What steps to make this look brass?
Hi
V5,
I have never used Rendered to actually apply a metal effect or any effect come to that !
I always do a printscreen of shaded instead.
I would like to make this with a brass material.
What are the EXACT STEPS 1,2,3,4 etc to do this please. note V5.
I have V8 should the method be far easier and more realistic if I were to open this in V8.
and also a better background to make it look decent :slight_smile:
I have managed to replicate the exact way the knurling was on this, quite chuffed at managing to do so.
so cannot have this visual as it stands.
I also have a rusty metal item to visual in the same manner, so steps to apply rust also welcome.
Cannot upload this file confidential but any thing as a demo would do.
Many Thanks in anticipation.
Steve
Yep, I’m guessing it is for historical accuracy only too.
This reminds me of when a well meaning old school engineer offered to help me with my sailing race boat. He made me a high load, plain bearing sheave that ran on a sintered bronze bush (ok, not exactly the same alloy as brass but…). Half way through the first days racing the damn thing seized solid.
When we got back to shore we tried to remove it and no amount of swearing and bashing would budge it. A twelve tonne hydraulic press finally did the job and then we replaced the offending thing with a nice “new school” stainless roller bearing. Still running strong many years later.
To answer your question Steve, for creating a texture material that does what you want is super easy with PBR materials and you can probably find one online so you don’t have to build it yourself, but you’ll need V8. I haven’t looked at V5 materials for a long time so can’t advise on that.
Steve
See if this scene helps a little.
Object is from McMaster-Carr
94775A030_High-Torque Low-Profile Thumb Nut.7z (3.0 MB)
If you need the thing to look old, you’ll have to paint it, either manually or occlusion based in Substance painter, which is a lot more work.
I have two display modes that mimic a bronze material. They could be also made into materials. This is just a plain environment map, no scratches.
Environment maps:
Bronze 2.rar (5.2 KB)
Bronze 3.rar (5.6 KB)
A basic material using the Bronze 3’s environment map. Works great with my Bobi 1 display mode optimized for the best performance:
Bronze 3 material.rar (5.1 KB)
Bobi 1.ini (13.8 KB)
Additionally, you can try the following:
Bobi X17.ini (13.9 KB)
Bobi X17 with the parts using SetObjectDisplayMode set to Bronze 3:
Bobi X17 with Bronze 3 material:
Bobi X12 delivers a similar result, except that it uses less contrasty shadows:
Bobi X12.ini (13.8 KB)
Hi, Not had chance yet to try these but awesome .
The item is in fact a genuine fastener, for something that is not load bearing much.
It was then painted gloss black (the simple one) and the ornate one was chemically blackened, becoming a dark brown with glints of brass through the worn areas.
As for mimicking that I wouldnt even attempt it. But you guys might fancy a challenge.
The item Gijs has found is a good one . and gorgeous result. Phenomenal…
…and as asked I need to show a rusty item (not the fastener but a W shaped thing 2 ft long) , steel with a rusty patina, though the original is 100% well rusty ! not flaky just rough textured like coarse sandpaper and a bright rust.
What does one do to get that effect ?
The shaded mode is also lovely,
Bobi …excellent.
Encephalon thanks as well.
All a joy to behold.
Is it also lighting setup as well as material applied ?
I need a step by step on how to get there.
a step by step for the Gijs one, would be a good start, there are folk out there that would love to brass up that way.
The environment map I presume has all we need for the shaded mode.
Steve
I think you need to have a think about the environment as well. One problem is creating materials that are reasonably agnostic of the environment. With cycles, I am sometimes amazed at how variable some materials can be.
Another example in Rhino 8, using a PBR with a series of additional inbuilt Rhino materials/textures, and a McMaster-Carr fitting. This is more for new brass I guess, which has been sand cast. Or, you can put it into a rumbler with a heavy stone.
I am itching to do these, as I have asked though, I do need a Step By Step .
1.XXXXX
2.UUUUU
3,KKKKK
etc.
as the territory you guys are in is completely uncharted by me.
@Gijs
@David53
for those totally real looking ones wouild be awesome.
Cheers
Steve
@Gijs
I wish to try initially for the most realistic brass I see here.
please a step by step on how to get it like yours.
I have a need to send it off and had been wanting to follow what you did, I am now well behind when I should have sent it off.
Just a step by step I can follow please.
Steve
Please anyone.
I am bowled over by how great the method 1 by Gijs looked, those I sent it to are hooked on Rhino managing this, if only I can do that from the off, not piggy back it inside an existing model.
sort of exam crib sheet method !
@Gijs
2025 is the year I learn how to do that…please anyone.
Steve
But Gijs already attached the scene here. You should be able to literally see the material he used to get this look.
Again though, as with any reflective material, it will also be about the correct lighting and environment setup; which will also be in his file.
I can see the material ,
I just dont know the first steps armed with a blank build area, what to do, what to select etc. where to select it.
if its so simple someone might just say
  1. select object.
  2. click on tab
  3. select from dropdown
  4. now place lights, to do so do
  5. draw a square for light one and one for light two
perhaps the lights already exist, never done it.
Steve.
