VisualARQ 3 - Version 3.10 RC1 released
VisualARQ 3.10 - Release Candidate 1 is now available for download.
:information_source:  NOTE: This is a release candidate (RC), meaning it is not the final version but has undergone internal testing and is considered stable enough for end-user testing. VisualARQ 3.10 is scheduled for official release on :spiral_calendar: Wednesday, June 3th, 2026
This release fixes most of the problems and crashes reported by users. Please report any problems or suggestions here or email us at visualarq@asuni.com.
Here is the list of changes:
New Features (1)
  • IFC:
    • 14424: IFC4 and IFC4x3 Export (initial support, geometry only)
Improvements (2)
  • Object: Tag:
    • 15625: Display Object Layer name in tags
  • Style:
    • 14981: Keep Layer list order in the Styles dialog
Fixed Errors (9)
  • Attributes:
    • 15618: Section hatch color is not used as printing color
  • Dynamic Section:
    • 15617: Section edges are not displayed in jogged sections
  • Object: Section:
    • 14765: Surfaces section edges are not displayed
  • Object: Tag:
    • 15609: Tag is not displayed in perspective view
    • 15383: Show tags above the cut plane in RCP
  • Plug-In: Block Edit New:
    • 15602: VisualARQ objects become block instances when exploding blocks created with the “Block Edit New” plug-in
    • 15354: Copied objects are not located correctly inside blocks, when using the “Block Edit New” plug-in
    • 15353: VisualARQ object control points are not available when using the “Block Edit New” plug-in
  • Print: Hidden Vector:
    • 15499: Dimension texts are not printed with the proper alignment
Download links:
Previous version:
Enjoy!
