Peugeot
(Thomas Peugeot)
February 16, 2019, 6:34pm
1
Sequence:
double click on the board → the “Enter a search keyword …” window popup
type “Mass” → the “Mass addition” appears in the above menu
select “Mass addition” → the “Mass addition” component appears with a tip window describing the “Mass addition” component
click anywhere on the board but on the component
Unexpected result:
The tip window remains forever until one clicks on the component (see screen capture below)
Expected result:
A short lived tip window
about rhino output.txt (2.4 KB)
dan
(Dan)
February 18, 2019, 4:48pm
2
Thank you for reporting this. I believe this is a case of RH-50725 , which we think we’ve fixed. The fix should be in the upcoming RhinoWIP. I’ll let you know when that is available to test.
dan
(Dan)
February 26, 2019, 11:49pm
3
This should be fixed in the latest RhinoWIP . Please give it try. Thanks again for reporting this.
Peugeot
(Thomas Peugeot)
February 27, 2019, 8:18pm
4
Problem solved with 6.14. Thanks.
