I have just reported the problem printing the pattern to find a solution, I will let you know. I found out printing from the layout is working fine, so you can do it like that for now.
As for the print width problem, as the pattern and inner lines are not printed, the width is not visible. Let’s see if this problem is solved once the first one is fixed.
We don’t have news yet, but I found out printing fromt the layout is working fine (the problem happens printing fromt the model viewport). You can print your drawings from the layout while the problem is fixed.
We have been working in the issue regarding hatches missing printing to pdf. We have been able to reproduce this issue in a simple model with a surface and a line using VisualARQ 2, so it looks like it is an old bug which can be reproduced only in certain conditions. We are trying to get more information about it, we’ll keep you updated.
Hi @alfmelbev . I am having a hard time printing my design because of the print issues. Even from layout I am having issues. Can you please document how you are able to get line width and hatch pattern right from visual arq prints?
Did you have this problem in VisualARQ 2? or just in the VisualARQ 3 Beta? I can see the file you attached was saved in Rhino 8.
In the current Beta version (VA 3.0.4) section hatches might not work as expected. We are working on this right now and it should work fine in the next Beta version.
Thanks @fsalla for the update. This happens only in Rhino 8. Everything works right while displaying in viewport. Only issue is while printing in vector mode this issue arises. Not able to print my works as of now.
