ctrl+z then before you exit the block editor, copy the block and lock everything else. exit the block editor, when your block disappears paste it back and select replace. Unlock the rest. Locked objects should not disappear.
I just encountered this issue again, but on Windows. Before it occurred, the command BlockEditApplyInPlaceEditItemChanges was triggered. Tried all the above, unable to recover.
To add on, everything in layouts is also gone, the only things left are lights and some text on a no print layer. File size is still the same; I saved a copy of the file.
Hi Brian -
Please run the Rhino SystemInfo
command and copy-paste the result here.
Can you post the file?
Rhino 7 SR21 2022-7-27 (Rhino 7, 7.21.22208.13001, Git hash:master @ c31aea87137a5d0de449338a7ef6856f49dd4797)
License type: Commercial, build 2022-07-27
License details: Cloud Zoo
Windows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 16Gb)
Primary display: Intel(R) HD Graphics 530 (Intel) Memory: 1GB, Driver date: 11-11-2016 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GTX 970M (NVidia) Memory: 6GB, Driver date: 6-6-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 516.40
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-6-2022
Driver Version: 31.0.15.1640
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Users\Brian\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.22201.1402
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.21.22208.13001
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.21.22208.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.21.22208.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.21.22208.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.21.22208.13001
C:\Program Files\Rhino 7\Plug-ins\BlockEdit.rhp “BlockEdit” 7.21.22208.13001
The file is too big so here is a download link. I hope this issue gets fixed, I had this same problem a long time back with R6, and the worse part is that it is not like crash, it completely wipes the entire file, so you’re banking on any previous file saves.
Hi there, I just had the same issue without any possible backup. Any help?
Rhino 6 SR35 2021-8-10 (Public Build, 6.35.21222.17002, Git hash:master @ 073ac7b225c67348731c6597127b9410126c3139)
License type: Educational Lab License, build 2021-08-10
License details: Cloud Zoo. In use by: Mar (TU Delft University Licenses)
Apple Intel 64-bit macOS Version 13.0.1 (Build 22A400) (Physical RAM: 16Gb)
Mac Model Identifier: MacBookPro18,3
Machine name: MacBook Pro
Language: en-ES (MacOS default)
Apple M1 Pro (OpenGL ver:4.1 Metal - 83)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Vendor Name: Apple
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 1 GB
Graphics: Apple M1 Pro
Displays: Unknown (255dpi 2x)
Graphics processors
Apple M1 Pro (N/A)
Color LCD (1512 x 982 @ 120.00Hz)
USB devices
None
Bluetooth devices
None
Third party kernel extensions
io.macfuse.filesystems.macfuse (2113.20) 649B36F2-EE80-3639-A883-213B3F56D041
Third party plugins
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/usr/lib/usd/libIex.dylib
/usr/lib/usd/libHalf.dylib
/usr/lib/usd/libAlembic.dylib
/usr/lib/usd/libusd_ms.dylib
/usr/lib/usd/libosdCPU.dylib
/usr/lib/usd/libImath.dylib
/usr/lib/usd/libIlmThread.dylib
/usr/lib/usd/libIexMath.dylib
/usr/lib/usd/libtbb.dylib
/usr/lib/usd/libMaterialXCore.dylib
/usr/lib/usd/libMaterialXFormat.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftExtensionFoundation.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftExtensionKit.dylib
/usr/lib/swift/libswiftWebKit.dylib
Rhino plugins
/Applications/Rhinoceros.app/Contents/PlugIns/RhinoBonusTools.rhp “Rhino Bonus Tools” 6.35.21222.1002
/Applications/Rhinoceros.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 6.35.21222.1002
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 6.35.21222.17002
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 6.35.21222.17002
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 6.35.21222.17002
/Applications/Rhinoceros.app/Contents/PlugIns/import_ACAD.rhp “AutoCAD file import: import_ACAD” 6.35.21222.1002
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 6.35.21222.17002
/Applications/Rhinoceros.app/Contents/PlugIns/SolidTools.rhp “SolidTools” 6.35.21222.1002
/Applications/Rhinoceros.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 6.35.21222.1002
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 6.35.21222.17002
/Applications/Rhinoceros.app/Contents/PlugIns/Displacement.rhp “Displacement” 6.35.21222.1002
/Applications/Rhinoceros.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 6.35.21222.1002
/Applications/Rhinoceros.app/Contents/PlugIns/RhinoRender.rhp “Rhino Render” 6.35.21222.1002
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 6.35.21222.17002
Hey team,
I had this problem on NOT a mac, and I found a pretty good solution! If you go into the block manager the hidden items show up and you can export the block you were working on to its own file! Saved me a lot of time!
For the past few months it happened to me few times. Firstly I thought it was my sort of mistake. But today, it happened again:
When I work with blockedit command and exit the block, whole model disappear except the block. I mean when I undo some steps back, only the object related to the last edited block are in the file. Rest of it is gone.
The size of the file apears to be the same. But when I tried to save it as a copy, The size shrinks to a few kB.
I am convinced that this problem is related to Block manager or Block edit command. And this is pretty scary to loos whole work!
Please, have a look on what is going on with this.
