  • Join: Unsuccessful join converts an extrusion to a surface (RH-84498)
Features Added:
  • BlockEdit: Allow sub-selected objects in blocks to be deleted (RH-80067)
  • Selection: New SelHatchPattern command (RH-63544)
Rhino 9 WIP (9.0.24325) is now available for Windows and Mac
Bugs Fixed:
  • Add search filtering to SelHatchPattern UI (RH-84728)
  • FilletCorners: Add History support to the FilletCorners command (RH-84822)
  • Mesh: Some display modes preview meshes in blue color (RH-84708)
  • Notes: Search does not update position of occurrence after editing notes (RH-84765)
  • SelHatchPattern: Does not work with preselection (RH-84702)
UI Change:
  • Add check selector to SelHatchPattern's grid (RH-84713)
Rhino 9 WIP (9.0.24331) is now available for Windows and Mac
Bugs Fixed:
  • v9 Alias wrong macro or no macro executed. (RH-84757)
  • Rhino 9 - plug-in error on launch (RH-79263)
  • BlockEdit: Do not allow deleting sub-selected objects in linked blocks (RH-84706)
Features Added:
  • Commands: Added BothSides option to Box, Cone, TruncatedCone, Pyramid, TruncatedPyramid, MeshBox, MeshCone, and MeshTruncatedCone commands (RH-63751)
Rhino 9 WIP (9.0.24338) is now available for Windows and Mac
Bugs Fixed:
  • GlobalEdgeContinuity:
    • Show only labels of numbers in table (RH-84908)
    • Change default edge thickness (RH-84914)
  • PushPull: Investigate allowing PushPull to not break history with certain commands (RH-81144)
Mac-Only Changes
Bugs Fixed:
  • Keyboard: Arrow keys when the command line has typing and focus (RH-79960)
Rhino 9 WIP (9.0.24345) is now available for Windows and Mac
Enhancements:
  • Ellipse: Added FitPoints option (RH-78096)
  • UserText: Added "Selection Function Object(s)" to context menu in Document and Layout User Text (RH-66060)
Windows-Only Changes
Bugs Fixed:
  • File IO: Added option to disable saving backup files for non-3dm file types (RH-48512)
Rhino 9 WIP (9.0.24352) is now available for Windows and Mac
Crashes Fixed:
  • Aliases: Instant ChangeLayer Crashes Rhino (RH-85206)
UI Change:
  • Document UserText: New icon for textfield driven by object (RH-85047)
Rhino 9 WIP (9.0.25007) is now available for Windows and Mac
Enhancements:
  • Rendering: Decals: Create a single decal widget for grouped objects (RH-38367)
  • TextObject: More group output options (RH-83240)
Features Added:
  • File IO: Saves image files used by Rhino "Pictures" in an image folder next to the DWG/DXF file (RH-85056)
Rhino 9 WIP (9.0.25014) is now available for Windows and Mac
Bugs Fixed:
  • Instant Alias crash report. (RH-85378)
  • File IO: Support importing nested layers from DWG/DXF files (RH-66996)
Crashes Fixed:
  • FilletEdge: Crashes when preview is enabled (RH-85486)
Enhancements:
  • Aliases: v9 Aliases export csv and optional Instant state export (RH-85207)
  • File IO: Supports reading vertex colors from Gaussian splat PLY files (RH-85444)
  • PushPull: Allows selecting multiple surfaces (RH-78277)
Enhancements:
  • Export: File export commands fill file name, and add/increase number suffix (RH-56888)
Rhino 9 WIP (9.0.25021) is now available for Windows and Mac
Enhancements:
  • Aliases: OptionsExport and OptionsImport needs Alias "Instant" support (RH-85561)
Mac-Only Changes
Crashes Fixed:
  • Zebra: Crash: ZebraOff command (RH-85557)
Rhino 9 WIP (9.0.25035) is now available for Windows and Mac
Bugs Fixed:
  • Emap: dialog flcker from Zebra settings (RH-79272)
Enhancements:
  • Grasshopper: Created new base class for Texture Mapping components (RH-84682)
  • Zebra:
    • Move the stripes (RH-38247)
    • Make a mode that displays dots instead of vertical or horizontal stripes (RH-75094)
Features Added:
  • Zebra: Wish for "static" zebra (RH-58682)
Bugs Fixed:
  • Display: Black pixels on the boundary of objects with Metal material. (RH-85884)
Rhino 9 WIP (9.0.25043) is now available for Windows and Mac
Bugs Fixed:
  • Display: Plastic materials hide zebra stripes (RH-68173)
  • Make2D:
    • Clipping Failure Sample (RH-84979)
    • Selective Clipping Participation: No Input Found (RH-84707)
  • Zebra: rendered mode shadows show through updated object (RH-85998)
Enhancements:
  • Block: Export and import support block definition properties (RH-85589)
  • Zebra:
    • Added several analysis modes (RH-75094)
    • Stripe colors can be set transparent (RH-86024)
Features Added:
  • Clipboard: New PasteAsBlock command (RH-2264)
  • Display: Support for Interpreted Color: AutoCAD Color 7 (RH-67037)
Rhino 9 WIP (9.0.25056) is now available for Windows and Mac
Bugs Fixed:
  • ClippingDrawings: EditClippingDrawings: Offsets Background (RH-84226)
Enhancements:
  • FillSrf: : add Grasshopper component (RH-86003)
Rhino 9 WIP (9.0.25063) is now available for Windows and Mac
Bugs Fixed:
  • Disable view change in markup (RH-86181)
  • Clipboard: CutAt Command (RH-86030)
  • CurvatureAnalysis: Colors are inverted (RH-86247)
  • Display: Black/White Switching does not work for surface control polygons (RH-86079)
  • Layout: SetDetailBorder command can run in model viewports (RH-86093)
  • RDK: Deleted material re-appears after selecting object (RH-86254)
Crashes Fixed:
  • Display: Black/White Switching crashes block related commands (RH-86314)
Enhancements:
  • UntrimHoles: Untrim: Window select edges (RH-21139)
  • Zebra: Added dot analysis mode (RH-75094)
Features Added:
  • Grasshopper 2: Shipping with Rhino 9 WIP (RH-85673)
SDK Enhancement:
  • RDK: Made it possible to set decal properties (RH-64608)
UI Change:
  • CommandHelp: Help panel could use ribbon control for back and forward (RH-59193)
  • Notes: Changed search UI in Notes panel (RH-86294)
Mac-Only Changes
Bugs Fixed:
  • File IO: Mesh data is not compressed in 3DM on Mac (RH-83527)
Bugs Fixed:
  • Aliases:
    • Underscore is not visible in command macros (RH-86185)
    • Instant Alias Delay time resets to default (RH-86182)
Rhino 9 WIP (9.0.25070) is now available for Windows and Mac
Bugs Fixed:
  • Clipboard: Copy slow when there are lots or large textures (RH-47093)
Enhancements:
  • FillSrf: GH component, use optional input for more user-friendly behavior (RH-86287)
Features Added:
  • OSnap: Restrict picks to snapped ones (RH-75012)
Rhino 9 WIP (9.0.25077) is now available for Windows and Mac
Bugs Fixed:
  • Elmo:
    • PrettyPolygon option has disappeared (RH-85266)
    • rebuilt curve deviation report different from CrvDeviation (RH-85265)
  • ExportBlockAttributes: Value of Insert Point Y is identical with Z (RH-86532)
  • File IO: Files Open Fine in RH7, Not in RH8 (RH-85040)
  • Rendering: Glass material is useless in Rendered mode. (RH-81590)
  • Section Tools:
    • SaveClippingSectionViews become parallel (RH-80002)
    • SaveClippingSectionCPlanes: Works differently on clipping widgets created by ClipppingPlane command (RH-76788)
  • SimplifyCrv: SimplifyCrv fails on closed polyline (RH-86176)
Enhancements:
  • Elmo: C++ Elmo enhanced to support variable point count (RH-86307)
  • FillSrf: Improved the Brep decoration in FilletEdge, FillSrf GH components (RH-86403)
  • OffsetSubD: Added Offset = ControlPoints / SurfacePoints option (RH-58984)
Performance Improvements:
  • Rendering: Materials: Content cache causes slowness (RH-85462)
SDK Enhancement:
  • OpenNURBS: Update opennurbs examples to platform toolset 143 (RH-86542)
Tasks Completed:
  • OpenNURBS: Update OpenNURBS zlib to 1.3.1 (RH-63503)
Rhino 9 WIP (9.0.25084) is now available for Windows and Mac
Bugs Fixed:
  • OffsetSrf: Solid option gives wrong result (RH-75692)
Enhancements:
  • FillSrf: : specify an input surface (RH-86009)
  • GlobalEdgeContinuity: EdgeContinuity: use display precision (RH-85975)
Mac-Only Changes
Bugs Fixed:
  • ScriptEditor: Hint menu does not work on macOS (RH-83726)
