Full Object Deletion During Block Editing
I was editing a block & when I clicked out I lost the block and everything else i the files. I can’t undo anything, I can’t select anything. This has happened to me once before and its baffling. I am attaching the file for reference.
Pivot Door & Steel Door & Jamb Details - another full delete.3dm (2.0 MB)
I tried running the audit command & the history of my redo’s and undo’s are still there…, The audit command shows that all the objects are still there. I’m so confused, I don’t know where the objects are. I tried selecting all, hiding, isolating, this time I lost some work, but I have indispensable files that I cannot lose like this.
I just found the Original File this happened to Luckily, I saved it, but this can be catastrophic. There is no record of the commands, you can’t undo it, the object audit as clean & overall It’s something I have never come across. I am attaching the original file as well. I really don’t want to look over my shoulder with Rhino like other software. It’s usually very solid. It’s a 20 MB file, if need be i can share it but i cannot upload it.
Hi Sam -
Is this something that you can reproduce at will? We’ve previously had reports of this bug but we haven’t been able to reproduce it.
No, I can’t unfortunately, twice it happened when I was editing block with a copy and paste function, but most of the time it works fine.
