Hi all. After testing out all the combinations I finally confirm that changing line print width doesn’t effect line weight in viewport or in print layout. I have toggled the print view mode to on still no change in line width. This is causing issues in printing as well. Changingline weight inside VA tab is not effecting line weight. This is only happening in VA3
Hi @asisintel we have done some changes in the section attributes interface and behavior in VisualARQ 3 Beta (see this topic), so until we don’t publish a new Beta with this changes, the section attributes in Rhino 8 might not be reliable.
Hi @fsalla . Just to follow up, is this issue solved in VA3 Beta6 version?
Hi @asisintel yes! if you detect any other issues, please let us know!
Is it perhaps a RC version of Rhino SR7 what you have? just in case, try to download it again to ensure it is the latest one.
can you pls send me a latest link of rhino 8 in which va3 beta 6 will work?
