VisualARQ 2 - Version 2.7.5 released
VisualARQ 2.7.5 is now available for download.
This is a minor release that solves most of the critical issues and crashes reported by users. Please report any problem or suggestion here or send us an email to visualarq@asuni.com.
Here is the list of changes:
Fixed bugs:
  • Block:
    • #9414: Wall joint is not editable in BlockEdit command
  • Crash:
    • #9676: Crash when double-clicking a level in Rhino 5
    • #9633: Crash when running Block command inside a GhPython component
  • File:
    • #9622: Crash when opening a file modified without VisualARQ being loaded
  • Grasshopper: Component:
    • #9095: Spaces in GH have wrong text size in the preview
  • IFC:
    • #9512: Change IFC RepresentationType of Curves
    • #8758: IFC Tag field is not stored in IFC files if the object is exported as an IfcProxy
  • Object: Curtain Wall:
    • #9523: Inserting an opening in a curtain wall changes the material of the panels
  • Object: Plan View:
    • #9578: Missing lines in plan view
See the list of changes of previous versions:
Enjoy!
Enric
what about Visualarq 3 ? :pensive:
Hi Jon,
We’re currently working on it, but there is no release date. Moreover, VisualARQ 3 is in early development stage, and there are no many new features currently implemented, begin Rhino 7 WIP (including Rhino.Inside.Revit) compatibility the most important one.
Our plan is to publish VisualARQ 3 WIP for Rhino 7 WIP the next month. Only commercial users of VisualARQ 2 will be able to use it.
In two weeks we’ll also publish VisualARQ 2.8 with 2 main features:
  • Support for overhead display of sectioned objects in plan views and viewports.
  • Cloud Zoo support.
Is there any specific feature that you want in VisualARQ 3?
Enric
i need to good Library
i need to plan of the ciling
i need a corner window
wall from profile
and to this toolbar
I wish have the reflected ceiling plan function
Is this comparable to reflected ceiling?
  • automatic connections of structural layers of walls/slabs/roofs
  • define regions of a wall with other style
  • being able to define an offset for roof by surface
  • wall wrap so we are able to place windows/doors that can be placed in front/back of the wall wrap (not very clear, so here is a quick sketch)
  • place a sill that extends under the opening (also for grasshopper style)
  • ability to control level of detail of styles
Hi @ME_Mark,
No, this feature in VisualARQ 2.8 allows to see the part of VisualARQ objects that is above the cut plane. You can specify the display attributes for those lines. Here are some examples:
As you can see in the last image, there is also a new property to override the cut elevation of openings, so openings that are below or above the cut plane will be shown in plan view as if there were actually cutted.
Enric
I can confirm that Reflected Ceiling Plans and Automatic wall-slab joins are planned for VisualARQ 3.
Enric
The wall wrap for windows/doors and the opening offset could be useful for us.
Also the seeling plan.
The VA 3 will work only en Rhino 7 WIP ?
VisualARQ will work on Rhino 6 and Rhino 7.
First WIP will be published very soon…
Enric
For me the best would to be able to substract the wall with a solid (from grasshopper style would be great). For example here I disabled the window to cut the wall and made a solid substration witht my own solid.
But then the finition layer is not wrapping.
Something that make it possible would be great!
Somethink like this
Or like this:
Is this version (2.8) available now?
Hi @evandroj.gomes,
VisualARQ 2.8 will be released today unless we find a stop-ship bug in the last minute… :crossed_fingers:
Regards,
Enric
