Rhino crashes when trying to render a drawing. It can be the smallest to the biggest rest.
Sorry, the last word is resolution.
Sorry, my question was about Rhino crashing when I am rendering a model. I was able to render a complicated model without a problem, even if it took quite a while, but these last few days Rhino crashed several times after clicking the render command and also using different resolutions.
Joe
Envoyé de mon iPhone
Hi - I moved your latest post to this thread as the other thread where it appeared was about copy-paste issues.
We will need some more information about this problem with rendering.
You write that you used to be able to render without problems. What has changed?
Does the crash happen with any model, like a simple box in a factory-default template file?
Are you sending in crash reports?
Please run the Rhino SystemInfo command and post the result here.
I will try different objects. The only thing that has changed is that the Rhino version is no longer the beta.
Thanks
Joe
So the problem has been solved?
Hi - which problem?
New question. When I use the rendered mode of objects in the workplace they are black, what can I do so that they are white like they are sunlit?
Wim - I have the same problem while attempting to render a very simple model within the Rhino 6 evaluation installed last night. Crash report and System info follows:
Rhino 6 for MAC trial crash when render
Anonymous UUID: F8791461-74C1-B665-9B38-DA0C65ABB2BB
Sun Nov 10 23:39:19 2019
*** Panic Report ***
panic(cpu 4 caller 0xffffff80142dd16d): Kernel trap at 0xffffff7f952bb716, type 14=page fault, registers:
CR0: 0x0000000080010033, CR2: 0x0000000000000030, CR3: 0x000000046b9dd0a4, CR4: 0x00000000001626e0
RAX: 0xffffff81e0044010, RBX: 0x0000000000000000, RCX: 0x0000000000000008, RDX: 0x0000000000000006
RSP: 0xffffff9246393780, RBP: 0xffffff92463937f0, RSI: 0x0000000000000000, RDI: 0xffffff81b39c91f0
R8: 0x0000000000000000, R9: 0xffffff8014a9fa30, R10: 0xffffff8014a9fa50, R11: 0xffffff921548aff0
R12: 0xffffff9246393898, R13: 0xffffff81e0044010, R14: 0x0000000000000008, R15: 0xffffff81e0035000
RFL: 0x0000000000010293, RIP: 0xffffff7f952bb716, CS: 0x0000000000000008, SS: 0x0000000000000010
Fault CR2: 0x0000000000000030, Error code: 0x0000000000000000, Fault CPU: 0x4, PL: 0, VF: 0
Backtrace (CPU 4), Frame : Return Address
0xffffff9246393250 : 0xffffff80141af82d
0xffffff92463932a0 : 0xffffff80142eb795
0xffffff92463932e0 : 0xffffff80142dcf4a
0xffffff9246393350 : 0xffffff801415cae0
0xffffff9246393370 : 0xffffff80141af247
0xffffff9246393490 : 0xffffff80141af093
0xffffff9246393500 : 0xffffff80142dd16d
0xffffff9246393670 : 0xffffff801415cae0
0xffffff9246393690 : 0xffffff7f952bb716
0xffffff92463937f0 : 0xffffff7f952baa28
0xffffff9246393870 : 0xffffff7f952bbf6c
0xffffff9246393900 : 0xffffff7f952bc7f2
0xffffff9246393960 : 0xffffff7f951f95e1
0xffffff92463939a0 : 0xffffff7f952bc4d0
0xffffff92463939f0 : 0xffffff7f951efdb8
0xffffff9246393a80 : 0xffffff8014888a2c
0xffffff9246393ae0 : 0xffffff8014886c50
0xffffff9246393b30 : 0xffffff801488ff92
0xffffff9246393c70 : 0xffffff80142970c6
0xffffff9246393d80 : 0xffffff80141b506c
0xffffff9246393dd0 : 0xffffff801418fa91
0xffffff9246393e50 : 0xffffff80141a42fe
0xffffff9246393ef0 : 0xffffff80142c3e87
0xffffff9246393fa0 : 0xffffff801415d2c6
Kernel Extensions in backtrace:
com.apple.iokit.IOAcceleratorFamily2(404.8)[2B970BDA-3F88-31F1-9A04-D52B72F2D784]@0xffffff7f951eb000->0xffffff7f9528ffff
dependency: com.apple.driver.AppleMobileFileIntegrity(1.0.5)[F3F09078-2CDE-3D01-A96C-CB38E035E1D5]@0xffffff7f951a4000
dependency: com.apple.iokit.IOSurface(255.4.2)[B0AD599E-B346-3695-B7BE-3433421D9085]@0xffffff7f951c0000
dependency: com.apple.iokit.IOPCIFamily(2.9)[54C3F778-4B95-3093-A51D-D761607C96CB]@0xffffff7f94a95000
dependency: com.apple.iokit.IOGraphicsFamily(530.60)[9E233908-09E1-332E-AE9B-CB27D514707B]@0xffffff7f94d7e000
dependency: com.apple.iokit.IOReportFamily(47)[86DDD149-2800-3D3E-9914-3556918455F1]@0xffffff7f951e4000
com.apple.GeForce(12.0)[C918EC81-3928-3EC3-8B8A-5CBF86E369F1]@0xffffff7f952a0000->0xffffff7f9533bfff
dependency: com.apple.iokit.IONDRVSupport(530.51)[458BF6DD-CD72-3528-9DA1-6E9803B42B77]@0xffffff7f94dd7000
dependency: com.apple.nvidia.driver.NVDAResman(12.0.0)[AE94AB7B-ECE1-31E6-8165-08FF46E8CF81]@0xffffff7f94df3000
dependency: com.apple.iokit.IOAcceleratorFamily2(404.8)[2B970BDA-3F88-31F1-9A04-D52B72F2D784]@0xffffff7f951eb000
BSD process name corresponding to current thread: Rhinoceros
Mac OS version:
18E226
Kernel version:
Darwin Kernel Version 18.5.0: Mon Mar 11 20:40:32 PDT 2019; root:xnu-4903.251.3~3/RELEASE_X86_64
Kernel UUID: 4170BF94-38B6-364F-A1B0-2F7C2C30F9A9
Kernel slide: 0x0000000013e00000
Kernel text base: 0xffffff8014000000
__HIB text base: 0xffffff8013f00000
System model name: MacBookPro11,3 (Mac-2BD1B31983FE1663)
System uptime in nanoseconds: 275524658719
last loaded kext at 26680160025: com.apple.filesystems.msdosfs 1.10 (addr 0xffffff7f958e8000, size 69632)
loaded kexts:
com.apple.driver.AppleBluetoothMultitouch 96
com.apple.driver.AppleHWSensor 1.9.5d0
com.apple.driver.AudioAUUC 1.70
com.apple.fileutil 20.036.15
com.apple.filesystems.autofs 3.0
com.apple.driver.AGPM 110.25.2
com.apple.driver.ApplePlatformEnabler 2.7.0d0
com.apple.driver.X86PlatformShim 1.0.0
com.apple.filesystems.ntfs 3.13
com.apple.driver.AppleHDAHardwareConfigDriver 282.54
com.apple.driver.AppleHDA 282.54
com.apple.driver.AppleGraphicsDevicePolicy 3.30.14
com.apple.AGDCPluginDisplayMetrics 3.30.14
com.apple.driver.AppleUpstreamUserClient 3.6.5
com.apple.GeForce 12.0.0
com.apple.driver.AppleHV 1
com.apple.iokit.IOUserEthernet 1.0.1
com.apple.iokit.IOBluetoothSerialManager 6.0.11f4
com.apple.driver.pmtelemetry 1
com.apple.driver.AppleIntelHD5000Graphics 12.0.8
com.apple.Dont_Steal_Mac_OS_X 7.0.0
com.apple.driver.eficheck 1
com.apple.driver.AppleFIVRDriver 4.1.0
com.apple.nvidia.NVDAStartup 12.0.0
com.apple.driver.AGDCBacklightControl 3.30.14
com.apple.driver.AppleLPC 3.1
com.apple.driver.AppleIntelFramebufferAzul 12.0.8
com.apple.driver.AppleOSXWatchdog 1
com.apple.driver.AppleMuxControl 3.30.14
com.apple.driver.AppleSMCLMU 212
com.apple.driver.AppleCameraInterface 6.8.0
com.apple.driver.ACPI_SMC_PlatformPlugin 1.0.0
com.apple.driver.AppleIntelSlowAdaptiveClocking 4.0.0
com.apple.driver.AppleThunderboltIP 3.1.2
com.apple.driver.AppleBacklight 170.12.11
com.apple.driver.AppleMCCSControl 1.5.6
com.apple.iokit.IOBluetoothUSBDFU 6.0.11f4
com.apple.iokit.SCSITaskUserClient 408.250.3
com.apple.driver.AppleUSBStorageCoexistentDriver 456.250.6
com.apple.driver.AppleUSBCardReader 456.250.6
com.apple.driver.AppleUSBTCKeyEventDriver 255
com.apple.driver.AppleUSBTCButtons 255
com.apple.driver.AppleUSBTCKeyboard 255
com.apple.driver.AppleFileSystemDriver 3.0.1
com.apple.driver.AppleVirtIO 2.1.3
com.apple.filesystems.hfs.kext 407.200.4
com.apple.AppleFSCompression.AppleFSCompressionTypeDataless 1.0.0d1
com.apple.BootCache 40
com.apple.AppleFSCompression.AppleFSCompressionTypeZlib 1.0.0
com.apple.AppleSystemPolicy 1.0
com.apple.filesystems.apfs 945.250.134
com.apple.driver.AppleAHCIPort 329.200.2
com.apple.private.KextAudit 1.0
com.apple.driver.AirPort.BrcmNIC 1400.1.1
com.apple.driver.AppleHPET 1.8
com.apple.driver.AppleSmartBatteryManager 161.0.0
com.apple.driver.AppleACPIButtons 6.1
com.apple.driver.AppleRTC 2.0
com.apple.driver.AppleSMBIOS 2.1
com.apple.driver.AppleACPIEC 6.1
com.apple.driver.AppleAPIC 1.7
com.apple.nke.applicationfirewall 190
com.apple.security.TMSafetyNet 8
com.apple.driver.IOBluetoothHIDDriver 6.0.11f4
com.apple.driver.AppleMultitouchDriver 2440.7
com.apple.driver.AppleInputDeviceSupport 2440.2
com.apple.kext.triggers 1.0
com.apple.driver.DspFuncLib 282.54
com.apple.kext.OSvKernDSPLib 528
com.apple.nvidia.driver.NVDAGK100Hal 12.0.0
com.apple.iokit.IOAVBFamily 740.1
com.apple.plugin.IOgPTPPlugin 740.2
com.apple.iokit.IOEthernetAVBController 1.1.0
com.apple.iokit.IOSkywalkFamily 1
com.apple.nvidia.driver.NVDAResman 12.0.0
com.apple.driver.AppleSSE 1.0
com.apple.AppleGPUWrangler 3.30.14
com.apple.driver.AppleHDAController 282.54
com.apple.iokit.IOHDAFamily 282.54
com.apple.driver.AppleSMBusPCI 1.0.14d1
com.apple.iokit.IOAcceleratorFamily2 404.8
com.apple.iokit.IOSurface 255.4.2
com.apple.AppleGraphicsDeviceControl 3.30.14
com.apple.driver.AppleGraphicsControl 3.30.14
com.apple.driver.IOPlatformPluginLegacy 1.0.0
com.apple.driver.X86PlatformPlugin 1.0.0
com.apple.driver.IOPlatformPluginFamily 6.0.0d8
com.apple.iokit.IOSlowAdaptiveClockingFamily 1.0.0
com.apple.driver.AppleThunderboltEDMSink 4.2.0
com.apple.driver.AppleThunderboltDPOutAdapter 5.6.2
com.apple.driver.AppleBacklightExpert 1.1.0
com.apple.iokit.IONDRVSupport 530.51
com.apple.driver.AppleSMBusController 1.0.18d1
com.apple.iokit.IOGraphicsFamily 530.60
com.apple.driver.AppleHIDKeyboard 208
com.apple.iokit.BroadcomBluetoothHostControllerUSBTransport 6.0.11f4
com.apple.iokit.IOBluetoothHostControllerUSBTransport 6.0.11f4
com.apple.iokit.IOBluetoothHostControllerTransport 6.0.11f4
com.apple.iokit.IOBluetoothFamily 6.0.11f4
com.apple.iokit.IOUSBMassStorageClass 4.0.4
com.apple.driver.AppleUSBMultitouch 263
com.apple.driver.AppleUSBAudio 315.6
com.apple.driver.usb.IOUSBHostHIDDevice 1.2
com.apple.iokit.IOAudioFamily 206.5
com.apple.vecLib.kext 1.2.0
com.apple.driver.usb.cdc 5.0.0
com.apple.driver.usb.networking 5.0.0
com.apple.driver.usb.AppleUSBHostCompositeDevice 1.2
com.apple.driver.usb.AppleUSBHub 1.2
com.apple.iokit.IOSerialFamily 11
com.apple.filesystems.hfs.encodings.kext 1
com.apple.driver.AppleUSBMergeNub 900.4.2
com.apple.driver.AppleXsanScheme 3
com.apple.iokit.IOAHCIBlockStorage 301.250.5
com.apple.iokit.IOAHCIFamily 288
com.apple.driver.AppleThunderboltDPInAdapter 5.6.2
com.apple.driver.AppleThunderboltDPAdapterFamily 5.6.2
com.apple.driver.AppleThunderboltPCIDownAdapter 2.1.4
com.apple.driver.AppleThunderboltNHI 4.7.6
com.apple.iokit.IOThunderboltFamily 6.8.4
com.apple.iokit.IO80211Family 1200.12.2
com.apple.driver.mDNSOffloadUserClient 1.0.1b8
com.apple.driver.corecapture 1.0.4
com.apple.driver.AppleIntelLpssGspi 3.0.60
com.apple.driver.usb.AppleUSBXHCIPCI 1.2
com.apple.driver.usb.AppleUSBXHCI 1.2
com.apple.driver.usb.AppleUSBHostPacketFilter 1.0
com.apple.iokit.IOUSBFamily 900.4.2
com.apple.driver.AppleUSBHostMergeProperties 1.2
com.apple.driver.AppleEFINVRAM 2.1
com.apple.driver.AppleEFIRuntime 2.1
com.apple.iokit.IOSMBusFamily 1.1
com.apple.iokit.IOHIDFamily 2.0.0
com.apple.security.quarantine 3
com.apple.security.sandbox 300.0
com.apple.kext.AppleMatch 1.0.0d1
com.apple.driver.DiskImages 493.0.0
com.apple.driver.AppleFDEKeyStore 28.30
com.apple.driver.AppleEffaceableStorage 1.0
com.apple.driver.AppleKeyStore 2
com.apple.driver.AppleUSBTDM 456.250.6
com.apple.driver.AppleMobileFileIntegrity 1.0.5
com.apple.iokit.IOUSBMassStorageDriver 145.200.2
com.apple.iokit.IOSCSIBlockCommandsDevice 408.250.3
com.apple.iokit.IOSCSIArchitectureModelFamily 408.250.3
com.apple.iokit.IOStorageFamily 2.1
com.apple.kext.CoreTrust 1
com.apple.driver.AppleCredentialManager 1.0
com.apple.driver.KernelRelayHost 1
com.apple.iokit.IOUSBHostFamily 1.2
com.apple.driver.usb.AppleUSBCommon 1.0
com.apple.driver.AppleBusPowerController 1.0
com.apple.driver.AppleSEPManager 1.0.1
com.apple.driver.IOSlaveProcessor 1
com.apple.iokit.IOTimeSyncFamily 740.2
com.apple.iokit.IONetworkingFamily 3.4
com.apple.iokit.IOReportFamily 47
com.apple.driver.AppleACPIPlatform 6.1
com.apple.driver.AppleSMC 3.1.9
com.apple.iokit.IOPCIFamily 2.9
com.apple.iokit.IOACPIFamily 1.4
com.apple.kec.pthread 1
com.apple.kec.Libm 1
com.apple.kec.corecrypto 1.0
EOF
Model: MacBookPro11,3, BootROM 151.0.0.0.0, 4 processors, Intel Core i7, 2.3 GHz, 16 GB, SMC 2.19f12
Graphics: kHW_IntelIrisProItem, Intel Iris Pro, spdisplays_builtin
Graphics: kHW_NVidiaGeForceGTX750MItem, NVIDIA GeForce GT 750M, spdisplays_pcie_device, 2 GB
Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54343147533641465238412D50422020
Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54343147533641465238412D50422020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x134), Broadcom BCM43xx 1.0 (7.77.61.2 AirPortDriverBrcmNIC-1305.8)
Bluetooth: Version 6.0.11f4, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
Serial ATA Device: APPLE SSD SM0512F, 500.28 GB
USB Device: USB 3.0 Bus
USB Device: G-DRIVE mobile
USB Device: Apple Internal Keyboard / Trackpad
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
USB Device: Keyboard Hub
USB Device: USB Receiver
USB Device: Apple Keyboard
Thunderbolt Bus: MacBook Pro, Apple Inc., 17.1
System info:
Rhino 6 SR19 2019-10-25 (Public Build, 6.19.19298.01152, Git hash:master @ 01a413724f36af3118af8e0ad5305b6671ef66be)
License type: Evaluation, build 2019-10-25
License details: Stand-Alone
Expires on: 2020-02-08
Apple Intel 64-bit macOS Version 10.14.4 (Build 18E226) (Physical RAM: 16Gb)
Mac Model Identifier: MacBookPro11,3
Machine name: Peter’s MacBook Pro
Language: en-US (MacOS default)
NVIDIA GeForce GT 750M OpenGL Engine (OpenGL ver:4.1 NVIDIA-12.0.23 355.11.10.50.10.103)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
Graphics: NVIDIA GeForce GT 750M
Displays: Color LCD (221dpi 2x), U28E590 (214dpi 2x)
Graphics processors
Intel Iris Pro (1536 MB)
NVIDIA GeForce GT 750M (2 GB)
Color LCD (1440 x 900)
U28E590 (2560 x 1440 @ 60 Hz)
USB devices
WesternDigital GTech: G-DRIVE mobile
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple Inc.: Bluetooth USB Host Controller
Logitech: USB Receiver
Apple Inc.: Apple Keyboard
Bluetooth devices
Apple: Apple Magic Mouse
Third party kernel extensions
None
Third party plugins
Rhino plugins
/Applications/Rhinoceros.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 6.19.19298.1002
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 6.19.19298.1152
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 6.19.19298.1152
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 6.19.19298.1152
/Applications/Rhinoceros.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 6.19.19298.1002
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 6.19.19298.1152
/Applications/Rhinoceros.app/Contents/PlugIns/Displacement.rhp “Displacement” 6.19.19298.1002
/Applications/Rhinoceros.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 6.19.19298.1002
/Applications/Rhinoceros.app/Contents/PlugIns/RhinoRender.rhp “Rhino Render” 6.19.19298.1002
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 6.19.19298.1152
Hi Peter - does this crash every time you are rendering or only for a specific model? Are you sending in the crash reports when the dialog appears?
Do you have an external display attached to your laptop?
Hi @gnemob - That crash report doesn’t have enough information in it for us to fix anything; the ones that get sent to us automatically might - though they’re not a ton better. Did you send in the crash report to us via the dialog that appeared?
I did.
okay thanks, when it was crashing, it skipped the designed crash dialog box.
i’ve sent report and system info to tech support.
the next day the sample model rendered without a hitch. hmmm.
and yes i’m connected to another external monitor…
A post was split to a new topic: Assigning textures
Hello again Brian,
While saving a retraced drawing to a file I had a second window open and when trying to turn the model in that second window the rhino window turned completely red. When I stopped the screen went back to normal but the model was frozen. What is that?
J. Neill
Hi Joe, sorry I missed this - what version of Rhino for Mac are you running?
Hi Brian,
It is 6 and it is updated to the latest version.There was no problem using the normal renderer, only the raytracer.
Hello again Brian,
I am getting more and more mystified by this Rhino version. I haven’t used this machine for 2 days and when I started rendering a drawing the raytracer is now functioning considerable slower than previously. The last time I used it the raytracer was rendering a little more than 1 pass per second. Today it is 5/6 times slower. What gives?
Joe
Hi Joe-
We are investigating a display related bug that might be impacting you.
If you simply open the file in question - and do nothing else at all except switch the viewport to Raytraced mode - does it raytrace at the “normal” speed?
Hello Brian,
It turns out that the drawing in question is very big, 205Mo so that explains the speed. However, the real problem is saving said drawing in “save viewport to file”. I have tried another drawing and when saved the title is there but no image. I did do a test with a simple cube with a texture applied and it worked fine. This is a problem that has developed progressively. I did not have this problem a month or so ago.
As far as the GPU is concerned mine is a Radeon Pro 580X.
Is there a special technique for applying a photo to a surface that allows it to be projected correctly? I have tried it through the materials panel and the image is distorted.
Joe
