Wish: Orient objects 3 points with a Vertical option
It would greatly improve the workflow if there was an option to pick a vertical orientation either for the 2nd or 3rd target point for the “Orient objects 3 points” command while working in the Perspective viewport.
Currently, the user is forced to leave the Perspective viewport and go into one of the orthogonal viewports to pick a vertical direction for the 2nd or 3rd target point.
Also, a “InPlace” option to place the 1st target point on the same location as the 1st reference point will make it easier and quicker, because many times the intent is to use the same origin point for the orientation of an object.
An “Undo” option will allow to undo an accidentally picked point and will let the user finish the command conveniently, rather than cancel it completely and start over again.
Sounds reasonable to me:
https://mcneel.myjetbrains.com/youtrack/issue/RH-58688
Hello - I have to admit I am a little lost with this - the developer asked me to try to understand better just what is being suggested , and does Elevator Mode not accomplish this?
I support the undo option to re-select :smile:
Elevator mode (holding the Gtrl key) will not help with this command. The idea is to be able to set the 2nd or 3rd target point vertically to the Cplane. Currently, Rhino only allows to set a horizontal direction when using Ortho (or when holding the Shift key if Ortho is turned off).
In order to try how this behaves in Rhino, simply go to the Perspective view and start the “Orient objects: 3 points” command. Set the 3 reference points, then do the same with the 1st and 2nd target points. However, when you try to set the 3rd target point vertically, you can’t. Ortho only allows to set the 3rd target point horizontally left or right. It will ignore the vertical directions up and down. This is why I proposed to upgrade the command so that one could use the Ctrl key to be able to set a vertical direction. Or, add a “Vertical” option in the command line. Or, allow Ortho to do its job as intended (when it’s set at 90 degrees, it actually “snaps” to 180 degrees during the “Orient objects: 3 points” command).
Hm. I see - I’d prefer to use existing functionality like Elevator mode rather than add an option, myself - which works - the weakness I see is that Point osnap does not pick up Target Point 2 ; if it did we’d be done. I’ll see if that can be tuned up and get there without a command line option…
Not sure why Ortho temporarily stops to snap to 90 degrees and switches to just 180 degrees inside the “Orient objects: 3 points” command. Once the command is completed, Ortho works at 90 degrees again with every other command. I think that if Ortho worked as usual at 90 degrees all the time, that would easily fix the issue.
Is there any progress with this proposal? :slight_smile:
I repeat my question 5 years later. :slight_smile: Still nothing done?
@Rhino_Bulgaria
Have you tried the _Orient_3D?
I just felt like a Calculus level person wondering what 1 plus 1 is. :smiley:
Well understood why though.
__
Edit: Should be Orient_Scale and 3D…
Yes, sometimes I use that command, but it has a very limited usage in my workflow. I mostly do car exterior panels, suspension, tubular chassis and mechanical design of aluminum parts for CNC-milling. Basically engineering work where positioning of the components in the 3d space is often used, hence I rely a lot on custom CPlanes, as well as the ! _Orient3Pt command.
→ relative coordinate r0,0,1
_orient3pt
can be combined with relative coordinate input
one or two of the following inputs after the first point picked
r1,0,0
r0,1,0
r0,0,1
and it can be combined with
_ProjectOsnap
_Planar
for more crazy transformations there is _RemapCPlane
i like the idea of undo option.
I would love to store transformations - see this topic:
I use that command a lot in models where I have moving geometry such like closed/opened doors, normal/minimum/maximum position of the suspension components, etc. I also combine this with “Named positions”.
Long time ago I wished for a “transformation plane” that acts like remap cplane but with a dynamic option.
I think working in rhinos cplanes that are tilted or off ortho can lead to slight errors that make downstream modeling difficult and error prone. This is why I stopped using custom cplanes for the most part and model mainly orthographically (if I can) and then use remap to cplane to orient my geometry.
If we had a dynamic remap cplane tool any objects chosen within the dynamic cplane would be auto remapped with a few clicks rather than having to be selected three times or more depending on if you had to reactivate a cplane. Your target cplanes could even be chosen from a drop down list allowing the user to add objects to cplanes at any orientation with one go.
There hasn’t been any real substance or improvements to Rhino’s History and how it could benefit users.
RM
One area where the Rhino developers could make enhancements is the _-NamedCplane _Select command. It has two known shortcomings at the moment:
  1. If a Cplane was left marked (not active, just marked) in the “Named CPlanes” list, then the _-NamedCplane _Select command is unable to highlight it in the viewport upon mouse hovering. This particular bug is extremely inconvenient and forces the used to open the “Named CPlanes” pop-up window, then navigate to the very bottom of the list and click on a blank area there, then close the window and run the _-NamedCplane _Select command again.
  2. Once the _-NamedCplane _Select command is active, the mouse hovering only highlights the saved CPlanes in the viewport, but will not show their saved name, which greatly reduces the usability of the command. In many cases CPlanes are saved close to each other, especially if they share the same axis but are rotated in a different angle. I have plenty of these and it’s very difficult to pick a CPlane with the _-NamedCplane _Select command for this reason. Lack of naming makes it unusable.
The “InPlace” Command line option for the “Orient objects 3 points” command could be renamed “Same” or “SameAsReferencePoint” to avoid a confusion with the “Copy in place” command.
That particular option must be shown when the user is asked to pick target points. That will make it much more convenient to pick the same 1st and 2nd target points in the same locations as the 1st and 2nd reference points.
If the user picks “Same” (or “SameAsReferencePoint”) for the 1st and 2nd target points, clicking it again for the 3rd target point will create a copy of the object in the same place.
@Rhino_Bulgaria I cannot find an “InPlace” option for Orient3Pt, and it is not shown in Help. What are you referring to?
This is a longtime request to implement an “InPlace” (or “Same”) Command line option. :smiley: Since it’s non-existent at the moment, the user is forced to manually pick the 3 target points, which is both, slow and with the potential risk of snapping to a wrong location where the geometry is more detailed. It also may reduce the unwanted camera manipulation, because the user will be able to simply press the Command line option to repeat the same location of the target point like the corresponding reference point.
