kt32
(Kt32)
May 26, 2020, 1:03am
1
There is a problem with the viewports in Rhino 6. Everything was fine but then once I opened a new file, the screen turned black and commands stopped working. I updated rhino and Intel drivers. Please help, I am not a tech person t.t
System Info: Rhino 6 SR25 2020-4-23 (Rhino 6, 6.25.20114.05271, Git hash:master @ f35d7ded15ec317635ced435d8df84327397038d)
License type: Educational, build 2020-04-23
License details: Cloud Zoo. In use by: K T ()
Windows 10.0 SR0.0 or greater (Physical RAM: 7.9Gb)
Machine name: DESKTOP-S5VA66N
Non-hybrid graphics.
Primary display and OpenGL: NVIDIA GeForce GTX 1060 (NVidia) Memory: 6GB, Driver date: 3-7-2018 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 389.12
Secondary graphics devices.
Intel® UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 5-5-2020 (M-D-Y).
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-7-2018
Driver Version: 23.21.13.8912
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.25.20114.5271
C:\Program Files\Rhino 6\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 6\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 6\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 6\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.25.20114.5271
C:\Program Files\Rhino 6\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.25.20114.5271
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.25.20114.5271
Open your Notifications Panel.
Is there a suggestiongto update your display drivers for your Nvidia GeForce card?
kt32
(Kt32)
May 26, 2020, 3:22am
3
I checked and uploaded newer drivers for NVIDIA. Rhino still looks like this-
stevebaer
(Steve Baer)
May 26, 2020, 3:31am
4
The screen shot shows “GPU disabled”. Go to Rhino’s advanced settings and make sure
“Rhino.Options.OpenGL.UseHardwareDriver” is set to true
Please run the SystemInfo command again please.
kt32
(Kt32)
May 27, 2020, 4:05pm
6
thanks! but the screens still haven’t changed
kt32
(Kt32)
7
Here:
OpenGL Settings
Safe mode: Off
Anti-alias mode: None
Render version: 4.6
Rhino plugins
@kt32
As I thought.
Your GeForce drive is still way too old.
The driver Check for Updates tools have a nearly 100% failure rate.
You must go look manually.
Please install this one from 27 May:
https://www.nvidia.com/Download/driverResults.aspx/159887/en-us
When you run the installer, click on the Advanced button and check the option to do a “Clean install”. This will reset any user twiddled settings in the driver.
Now does it work?
kt32
(Kt32)
May 27, 2020, 4:45pm
9
Did everything exactly like you said (clean install) but the screens are still black…
Does SystemInfo show the new updated driver now?
kt32
(Kt32)
May 27, 2020, 5:06pm
11
Yes
Primary display and OpenGL: NVIDIA GeForce GTX 1060 (NVidia) Memory: 6GB, Driver date: 5-15-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 446.14
OpenGL Settings
Safe mode: Off
Render version: 4.6
Driver Date: 5-15-2020
Driver Version: 26.21.14.4614
Rhino plugins
Okay, that looks good now.
I don’t see any plug-ins that are likely to cause problems.
How many monitors are you running and at what resolution?
Have you changed any of the display mode settings?
Do all display modes do this black screen?
Are any monitors plugged into the Intel display card, or are you monitors plugged directly into the ports on the GeForce card?
kt32
(Kt32)
May 27, 2020, 5:29pm
13
I only use my laptop screen (1920 x 1080)
The display mode settings were untouched. I haven’t changed anything prior to the screens in rhino turning black.
‘Floating Viewport’ works. Maybe I could clip it to the main window somehow?
theoutside
(Kyle Houchens)
June 9, 2020, 8:52pm
14
type 4view in your command line… do windows come back? It appears you have somehow closed your viewports…
