VisualARQ 3 - Version 3.8 RC2 released
VisualARQ 3.8 - Release Candidate 2 is now available for download.
:information_source:  NOTE: This is a release candidate (RC), meaning it is not the final version but has undergone internal testing and is considered stable enough for end-user testing. VisualARQ 3.8 is scheduled for official release on :spiral_calendar: Wednesday, February 4th, 2026
This release fixes most of the problems and crashes reported by users. Please report any problems or suggestionas here or email us at visualarq@asuni.com.
Here is the list of changes:
Fixed Errors (16)
  • API: Script:
    • 14911: Error in the funcion AddRoofFromCurve. Roof Type parameter is
  • Clashes:
    • 14441: Clashes report doesn’t work with blocks
  • Crash:
    • 15348: Crash when moving 2 plan views
    • 15346: Rhino freezes after changing the height of two walls
  • DWG Export:
    • 15430: Imperial dimensions change format in the DWG Export
    • 15429: Missing geometry in the exported DWG
    • 14658: Text size inside blocks is not preserved in DWG export
  • IFC:
    • 15434: Crash when trying to import an IFC and VisualARQ was not loaded
    • 9615: Wrong import of geometry in IFC
    • 6109: Load VisualARQ when opening an IFC file
  • Interferences:
    • 15165: Wall-Slab intersection not solved correctly
    • 14831: Roof-Wall intersection issue
  • Object: Guide:
    • 15227: “Perp” snap doesn’t work with guides
  • Object: Plan View:
    • 15435: Crash when updating two plan views that look at each other
    • 15121: Geometry disappears from plan view after update
  • Object: Slab:
    • 15344: Slab selection selects other walls
    • 15318: Rhino freezes after copying a group of slabs from one document to another
Download links:
Previous versions:
Enjoy!
