Hey hey folks, I’m doing some studying and I wonder if there was a way to optimize my current workflow to make things less convoluted in the script, here’s what I’m looking to accomplish in terms of 3d solid:
A double folded panel with 1,5mm thickness. as you can see it folds two times to the inside, the second time making a chamfer on the diagonal.
And here’s my current workflow:
Took the surface, took its edges and offset and moved them to create so in the end I could loft all of them into the solid. Just think it’s a method that takes way too much detours and as a beginner I was wondering if anyone could help me optmize it. I looked for kangaroo plugin and saw some folks using it to create origami structures, but I’m quite new to the plugin and don’t know how it works properly
