Occasional black/blank viewport
Please see the attached video.
In shaded mode, occasionally one of the views turns black it happened with the Front view as well before, [I can see no pattern that leads to that.]
thanks a lot
Akash
i’m seeing the same behavior here but i didn’t report cause i can see no rhyme or reason. seems like it has to do with using the view names at the top of the window to change the view.
mine turns red though.
@Akash, @kleerkoat - can you please run SystemInfo in Rhino and paste the results here?
thanks,
here’s my Sist-Info Pascal
It seems that my Nvida M750 2gb card didn’t make it to the list.
thanks a lot
Akash
Software information
Software versions
Rhinoceros version: 6 WIP (6.10.18254.12026, 2018-09-11)
Rhinoceros path: /Applications/RhinoWIP.app
IronPython version: 5.1.2015.131
WIP expiration: 26 October 2018
Language: en-IL (MacOS default)
macOS version: Version 10.13.6 (Build 17G65)
Plug-ins
/Applications/RhinoWIP.app/Contents/MacOS/Rhinoceros
/Applications/RhinoWIP.app/Contents/Frameworks/OpenNURBS.framework/Versions/A/OpenNURBS
/Library/Frameworks/3DconnexionClient.framework/Versions/A/3DconnexionClient
/Applications/RhinoWIP.app/Contents/Frameworks/CustomViews.framework/Versions/A/CustomViews
/Applications/RhinoWIP.app/Contents/Frameworks/RhCommon.framework/RhCommon
/Applications/RhinoWIP.app/Contents/Frameworks/libxammac.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/RhMaterialEditor.framework/RhMaterialEditor
/Applications/RhinoWIP.app/Contents/Frameworks/RhCommonRDK.framework/RhCommonRDK
/Applications/RhinoWIP.app/Contents/PlugIns/NamedSnapshots.rhp/Contents/MacOS/NamedSnapshots
/Applications/RhinoWIP.app/Contents/Frameworks/libccycles.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/libOpenImageIO.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/libboost_thread-mt.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/libboost_system-mt.dylib
/usr/local/cuda/lib/libcuda.dylib
/Library/Frameworks/CUDA.framework/Versions/A/CUDA
/Applications/RhinoWIP.app/Contents/PlugIns/export_SKP.rhp/Contents/MacOS/export_SKP
/Applications/RhinoWIP.app/Contents/Frameworks/SketchUpAPI.framework/Versions/A/SketchUpAPI
/Applications/RhinoWIP.app/Contents/Frameworks/SketchUpAPI.framework/Versions/A/Libraries/libCommonPreferences.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/SketchUpAPI.framework/Versions/A/Libraries/libCommonUnits.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/SketchUpAPI.framework/Versions/A/Libraries/libCommonGeometry.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/SketchUpAPI.framework/Versions/A/Libraries/libCommonGeoutils.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/SketchUpAPI.framework/Versions/A/Libraries/libCommonImage.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/SketchUpAPI.framework/Versions/A/Libraries/libCommonUtils.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/SketchUpAPI.framework/Versions/A/Libraries/libCommonZip.dylib
/Applications/RhinoWIP.app/Contents/PlugIns/Export_UDO.rhp/Contents/MacOS/Export_UDO
/Applications/RhinoWIP.app/Contents/PlugIns/import_RAW.rhp/Contents/MacOS/import_RAW
/Applications/RhinoWIP.app/Contents/PlugIns/Import_DGN.rhp/Contents/MacOS/Import_DGN
/Applications/RhinoWIP.app/Contents/Frameworks/libTD_Zlib.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/libTD_Db.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/libTD_Gi.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/TD_Tf.tx
/Applications/RhinoWIP.app/Contents/Frameworks/TG_Db.tx
/Applications/RhinoWIP.app/Contents/Frameworks/libTD_Br.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/libsisl.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/TxHostLib.tx
/Applications/RhinoWIP.app/Contents/Frameworks/libTD_Alloc.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/libTD_Ge.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/libTD_DbRoot.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/libTD_Root.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/liboless.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/libTD_SpatialIndex.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/TG_Dgn7IO.tx
/Applications/RhinoWIP.app/Contents/PlugIns/import_VRML.rhp/Contents/MacOS/import_VRML
/Applications/RhinoWIP.app/Contents/PlugIns/AnimationTools.rhp/Contents/MacOS/AnimationTools
/Applications/RhinoWIP.app/Contents/PlugIns/Import_WAMIT.rhp/Contents/MacOS/Import_WAMIT
/Applications/RhinoWIP.app/Contents/PlugIns/NamedPositions.rhp/Contents/MacOS/NamedPositions
/Applications/RhinoWIP.app/Contents/PlugIns/import_SKP.rhp/Contents/MacOS/import_SKP
/Applications/RhinoWIP.app/Contents/PlugIns/Export_RAW.rhp/Contents/MacOS/Export_RAW
/Applications/RhinoWIP.app/Contents/PlugIns/MPlane.rhp/Contents/MacOS/MPlane
/Applications/RhinoWIP.app/Contents/PlugIns/Export_XGL.rhp/Contents/MacOS/Export_XGL
/Applications/RhinoWIP.app/Contents/PlugIns/RhinoRender.rhp/Contents/MacOS/RhinoRender
/Applications/RhinoWIP.app/Contents/PlugIns/Export_CD.rhp/Contents/MacOS/Export_CD
/Applications/RhinoWIP.app/Contents/PlugIns/export_LWO.rhp/Contents/MacOS/export_LWO
/Applications/RhinoWIP.app/Contents/PlugIns/export_SLC.rhp/Contents/MacOS/export_SLC
/Applications/RhinoWIP.app/Contents/PlugIns/import_3MF.rhp/Contents/MacOS/import_3MF
/Applications/RhinoWIP.app/Contents/Frameworks/lib3MF_darwin.dylib
/Applications/RhinoWIP.app/Contents/PlugIns/export_STEP.rhp/Contents/MacOS/export_STEP
/Applications/RhinoWIP.app/Contents/Frameworks/librose.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/libstpcad.dylib
/Applications/RhinoWIP.app/Contents/PlugIns/export_3MF.rhp/Contents/MacOS/export_3MF
/Applications/RhinoWIP.app/Contents/PlugIns/Export_WAMIT.rhp/Contents/MacOS/Export_WAMIT
/Applications/RhinoWIP.app/Contents/PlugIns/Import_SLC.rhp/Contents/MacOS/Import_SLC
/Applications/RhinoWIP.app/Contents/PlugIns/Import_OFF.rhp/Contents/MacOS/Import_OFF
/Applications/RhinoWIP.app/Contents/PlugIns/Squish.rhp/Contents/MacOS/Squish
/Applications/RhinoWIP.app/Contents/PlugIns/Export_X_T.rhp/Contents/MacOS/Export_X_T
/Applications/RhinoWIP.app/Contents/PlugIns/RhinoBonusTools.rhp/Contents/MacOS/RhinoBonusTools
/Applications/RhinoWIP.app/Contents/PlugIns/RhinoLabsTools.rhp/Contents/MacOS/RhinoLabsTools
/Applications/RhinoWIP.app/Contents/PlugIns/Export_X3D.rhp/Contents/MacOS/Export_X3D
/Applications/RhinoWIP.app/Contents/PlugIns/Import_M.rhp/Contents/MacOS/Import_M
/Applications/RhinoWIP.app/Contents/PlugIns/Import_X.rhp/Contents/MacOS/Import_X
/Applications/RhinoWIP.app/Contents/PlugIns/import_IGES.rhp/Contents/MacOS/import_IGES
/Applications/RhinoWIP.app/Contents/PlugIns/Alerter.rhp/Contents/MacOS/Alerter
/Applications/RhinoWIP.app/Contents/PlugIns/export_AI.rhp/Contents/MacOS/export_AI
/Applications/RhinoWIP.app/Contents/PlugIns/export_ACAD.rhp/Contents/MacOS/export_ACAD
/Applications/RhinoWIP.app/Contents/Frameworks/libTD_AcisBuilder.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/libTD_BrepRenderer.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/libTD_BrepBuilder.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/RecomputeDimBlock.tx
/Applications/RhinoWIP.app/Contents/Frameworks/PlotSettingsValidator.tx
/Applications/RhinoWIP.app/Contents/Frameworks/ModelerGeometry.tx
/Applications/RhinoWIP.app/Contents/PlugIns/Displacement.rhp/Contents/MacOS/Displacement
/Applications/RhinoWIP.app/Contents/PlugIns/import_LWO.rhp/Contents/MacOS/import_LWO
/Applications/RhinoWIP.app/Contents/PlugIns/export_SAT.rhp/Contents/MacOS/export_SAT
/Applications/RhinoWIP.app/Contents/PlugIns/Export_CSV.rhp/Contents/MacOS/Export_CSV
/Applications/RhinoWIP.app/Contents/PlugIns/import_PDF.rhp/Contents/MacOS/import_PDF
/Applications/RhinoWIP.app/Contents/PlugIns/export_STL.rhp/Contents/MacOS/export_STL
/Applications/RhinoWIP.app/Contents/PlugIns/import_VDA.rhp/Contents/MacOS/import_VDA
/Applications/RhinoWIP.app/Contents/PlugIns/import_STEP.rhp/Contents/MacOS/import_STEP
/Applications/RhinoWIP.app/Contents/PlugIns/export_FBX.rhp/Contents/MacOS/export_FBX
/Applications/RhinoWIP.app/Contents/Frameworks/libfbxsdk.dylib
/Applications/RhinoWIP.app/Contents/PlugIns/Import_SolidWorks.rhp/Contents/MacOS/Import_SolidWorks
/Applications/RhinoWIP.app/Contents/PlugIns/import_STL.rhp/Contents/MacOS/import_STL
/Applications/RhinoWIP.app/Contents/PlugIns/Export_RIB.rhp/Contents/MacOS/Export_RIB
/Applications/RhinoWIP.app/Contents/PlugIns/import_FBX.rhp/Contents/MacOS/import_FBX
/Applications/RhinoWIP.app/Contents/PlugIns/export_Points.rhp/Contents/MacOS/export_Points
/Applications/RhinoWIP.app/Contents/PlugIns/export_VDA.rhp/Contents/MacOS/export_VDA
/Applications/RhinoWIP.app/Contents/PlugIns/import_ACAD.rhp/Contents/MacOS/import_ACAD
/Applications/RhinoWIP.app/Contents/PlugIns/Export_X.rhp/Contents/MacOS/Export_X
/Applications/RhinoWIP.app/Contents/PlugIns/CreaseAngle.rhp/Contents/MacOS/CreaseAngle
/Applications/RhinoWIP.app/Contents/PlugIns/export_3DS.rhp/Contents/MacOS/export_3DS
/Applications/RhinoWIP.app/Contents/PlugIns/import_PLY.rhp/Contents/MacOS/import_PLY
/Applications/RhinoWIP.app/Contents/PlugIns/MeshTools.rhp/Contents/MacOS/MeshTools
/Applications/RhinoWIP.app/Contents/PlugIns/import_Points.rhp/Contents/MacOS/import_Points
/Applications/RhinoWIP.app/Contents/PlugIns/PanelingTools.rhp/Contents/MacOS/PanelingTools
/Applications/RhinoWIP.app/Contents/PlugIns/MeshFromPoints.rhp/Contents/MacOS/MeshFromPoints
/Applications/RhinoWIP.app/Contents/PlugIns/export_VRML.rhp/Contents/MacOS/export_VRML
/Applications/RhinoWIP.app/Contents/PlugIns/Import_GTS.rhp/Contents/MacOS/Import_GTS
/Applications/RhinoWIP.app/Contents/PlugIns/SolidTools.rhp/Contents/MacOS/SolidTools
/Applications/RhinoWIP.app/Contents/PlugIns/Export_GTS.rhp/Contents/MacOS/Export_GTS
/Applications/RhinoWIP.app/Contents/PlugIns/Export_POV.rhp/Contents/MacOS/Export_POV
/Applications/RhinoWIP.app/Contents/PlugIns/IgesCoreLib.rhp/Contents/MacOS/IgesCoreLib
Third party kernel extensions
com.3dconnexion.driver (10.5.2) 23F2462E-B272-3BBC-A8DC-BEE242EE3FA7
com.rim.driver.BlackBerryUSBDriverInt (0.0.67) 3D68C30B-05F8-FB91-8606-B0F892DAA206
com.nvidia.CUDA (1.1.0) 5AFE550D-6361-3897-912D-897C13FF6983
com.sophos.nke.swi (9.7.4) AFB9B66E-C67A-32D1-A8A8-654F475EECFC
com.sophos.kext.oas (9.7.4) FE151087-F3B0-3F51-BD15-3313B8BCDDAB
Hardware information
Computer hardware
Hardware model: MacBookPro11,3
Processor: Intel Core i7-4960HQ CPU @ 2.60GHz
Memory: 16 GB
Architecture: Intel 64 bit
Video hardware
Graphics: Intel Iris Pro 1536 MB
Memory: 1536 MB
Screen size: 1440 x 900
Displays: Color LCD (221dpi 2x)
USB devices
Apple: Internal Memory Card Reader
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple Inc.: Bluetooth USB Host Controller
3Dconnexion: SpaceNavigator for Notebooks
Bluetooth devices
Apple: Apple Magic Mouse
OpenGL information
OpenGL software
OpenGL version: 4.1 NVIDIA-10.32.0 355.11.10.10.40.102
Render version: 4.1
Shading language: 4.10
Maximum texture size: 16384 x 16384
Z-buffer depth: 24 bits
Stencil depth: 8 bits
Maximum viewport size: 16384 x 16384
Implementation settings
Use texture compression: No
Appearance settings
Antialiasing: 4x
Mip map filtering: Linear
Anisotropic filtering: High
here you go Pascal. I waiting to make sure that the latest WIP still showed this behavior. It just did it. So it hasn’t been fixed.
Rhino 6 SR10 2018-9-18 (Public Build, 6.10.18261.18456, Git hash:master @ f2193f037533e07a202903b18d74cd24b6bce32b)
Licence type: Beta, build 2018-09-18
License details: Stand-Alone
Expires on: 2018-11-02
Apple Intel 64-bit macOS Version 10.14 (Build 18A389) (Physical RAM: 16Gb)
Machine name: DMC4000
AMD Radeon R9 M370X OpenGL Engine (OpenGL ver:4.1 ATI-2.0.36)
OpenGL Settings
  Safe mode: Off
  Anti-alias mode: 4x
  Mip Map Filtering: Linear
  Render version: 4.1
  Shading Language: 4.10
  Driver Date: (null)
  Driver Version: (null)
  Z-Buffer depth: 24 bits
  Total Video Memory: 2 GB
/Applications/RhinoWIP.app/Contents/PlugIns/Alerter.rhp	"Alerter"	6.10.18261.1002
/Applications/RhinoWIP.app/Contents/PlugIns/NamedSnapshots.rhp	"Snapshots"	6.10.18261.1002
/Applications/RhinoWIP.app/Contents/PlugIns/PanelingTools.rhp	"PanelingTools"	6.10.18261.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp	"IronPython"	5.1.2015.132
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp	"Commands"	6.10.18261.18456
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp	"Grasshopper"	6.10.18261.18456
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp	"RDK_EtoUI"	6.10.18261.18456
/Applications/RhinoWIP.app/Contents/PlugIns/Displacement.rhp	"Displacement"	6.10.18261.1002
/Applications/RhinoWIP.app/Contents/PlugIns/RhinoRender.rhp	"Rhino Render"	6.10.18261.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp	"RhinoCycles"	6.10.18261.18456
/Applications/RhinoWIP.app/Contents/Frameworks/RhMaterialEditor.framework	"Renderer Development Kit"	6.10.18261.1002
@kleerkoat and @Akash Are either of you still having this problem with the Rhino 6 for Mac Beta? Thanks.
