I edited a block and when I exited the block manager the entirety of my model disappeared (except for the object I had tried to add to the block). The history of all of my actions is still there and so are the layers. The file size has also not changed. However even after entering ‘show’ and ‘unlock’, no objects can be found in the model. Unfortunately I have no old versions of the file but I have spent about 8 solid hours working on it and can’t afford to redo it! The audit report says this:
Yes - please UndoMultiple first, just in case that helps recover the model - also, before you save, locate and open the 3dmbak file of the same name in that file’s folder and save that to a new name - this may help recover your stuff as well.
Just had this same problem on Mac Version 10.14.6 Rhino v6 (6.30.20288.16412, 2020-10-14). Unfortunately I saved and quit, and am not seeing any previous versions.
I’m having the same problem. And when I went to try and restore past versions my Mac froze up. I’m currently waiting in horror at the possibility of losing all my work. Does anyone have any advice on what I can do?
I just had the same issue. Edited a block and then entire model went missing. The model is still 147MB so the objects should still be saved in the file.
I have a backup one hour ago but it still wasted me around 2 hours.
Let me know if you want my file to look into it.
Windows 10.0.18363 SR0.0 or greater (Physical RAM: 32Gb)
Primary display and OpenGL: NVIDIA Quadro P3200 with Max-Q Design (NVidia) Memory: 6GB, Driver date: 3-11-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 461.92
Secondary graphics devices.
Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 4-30-2019 (M-D-Y).
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-11-2021
Driver Version: 27.21.14.6192
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Users\CWAI\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.20335.757
Any solution yet???
I can’t lose this model!
In the audit, all of the objects, etc. are still in the file, I just can’t see anything beyond what was in the block I was working in. And I made the mistake of saving the file with a new name, hoping I’d get an autosave or something, so I can’t revert.
