VisualARQ 2.13.2 is now available for download.
This is a minor release that solves most of the critical issues and crashes reported by users. Please report any problem or suggestion here or send us an email to visualarq@asuni.com.
Here is the list of changes:
FIXED BUGS
API: Script:
#13067
: Problem with adding integers to parameter with VisualARQ APICrash:
#13183
: Crash when redoing a change that involves groups#13140
: Crash selecting a block in the block manager#13031
: Rhino hangs after trying to export a block to .AI (Adobe Illustrator)#12874
: Crash deleting a roof with walls extended#12831
: Crash after creating a roof from a surface#12629
: SetObjectSectionPatternColor method makes the file crashGrasshopper: Components:
#13055
: Slab Subtract Boundary component is not working#12805
: Roof component doesn’t accept non-planar surfacesLayout:
#12785
: Current command is interrupted when changing between layout and model#12775
: Snapping to VisualARQ objects in layout space is not reliableMaterial:
#13076
: Wrong texture mapping on VisualARQ objects#12997
: UVW mapping values don’t work on VisualARQ objects#12478
: The rotation of texture mapping on VisualARQ objects doesn’t work.Object: Element:
#12976
: Element is displayed with all the mesh edgesObject: Plan View:
#12774
: Plan view name field is empty in the properties panelObject: Space:
#12973
: “Int” snap detected is in space hatchesObject: Stair:
#13126
: Error mirroring stairs#13086
: Stair disappears when rotating it 180ÂşObject: Tag:
#12683
: Tag label boundary is not displayed in Top viewportObject: Views:
#12929
: Section hatches in plan and section views are not in the correct layerObject: Wall:
#12994
: VisualARQ crashes creating two walls in Rhino 5Other:
#12839
: Extract solids is not working if I run the command after selecting the objectStyle:
#12814
: Component property value is not saved while editing other style propertiesView:
#12796
: Scale icon is wrong in Imperial documentsWorksessions:
#13120
: Roof in attached file in a Worksession disappears after save#13053
: Crash linking files with Worksession
See the list of changes of VisualARQ 2.13
See the list of changes of VisualARQ 2.13.1
Enjoy!
Enric
