All of my viewports are black, I tried everything I could, nothing works
Hello, my viewports in Rhino are all black. Sometimes when I open a project only 1 would be showing and I could switch one viewports to other viewports, but when I try to do a 4 view, 3 screens are black. That is only with old projects, if I open a new project, all screens are black.
My OpenGL is set to true. MY drivers have been updated, even though I just tried downgrading to older drivers and Im nots sure if doing updates in the settings for updates again got me back to the new drivers. Regardless, it is not working for new or old drivers.
Here is some of my system info:
OS Name Microsoft Windows 10 Pro
Version 10.0.19043 Build 19043
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Manufacturer Dell Inc.
System Model Precision 5540
System Type x64-based PC
System SKU 0906
Processor Intel(R) Core™ i7-9750H CPU @ 2.60GHz, 2592 Mhz, 6 Core(s), 12 Logical Processor(s)
BIOS Version/Date Dell Inc. 1.13.0, 7/22/2021
SMBIOS Version 3.2
Embedded Controller Version 255.255
BIOS Mode UEFI
BaseBoard Manufacturer Dell Inc.
BaseBoard Product 07C17G
BaseBoard Version A00
Platform Role Mobile
Secure Boot State Off
PCR7 Configuration Elevation Required to View
Windows Directory C:\WINDOWS
System Directory C:\WINDOWS\system32
Boot Device \Device\HarddiskVolume1
Locale United States
Hardware Abstraction Layer Version = 10.0.19041.1151
Time Zone Eastern Standard Time
Installed Physical Memory (RAM) 16.0 GB
Total Physical Memory 15.7 GB
Available Physical Memory 7.31 GB
Total Virtual Memory 24.2 GB
Available Virtual Memory 13.4 GB
Page File Space 8.50 GB
Page File C:\pagefile.sys
Kernel DMA Protection Off
Virtualization-based security Not enabled
Device Encryption Support Elevation Required to View
Hyper-V - VM Monitor Mode Extensions Yes
Hyper-V - Second Level Address Translation Extensions Yes
Hyper-V - Virtualization Enabled in Firmware Yes
Hyper-V - Data Execution Protection Yes
Hello- please run the Rhino command SystemInfo and copy/paste the results here.
Rhino 7 SR12 2021-11-9 (Rhino 7, 7.12.21313.06341, Git hash:master @ 5590153808223b57a9f41516a969fd949aa81bff)
License type: Educational, build 2021-11-09
License details: Cloud Zoo
Windows 10.0.19043 SR0.0 or greater (Physical RAM: 16Gb)
Primary display: Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 6-1-2021 (M-D-Y).
Primary OpenGL: NVIDIA Quadro T1000 (NVidia) Memory: 4GB, Driver date: 4-8-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 462.31
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-8-2021
Driver Version: 27.21.14.6231
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.12.21313.6341
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.12.21313.6341
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.12.21313.6341
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.12.21313.6341
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.12.21313.6341
Sorry, is anyone able to help me right now? I’m kind of in a rush since I have work to get started on. Again, sorry, and thank you.
I’d hit the NVIDIA web site and look for an updated video driver for your system.
Like this:
https://www.nvidia.com/Download/driverResults.aspx/183584/en-us
— Dale
Okay I have tried downloading that driver but it still does not work.
Hi @user1940,
have you made the Nvidia processor the primary graphics adapter for Rhino using the Nvidia Control Panel in Windows?
For your laptop, see: How to make the nVidia graphics processor the default graphics adapter using the NVIDIA Control Panel | Dell UK.
HTH
Jeremy
I tried setting openGL to both Quadro processor and the Auto_select, none worked.
Did it make any difference at all? That it didn’t is hard to believe.
Hi -
I would start with a clean install of the drivers with the instructions found here:
Make sure to include step 4 of the uninstalling process!
okay I will try this thank you.
No difference.
call us 206-545-6877
Hello. My entire middle section of the viewports is black. No divisions dividing all four sections are even present. I cannot even go into the options in rhino as nothing happens when I click it. My graphic drivers seem to be up to date. Please help.
What else are you using? What is your laptop? How high resolution is your monitor? You seem to be having unique troubles.
I am using a Dell Precision 5540, I am not using a monitor right now.
Is it a 4k screen?
1080p
Please type _SystemInfo at the command line and copy/paste the info here…
Rhino 7 SR17 2022-4-12 (Rhino 7, 7.17.22102.05001, Git hash:master @ 13b57035af8fb22da005ef72c56e4555d9dbcfe3)
License type: Educational, build 2022-04-12
Windows 10.0.22000 SR0.0 or greater (Physical RAM: 16Gb)
Primary display: Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 3-18-2022 (M-D-Y).
Primary OpenGL: NVIDIA Quadro T1000 (NVidia) Memory: 4GB, Driver date: 10-26-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 472.47
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 10-26-2021
Driver Version: 30.0.14.7247
C:\Users\yamil\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.22102.1509
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.17.22102.5001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.17.22102.5001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.17.22102.5001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.17.22102.5001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.17.22102.5001
