There is a new Rhino 6 for Mac Work In Progress (WIP) build available.
WARNING: The in-application update process DOES NOT work when running 6.14.19043.12076. It will act like it works, but it will always fail. Please download a new version directly from http://www.rhino3d.com/go/download/rhino-for-mac/wip/latest
This build is for testing purposes only. DO NOT USE for critical work.
IMPORTANT: If you have not already done so, please update AND RUN the latest Rhino 5 for Mac before using this RhinoWIP. This will migrate your Mac V5.4 Preference settings to the latest Mac V5/Mac V6 Preference settings.
What’s New in this RhinoWIP:
- Update system should now work as expected
- Fixed a major bug that caused object properties controls to deactivate
- Match Hatch now works as it should
- Display pipeline changes to address red viewports
- Autosave is now disabled for V5 files and displays a warning
- Fixed a bug with Layer visibility toggle
- Light controls should now work
- Grasshopper:
- Splash screen now shows CloudZoo User and Team information
- Other bug fixes, performance, and stability enhancements
Please report any problems you find in the Serengeti Mac forum.
Requires macOS High Sierra or later
