VisualARQ 2 - Version 2.8.3 released
VisualARQ 2.8.3 is now available for download.
This is a minor release that solves most of the critical issues and crashes reported by users. Please report any problem or suggestion here or send us an email to visualarq@asuni.com.
Here is the list of changes:
Fixed bugs:
  • Crash:
    • #9872: Crash when serializing a Hatch when a debugger is attached to Rhino process
    • #9862: Crash when opening a document when Lands plug-in is already loaded
  • IFC:
    • #9858: Beams are not exported to IFC
  • License:
    • #9832: Detect the proper email in Rhino accounts when using Cloud Zoo
  • Object: Column:
    • #9407: Subtract Solids command not working properly on columns with spheres
  • Object: Curtain Wall:
    • #9873: Top and bottom frame resulting from extensions have a smaller depth value when target surface is inclined
  • Object: Element:
    • #9854: Element from GH style jumps to 0 coordinates after vaSubtract
  • Object: Roof:
    • #9863: Roof shows the overhead always
  • Print:
    • #9094: Incomplete hatch on print
    • #8652: 2D representation of a custom GH element doesn’t appear if I print form the model
See the list of changes of VisualARQ 2.8
See the list of changes of VisualARQ 2.8.1
See the list of changes of VisualARQ 2.8.2
Enjoy!
Enric
Hi, I just downloaded the new version, but it will not load on rhino5.
Rhino6 works normally.
Hi @jari1,
Did you download the installer for the Rhino 5 version? Because it is not the same for Rhino 6. Furthermore you have to chose the x64 or x86 depending on the Rhino 5 you use.
If you already installed the right version and you get some kind of error message please share that.
Kind regards
3 posts were split to a new topic: Blocks are exported rotated to IFC
HI, I downloaded and installed it for the 8th time and that seems to have worked. Now it´s up and running like before.
