One more issue is that if I add Red color in section boundary, in the Rhino viewport its showing blue as shown below. It happens with different colors too
Hi @asisintel thanks to report these issues so quickly.
I could reproduce the two first, but no the one of hatches not visible in a page layout. Your document doesn’t include any page layout, so could you share a new file with a page layout as you have it? I’ve tried to show that wall intersection in a layout detail and the hatches appear:
@fsalla . here is the file with attached Layout. I am still facing issue. R1Test12.3dm (6.2 MB)
Just to add another issue in this, when i change to Hidden mode inside layout Detail, everything goes blank inside detail. Only works with wireframe mode inside layout.
@asisintel you need to activate the cut plane on the level you want to display in plan view to see the wall hatches, otherwise you just see the walls in projection and that’s why you don’t see any hatches:
@fsalla Thanks. You were correct. I didn’t knew we could enable disable plans views inside layout too. That solved the hatch problem. Now in Hidden mode the lines are visible.
Another issue, is Print width (along with line colors) still not seen after print.
In the image below you can see that on rhino viewport we could see the line width (Width =8) is changing:
This is the same attribute as the Boundary Scale in the Rhino Section styles dialog, which is used for display purposes:
What you are looking for is the “Print Width” attribute which right now is only available from the VisualARQ Section Attributes section, in the Rhino Properties panel:
We still need to implement this attribute in the VisualARQ object Styles dialog. We are currently working on that.
Right now you can only control the section print widths from the properties panel, but when we implement it in the styles dialog, it will be easier for VisualARQ objects.
