There is a problem with the viewports in Rhino 6. Everything was fine but then once I opened a new file, the screen turned black and commands stopped working. I updated rhino, NVIDIA and Intel drivers. Please help t.t
Windows 10.0 SR0.0 or greater (Physical RAM: 7.9Gb)
Machine name: DESKTOP-S5VA66N
go to windows> add or remove programs then find rhino, left click once on rhino, the hit the modify button… then hit repair and let it go through the repair function. then restart your machine and try it again.
I am having this same exact issue years later on Rhino 7… and this solution did not work either. Ive unistalled and reinstalled multiple times and restarted my laptop multiple times and nothing has worked.
Primary display and OpenGL: NVIDIA GeForce RTX 2080 Super with Max-Q Design (NVidia) Memory: 8GB, Driver date: 6-2-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 532.09
Secondary graphics devices.
Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 6-1-2021 (M-D-Y).
> Integrated graphics device with 2 adapter port(s)
- There are no monitors attached to this device. Laptop lid is probably closed
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-2-2023
Driver Version: 31.0.15.3209
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Users\ljgoc\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\Lumion LiveSync for Rhino (839d6175-32d1-4ffe-a0a4-b7fb43cf0ff5)\2021.3.25.899\Lumion\Rhino 7.0\LumionPlugin.rhp “Lumion LiveSync for Rhino”
Disabling the lumion plug in did not fix the issue. I unchecked the box for the plug in, closed rhino out, and opened it back up and it still looks the same
