VisualARQ 2.8.5 is now available for download.
This is a minor release that solves most of the critical issues and crashes reported by users. Please report any problem or suggestion here or send us an email to visualarq@asuni.com.
Here is the list of changes:
Fixed bugs:
- Attributes:
#10018
: When section pattern color is set “By Parent” on a Rhino geometry without a parent it doesn’t take the value of its layer- Block:
#10013
: Crash after undoing an insert of a file- Display:
#10034
: Tangent edges displayed in Hidden mode- Dynamic Section:
#10077
: Crash when working on a plan or section viewport#9861
: Missing section perimeter on beams with a custom profile- Grasshopper: Component:
#10027
: The Update Property component corrupts some VisualARQ objects- IFC:
#10073
: Crash opening an IFC file- Object:
#9988
: Grip points stay visible after changing section properties- Object: Openings:
#10016
: Openings with “Cut Plan Elevation” different than “By Level” are visible from levels above when the cut plane is enabled- Other:
#9855
: Accept preselected VisualARQ objects as first input in vaAddSolids and vaSubtractSolids commands- Performance:
#10095
: I take a long time to switch from Perspective to a Top-Level view- Print:
#10011
: Geometry is not printed with the right color
See the list of changes of VisualARQ 2.8
See the list of changes of VisualARQ 2.8.1
See the list of changes of VisualARQ 2.8.2
See the list of changes of VisualARQ 2.8.3
See the list of changes of VisualARQ 2.8.4
Enjoy!
Enric
